High Efficiency Solar Panel for Wyze Outdoor Cameras
If you're looking to extend the battery life of your Wyze outdoor cameras, especially the Wyze Battery Cam Pro, the
Wyze Battery Cam Solar Panel is the perfect accessory. Designed to pair seamlessly with Wyze outdoor cameras, this solar panel harnesses the power of the sun to keep your cameras running longer without frequent recharging.
Wyze Battery Cam Solar Panel: Power Your Camera with Sunlight
The Wyze Battery Cam Solar Panel is engineered for efficiency and durability:
- Solar Power Rating: 2.5W, 5VDC — optimized to provide continuous charging under sunlight.
- Weather Resistant: IP65 rating ensures it withstands rain, dust, and outdoor elements.
- Mounting Flexibility: Features an easy 360° mount allowing installation in any direction for maximum sun exposure.
- Long Cable: Comes with a 13-foot (4m) micro USB cable for flexible placement.
- Compatibility: Works flawlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
Included in the package are the solar panel, wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide — everything you need for a hassle-free setup.
Extend your Wyze Battery Cam Pro’s runtime effortlessly by tapping into renewable solar energy, reducing the need for manual recharging.
Harness sunlight to power your Wyze camera continuously
Wyze Battery Cam Pro: The Ideal Camera for Solar Power
Pairing the solar panel with the
Wyze Battery Cam Pro creates a powerful, wire-free security solution:
- Video Quality: Crisp 2.5K HDR resolution for clear, detailed footage.
- Battery Life: Up to 6 months on a single charge, extendable with the solar panel.
- Weatherproof: IP65 rating ensures reliable outdoor performance.
- Advanced Detection: Radar + PIR motion sensors for accurate alerts.
- Integrated Spotlight & Siren: Enhances security with bright illumination and loud siren.
- Connectivity: Supports both 2.4 GHz and 5 GHz WiFi for stable streaming.
- Local & Cloud Storage: Supports up to 256GB microSD cards and cloud recording with Cam Plus.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
The camera’s compact size and matte finish make it unobtrusive yet stylish for any outdoor setting.
Combining the Wyze Battery Cam Pro with the solar panel means less downtime and more peace of mind.
Wireless, rechargeable, and ready for any outdoor environment
Wyze Battery Cam Pro + Solar Panel Bundle: Convenience and Value
For those who want an all-in-one solution, the
Wyze Battery Cam Pro + Solar Panel bundle offers:
- The same high-quality 2.5K HDR camera with integrated spotlight and siren.
- The efficient solar panel accessory to keep your camera charged continuously.
- Hassle-free setup with included mounts and cables.
- Weatherproof design for year-round outdoor use.
- Wireless freedom with no hub required.
This bundle is perfect for users who want to maximize their outdoor camera’s uptime while minimizing maintenance.
Get the best of both worlds: premium video security and sustainable solar charging.
Why Choose Wyze Solar Panel with Your Outdoor Camera?
- Eco-Friendly: Solar power reduces electricity consumption and carbon footprint.
- Extended Battery Life: Keeps your camera running longer without manual recharging.
- Weatherproof Durability: Both camera and solar panel are built to withstand harsh outdoor conditions.
- Easy Installation: Flexible mounting options and long cables make setup simple.
- Seamless Compatibility: Designed specifically for Wyze outdoor cameras, ensuring optimal performance.
Summary of Compatible Wyze Products for Solar Charging
Product Name | Key Features | Compatibility with Solar Panel |
Wyze Battery Cam Solar Panel | 2.5W solar power, IP65, 13 ft cable, 360° mount | Works with Wyze Battery Cam Pro, Outdoor v1/v2 |
Wyze Battery Cam Pro | 2.5K HDR, IP65, 6-month battery, spotlight, siren | Compatible with solar panel for extended battery life |
Wyze Battery Cam Pro + Solar Panel Bundle | Camera + solar panel combo, weatherproof, wireless | Ready to use out of the box |
Enhance your Wyze outdoor camera setup with the high-efficiency Wyze Battery Cam Solar Panel and enjoy uninterrupted security powered by the sun.
What is the Wyze Battery Cam Solar Panel and how does it work?
The Wyze Battery Cam Solar Panel is a high-efficiency solar accessory designed to keep your Wyze outdoor cameras, such as the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2, charged using sunlight. It provides continuous charging with a 2.5W, 5VDC output, reducing the need for frequent manual recharging.Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1 and v2 models. It is specifically designed to work seamlessly with these Wyze outdoor cameras for optimal performance.Is the Wyze Battery Cam Solar Panel weatherproof?
Yes, the Wyze Battery Cam Solar Panel has an IP65 weather resistance rating, making it durable and able to withstand rain, dust, and other outdoor elements for reliable year-round use.What is included in the Wyze Battery Cam Solar Panel package?
The package includes the solar panel, a wall mount, a 13-foot (4m) micro USB cable, USB-C adapter cables, screws, wall anchors, and a quick start guide—everything needed for a hassle-free installation.How does the Wyze Battery Cam Pro benefit from using the solar panel?
Pairing the Wyze Battery Cam Pro with the solar panel extends the camera’s battery life, allowing for continuous operation with minimal manual recharging. This combination provides a wire-free, eco-friendly security solution with less downtime.What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features 2.5K HDR video quality, up to 6 months of battery life (extendable with the solar panel), IP65 weatherproofing, radar and PIR motion detection, an integrated spotlight and siren, dual-band WiFi (2.4 GHz and 5 GHz), support for up to 256GB microSD cards, cloud recording with Cam Plus, and compatibility with Alexa, Google Assistant, and IFTTT.Does the Wyze Battery Cam Pro + Solar Panel bundle include everything needed for setup?
Yes, the Wyze Battery Cam Pro + Solar Panel bundle includes the camera, solar panel, mounting hardware, and cables, providing a complete, ready-to-use solution for outdoor security and sustainable charging.How long is the cable included with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel comes with a 13-foot (4-meter) micro USB cable, allowing for flexible placement and optimal sun exposure during installation.What are the benefits of using a solar panel with Wyze outdoor cameras?
Using a solar panel with Wyze outdoor cameras offers eco-friendly, renewable energy, extends battery life, reduces maintenance, and ensures your security cameras remain operational with minimal manual intervention.Is the installation of the Wyze Battery Cam Solar Panel easy?
Yes, the Wyze Battery Cam Solar Panel features a 360° adjustable mount and includes all necessary hardware, making installation simple and allowing you to position the panel for maximum sunlight.
