AI Garage Door Sensor System for Smart Home Security
AI Garage Door Sensor System for Home Security
Enhance your home security with an intelligent AI garage door sensor system that integrates advanced cameras and smart monitoring devices. Whether you want to monitor your garage entrance, detect motion, or secure your entire home perimeter, the following Wyze products offer cutting-edge technology, seamless connectivity, and reliable performance to keep your home safe 24/7.
Comprehensive AI-Powered Security Cameras for Garage and Home
Wyze Cam v4 – Crystal Clear Surveillance with AI Motion Detection
The Wyze Cam v4 is a powerful wired camera designed to deliver unmatched security for your garage and home. Featuring a crystal-clear 2.5K QHD resolution and enhanced color night vision, it captures every detail day or night. Its AI-powered motion detection triggers alerts and activates a motion-activated spotlight to deter intruders instantly.
  • Resolution: 2.5K QHD (2560x1440) for sharp, detailed video
  • Night Vision: Color night vision with 4 IR LEDs + 2 white spotlight LEDs (72 lumens)
  • Field of View: Wide 115.8° diagonal for broad coverage
  • Connectivity: Supports Wi-Fi 6 and works with Alexa and Google Assistant
  • Local & Cloud Storage: 24/7 local recording with microSD support up to 512 GB; optional cloud subscription
  • Mounting Options: Flexible installation with stand, wall, ceiling, or magnetic mounts
  • Durability: Weather-resistant IP65 rating, suitable for outdoor garage entrances
This camera’s AI capabilities make it ideal for detecting people, packages, and vehicles approaching your garage, providing real-time alerts to your smartphone.
Wyze Cam Pan v3 – 360° Pan and Tilt for Full Garage Coverage
For dynamic monitoring of your garage space, the Wyze Cam Pan v3 offers 360° horizontal and 180° vertical rotation, ensuring no blind spots. This IP65 weather-resistant camera is perfect for outdoor garage areas when paired with the Wyze Outdoor Power Adapter.
  • Resolution: Full HD 1080p video with smooth 20 FPS daytime and 15 FPS nighttime
  • Field of View: 120° fixed lens with pan and tilt for full 360° coverage
  • Night Vision: 4 IR LEDs for clear black-and-white night vision
  • Audio: Two-way audio with noise and echo cancellation for communication
  • Smart Alerts: Push notifications for motion detection
  • Mounting: Screw mount with compact design for easy placement
  • Weatherproof: IP65 rating withstands snow, rain, and harsh conditions
This camera is perfect for garages with wide entrances or multiple access points, allowing you to remotely pan and tilt to check any suspicious activity. Wyze Cam Pan v3 in snowy outdoor garage setting Reliable outdoor garage security with Wyze Cam Pan v3
Wyze Battery Cam Pro – Wire-Free, AI-Enhanced Garage Monitoring
If you prefer a wire-free solution, the Wyze Battery Cam Pro offers 2.5K HDR video with AI-powered radar and PIR motion detection. Its rechargeable battery lasts up to 6 months, making it ideal for garage doors without easy access to power outlets.
  • Resolution: 2.5K HDR for vibrant, detailed video
  • Motion Detection: Radar + PIR sensors for precise AI motion alerts
  • Battery Life: Up to 6 months on a single charge with removable battery packs
  • Night Vision: 2 IR LEDs + 2 powerful white LEDs (187 lumens) for color night vision
  • Connectivity: Dual-band Wi-Fi (2.4 & 5 GHz) for stable connection
  • Weather Resistance: IP65 rated for outdoor garage use
  • Audio: Two-way audio with built-in speaker and microphone
  • Storage: Supports up to 256 GB microSD cards for local storage
This camera’s wire-free design and AI detection make it a flexible and smart choice for garage security without complicated wiring.
Smart Lighting and Doorbell Integration for Garage Security
Wyze Bulb Cam – 2-in-1 Security Camera and Smart LED Light
The Wyze Bulb Cam combines a 2K HD security camera with a smart LED light bulb, perfect for garage lighting and surveillance in one device. It fits standard E26 sockets, making installation effortless.
