Quick Solar Charging Installation for Wyze Battery Cam Pro
Quick and Efficient Field Installation of Solar Charging for Wyze Battery Cam
When it comes to extending the battery life of your Wyze Battery Cam Pro, the Wyze Battery Cam Solar Panel is the perfect accessory for quick and efficient field installation. Designed specifically to keep your Wyze security cameras powered longer using clean, renewable solar energy, this solar panel is a must-have for outdoor surveillance without the hassle of frequent recharging.
Wyze Battery Cam Solar Panel: Power Your Camera with the Sun
Designed for Outdoor Durability and Easy Installation
The Wyze Battery Cam Solar Panel is engineered to withstand the elements with an IP65 weather resistance rating, making it dustproof and water-resistant. This means you can mount it anywhere outdoors without worrying about rain or dust affecting its performance.
  • Dimensions: 173 mm x 120 mm x 17 mm
  • Solar Power Rating: 2.5W, 5VDC
  • Cable Length: 13 feet (4 meters) micro USB cable for flexible placement
  • Color: White frame with black solar cells
Simple 360° Mounting for Optimal Sun Exposure
The solar panel comes with a versatile wall mount that allows a full 360° rotation and up to 90° tilt adjustment. This flexibility ensures you can position the panel to capture the most direct sunlight throughout the day, maximizing charging efficiency.
Pro Tip: For best results, angle the panel upward about 30° and point it south if you are in the northern hemisphere (or north if in the southern hemisphere).
What’s Included in the Package?
  • Solar panel x1
  • Wall mount x1
  • Micro USB adapter cable x1
  • USB-C adapter cable x1 (required for Wyze Battery Cam Pro)
  • Screws x3 and wall anchors x3
  • Quick start guide x1
Compatibility
  • Wyze Battery Cam Pro
  • Wyze Cam Outdoor v1 and v2
How It Works
The solar panel charges your Wyze Battery Cam Pro by connecting via the micro USB port (bottom of the camera). It automatically stops charging once the battery reaches 100% and resumes when the battery drops below 90%, ensuring efficient power management without overcharging. Charging requires direct sunlight and will not work at night, but with proper installation, it can keep your camera running for months without manual recharging.
Outdoor Solar Panel Installation Alt text: Wyze Battery Cam Solar Panel mounted outdoors in sunlight
Why Choose Wyze Solar Panel for Your Wyze Battery Cam?
Extend Battery Life Without Interruptions
With normal use, the Wyze Battery Cam Pro’s battery can last up to 6 months on a single charge. The solar panel extends this by continuously topping off the battery during daylight hours, reducing the need to bring your camera inside for charging.
Weather-Resistant and Reliable
The IP65 rating means the solar panel is built to handle rain, dust, and other outdoor conditions, making it ideal for remote or hard-to-reach locations like RVs, campers, or vacation homes.
Easy Field Installation
The included mounting hardware and long 13-foot cable allow you to install the solar panel in the best sun-exposed location while keeping your camera securely mounted nearby. The quick start guide simplifies setup, making it accessible even for users new to solar charging.
Additional Tips for Optimal Solar Charging
  • Check Cable Connections: Ensure the micro USB cable is securely connected to both the solar panel and the camera’s charging port.
  • Keep Solar Panel Clean: Wipe the surface with a soft, damp cloth to remove dust or debris that could block sunlight.
  • Monitor Battery Status: The camera’s status light flashes red when charging and shows solid green when fully charged.
  • Use the USB-C Adapter Cable: Required for Wyze Battery Cam Pro to connect the solar panel properly.
Summary
For anyone looking to maintain continuous outdoor security with the Wyze Battery Cam Pro, the Wyze Battery Cam Solar Panel offers a quick, efficient, and weatherproof solution to solar charging. Its easy installation, durable design, and compatibility with multiple Wyze outdoor cameras make it an essential accessory for hassle-free, long-term surveillance.
FeatureWyze Battery Cam Solar Panel
Compatible CamerasWyze Cam Outdoor v1/v2, Wyze Battery Cam Pro
PurposeExtends battery life of Wyze Battery Cam Pro
Weather ResistanceYes (IP65)
MountingMountable anywhere with 360° freestyle mount
Power Cable Length13-foot weatherproof cable
VariantsSolar Panel, USB-C Adapter Cable
PriceSolar Panel: $24.99 (Sold out)
USB-C Adapter Cable: $5.99 (Sold out)
Return Policy30-day hassle-free returns
What is the Wyze Battery Cam Solar Panel and how does it work?The Wyze Battery Cam Solar Panel is an accessory designed to keep your Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 powered using solar energy. It connects to your camera via a micro USB or USB-C adapter cable and charges the battery during daylight hours. The panel automatically stops charging when the battery reaches 100% and resumes when it drops below 90%, ensuring efficient power management.
Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1 and v2. For the Wyze Battery Cam Pro, the included USB-C adapter cable is required for proper connection.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is IP65 weather resistant, making it dustproof and water-resistant. It is designed to withstand outdoor conditions such as rain and dust, making it ideal for use in various environments.
How do I install the Wyze Battery Cam Solar Panel for optimal performance?To install the Wyze Battery Cam Solar Panel, use the included wall mount, which allows 360° rotation and up to 90° tilt adjustment. For best results, angle the panel upward about 30° and point it south if you are in the northern hemisphere (or north if in the southern hemisphere) to maximize sun exposure. The 13-foot cable allows flexible placement for optimal sunlight.
What is included in the Wyze Battery Cam Solar Panel package?The package includes one solar panel, one wall mount, one micro USB adapter cable, one USB-C adapter cable (required for Wyze Battery Cam Pro), three screws, three wall anchors, and a quick start guide.
How long can the Wyze Battery Cam Pro last with the solar panel installed?With normal use, the Wyze Battery Cam Pro’s battery can last up to 6 months on a single charge. The solar panel extends this by continuously charging the battery during daylight hours, potentially keeping your camera running for months without manual recharging.
Does the Wyze Battery Cam Solar Panel charge the camera at night?No, the Wyze Battery Cam Solar Panel requires direct sunlight to charge the camera and does not work at night. However, with proper installation, it can keep your camera powered for extended periods during the day.
How do I know if my Wyze camera is charging with the solar panel?The camera’s status light will flash red when charging and show a solid green light when fully charged. Make sure the cable connections are secure for proper charging.
What maintenance does the Wyze Battery Cam Solar Panel require?To maintain optimal performance, keep the solar panel clean by wiping its surface with a soft, damp cloth to remove dust or debris that could block sunlight.
Can I install the Wyze Battery Cam Solar Panel in remote or hard-to-reach locations?Yes, the Wyze Battery Cam Solar Panel is ideal for remote or hard-to-reach locations such as RVs, campers, or vacation homes due to its weather-resistant design and long 13-foot cable for flexible placement.
What are the dimensions of the Wyze Battery Cam Solar Panel?How does the solar panel ensure efficient power management for the Wyze Battery Cam Pro?Can the solar panel be used in all weather conditions?
