Wyze Garage Door Controller with Real-Time Notifications via Wyze App
Experience the ultimate convenience and security for your garage with the
Wyze Garage Door Controller. Designed to integrate seamlessly with the Wyze app, this smart controller offers real-time notifications, remote control, and live video monitoring — all from your smartphone. Whether you want to check if your garage door is open or closed, or keep an eye on your garage with HD video, Wyze has you covered.
Wyze Garage Door Controller: Smart Features & Specifications
The Wyze Garage Door Controller is the world’s first AI vision-sensing smart garage door controller, combining advanced technology with user-friendly features:
- Remote Control: Open or close your garage door from anywhere using the Wyze app.
- Real-Time Notifications: Receive instant alerts when your garage door opens, closes, or is left open.
- 1080p HD Video Monitoring: Includes the award-winning Wyze Cam v3 with color night vision to see your garage clearly day or night.
- Compatibility: Works with most garage door openers (indoor use only).
- Connectivity: Wired connection with 2.4 GHz Wi-Fi (802.11 b/g/n).
- Safety & Standards: ETL-listed and meets UL325 safety standards.
- Easy Installation: Setup takes just 10-20 minutes with included accessories.
- What’s in the Box: Wyze Garage Door Controller, Wyze Cam v3, QR Code Sticker, Micro USB Cable Splitter, Power Adapter & Cord, Adhesive Mounting Sticker, Cable Clips, Quick Start Guide.
The USB cable design includes a signal shielding layer to prevent interference with garage door clickers, ensuring smooth operation.
Product Variants and Pricing
- Garage Door Controller Only (no camera): $18.99
- Wyze Cam v3 + Controller + 32GB MicroSD Card Bundle: $63.96
- Wyze Cam v3 + Garage Door Controller Bundle: $49.98
Stay connected with two-way audio and real-time alerts via the Wyze app.
Essential Replacement Parts for Your Wyze Garage Door Controller
To keep your system running smoothly, Wyze offers key replacement parts designed specifically for the Garage Door Controller:
Wyze Garage Door Controller QR Code Sticker
- Purpose: Replacement QR code sticker for easy device setup and identification.
- Compatibility: Works exclusively with the Wyze Garage Door Controller.
- Price: $0.99
- Return Policy: 30-day hassle-free returns.
Wyze Garage Door Controller Part
- Description: Replacement controller part only (not a full kit).
- Compatibility: Compatible with Wyze Cam v3 Garage Door Controller.
- Price: $6.99
Wyze Garage Door Controller Mounting Kit
- Description: Replacement mounting kit to securely install your controller.
- Price: $4.99
These parts ensure your garage door controller remains functional and easy to maintain without needing to replace the entire system.
Why Choose Wyze for Your Garage Door Security?
Wyze is a trusted brand known for affordable, reliable smart home products. The Garage Door Controller stands out by combining AI vision sensing with real-time notifications and HD video monitoring, all integrated into the Wyze app ecosystem. This means you get:
- Peace of Mind: Know instantly when your garage door status changes.
- Enhanced Security: Watch live or recorded footage anytime.
- Smart Home Integration: Works seamlessly with Wyze Cam v3 and other Wyze devices.
Additional Wyze Cameras for Enhanced Home Security
While the Wyze Garage Door Controller includes the Wyze Cam v3, you can also consider other Wyze cameras to expand your home security system:
Wyze Cam Pan v3
- Features: 360° horizontal pan, 180° vertical tilt, 1080p HD video, IP65 weather resistance for indoor/outdoor use.
- Audio: Two-way audio with noise and echo cancellation.
- Smart Alerts: Push notifications and custom detection zones.
- Compatibility: Works with Alexa, Google Assistant, and IFTTT.
- Price: Starting at $39.98
Wyze Cam Pan v3 offers versatile indoor/outdoor coverage with weather resistance.
Wyze Cam OG
- Features: 1080p HD video, built-in spotlight, 3X faster notifications, improved 2-way audio.
- Use Case: Ideal for indoor/outdoor monitoring with IP65 rating.
