Wyze Garage Door Controller Replacement for Camera Integration
Wyze Garage Door Controller Replacement Part
If you're experiencing controller malfunction with your Wyze Garage Door system or need a replacement part for camera integration, the Wyze Garage Door Controller Part is the perfect solution. This replacement controller unit is designed specifically to restore your garage door's smart functionality without the need to purchase a complete kit.
Key Features:
  • Replacement controller only: Ideal for fixing controller malfunctions or upgrading your existing setup.
  • Affordable and easy to install: Priced at just $6.99, this part helps you get your garage door system back in working order quickly.
  • Compatible with Wyze camera integration: Ensures seamless communication between your garage door and Wyze cameras for enhanced security and monitoring.
Keep your garage door smart and secure by replacing faulty controllers with this dedicated Wyze part, ensuring your camera integration remains uninterrupted.
Enhance Your Wyze Security with Compatible Cameras and Bundles
While the garage door controller replacement part addresses the core malfunction, pairing it with Wyze cameras can elevate your home security and monitoring experience.
Wyze Cam v4 – Advanced Security Camera
The Wyze Cam v4 is a powerful security camera that complements your garage door system by providing crystal-clear video and smart features.
  • 2.5K QHD video resolution for sharp, detailed footage.
  • Color night vision and 4 IR LEDs for clear images even in low light.
  • Multiple mounting options including wall, ceiling, and magnetic mounts for flexible placement.
  • Weather-resistant (IP65), suitable for indoor and outdoor use.
  • Smart integrations with Alexa, Google Assistant, and IFTTT.
  • Two-way audio and built-in siren for interactive security.
  • Wi-Fi 6 support ensures fast and reliable connectivity.
This camera is perfect for monitoring your garage area, providing real-time alerts and video recordings to your phone.
Wyze Cam v4 Outdoor Bundle
For a complete outdoor security solution, consider the Wyze Cam v4 Outdoor Bundle which includes:
  • Wyze Cam v4 with enhanced color night vision.
  • Wyze Outdoor Power Adapter for continuous power supply.
  • 128GB Wyze MicroSD card for 24/7 local recording.
This bundle ensures your garage and surrounding areas are monitored around the clock with high-quality video and reliable power.
Why Integrate Wyze Cameras with Your Garage Door Controller?
Integrating Wyze cameras with your garage door controller replacement part offers several benefits:
  • Real-time monitoring: Watch your garage door activity live from anywhere.
  • Motion detection alerts: Receive instant notifications when movement is detected near your garage.
  • Two-way communication: Speak through your camera to anyone at your garage door.
  • Enhanced security: Combine smart locking and surveillance for comprehensive protection.
Summary
If your Wyze garage door controller is malfunctioning or you need a replacement part for camera integration, the Wyze Garage Door Controller Part is an affordable and effective fix. Pair it with the Wyze Cam v4 or the Wyze Cam v4 Outdoor Bundle to maximize your home security and keep your garage monitored day and night.
Home Security with Wyze Cam Alt text: Family monitoring garage door with Wyze camera on smartphone Wyze Cam v4 Outdoor Installation Alt text: Wyze Cam v4 installed outside garage for security Smart Garage Door Control Alt text: Person using smartphone to control garage door with Wyze system
FeatureWyze Garage Door ControllerWyze Cam v4Wyze Cam v4 Outdoor Bundle
Product TypeGarage Door ControllerWired Security CameraWired Security Camera Bundle
PurposeControl and monitor garage doorIndoor/Outdoor security cameraIndoor/Outdoor security camera + accessories
Camera Resolution1080p HD2.5K QHD + WDR2.5K QHD + WDR
Field of ViewN/A115.9° (D) x 98.5° (H) x 53.1° (V)115.9° (D) x 98.5° (H) x 53.1° (V)
Night VisionN/AB&W + Enhanced ColorB&W + Enhanced Color
SpotlightN/AYes, built-in (65 lumens)Yes, built-in (65 lumens)
SoundN/A99 dB siren99 dB siren
Setup MethodRequires Wyze Cam v3, app setupBluetoothⓇBluetoothⓇ
Wi-Fi ConnectivityN/AWi-Fi 6, 2.4 GHzWi-Fi 6, 2.4 GHz
Local StorageN/AYes: 512 GB MicroSD SlotYes: 512 GB MicroSD Slot
Weather ResistanceN/AIP65, Indoor/OutdoorIP65, Indoor/Outdoor
PowerPowered via existing garage door opener wiringIndoor 5V/1A USB-A to USB-C cableIndoor 5V/1A USB-A to USB-C cable
Additional FeaturesRemote open/close, scheduling, AI sensing, notificationsAdvanced AI person detection, enhanced 2-way talkAdvanced AI person detection, enhanced 2-way talk
Release Year2021 (approximate)20242024
What is the Wyze Garage Door Controller Replacement Part?The Wyze Garage Door Controller Replacement Part is a dedicated replacement unit designed to restore smart functionality to your Wyze Garage Door system. It is ideal for fixing controller malfunctions or upgrading your existing setup without purchasing a complete kit.
How much does the Wyze Garage Door Controller Replacement Part cost?The Wyze Garage Door Controller Replacement Part is affordably priced at just $6.99, making it an economical solution for restoring your garage door's smart features.
Is the Wyze Garage Door Controller Replacement Part compatible with Wyze cameras?Yes, the replacement controller is fully compatible with Wyze camera integration, ensuring seamless communication between your garage door and Wyze cameras for enhanced security and monitoring.
How easy is it to install the Wyze Garage Door Controller Replacement Part?The Wyze Garage Door Controller Replacement Part is designed for easy installation, allowing you to quickly get your garage door system back in working order without professional assistance.
What are the benefits of integrating Wyze cameras with my garage door controller?Integrating Wyze cameras with your garage door controller provides real-time monitoring, motion detection alerts, two-way communication, and enhanced security by combining smart locking and surveillance features.
Which Wyze camera is recommended for garage security?The Wyze Cam v4 is highly recommended for garage security. It offers 2.5K QHD video resolution, color night vision, weather resistance (IP65), multiple mounting options, smart integrations, two-way audio, and Wi-Fi 6 support for reliable connectivity.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 with enhanced color night vision, a Wyze Outdoor Power Adapter for continuous power, and a 128GB Wyze MicroSD card for 24/7 local video recording.
How does the Wyze Garage Door Controller Replacement Part enhance home security?By replacing a faulty controller with the Wyze Garage Door Controller Replacement Part and integrating it with Wyze cameras, you can monitor your garage in real time, receive instant motion alerts, communicate with visitors, and ensure comprehensive protection for your home.
What are the installation steps for the Wyze Garage Door Controller Replacement Part?Can the Wyze Garage Door Controller be used with any Wyze camera model?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Garage Door Controller?
