20ft Wyze Cam USB Extension Cable for Shaded Patio Power
Extend Your Wyze Cam Power with the 20ft USB Extension Cable
If you have a Wyze Cam installed near a heavily shaded patio or any outdoor area where power outlets are limited or far away, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach without compromising power or connectivity. This 20-foot cable is designed specifically to work seamlessly with a wide range of Wyze cameras including Wyze Cam v2, v3, v4, Wyze Cam Pan v2/v3, and the original Wyze Cam models.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet of flexible USB extension cable to reach distant power sources.
  • Compatibility: Works with Wyze Cam v2, v3, v4, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Telephoto models.
  • Ease of Use: Simply plug in to extend your camera’s power cable without any complicated setup.
  • Durability: Designed to maintain stable power delivery over long distances.
This cable is an essential solution for patios or shaded outdoor areas where the original 6-foot cable might fall short, ensuring your Wyze Cam stays powered and operational at all times.
Wyze Cam v4 – Advanced Security with Weather Resistance
The Wyze Cam v4 is an excellent choice for outdoor or shaded patio surveillance, offering high-quality video and robust features to keep your home secure.
Why Choose Wyze Cam v4 for Your Patio?
  • 2.5K QHD Video Resolution: Crystal-clear 2560x1440 video quality for detailed monitoring.
  • Color Night Vision: Equipped with 4 IR LEDs and 2 white spotlight LEDs to capture vibrant color footage even in low light.
  • Weather Resistant (IP65): Built to withstand rain, snow, and harsh outdoor conditions.
  • Flexible Mounting Options: Includes wall, ceiling, and magnetic mounts for easy installation near patios.
  • Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for reliable streaming.
  • Power: Comes with a 6-foot USB cable, which can be extended with the 20ft USB extension cable for shaded or distant locations.
With its compact size and powerful sensor, the Wyze Cam v4 is ideal for shaded patios where lighting conditions vary, ensuring you never miss a moment.
Wyze Cam Pan v3 – 360° Coverage for Large Outdoor Areas
For patios or outdoor spaces that require wide-angle surveillance, the Wyze Cam Pan v3 offers dynamic pan and tilt capabilities combined with weather resistance.
Highlights of Wyze Cam Pan v3
  • 360° Horizontal & 180° Vertical Movement: Covers every corner of your patio with smooth pan and tilt.
  • 1080p Full HD Video: Clear and sharp video quality day and night.
  • Color Night Vision: Four IR LEDs provide excellent night vision.
  • IP65 Weather Resistance: Perfect for outdoor use in shaded or exposed areas.
  • Two-Way Audio: Built-in microphone and speaker allow you to communicate through the camera.
  • Power Options: Requires Wyze Outdoor Power Adapter (sold separately) and can benefit from the 20ft USB extension cable for flexible placement.
This camera is perfect for users who want to monitor large patios or outdoor spaces with the ability to remotely control the camera’s view. Wyze Cam Pan v3 in snowy outdoor setting
Optimize Your Wyze Cam Setup Near Shaded Patios
"A shaded patio can limit sunlight and power outlet access, but with the Wyze Cam USB Extension Cable, you can easily position your camera exactly where you need it without worrying about cable length."
Using the Wyze Cam USB Extension Cable - 20ft allows you to extend your camera’s power source to reach shaded or hard-to-access areas, ensuring continuous surveillance coverage. Whether you pair it with the Wyze Cam v4 for high-resolution video or the Wyze Cam Pan v3 for panoramic views, this cable enhances your installation flexibility.
Summary of Recommended Products for Extended Patio Surveillance
ProductKey BenefitPrice (Approx.)