  • Video Quality: 2K HD with color night vision and IR night vision
  • Field of View: Ultra-wide 160° diagonal for broad garage coverage
  • Lighting: Up to 800 lumens with motion-activated and scheduled lighting control
  • Audio: Two-way audio with built-in microphone and speaker
  • Alerts: Instant motion notifications to your phone
  • Storage: Local microSD support up to 256 GB; cloud storage available
  • Weatherproof: IP65 rating for outdoor use in garage fixtures
This device not only illuminates your garage but also keeps an eye on any movement, deterring unwanted visitors effectively. Wyze Bulb Cam installed in outdoor garage light fixture Smart lighting and security with Wyze Bulb Cam
Wyze Video Doorbell v2 – Secure Your Garage Entry with 2K Video
The Wyze Video Doorbell v2 is an essential addition for garage doors with pedestrian access. It offers 2K video resolution and real-time alerts, allowing you to answer the door from anywhere.
  • Resolution: 2K (2048 x 1536) for clear video calls and recordings
  • Field of View: Wide 135° horizontal and 103° vertical coverage
  • Night Vision: 6 IR LEDs for clear night monitoring
  • Motion Detection: Motion-activated voice deterrence to warn off intruders
  • Storage: Local microSD storage up to 256 GB; cloud option available
  • Weather Resistance: IP65 rated for outdoor installation on garage doors
This doorbell integrates seamlessly with your AI garage sensor system, providing an extra layer of security and convenience.
Centralized Monitoring with Wyze Sense Hub
To unify your AI garage door sensor system, the Wyze Sense Hub acts as the central brain connecting all sensors and cameras. It sends instant alerts and supports up to 100 sensors, ensuring comprehensive monitoring.
  • Connectivity: Ethernet, Wi-Fi 2.4 GHz, Bluetooth 4.1 + BLE 5.1, and 915 MHz RF
  • Siren: Built-in 88 dB siren for audible alerts
  • Battery Backup: Rechargeable battery with 10 hours backup
  • Indoor Use: Designed for indoor placement to coordinate your garage security devices
The Sense Hub enhances your AI system’s responsiveness and reliability, making your garage security smarter and more efficient.
Why Choose Wyze AI Garage Door Sensor System?
"Protect your garage and home with smart, AI-powered cameras and sensors that provide real-time alerts, crystal-clear video, and seamless integration with your smart home ecosystem."
  • Advanced AI motion detection reduces false alarms
  • Multiple mounting and power options for flexible installation
  • Weather-resistant designs built for outdoor garage environments
  • Integration with Alexa, Google Assistant, and IFTTT for voice control and automation
  • Local and cloud storage options for secure video retention
Secure your garage and home with Wyze’s AI garage door sensor system — combining smart cameras, lighting, doorbell, and sensor hub for a comprehensive, intelligent home security solution. Two-way audio interaction with Wyze Cam v4 indoors Stay connected with two-way audio on Wyze Cam v4
Product Summary
  • Wyze Cam v4: Advanced wired camera with 2.5K QHD, color night vision, spotlight, and AI motion detection.
  • Wyze Cam Pan v3: 360° pan/tilt camera with weather resistance, perfect for wide garage coverage.
  • Wyze Battery Cam Pro: Wire-free 2.5K HDR camera with radar + PIR AI motion detection and long battery life.
  • Wyze Bulb Cam: 2-in-1 security camera and smart LED light bulb with 2K video and motion-activated lighting.
  • Wyze Video Doorbell v2: Wired 2K video doorbell with two-way audio and motion-activated voice deterrence.
  • Wyze Sense Hub: Central hub connecting sensors and cameras, with siren and multi-protocol communication.