- Price: Starting at $29.98
Conclusion
For a smart, reliable, and easy-to-use garage door controller with real-time notifications via the Wyze app, the
Wyze Garage Door Controller is the perfect choice. Supported by essential replacement parts and complemented by Wyze’s range of smart cameras, it offers comprehensive garage security and peace of mind.
Upgrade your garage security today with Wyze’s innovative technology and stay connected wherever you go.
Product Summary
Wyze Cam Pan v3
Wyze Cam OG
What is the Wyze Garage Door Controller?
The Wyze Garage Door Controller is a smart device that allows you to remotely open, close, and monitor your garage door using the Wyze app. It features real-time notifications, 1080p HD video monitoring with the Wyze Cam v3, and integrates seamlessly with your smart home setup.How do real-time notifications work with the Wyze Garage Door Controller?
The Wyze Garage Door Controller sends instant alerts to your smartphone via the Wyze app whenever your garage door opens, closes, or is left open. This ensures you are always aware of your garage door’s status for enhanced security and peace of mind.Can I control my garage door remotely with the Wyze Garage Door Controller?
Yes, you can open or close your garage door from anywhere using the Wyze app on your smartphone. This remote control feature provides convenience and added security, allowing you to manage your garage door even when you’re not at home.Does the Wyze Garage Door Controller include video monitoring?
Yes, the Wyze Garage Door Controller includes the Wyze Cam v3, which provides 1080p HD video monitoring with color night vision. You can view live or recorded footage of your garage directly from the Wyze app.Is the Wyze Garage Door Controller compatible with my garage door opener?
The Wyze Garage Door Controller is compatible with most garage door openers for indoor use. It connects via a wired setup and requires a 2.4 GHz Wi-Fi network (802.11 b/g/n).How easy is it to install the Wyze Garage Door Controller?
Installation is straightforward and typically takes just 10-20 minutes. The package includes all necessary accessories, such as a QR code sticker, micro USB cable splitter, power adapter, adhesive mounting sticker, cable clips, and a quick start guide.What safety standards does the Wyze Garage Door Controller meet?
The Wyze Garage Door Controller is ETL-listed and meets UL325 safety standards, ensuring reliable and safe operation for your home.What is included in the Wyze Garage Door Controller box?
The box includes the Wyze Garage Door Controller, Wyze Cam v3, QR code sticker, micro USB cable splitter, power adapter and cord, adhesive mounting sticker, cable clips, and a quick start guide.What are the available Wyze Garage Door Controller bundles and their prices?
The Wyze Garage Door Controller is available in several options: Controller only (no camera) for $18.99, Wyze Cam v3 + Controller + 32GB MicroSD Card Bundle for $63.96, and Wyze Cam v3 + Garage Door Controller Bundle for $49.98.Are there replacement parts available for the Wyze Garage Door Controller?
Yes, Wyze offers essential replacement parts including the QR code sticker ($0.99), controller part only ($6.99), and mounting kit ($4.99). These parts help maintain your system without needing to replace the entire controller.What is the return policy for Wyze Garage Door Controller replacement parts?
Wyze offers a 30-day hassle-free return policy on replacement parts such as the QR code sticker and controller part.Why should I choose Wyze for my garage door security?
Wyze is a trusted brand known for affordable and reliable smart home products. The Wyze Garage Door Controller combines AI vision sensing, real-time notifications, and HD video monitoring, all integrated into the Wyze app for comprehensive garage security and peace of mind.Can I expand my home security system with other Wyze cameras?
Yes, you can enhance your home security by adding other Wyze cameras such as the Wyze Cam Pan v3, which offers 360° pan and 180° tilt, and the Wyze Cam OG, which features a built-in spotlight and fast notifications. Both are suitable for indoor and outdoor use.Does the Wyze Garage Door Controller support two-way audio?
Yes, the Wyze Cam v3 included with the Garage Door Controller supports two-way audio, allowing you to communicate in real time through the Wyze app.What connectivity does the Wyze Garage Door Controller require?
The Wyze Garage Door Controller requires a wired connection and a 2.4 GHz Wi-Fi network (802.11 b/g/n) for optimal performance and real-time notifications.