Wyze Cam USB Extension CableExtends power cable by 20 feet$7.99
Wyze Cam v42.5K QHD, color night vision, IP65$100.00
Wyze Cam Pan v3360° pan/tilt, weather resistant$39.98
Enhance Your Outdoor Security Setup Today
With the combination of the Wyze Cam USB Extension Cable - 20ft and versatile Wyze cameras like the Wyze Cam v4 and Wyze Cam Pan v3, you can confidently monitor shaded patios and outdoor spaces with ease. Enjoy flexible installation, superior video quality, and reliable power delivery no matter where your camera is placed. Wyze Cam indoor two-way audio lifestyle
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Wyze Cam Pan v3
TypeAccessoryCameraCamera
Price$7.99$107.94 (varies by pack)$39.98 (single)
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraStandalone camera
ResolutionN/A2.5K QHD (2560x1440)1080p (1920x1080)
Field of ViewN/ADFOV 115.8°, HFOV 98.5°, VFOV 53.1°120° FOV
Night VisionN/A4 IR LEDs (850 nm) + 2 white spotlight LEDs (Color Night Vision)4 IR LEDs (850 nm), Color Night Vision
Weather ResistanceN/AIP65IP65
Power SourceUSB Extension CableWired (5V/1A adapter)Wired (5V/2000mA adapter)
Cable Length20 ft USB extension cable6 ft flat micro USB to USB-A cable6" (1.8 m) power cable
AudioN/A99dB speaker, 2-way talk, built-in sirenBuilt-in speaker and microphone, 2-way audio
ConnectivityUSB2.4 GHz Wi-Fi, Wi-Fi 6, Bluetooth 5.2802.11 b/g/n 2.4 GHz Wi-Fi (no 5 GHz)
Mounting OptionsN/AStand, wall, ceiling, magnetic wall mountScrew 1/4" - 20 mount
DimensionsN/A2in x 2in x 2 3/8in124mm (H) x 60mm (W) x 63mm (D)
WeightN/A0.49 lb (222 g)11.29 oz (320 g)
StorageN/AmicroSD card up to 512 GBSupports up to 256 GB microSD
Video FPSN/ADaytime 20 FPS / Nighttime 15 FPSDaytime 20 fps / Nighttime 15 fps
ZoomN/A8x digital zoom8x digital zoom
Special FeaturesExtends USB cable length for Wyze CamsEnhanced Color Night Vision, motion-activated spotlight, Wide Dynamic Range (WDR), IP65 weather resistance, integrated siren360° pan, 180° tilt, IP65 weather resistance, noise & echo cancellation
Warranty30-day hassle-free returns1-Year1-Year
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the power reach of your Wyze Cam, allowing you to install your camera in shaded patios or outdoor areas where power outlets are far away. It ensures your camera stays powered and operational without compromising connectivity.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Telephoto models, as well as the original Wyze Cam.
How long is the Wyze Cam USB Extension Cable and is it durable?The Wyze Cam USB Extension Cable is 20 feet long and is designed for durability, maintaining stable power delivery over long distances for reliable camera operation.
Is the Wyze Cam v4 suitable for outdoor or shaded patio surveillance?Yes, the Wyze Cam v4 is ideal for outdoor or shaded patio surveillance. It features 2.5K QHD video resolution, color night vision, IP65 weather resistance, and flexible mounting options, making it perfect for varying lighting conditions and outdoor environments.
Does the Wyze Cam v4 support night vision?Yes, the Wyze Cam v4 is equipped with color night vision, featuring 4 IR LEDs and 2 white spotlight LEDs to capture vibrant color footage even in low-light conditions.
What are the key features of the Wyze Cam Pan v3 for outdoor use?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical movement for full coverage, 1080p Full HD video, color night vision, IP65 weather resistance, and two-way audio. It is ideal for monitoring large patios or outdoor spaces.
Can I use the 20ft USB Extension Cable with the Wyze Cam Pan v3?Yes, the 20ft USB Extension Cable can be used with the Wyze Cam Pan v3 to extend its power source, allowing for flexible placement in shaded or distant outdoor areas. Note that the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter, sold separately.
How can I optimize my Wyze Cam setup for shaded patios?To optimize your Wyze Cam setup for shaded patios, use the Wyze Cam USB Extension Cable - 20ft to extend your camera’s power source. Pair it with weather-resistant models like the Wyze Cam v4 or Wyze Cam Pan v3 for reliable surveillance and flexible installation.
What is the price of the Wyze Cam USB Extension Cable - 20ft?The Wyze Cam USB Extension Cable - 20ft is priced at approximately $7.99.
What are the benefits of using Wyze Cam products for outdoor security?Wyze Cam products like the Wyze Cam v4 and Wyze Cam Pan v3 offer high-resolution video, color night vision, weather resistance, and flexible mounting options, making them excellent choices for outdoor security and shaded patio surveillance.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze camera models?What are the benefits of using the Wyze Cam v4 for outdoor surveillance?Is there a warranty available for the Wyze Cam USB Extension Cable?
