Comprehensive Security Systems for Your Home
When it comes to protecting your home, having a reliable and advanced security system is essential. Whether you want to monitor your front door, keep an eye on your backyard, or detect leaks and unusual activity, Wyze offers a range of smart security products designed to keep your home safe and connected. Explore the best-in-class cameras, monitoring hubs, and sensors that combine cutting-edge technology with user-friendly features.
Advanced Smart Cameras for Ultimate Surveillance
Wyze Battery Cam Pro: Wireless Freedom with 2.5K HDR Video
Experience crystal-clear security footage with the
Wyze Battery Cam Pro, featuring an impressive 2.5K HDR video resolution. This wire-free camera requires no hub, making installation quick and hassle-free. Equipped with an integrated spotlight and siren, it actively deters intruders. The camera uses radar and PIR motion detection for precise alerts and comes with removable, rechargeable 6200mAh battery packs for long-lasting power. Its IP65 weatherproof rating ensures reliable outdoor performance in all conditions.
- 2560 x 1440 (2.5K) HDR video quality
- Wireless with dual-band 2.4 & 5GHz WiFi support
- Integrated spotlight and siren for active deterrence
- Radar + PIR motion detection for accurate alerts
- Removable, rechargeable battery packs (6200mAh)
- IP65 weatherproof for outdoor durability
- Available in Black and White, sold in packs of 1, 2, or 3
Wyze Video Doorbell v2: Clear 2K Video at Your Doorstep
Never miss a visitor with the
Wyze Video Doorbell v2, offering sharp 2K video resolution and local microSD storage to capture every detail. This wired doorbell provides two-way audio, real-time alerts, and motion-activated voice deterrence, allowing you to answer your door from anywhere. Its sleek black design fits seamlessly with any home exterior.
- 2K video resolution for clear visuals
- Local microSD storage for continuous recording
- Two-way audio for real-time communication
- Motion-activated voice deterrence to ward off unwanted guests
- Wired installation for consistent power
Wyze Cam v4: Crystal-Clear 2.5K QHD with Night Vision
The
Wyze Cam v4 delivers unmatched security with 2.5K QHD resolution and enhanced color night vision, ensuring your home is protected day and night. Its motion-activated spotlight adds an extra layer of security by illuminating suspicious activity. With 24/7 local recording and Wi-Fi 6 support, this camera integrates smoothly with Alexa and Google Assistant for voice control convenience.
- 2.5K QHD video resolution
- Enhanced color night vision for low-light clarity
- Motion-activated spotlight for active monitoring
- 24/7 local recording capability
- Wi-Fi 6 support for faster, stable connections
- Compatible with Alexa and Google Assistant
- Available in Black, White, Grey, and Clear
Wyze Cam Pan v3: 360° Pan and 180° Tilt Coverage
Cover every angle with the
Wyze Cam Pan v3, a versatile indoor/outdoor camera featuring 360° horizontal pan and 180° vertical tilt. Fully IP65 weather resistant, it’s perfect for monitoring large areas. Note that outdoor use requires the Wyze Outdoor Power Adapter (sold separately). Available in Black and White, this camera is ideal for dynamic surveillance needs.
- 360° pan and 180° tilt for full coverage
- IP65 weather resistance for outdoor use
- Redesigned for enhanced performance and durability
Essential Home Monitoring Components
Wyze Sense Hub: The Central Brain of Your Security System
The
Wyze Sense Hub acts as the command center, connecting all your Wyze monitoring components and sending instant alerts to your devices. Its compact design with a white base and grey speaker top fits discreetly into any home environment.
- Connects and manages Wyze monitoring devices
- Sends real-time alerts for security events
- Compact and unobtrusive design
Wyze Sense Leak Sensor & Probe: Early Leak Detection
Protect your home from water damage with the
Wyze Sense Leak Sensor & Probe. Designed to work with the Wyze Sense Hub or Wyze Home Monitoring, it notifies you immediately if leaks are detected. The sensor operates effectively within a temperature range of 32-104°F and up to 500 feet sensor range, making it ideal for basements, kitchens, and bathrooms.
- Leak detection with instant notifications
- Compatible with Wyze Sense Hub and Home Monitoring
- Operating temperature: 32-104°F (0-40°C)
- Sensor range up to 500 feet
Why Choose Wyze Security Systems?
