20ft Wyze Cam USB Extension Cable for Nighttime Front Yard Security
Extend Your Wyze Cam Coverage with the 20ft USB Extension Cable
When monitoring your front yard at night, having the right setup is crucial for clear, uninterrupted security footage. The Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach without compromising power or connectivity. Say goodbye to short cables limiting your placement options and enjoy the freedom to position your Wyze Cam exactly where you need it—whether mounted on a porch, tree, or fence.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet of durable USB cable to cover large outdoor areas.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Easy Setup: Simply plug in to extend your camera’s power source without any complicated installation.
  • Weather-Ready: Designed to support outdoor camera setups when paired with weather-resistant Wyze Cams.
This cable is an essential upgrade for anyone looking to monitor their front yard or backyard with Wyze cameras, especially during nighttime activities.
Wyze Cam v4: The Ultimate Nighttime Security Camera
For front yard security at night, the Wyze Cam v4 stands out as the best plug-in camera option. It offers advanced features that ensure you never miss a moment, even in low-light conditions.
Why Choose Wyze Cam v4 for Nighttime Front Yard Monitoring?
  • 2.5K Quad HD Resolution: Capture crystal-clear video with four times the detail of 1080p cameras.
  • Enhanced Color Night Vision: See vibrant colors in the dark, revealing details that traditional black-and-white night vision misses.
  • Integrated Spotlight & Siren: Motion-activated spotlight illuminates your yard, while the siren deters unwanted visitors.
  • IP65 Weather Resistance: Built to withstand rain, snow, and dust, making it perfect for outdoor use.
  • Advanced Audio: Clear two-way talk with noise reduction for easy communication.
  • Smart Detection & Alerts: Detects motion, sound, and even smoke or CO alarms, sending instant notifications to your phone.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection even at greater distances.
  • MicroSD Card Support: Record continuously with local storage up to 512GB (microSD card sold separately).
With the Wyze Cam v4 paired with the 20ft USB extension cable, you can position your camera optimally to cover your entire front yard, ensuring safety and peace of mind throughout the night. Wyze Cam v4 monitoring a home exterior at night
Enhance Your Outdoor Security with the Wyze Cam v4 Outdoor Bundle
For a comprehensive front yard security solution, consider the Wyze Cam v4 Outdoor Bundle. This package combines the powerful Wyze Cam v4 with essential accessories to maximize your outdoor surveillance capabilities.
What’s Included in the Wyze Cam v4 Outdoor Bundle?
  • Wyze Cam v4: Featuring 2.5K QHD resolution and enhanced color night vision.
  • Wyze Outdoor Power Adapter: Provides reliable power for continuous operation outdoors.
  • Wyze MicroSD Card (128GB): Enables 24/7 local recording without monthly fees.
Benefits of the Outdoor Bundle
  • All-in-One Convenience: Everything you need to set up a robust outdoor security system.
  • Motion-Activated Spotlight & Siren: Illuminate and protect your property automatically.
  • Smart Home Integration: Compatible with Alexa and Google Assistant for voice control and automation.
  • Weatherproof Design: Ready to brave the elements for year-round protection.
This bundle is ideal for users who want a plug-and-play solution with extended power options and local storage, perfect for monitoring front yard activity at night. Family enjoying a safe, well-lit front yard monitored by Wyze Cam
Why Choose Wyze for Your Front Yard Night Security?
Wyze offers a range of smart security products designed to work together seamlessly. Whether you’re extending your camera’s reach with the 20ft USB extension cable or upgrading to the latest Wyze Cam v4 with enhanced night vision, you get:
  • Affordable, High-Quality Security: Advanced features without breaking the bank.
  • Easy Installation: User-friendly setup with Bluetooth and magnetic mounts.
  • Smart Alerts & AI Detection: Stay informed with precise notifications tailored to your needs.
  • Flexible Power Options: Wired or wireless solutions to fit any outdoor environment.
By combining the Wyze Cam USB Extension Cable - 20ft with the Wyze Cam v4 or the Wyze Cam v4 Outdoor Bundle, you create a powerful, extended security system that covers your front yard day and night.
