20ft Wyze Cam USB Extension Cable for Finished Basements
Extend Your Wyze Cam Power with the 20ft USB Extension Cable
If you have a finished basement or any area where the standard Wyze Cam USB cable length feels restrictive, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This accessory allows you to extend the reach of your Wyze Cam’s power source without compromising performance or reliability.
Why Choose the Wyze Cam USB Extension Cable - 20ft?
  • Longer Reach: Say goodbye to short cables and limited placement options. With 20 feet of extension, you can position your Wyze Cam exactly where you need it, even in hard-to-reach spots like finished basements.
  • Wide Compatibility: Works seamlessly with a variety of Wyze Cam models including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam OG Standard and Telephoto.
  • Easy Setup: Simply plug the extension cable between your Wyze Cam and power adapter to instantly increase your camera’s power cable length.
  • Affordable and Reliable: Priced at just $7.99, this extension cable offers a cost-effective way to enhance your home security setup without the need for complicated wiring or additional power sources.
Perfect for finished basements, garages, or any location where power outlets are distant from your camera placement.
Enhance Your Wyze Cam Setup in Finished Basements
Finished basements often have limited power outlet availability or inconvenient outlet locations. Using the Wyze Cam USB Extension Cable - 20ft, you can:
  • Mount your Wyze Cam high on walls or ceilings for optimal coverage.
  • Avoid unsightly power strips or extension cords that clutter your space.
  • Maintain a clean, professional look while ensuring your camera stays powered.
This cable extension is designed to maintain stable power delivery over the longer distance, ensuring your Wyze Cam operates smoothly without interruptions.
Compatible Wyze Cameras for Basement Security
While the USB extension cable is a versatile accessory, pairing it with the right Wyze Cam model can maximize your basement security:
Wyze Cam v4
  • Video Quality: 2.5K QHD (2560x1440) resolution for crystal-clear footage.
  • Night Vision: Color night vision with 4 IR LEDs and 2 white spotlight LEDs.
  • Field of View: Wide 115.8° diagonal field of view to cover large basement areas.
  • Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for reliable streaming.
  • Mounting Options: Includes wall, ceiling, and magnetic mounts for flexible installation.
  • Power: Comes with a 6-foot USB cable, which can be extended with the 20ft USB extension cable for greater reach.
The Wyze Cam v4’s advanced features combined with the extended USB cable make it ideal for monitoring finished basements, ensuring you never miss a moment.
Summary
For anyone looking to extend the power cable length of their Wyze Cam in a finished basement or any other space, the Wyze Cam USB Extension Cable - 20ft is an essential accessory. It offers:
  • Compatibility with multiple Wyze Cam models.
  • A generous 20-foot length for flexible camera placement.
  • Easy plug-and-play setup.
  • Affordable pricing.
Pair it with the Wyze Cam v4 for a powerful, high-resolution security solution that covers every corner of your basement with ease.
Wyze Cam in Home Setting Alt text: Wyze Cam mounted in a finished basement with extended USB cable for power
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4
Product TypeUSB Extension CableSecurity Camera
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone camera
Cable Length20 ft6 ft (included power cable)
Price$7.99$100.00 (standard), other bundles vary
ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision
Weather ResistanceN/AIP65
Power SourceUSB extension cable (powered by original USB source)Wired (5V/1A adapter)
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic mount
ConnectivityUSBWi-Fi 6, Bluetooth 5.2
Audio FeaturesN/AEnhanced Two-Way Talk, Built-in Siren
Additional FeaturesExtends USB cable length for Wyze CamsMotion-activated spotlight, AI Auto-Zoom, Smart Detection Zones, Smoke & CO Alerts
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power source, allowing you to place your camera in hard-to-reach areas such as finished basements, garages, or rooms with distant power outlets.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam OG Standard and Telephoto models.
How do I set up the Wyze Cam USB Extension Cable - 20ft?Setup is simple—just plug the extension cable between your Wyze Cam and its power adapter to instantly increase the length of your camera’s power cable.
Is the Wyze Cam USB Extension Cable - 20ft reliable for long-term use?Yes, the extension cable is designed to maintain stable power delivery over the 20-foot distance, ensuring your Wyze Cam operates smoothly without interruptions.
Can I use the Wyze Cam USB Extension Cable - 20ft in finished basements?Absolutely. The 20ft extension cable is perfect for finished basements, allowing you to mount your Wyze Cam high on walls or ceilings and keep your space clutter-free by avoiding unsightly power strips or extension cords.
What are the benefits of using the Wyze Cam USB Extension Cable - 20ft?Benefits include a generous 20-foot length for flexible camera placement, wide compatibility with multiple Wyze Cam models, easy plug-and-play setup, and affordable pricing at just $7.99.
Why is the Wyze Cam v4 recommended for basement security with the extension cable?The Wyze Cam v4 offers 2.5K QHD resolution, color night vision, a wide 115.8° field of view, and flexible mounting options. When paired with the 20ft USB extension cable, it provides comprehensive coverage and reliable power in large or hard-to-reach basement areas.
Does the Wyze Cam USB Extension Cable - 20ft affect camera performance?No, the extension cable is engineered to deliver stable power over the extended distance, so your Wyze Cam’s performance and reliability are not compromised.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99, making it a cost-effective solution for extending your camera’s power reach.
What are the installation options for the Wyze Cam v4 in a finished basement?Can the Wyze Cam USB Extension Cable be used with other Wyze Cam models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam USB Extension Cable?
