Affordable Replacement Parts for Wyze Garage Door Controller
If you own a Wyze Garage Door Controller and need affordable replacement parts such as the QR code sticker or mounting kit, this guide will help you find exactly what you need. Whether you’re looking to replace a lost or damaged component or want to maintain your smart garage system, these genuine Wyze parts ensure compatibility and reliability.
Wyze Garage Door Controller QR Code Sticker
Essential Replacement for Easy Setup
The Wyze Garage Door Controller QR Code Sticker is a small but crucial part of your smart garage system. This replacement sticker allows you to quickly scan and connect your controller to the Wyze app, ensuring seamless setup and operation.
- Price: $0.99 USD
- Compatibility: Designed specifically for the Wyze Garage Door Controller
- Return Policy: 30-day hassle-free returns
- Use Case: Ideal for replacing lost or damaged QR stickers to maintain easy device pairing
This affordable sticker keeps your system running smoothly without the need to replace the entire controller.
Wyze Garage Door Controller Mounting Kit
Secure and Neat Installation
The Wyze Garage Door Controller Mounting Kit provides all the necessary components to securely mount your controller in your garage. If your original mounting kit is worn out or missing, this replacement kit is a cost-effective solution.
- Price: $4.99 USD
- Description: Replacement mounting hardware for the Wyze Garage Door Controller
- Compatibility: Perfectly fits the Wyze Garage Door Controller
Keep your controller firmly in place and maintain a clean, organized garage setup with this mounting kit.
Additional Replacement Parts for Wyze Garage Door Controller
Wyze Garage Door Controller Part
If you need to replace the controller part itself, this replacement is available separately. Note that this is not a complete kit but just the controller component.
- Price: $6.99 USD
- Compatibility: Compatible with Wyze Cam v3 Garage Door Controller
Wyze Garage Door Controller Cable Splitter
The cable splitter is another small but important replacement part that helps manage wiring connections for your controller.
- Price: $1.99 USD
- Compatibility: Designed for Wyze Garage Door Controller
Why Choose Genuine Wyze Replacement Parts?
Using authentic Wyze replacement parts ensures your garage door controller continues to function optimally with guaranteed compatibility. These parts are designed specifically for Wyze products, providing peace of mind and maintaining the integrity of your smart home system.
Summary of Affordable Wyze Garage Door Controller Replacement Parts
Product | Price (USD) | Key Feature |
Wyze Garage Door Controller QR Code Sticker | $0.99 | Easy device pairing |
Wyze Garage Door Controller Mounting Kit | $4.99 | Secure mounting solution |
Wyze Garage Door Controller Part | $6.99 | Controller replacement |
Wyze Garage Door Controller Cable Splitter | $1.99 | Wiring management |
Investing in these affordable parts helps extend the life of your Wyze Garage Door Controller without the expense of a full replacement.
Alt text: Person using smartphone to control smart garage door
Experience the convenience of smart garage control with genuine Wyze replacement parts.
Maintain your smart garage system effortlessly with these affordable and reliable Wyze replacement parts. Whether it’s the QR code sticker, mounting kit, or controller components, you can keep your garage door controller running smoothly and securely.
What replacement parts are available for the Wyze Garage Door Controller?
Available replacement parts for the Wyze Garage Door Controller include the QR code sticker, mounting kit, controller part, and cable splitter. These genuine Wyze parts ensure compatibility and reliable performance for your smart garage system.How much does the Wyze Garage Door Controller QR code sticker cost?
The Wyze Garage Door Controller QR code sticker is priced at $0.99 USD. It is an affordable replacement that allows for easy device pairing and setup with the Wyze app.Why is the QR code sticker important for my Wyze Garage Door Controller?
The QR code sticker is essential for quickly scanning and connecting your Wyze Garage Door Controller to the Wyze app. Replacing a lost or damaged sticker ensures seamless setup and continued operation of your smart garage system.What is included in the Wyze Garage Door Controller Mounting Kit?
The Wyze Garage Door Controller Mounting Kit includes all necessary hardware to securely mount your controller in your garage. It is designed specifically for the Wyze Garage Door Controller and helps maintain a clean, organized installation.How much does the Wyze Garage Door Controller Mounting Kit cost?
The Wyze Garage Door Controller Mounting Kit is available for $4.99 USD. It provides a cost-effective solution for replacing worn out or missing mounting hardware.Can I buy just the Wyze Garage Door Controller part separately?
Yes, you can purchase the Wyze Garage Door Controller part separately for $6.99 USD. This replacement is compatible with the Wyze Cam v3 Garage Door Controller and is ideal if you need to replace only the controller component.What is the Wyze Garage Door Controller cable splitter and how much does it cost?
The Wyze Garage Door Controller cable splitter is a replacement part designed to help manage wiring connections for your controller. It is available for $1.99 USD and ensures proper wiring management for your smart garage setup.Are these Wyze Garage Door Controller replacement parts genuine?
Yes, all listed replacement parts are genuine Wyze products. Using authentic Wyze parts guarantees compatibility, reliability, and optimal performance for your garage door controller.What is the return policy for Wyze Garage Door Controller replacement parts?
All Wyze Garage Door Controller replacement parts come with a 30-day hassle-free return policy, allowing you to shop with confidence.Why should I use genuine Wyze replacement parts for my garage door controller?
Genuine Wyze replacement parts are specifically designed for Wyze products, ensuring guaranteed compatibility and maintaining the integrity of your smart home system. They help your garage door controller function optimally and extend its lifespan.
