Garage Door Controllers Compatible with Most Garage Openers
When it comes to upgrading or replacing your garage door controller, compatibility and smart features are key. The Wyze Garage Door Controller lineup offers versatile options designed to work seamlessly with most garage openers, providing you with remote control, enhanced security, and easy installation.
Wyze Garage Door Controller: Smart and Vision-Sensing
Advanced AI Vision-Sensing Technology
The Wyze Garage Door Controller is the world’s first AI vision-sensing smart garage door controller. It integrates with the Wyze Cam v3 to provide 1080p HD video clarity and award-winning color night vision, allowing you to monitor your garage remotely with crystal-clear visuals.
Remote Control and Monitoring
Control your garage door from anywhere using your smartphone. Whether you want to open, close, or check the status of your garage door, the Wyze Garage Door Controller makes it simple and secure.
Flexible Purchase Options
- Garage Door Controller Only (for those who already own a Wyze Cam v3)
- Wyze Cam v3 + Controller + 32GB MicroSD Card bundle
- Wyze Cam v3 + Garage Door Controller bundle
These options allow you to customize your setup based on your needs and budget.
Experience seamless garage control with Wyze’s smart technology.
Essential Replacement Parts for Your Wyze Garage Door Controller
Wyze Garage Door Controller Part
If you need to replace the controller component itself, the Wyze Garage Door Controller Part is available as a standalone replacement. This is ideal if your existing controller is malfunctioning but you want to keep the rest of your system intact.
- Compatible with Wyze Cam v3 Garage Door Controller
- Affordable and easy to install
- 30-day hassle-free return policy
Wyze Garage Door Controller Mounting Kit
For secure and stable installation, the Wyze Garage Door Controller Mounting Kit provides all necessary mounting hardware. This kit ensures your controller stays firmly in place for optimal performance.
- Replacement mounting hardware
- Designed specifically for Wyze Garage Door Controller
- Simple installation process
Wyze Garage Door Controller Cable Splitter
The Cable Splitter is a handy replacement part that allows you to manage wiring connections efficiently. It’s compatible with the Wyze Garage Door Controller and helps maintain a clean and organized setup.
- Replacement cable splitter
- Ensures reliable connectivity
- 30-day hassle-free returns
Wyze Garage Door Controller QR Code Sticker
Keep your system organized with the Wyze Garage Door Controller QR Code Sticker. This replacement sticker helps you quickly identify your controller and streamline setup or troubleshooting.
- Replacement QR code sticker
- Compatible with Wyze Garage Door Controller
- Easy to apply and durable
Why Choose Wyze Garage Door Controllers?
Wyze Garage Door Controllers combine smart technology with user-friendly design, making them compatible with most garage openers and perfect for modern connected homes. Their AI vision-sensing capabilities and flexible replacement parts ensure your garage remains secure and easy to manage.
Upgrade your garage door system today with Wyze’s reliable and innovative solutions.
Summary of Wyze Garage Door Controller Products
Product | Type | Price (USD) | Key Feature |
Wyze Garage Door Controller | Smart Camera | From 18.99 | AI vision-sensing, remote control |
Wyze Garage Door Controller Part | Replacement Part | 6.99 | Controller replacement |
Wyze Garage Door Controller Mounting Kit | Replacement Part | 4.99 | Mounting hardware |
Wyze Garage Door Controller Cable Splitter | Replacement Part | 1.99 | Cable management |
Wyze Garage Door Controller QR Code Sticker | Replacement Part | 0.99 | Identification sticker |
Enhance your garage door experience with Wyze’s smart and compatible controllers and parts.
Are Wyze Garage Door Controllers compatible with most garage door openers?
Yes, Wyze Garage Door Controllers are designed to be compatible with most garage door openers, making them a versatile choice for upgrading or replacing your current system.What smart features does the Wyze Garage Door Controller offer?
The Wyze Garage Door Controller features advanced AI vision-sensing technology, remote control and monitoring via smartphone, 1080p HD video clarity, and award-winning color night vision when paired with the Wyze Cam v3.Can I control my garage door remotely with the Wyze Garage Door Controller?
Yes, you can open, close, and monitor your garage door from anywhere using your smartphone with the Wyze Garage Door Controller.What purchase options are available for the Wyze Garage Door Controller?
You can purchase the Wyze Garage Door Controller alone (if you already own a Wyze Cam v3), as a bundle with the Wyze Cam v3 and a 32GB MicroSD card, or as a bundle with just the Wyze Cam v3 and the controller.What replacement parts are available for the Wyze Garage Door Controller?
Wyze offers several replacement parts, including the Wyze Garage Door Controller Part, Mounting Kit, Cable Splitter, and QR Code Sticker, all designed for easy installation and compatibility with the Wyze Garage Door Controller.How do I replace the Wyze Garage Door Controller component?
If your controller is malfunctioning, you can purchase the Wyze Garage Door Controller Part as a standalone replacement. It is affordable, easy to install, and compatible with the Wyze Cam v3 Garage Door Controller.What is included in the Wyze Garage Door Controller Mounting Kit?
The Mounting Kit includes all necessary hardware for securely installing your Wyze Garage Door Controller, ensuring stable and optimal performance.What is the purpose of the Wyze Garage Door Controller Cable Splitter?
The Cable Splitter is a replacement part that helps manage wiring connections efficiently, ensuring reliable connectivity and a clean setup for your Wyze Garage Door Controller.How can I identify my Wyze Garage Door Controller for setup or troubleshooting?
You can use the Wyze Garage Door Controller QR Code Sticker, a replacement sticker that helps you quickly identify your controller and streamline setup or troubleshooting.What is the return policy for Wyze Garage Door Controller replacement parts?
Wyze offers a 30-day hassle-free return policy on replacement parts such as the controller part and cable splitter, ensuring customer satisfaction.Why should I choose Wyze Garage Door Controllers for my home?
Wyze Garage Door Controllers combine smart technology, AI vision-sensing, user-friendly design, and compatibility with most garage openers, making them an ideal choice for modern connected homes.
