20ft Wyze Cam USB Extension Cable for Outdoor Balcony Setup
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you're looking to install your Wyze Cam on a second-floor outdoor balcony or any location where the original cable length falls short, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This accessory gives you the freedom to position your camera exactly where you need it without worrying about power outlet proximity.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: A generous 20 feet of USB extension cable to cover longer distances.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Easy Setup: Simply plug the extension cable between your Wyze Cam and power source to extend your camera’s reach.
  • Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your camera installation options.
This cable is ideal for outdoor balconies, second floors, or any area where the original 6-foot cable is insufficient, ensuring your Wyze Cam stays powered and connected without compromise.
Wyze Cam v4: The Ultimate Outdoor Security Camera
For outdoor balcony installations, the Wyze Cam v4 offers unmatched security and clarity, making it an excellent choice for monitoring your home or outdoor spaces.
Why Choose Wyze Cam v4 for Your Balcony?
  • Crystal-clear 2.5K QHD Resolution: Capture every detail with stunning clarity.
  • Enhanced Color Night Vision: See vibrant colors even in low light, perfect for nighttime monitoring.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring intruders.
  • 24/7 Local Recording: Continuous recording with a microSD card slot supporting up to 512GB.
  • Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
  • Smart Home Integration: Compatible with Alexa and Google Assistant for voice control.
  • Weather Resistant: Rated IP65, built to withstand outdoor conditions from -4°F to 122°F (-20°C to 50°C).
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible installation.
With the Wyze Cam v4 paired with the 20ft USB extension cable, you can easily position your camera on a second-floor balcony or any outdoor spot, ensuring comprehensive coverage and reliable power.
"Get unmatched security with Wyze Cam v4 and extend your installation possibilities with the 20ft USB extension cable."
Outdoor Balcony Security Alt text: Wyze Cam installed on a second-floor outdoor balcony overlooking a garden
Enhance Your Outdoor Setup with Power Options
If you want to power your Wyze Cam without relying on nearby outlets, consider the Cam v4 + Lamp Socket v2 Bundle. This bundle allows you to power your camera through an existing lamp socket, eliminating the need for additional wiring or outlets.
Features of the Cam v4 + Lamp Socket v2 Bundle
  • Convenient Power Source: Use your outdoor lamp socket to power the camera.
  • Motion-Activated Lights: The lamp socket supports smart lighting features.
  • Compatible with Multiple Wyze Cams: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Dusk to Dawn Scheduling: Automate lighting based on time of day.
  • Compact and Durable: Made from polycarbonate and plastic, suitable for damp locations (not fully weatherproof).
This bundle is a smart choice for outdoor balconies where power outlets are limited but lamp sockets are available.
Summary
For extending your Wyze Cam USB cable length to a second-floor outdoor balcony, the Wyze Cam USB Extension Cable - 20ft is the ideal accessory. Pair it with the Wyze Cam v4 for superior outdoor security with crystal-clear video and smart features. For even more flexible power options, the Cam v4 + Lamp Socket v2 Bundle offers a convenient way to power your camera through existing lighting fixtures. Together, these products provide a comprehensive solution for outdoor balcony camera installations, ensuring your home stays safe and monitored with ease.
Product Highlights
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Cam v4 + Lamp Socket v2 Bundle
TypeAccessoryCameraBundle (Camera + Lamp Socket)
Price$7.99$100.00 (regular), $35.98 (some bundles)$49.96
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraWyze Cam v3, v3 Pro, v4, OG, Pan v3
Cable Length20 ft USB extension cable6-Foot Flat micro USB to USB-A cableIncludes Wyze Cam v4 + Lamp Socket v2
Camera ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Motion-Activated SpotlightN/AYesYes
Power AdapterN/AIndoor 5V/1A (Outdoor adapter sold separately)Lamp Socket powers camera without outlet
Weather ResistanceN/AIP65Lamp Socket: Not weatherproof, suitable for damp locations
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic mountN/A
ConnectivityN/A2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Bluetooth
Additional FeaturesExtends USB cable length8x digital zoom, 24/7 local recording, Alexa & Google Assistant compatibleMotion-activated lights, dusk to dawn scheduling, linkability
Included Items1 x 20ft USB extension cableWyze Cam v4, Quick Start Guide, Wall Mount Plate, Tape, Screw Kit, Power Adapter, 6ft USB cableWyze Cam v4 + Lamp Socket v2
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to install your camera in locations farther from a power outlet, such as second-floor outdoor balconies or areas where the original cable is too short.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
How do I set up the Wyze Cam USB Extension Cable?Setting up the Wyze Cam USB Extension Cable is easy. Simply plug the extension cable between your Wyze Cam and the power source to extend your camera’s reach.
What is the price of the Wyze Cam USB Extension Cable - 20ft?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99.
Why is the Wyze Cam v4 recommended for outdoor balcony security?The Wyze Cam v4 is ideal for outdoor balcony security because it offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support, smart home integration, weather resistance (IP65), and multiple mounting options.
Can the Wyze Cam v4 be used outdoors?Yes, the Wyze Cam v4 is weather resistant with an IP65 rating, making it suitable for outdoor use in temperatures ranging from -4°F to 122°F (-20°C to 50°C).
What are the power options for installing Wyze Cam on a balcony without nearby outlets?If you don’t have a nearby power outlet, you can use the Cam v4 + Lamp Socket v2 Bundle, which allows you to power your Wyze Cam through an existing outdoor lamp socket.
What features does the Cam v4 + Lamp Socket v2 Bundle offer?The Cam v4 + Lamp Socket v2 Bundle offers convenient power through a lamp socket, motion-activated lights, dusk to dawn scheduling, compatibility with multiple Wyze Cam models, and a compact, durable design suitable for damp locations.
Is the Lamp Socket v2 fully weatherproof?The Lamp Socket v2 is made from polycarbonate and plastic and is suitable for damp locations, but it is not fully weatherproof.
How much local storage does the Wyze Cam v4 support?The Wyze Cam v4 supports continuous 24/7 local recording with a microSD card slot that accommodates up to 512GB.
Does the Wyze Cam v4 work with smart home assistants?Yes, the Wyze Cam v4 is compatible with Alexa and Google Assistant for convenient voice control and smart home integration.
What are the installation steps for the Wyze Cam USB Extension Cable - 20ft?Is the Wyze Cam USB Extension Cable compatible with all Wyze Cam models?Are there any ongoing promotions or discounts available for Wyze products?
