Wyze Duo Cam Doorbell: Smart Entryway Monitoring for Your Devices
Entryway Monitoring Systems Compatible with Personal Smart Devices Featuring Wyze Duo Cam Doorbell
Enhance your home security and convenience with an entryway monitoring system that integrates seamlessly with your personal smart devices. Whether you want to keep an eye on your front door, monitor package deliveries, or control your smart home ecosystem, Wyze offers a range of products designed to deliver crystal-clear video, smart alerts, and effortless connectivity. This guide highlights the best Wyze products tailored for entryway monitoring, including the Wyze Video Doorbell v2, security camera bundles, and smart accessories that work harmoniously with your smartphone and voice assistants.
Wyze Video Doorbell v2: The Ultimate Smart Doorbell Experience
Crisp 2K Video and Wide Field of View
The Wyze Video Doorbell v2 is your first line of defense at the front door, offering stunning 2K (2048 x 1536) resolution video that captures every detail with clarity. Its wide 166.8° diagonal field of view ensures you see visitors and packages clearly, covering a broad area without blind spots.
Advanced Features for Enhanced Security
  • Two-way audio: Communicate directly with visitors or delivery personnel from anywhere using your smartphone.
  • Motion-activated voice deterrence: Automatically play a warning message to deter unwanted guests.
  • Local microSD storage: Save video footage locally with up to 256GB microSD support, ensuring your data is secure even without cloud access.
  • Weather-resistant design: Rated IP65, it withstands harsh outdoor conditions, from rain to snow.
  • Smartphone compatibility: Works with Android 9.0+ and iOS 15.0+, plus integrates with Alexa, Google Assistant, and IFTTT for voice control and automation.
Included Accessories for Easy Installation
The package includes a Wyze Chime Controller, wall plate, wedge for angled mounting, wire caps, and a comprehensive installation kit, making setup straightforward for any home.
Experience peace of mind knowing you can answer your door from anywhere with the clearest and most capable wired video doorbell yet.
Wyze Video Doorbell Lifestyle Stay connected and secure with Wyze Video Doorbell v2
Security Starter Pack: Comprehensive Home Monitoring Bundle
What’s Included?
This starter pack combines the Wyze Cam v4 and Wyze Cam Pan v3, providing a versatile duo for entryway and perimeter monitoring.
Wyze Cam v4 Highlights
  • 2.5K QHD video resolution: Crystal-clear footage with wide dynamic range for balanced lighting.
  • Night vision: Equipped with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens) for color night vision.
  • Compact and versatile: Small form factor (2in x 2in x 2 3/8in) with multiple mounting options including wall, ceiling, and magnetic mounts.
  • Connectivity: Bluetooth and 2.4GHz Wi-Fi compatible with Android 9.0+ and iOS 15.0+.
  • Smart integrations: Works with Alexa, Google Assistant, and IFTTT for seamless smart home control.
Wyze Cam Pan v3 Highlights
  • 360° horizontal and 180° vertical coverage: Pan and tilt your camera remotely to cover every angle of your entryway.
  • 1080p full HD video: Clear and smooth video streaming at 20 fps daytime and 15 fps nighttime.
  • Night vision: 4 IR LEDs (850 nm) for reliable black-and-white night vision.
  • Easy installation: Includes mounting kit and power adapter with a 6-foot micro USB cable.
This bundle is perfect for those starting their home security journey, offering comprehensive coverage and smart device compatibility at an affordable price.
Wyze Cam Pan v3 Lifestyle Monitor your entryway with 360° coverage using Wyze Cam Pan v3
Lamp Socket Bundles: Power Your Cameras Without Outlets
Cam v4 + Lamp Socket v2 Bundle
Ideal for outdoor lighting fixtures, this bundle powers your Wyze Cam v4 directly from a lamp socket, eliminating the need for nearby outlets. Features include:
  • Motion-activated lights: Automatically turn on lights when motion is detected, enhancing security and visibility.
