How to Remotely Control Your Garage Door with Wyze
If you're looking to control your garage door remotely with ease and security, the
Wyze Garage Door Controller is the perfect smart home accessory. Designed to integrate seamlessly with your existing garage door opener, this device allows you to open, close, and monitor your garage door from anywhere using the Wyze app on your smartphone. Below, we break down everything you need to know about setting up and using the Wyze Garage Door Controller for remote garage door control.
About Wyze Garage Door Controller
The Wyze Garage Door Controller is a smart device that connects to your existing garage door opener and pairs with the Wyze Cam v3 to provide remote control and monitoring capabilities.
Key Features
- Remote Viewing and Control: Open or close your garage door from anywhere using the Wyze app.
- Advanced AI Sensing: The system uses AI technology and a QR code sticker on your garage door to detect whether the door is open or closed—no extra sensors needed.
- 1080p HD Video: Monitor your garage with crystal-clear video through the Wyze Cam v3.
- Scheduling and Automation: Set schedules to automatically close your garage door or create automations triggered by your Wyze Cam v3.
- Fast Notifications: Receive instant alerts if your garage door is left open for a custom amount of time.
- Easy Installation: Compatible with most garage door openers and installs in about 20 minutes.
- Works with Voice Assistants: Control your garage door hands-free using Alexa or Google Assistant.
The Wyze Garage Door Controller is designed as a DIY device, making installation quick and straightforward without the need for professional services.
Setting Up Your Wyze Garage Door Controller
Compatibility Check
Before purchasing or installing, use Wyze’s Compatibility Checker to ensure your garage door opener is supported. The controller works with most openers but requires a compatible model for smooth operation.
Installation Overview
1.
Connect the Controller: Attach the Wyze Garage Door Controller wires to the terminals on your existing garage door opener where the wall button wires connect.
2.
Mount the QR Code Sticker: Place the provided QR code sticker on your garage door within 3-15 feet of the Wyze Cam v3’s view.
3.
Pair with Wyze Cam v3: The Garage Door Controller requires a Wyze Cam v3 to function, as the camera provides video and AI sensing.
4.
Configure in Wyze App: Follow the in-app setup guide to calibrate the QR code and complete the installation.
Installation typically takes 10-20 minutes and does not require any special tools or expertise.
Using the Wyze App to Control Your Garage Door
Remote Control
Once set up, you can open or close your garage door remotely via the Wyze app. The app also shows the current status of your door (open or closed) using AI detection.
Notifications
Enable notifications to get alerts when your garage door opens, closes, or remains open longer than your set threshold. This feature helps enhance home security by keeping you informed in real-time.
Scheduling and Automations
- Close Scheduling: You can schedule your garage door to close automatically at specific times.
- Automations: Use Wyze automations to trigger your garage door to close based on other device events, such as when you leave home or when your Wyze Cam v3 detects motion.
For security reasons, automatic opening schedules are disabled to prevent unauthorized access.
Voice Control with Alexa and Google Assistant
Alexa Integration
- Link your Wyze account with the Amazon Alexa app.
- Discover your garage door controller device.
- Set a 4-digit voice code for secure voice commands.
- Use voice commands like:
- "Alexa, open [garage name]"
- "Alexa, close [garage name]"
- "Alexa, what is the status of [garage name]?"
Google Assistant Integration
- Connect your Wyze account through the Google Home app.
- Create a 4-digit voice PIN.
- Use voice commands such as:
- "Hey Google, open [garage name]"
- "Hey Google, close [garage name]"
- "Hey Google, is my [garage name] open or closed?"
Voice control requires a PIN for security, ensuring only authorized users can operate your garage door.
Maintaining and Troubleshooting Your Wyze Garage Door Controller
Common Tips
- Ensure your Wyze Cam v3 and Garage Door Controller firmware are up to date.
- Verify wiring connections are secure and correctly attached to the garage door opener terminals.
- Place the Wyze Cam v3 at least 3 feet away from the garage door controller to avoid signal interference.
- If the garage door is not responding consistently, adjust the trigger duration in the Wyze app under Settings > Accessories > Garage Door Controller.
Power and Connectivity
- The Garage Door Controller requires power via the included 5V 2A adapter.