Wyze security products combine high-resolution video, smart detection technologies, and seamless integration with your smart home ecosystem. Whether you need wireless cameras, wired doorbells, or comprehensive home monitoring, Wyze offers affordable, reliable solutions tailored to your security needs.
With options ranging from battery-powered cameras to wired video doorbells and smart sensors, Wyze ensures your home is protected around the clock with easy installation and intuitive controls.
Summary of Wyze Security Products
Product | Key Features | Price Range (USD) |
Wyze Battery Cam Pro | 2.5K HDR, wireless, spotlight, siren | $89.98 - $219.98 |
Wyze Video Doorbell v2 | 2K video, two-way audio, voice deterrence | $44.98 |
Wyze Cam v4 | 2.5K QHD, color night vision, Wi-Fi 6 | $35.98 - $107.94 |
Wyze Cam Pan v3 | 360° pan, 180° tilt, IP65 weather resistant | $39.98 - $114.94 |
Wyze Sense Hub | Central hub for monitoring devices | $45.98 |
Wyze Sense Leak Sensor | Leak detection, alerts, compatible with hub | $13.98 - $55.98 |
Protect your home with Wyze’s innovative security systems that blend technology, convenience, and affordability to give you peace of mind every day.
What types of home security products does Wyze offer?
Wyze offers a comprehensive range of home security products, including smart cameras (such as Wyze Battery Cam Pro, Wyze Cam v4, and Wyze Cam Pan v3), video doorbells, a central monitoring hub (Wyze Sense Hub), and leak sensors. These products are designed to provide advanced surveillance, real-time alerts, and seamless integration with your smart home ecosystem.What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features 2.5K HDR video resolution, wireless installation with dual-band WiFi, an integrated spotlight and siren for active deterrence, radar and PIR motion detection for accurate alerts, removable rechargeable battery packs, and an IP65 weatherproof rating for reliable outdoor use.How does the Wyze Video Doorbell v2 enhance home security?
The Wyze Video Doorbell v2 offers sharp 2K video resolution, local microSD storage for continuous recording, two-way audio for real-time communication, and motion-activated voice deterrence to ward off unwanted guests. Its wired installation ensures consistent power and reliability.What makes the Wyze Cam v4 suitable for 24/7 home monitoring?
The Wyze Cam v4 provides 2.5K QHD video resolution, enhanced color night vision for low-light clarity, a motion-activated spotlight, 24/7 local recording capability, Wi-Fi 6 support for faster connections, and compatibility with Alexa and Google Assistant for voice control.Can the Wyze Cam Pan v3 be used outdoors?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for both indoor and outdoor use. For outdoor installation, the Wyze Outdoor Power Adapter (sold separately) is required. It offers 360° pan and 180° tilt for comprehensive coverage.What is the function of the Wyze Sense Hub?
The Wyze Sense Hub acts as the central brain of your Wyze security system, connecting and managing all Wyze monitoring devices. It sends real-time alerts to your devices and features a compact, unobtrusive design that fits seamlessly into any home.How does the Wyze Sense Leak Sensor & Probe protect my home?
The Wyze Sense Leak Sensor & Probe detects water leaks and sends instant notifications to your devices, helping prevent water damage. It is compatible with the Wyze Sense Hub and Wyze Home Monitoring, operates within a temperature range of 32-104°F, and has a sensor range of up to 500 feet.Are Wyze security cameras easy to install?
Yes, Wyze security cameras are designed for easy installation. The Wyze Battery Cam Pro is wire-free and requires no hub, while other cameras like the Wyze Cam v4 and Wyze Cam Pan v3 offer straightforward setup and integration with your home network.Do Wyze security products support smart home integration?
Yes, Wyze security products are compatible with popular smart home platforms such as Alexa and Google Assistant, allowing for convenient voice control and seamless integration into your existing smart home ecosystem.What is the price range for Wyze security products?
Wyze security products are affordably priced, with cameras ranging from $35.98 to $219.98, the Wyze Sense Hub at $45.98, and leak sensors from $13.98 to $55.98. This makes Wyze an accessible option for comprehensive home security.