Protect your garage with the best AI garage door sensor system from Wyze — smart, reliable, and designed for your peace of mind.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Bulb CamWyze Video Doorbell v2Wyze Sense Hub
TypeWired Security CameraWired Pan & Tilt Security CameraWire-Free Battery Security CameraOutdoor Security Camera + LightWired Video DoorbellHome Monitoring Hub
Video Resolution2.5K QHD (2560 x 1440)Not specified (Award-winning)2.5K HDR (2560 x 1440)2K HD (2304 x 1296)2K (2048 x 1536)N/A
Field of View (Diagonal)115.9°360° Pan, 180° Tilt134°166°166.8°N/A
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)2 IR LEDs + 2 White LEDs (Color)Color Night Vision + IR6 x 940nm IR lightsN/A
AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way AudioTwo-Way AudioTwo-Way AudioN/A
Siren Volume99 dBNot specified100 dB SPL95 dB at 4 inNot specified88 dB @ 2 ft
SpotlightMotion-activated spotlightNoIntegrated SpotlightSmart LED Light BulbNoN/A
Weather ResistanceIP65IP65IP65IP65IP65Indoor use only
Power SourceWiredWiredRemovable, Rechargeable Battery120V AC (bulb socket)Wired (16V-24V AC)Built-in rechargeable battery
Battery LifeN/AN/AUp to 6 monthsN/AN/A10 hours backup
Wireless ConnectivityWi-Fi 6Wi-Fi (2.4 GHz)Wi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz, Ethernet, RF
Local Storage SupportmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBN/A
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTTN/A
MountingMagnetic mount, screw-freeMount with outdoor power adapterWall mount includedStandard E26 bulb socketWall mount includedN/A
Dimensions (inches)Not specifiedNot specified2.5 x 1.8 x 3.5Not specified4.3 x 1.7 x 0.94.5 x 4 x 1
WeightNot specifiedNot specified0.94 lbsNot specifiedNot specifiedNot specified
Price (Single Pack)$35.98$39.98$159.98$49.98$44.98$45.98
What is an AI garage door sensor system and how does it enhance home security?An AI garage door sensor system uses advanced cameras and smart monitoring devices to detect motion, monitor garage entrances, and secure your home perimeter. With AI-powered motion detection, real-time alerts, and seamless integration with smart home platforms, it provides 24/7 protection and reduces false alarms, making your home safer and more secure.
Which Wyze camera is best for monitoring my garage entrance?The Wyze Cam v4 is ideal for garage entrances, offering 2.5K QHD resolution, color night vision, AI-powered motion detection, and a motion-activated spotlight. Its weather-resistant IP65 rating makes it suitable for outdoor use, ensuring reliable surveillance day and night.
How does the Wyze Cam Pan v3 provide full garage coverage?The Wyze Cam Pan v3 features 360° horizontal and 180° vertical rotation, allowing you to remotely pan and tilt the camera for complete coverage of your garage. Its IP65 weather resistance and two-way audio make it perfect for monitoring wide entrances or multiple access points.
Is there a wire-free security camera option for garages without power outlets?Yes, the Wyze Battery Cam Pro is a wire-free solution with 2.5K HDR video, AI-powered radar and PIR motion detection, and up to 6 months of battery life. Its weather-resistant design and flexible installation make it ideal for garages lacking easy access to power.
Can I combine lighting and security in my garage with Wyze products?Absolutely. The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED light bulb. It offers motion-activated and scheduled lighting, color night vision, and instant motion alerts, making it perfect for illuminating and monitoring your garage.
How does the Wyze Video Doorbell v2 improve garage entry security?The Wyze Video Doorbell v2 provides 2K video resolution, wide field of view, two-way audio, and motion-activated voice deterrence. It sends real-time alerts to your phone, allowing you to see and communicate with visitors at your garage entry from anywhere.
What is the Wyze Sense Hub and why is it important for garage security?The Wyze Sense Hub acts as the central brain of your AI garage door sensor system, connecting up to 100 sensors and cameras. It provides instant alerts, features a built-in siren, and ensures all your security devices work together for comprehensive monitoring and faster response.
Are Wyze garage security products weather-resistant?Yes, Wyze security cameras and devices such as the Cam v4, Cam Pan v3, Battery Cam Pro, Bulb Cam, and Video Doorbell v2 are all IP65 rated, making them weather-resistant and suitable for outdoor garage environments.
Do Wyze garage security cameras support local and cloud storage?Wyze cameras support both local storage via microSD cards (up to 256 GB or 512 GB depending on the model) and optional cloud storage subscriptions, giving you flexible and secure video retention options.
Can Wyze AI garage door sensor systems integrate with smart home platforms?Yes, Wyze security products integrate seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control, automation, and enhanced smart home connectivity.
What are the main benefits of choosing Wyze for garage security?Wyze offers advanced AI motion detection, flexible installation options, weather-resistant designs, integration with popular smart home platforms, and both local and cloud storage. These features provide reliable, comprehensive, and intelligent security for your garage and home.
What features does the Wyze Cam v4 offer for garage security?How does the AI motion detection work in the Wyze Cam v4?Do you have any ongoing sales or discounts for the Wyze products?