- In case of power outages, the garage door opener will not function remotely.
- Wi-Fi outages will disable remote control but your manual garage door opener will still work.
Sharing Access and Using Existing Remotes
- You can share access to your Wyze Garage Door Controller with trusted family or friends through the Wyze app.
- Your existing garage door remotes, wall buttons, and keypads will continue to work normally after installing the Wyze Garage Door Controller.
- The device does not come with a separate remote; all remote control is done via the Wyze app or voice assistants.
Summary
The Wyze Garage Door Controller offers a smart, secure, and convenient way to remotely control your garage door. With easy installation, AI-powered status detection, and integration with popular voice assistants, it transforms your garage door into a connected smart home device. Whether you want to check if you left the door open or open it remotely for a guest, Wyze makes it simple and reliable.
Control your garage door remotely with Wyze for enhanced convenience and security.
Quick and easy DIY installation in under 20 minutes.
Use Alexa or Google Assistant to control your garage door hands-free.
What is the Wyze Garage Door Controller and how does it work?
The Wyze Garage Door Controller is a smart device that connects to your existing garage door opener and pairs with the Wyze Cam v3. It allows you to open, close, and monitor your garage door remotely using the Wyze app on your smartphone. The system uses AI technology and a QR code sticker to detect the door's status, eliminating the need for extra sensors.How do I install the Wyze Garage Door Controller?
Installation is quick and easy, typically taking 10-20 minutes. Attach the controller wires to your garage door opener's terminals, mount the provided QR code sticker on your garage door, pair the device with a Wyze Cam v3, and follow the in-app setup guide to calibrate and complete installation. No special tools or professional services are required.Is my garage door opener compatible with the Wyze Garage Door Controller?
The Wyze Garage Door Controller is compatible with most garage door openers. Before purchasing, use Wyze’s Compatibility Checker to ensure your specific model is supported for smooth operation.Can I control my garage door remotely with the Wyze app?
Yes, once set up, you can open or close your garage door from anywhere using the Wyze app. The app also displays the current status of your garage door using AI-powered detection.Does the Wyze Garage Door Controller support voice control?
Yes, the Wyze Garage Door Controller works with Amazon Alexa and Google Assistant. You can use secure voice commands to open, close, or check the status of your garage door. A 4-digit PIN is required for added security.Will my existing garage door remotes and wall buttons still work?
Yes, after installing the Wyze Garage Door Controller, your existing remotes, wall buttons, and keypads will continue to function as usual. The Wyze device adds smart control without affecting your current setup.How does the Wyze Garage Door Controller detect if my garage door is open or closed?
The system uses advanced AI sensing with a QR code sticker placed on your garage door. The Wyze Cam v3 reads the QR code to determine if the door is open or closed, so no additional sensors are needed.Can I receive notifications if my garage door is left open?
Yes, you can enable notifications in the Wyze app to receive instant alerts if your garage door is opened, closed, or left open longer than your set threshold. This helps enhance your home’s security.Is it possible to schedule my garage door to close automatically?
Yes, you can set schedules in the Wyze app to automatically close your garage door at specific times. For security reasons, automatic opening schedules are disabled to prevent unauthorized access.What should I do if my Wyze Garage Door Controller is not working properly?
Ensure your Wyze Cam v3 and Garage Door Controller firmware are up to date, check that wiring connections are secure, and make sure the camera is placed at least 3 feet from the controller. If issues persist, adjust the trigger duration in the Wyze app under Settings > Accessories > Garage Door Controller.How is the Wyze Garage Door Controller powered?
The controller is powered by the included 5V 2A adapter. In the event of a power outage, remote control will not function, but you can still operate your garage door manually.Can I share access to my Wyze Garage Door Controller with others?
Yes, you can share access with trusted family members or friends through the Wyze app, allowing them to control and monitor your garage door remotely.What happens if my Wi-Fi goes out?
If your Wi-Fi connection is lost, remote control of your garage door through the Wyze app will be disabled. However, your manual garage door opener, remotes, and wall buttons will continue to work normally.Do I need a Wyze Cam v3 for the Garage Door Controller to work?
Yes, the Wyze Garage Door Controller requires a Wyze Cam v3 for video monitoring and AI-powered status detection. The camera is essential for the system to function properly.
