Easy Add-On Solar Panel for Wyze Cameras: Reduce Manual Battery Interventions
If you own a Wyze Battery Cam and want to minimize the hassle of frequent battery recharges, the
Wyze Battery Cam Solar Panel is the perfect accessory to extend your camera’s battery life effortlessly. Designed specifically for Wyze’s outdoor battery cameras, this solar panel harnesses the power of the sun to keep your security system running longer without manual intervention.
Wyze Battery Cam Solar Panel: Continuous Power for Your Wyze Cameras
Designed for Seamless Integration
The Wyze Battery Cam Solar Panel is engineered to work flawlessly with the
Wyze Cam Outdoor v1/v2 and the
Wyze Battery Cam Pro. This means you can easily attach the solar panel to your existing Wyze battery camera setup and enjoy extended recording times without worrying about frequent battery swaps or recharging.
Weather-Resistant and Flexible Mounting
Built with an IP65 weather resistance rating, the solar panel is dustproof and waterproof, making it ideal for all outdoor conditions—rain, sun, or snow. Its 360° freestyle mount allows you to position the panel at the perfect angle to maximize sun exposure, ensuring efficient solar charging throughout the day.
Long-Range Power Cable for Ultimate Flexibility
The included 13-foot weatherproof power cable gives you the freedom to mount your camera and solar panel in the most optimal locations, even if they are far apart. This flexibility helps you secure your property without compromising on power supply.
Record for longer. Attach the Wyze Battery Cam Solar Panel to your Wyze Battery Cam Pro or Wyze Cam Outdoor and enjoy extended battery life with minimal maintenance.
Wyze Battery Cam Pro: Advanced Wireless Security with Solar Power Option
High-Resolution Video and Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, providing crystal-clear footage day and night. Equipped with integrated spotlight and siren, plus radar and PIR motion detection, it offers pro-grade security without the need for wires or hubs.
Removable, Rechargeable Battery Packs
Say goodbye to downtime. The camera features removable battery packs that you can hot-swap easily, ensuring your security system stays active. When paired with the Wyze Battery Cam Solar Panel, you can significantly reduce the frequency of manual battery changes.
Weatherproof and Dual-Band WiFi Support
With an IP65 rating, the Wyze Battery Cam Pro withstands harsh weather conditions. It supports both 2.4 GHz and 5 GHz WiFi networks for faster, more reliable connectivity.
Smart Features and Local Storage
- Local recording with microSD card support (up to 256GB)
- Two-way audio for communication
- Compatible with Alexa, Google Assistant, and IFTTT
- Bird detection available with Wyze Security Plans
Wireless freedom meets solar power. Combine the Wyze Battery Cam Pro with the solar panel to create a truly maintenance-free outdoor security solution.
Wyze Battery Cam Pro + Solar Panel Bundle: The Ultimate Solar-Powered Security Kit
All-in-One Convenience
For those looking to get started quickly, the
Wyze Battery Cam Pro + Solar Panel bundle offers a complete package. This bundle includes the camera and the solar panel designed to work together seamlessly, providing up to 6 months of battery life on a single charge when paired with solar power.
Key Specifications
- Video Resolution: 2560 x 1440 (2.5K HDR)
- Battery Capacity: 6200mAh rechargeable packs
- Charging Time: Approximately 9 hours (solar or wired)
- Weather Resistance: IP65 rated for outdoor durability
- Wireless: Supports 2.4 GHz and 5 GHz WiFi
- Motion Detection: Radar + PIR sensors for precise alerts
- Integrated Spotlight & Siren for enhanced security
- Local and cloud storage options available
Easy Setup and Mounting
The camera and solar panel come with versatile mounting options, including a standard 1/4” - 20 mount and a wall mount, allowing you to install your system wherever you need it most.
Alt text: Wyze Battery Cam Pro with solar panel mounted outdoors on a house wall
Why Choose Wyze Solar Panel for Your Battery Cam?
- Reduce Manual Battery Interventions: Solar power keeps your camera charged longer, reducing the need to bring it indoors for recharging.
- Weatherproof Durability: Designed to withstand outdoor elements, ensuring reliable performance year-round.
- Flexible Installation: Long power cable and 360° mount allow you to position the panel for optimal sunlight.
- Cost-Effective: At just $24.99, it’s an affordable upgrade to enhance your Wyze camera’s battery life.
Summary
For Wyze Battery Cam users seeking a hassle-free, extended power solution, the
Wyze Battery Cam Solar Panel is an essential accessory. Whether you own the Wyze Cam Outdoor v1/v2 or the advanced Wyze Battery Cam Pro, adding this solar panel means less manual battery swapping and more continuous security coverage. For the best value and convenience, consider the
Wyze Battery Cam Pro + Solar Panel bundle to get everything you need in one package.
Enhance your home security with solar-powered peace of mind today!
What Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is designed to work seamlessly with the Wyze Cam Outdoor v1/v2 and the Wyze Battery Cam Pro, providing extended battery life for these outdoor battery-powered cameras.How does the Wyze Battery Cam Solar Panel help reduce manual battery recharging?
The Wyze Battery Cam Solar Panel harnesses solar energy to keep your Wyze battery camera charged, significantly reducing the need for frequent manual battery swaps or recharging, and allowing for more continuous security coverage.Is the Wyze Battery Cam Solar Panel weatherproof?
Yes, the Wyze Battery Cam Solar Panel is IP65 rated, making it dustproof and waterproof. It is built to withstand all outdoor conditions, including rain, sun, and snow.How flexible is the installation of the Wyze Battery Cam Solar Panel?
The solar panel features a 360° freestyle mount and comes with a 13-foot weatherproof power cable, allowing you to position the panel for optimal sunlight and mount your camera and panel in the most convenient locations.What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers 2.5K HDR video resolution, radar and PIR motion detection, integrated spotlight and siren, removable rechargeable battery packs, IP65 weather resistance, dual-band WiFi support (2.4 GHz and 5 GHz), two-way audio, local microSD card storage, and compatibility with Alexa, Google Assistant, and IFTTT.How long does the Wyze Battery Cam Pro last on a single charge with the solar panel?
When paired with the Wyze Battery Cam Solar Panel, the Wyze Battery Cam Pro can achieve up to 6 months of battery life on a single charge, depending on usage and sunlight exposure.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the Wyze Battery Cam Pro camera and the Wyze Battery Cam Solar Panel, providing a complete, easy-to-install solar-powered security solution.What mounting options are available for the Wyze Battery Cam Pro and Solar Panel?
Both the camera and solar panel come with versatile mounting options, including a standard 1/4” - 20 mount and a wall mount, allowing for flexible installation wherever you need security coverage.How much does the Wyze Battery Cam Solar Panel cost?
The Wyze Battery Cam Solar Panel is priced at just $24.99, making it an affordable upgrade to extend your Wyze camera’s battery life.Does the Wyze Battery Cam Pro support local storage?
Yes, the Wyze Battery Cam Pro supports local recording with a microSD card (up to 256GB), in addition to offering cloud storage options.