Summary of Products for Extended Front Yard Night Security
Product NameKey FeaturesPrice
Wyze Cam USB Extension Cable - 20ft20ft length, compatible with multiple Wyze Cams$7.99
Wyze Cam v42.5K QHD, color night vision, IP65 rated$100.00
Wyze Cam v4 Outdoor BundleIncludes Cam v4, outdoor power adapter, 128GB SD$69.99
Equip your home with these trusted Wyze products to ensure your front yard is well-monitored and secure, especially during nighttime activities.
"Extend your camera’s reach and enhance your night vision with Wyze’s trusted accessories and cameras — perfect for keeping your front yard safe and visible after dark."
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Wyze Cam v4 Outdoor Bundle
Product TypeAccessory (USB Extension Cable)CameraCamera Bundle
Price$7.99$100.00 (standard), $35.98 (with 32GB MicroSD)$69.99
Cable Length20 ft USB extension6 ft micro USB to USB-A6 ft micro USB to USB-A
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard/TelephotoWyze Cam v4Wyze Cam v4 + Outdoor Power Adapter + 128GB MicroSD Card
ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Weather ResistanceN/AIP65IP65
Local RecordingN/AmicroSD card support up to 512GB24/7 local recording with 128GB MicroSD included
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6
Motion DetectionN/AYesYes
Sound DetectionN/AYesYes
SpotlightN/AMotion-activated spotlightMotion-activated spotlight
Power SourceN/AWiredWired
Included AccessoriesUSB Extension CableCamera onlyCamera, Outdoor Power Adapter, 128GB MicroSD Card
Use CaseExtends USB cable length for Wyze CamsIndoor/outdoor security cameraOutdoor security camera bundle
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power source, allowing you to position your camera in optimal locations such as porches, trees, or fences without compromising power or connectivity.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable is designed to support outdoor camera setups when paired with weather-resistant Wyze Cams, making it ideal for front yard or backyard monitoring.
What are the key features of the Wyze Cam v4 for nighttime front yard security?The Wyze Cam v4 offers 2.5K Quad HD resolution, enhanced color night vision, an integrated spotlight and siren, IP65 weather resistance, advanced two-way audio, smart detection and alerts, Wi-Fi 6 support, and microSD card support for continuous local recording.
How does the Wyze Cam v4 improve night vision compared to other cameras?The Wyze Cam v4 features enhanced color night vision, allowing you to see vibrant colors and more details in low-light conditions, unlike traditional cameras that only offer black-and-white night vision.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter for reliable outdoor power, and a Wyze MicroSD Card (128GB) for 24/7 local recording.
Does the Wyze Cam v4 Outdoor Bundle support smart home integration?Yes, the Wyze Cam v4 Outdoor Bundle is compatible with Alexa and Google Assistant, allowing for voice control and smart home automation.
Can I record continuously with the Wyze Cam v4?Yes, the Wyze Cam v4 supports continuous local recording with a microSD card of up to 512GB (microSD card sold separately or included in the Outdoor Bundle).
Is the Wyze Cam v4 weatherproof for outdoor use?Yes, the Wyze Cam v4 is IP65 rated, making it weather-resistant and suitable for outdoor use in rain, snow, and dust.
What are the benefits of using the Wyze Cam USB Extension Cable with Wyze Cam v4?Using the Wyze Cam USB Extension Cable with the Wyze Cam v4 allows you to position your camera further from power outlets, ensuring optimal coverage of your front yard or backyard without losing power or connectivity.
How easy is it to install Wyze security products for front yard monitoring?Wyze security products are designed for easy installation, featuring user-friendly setup with Bluetooth and magnetic mounts, making it simple to secure your front yard quickly.
What makes Wyze security solutions affordable and high-quality?Wyze offers advanced security features such as high-resolution video, smart alerts, AI detection, and weather resistance at competitive prices, providing excellent value for front yard night security.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Is the Wyze Cam USB Extension Cable compatible with all Wyze Cam models?Do you have any deals, ongoing sales, discounts, or promotions?