  • Dusk to dawn scheduling: Lights operate only when needed, saving energy.
  • Linkability: Connect multiple devices for synchronized operation.
  • Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
Pan v3 + Lamp Socket v2 Bundle
Similar to the Cam v4 bundle, this kit powers the Wyze Cam Pan v3 via a lamp socket, perfect for outdoor setups where power outlets are scarce. It shares the same smart lighting features and compatibility.
These bundles are perfect for enhancing your entryway monitoring system with smart lighting and flexible power options.
Wyze Universal Wi-Fi Chime: Never Miss a Visitor
Simple and Smart Doorbell Alerts
The Wyze Universal Wi-Fi Chime plugs into any indoor outlet and pairs effortlessly with all Wyze Cams and doorbells, including the Wyze Video Doorbell v2. Key features:
  • 17 different chime tones: Customize your alert sounds to fit your home ambiance.
  • Smart automations: Set the chime to ring when your camera detects a person, even if they don’t press the doorbell.
  • Easy installation: No wiring required, just plug and play.
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
Stay informed of every visitor or delivery with this convenient and fuss-free chime.
Seamless Integration with Personal Smart Devices
Wyze products are designed to work flawlessly with your smartphone and popular smart home ecosystems. Whether you use Android or iOS, Alexa, or Google Assistant, you can:
  • View live streams and recorded footage on your phone.
  • Receive instant motion and doorbell alerts.
  • Control cameras and doorbells with voice commands.
  • Automate routines combining cameras, chimes, and lighting.
This makes Wyze an ideal choice for anyone looking to build a smart, connected entryway monitoring system that fits effortlessly into their digital lifestyle.
Conclusion
For a reliable, smart, and easy-to-use entryway monitoring system that works seamlessly with your personal smart devices, Wyze offers a comprehensive lineup:
  • Wyze Video Doorbell v2 for crystal-clear door monitoring and two-way communication.
  • Security Starter Pack combining Wyze Cam v4 and Pan v3 for versatile coverage.
  • Lamp Socket Bundles to power cameras and smart lights without outlets.
  • Universal Wi-Fi Chime to ensure you never miss a visitor.
Together, these products create a smart, secure, and connected entryway that keeps you informed and in control, wherever you are. Wyze Cam v4 Lifestyle Wyze Cam v4 integrates perfectly with your smart home devices
Feature / ProductWyze Video Doorbell v2Security Starter PackCam v4 + Lamp Socket v2 BundlePan v3 + Lamp Socket v2 BundleWyze Universal Wi-Fi Chime
TypeWired Video DoorbellSecurity Camera BundleCamera + Lamp Socket BundleCamera + Lamp Socket BundleDoorbell Accessory (Chime)
Price$44.98 (Doorbell + Chime Controller)$64.99$49.96$53.96$19.98
Video Resolution2K (2048 x 1536)Wyze Cam v4: 2.5K QHD, Wyze Cam Pan v3: 1080pWyze Cam v4: 2.5K QHDWyze Cam Pan v3: 1080pN/A
Local StoragemicroSD card slot (24/7 local recording)microSD card support (24/7 local recording)Depends on Cam v4 (supports microSD)Depends on Pan v3 (supports microSD)N/A
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionN/A
Two-Way AudioYesYes (both cameras)Yes (Cam v4)Yes (Pan v3)N/A
Motion DetectionYes, with motion-activated voice deterrence*Yes, motion and sound detectionYes (Cam v4)Yes (Pan v3)N/A
Night VisionColor Night Vision (Starlight sensor)Color Night Vision (both cameras)Color Night Vision (Cam v4)Color Night Vision (Pan v3)N/A
Weather ResistanceIP65IP65 (Wyze Cam v4)Not weatherproof (Lamp Socket), Cam v4 is IP65Not weatherproof (Lamp Socket), Pan v3 is IP65Indoor use only
Compatibility with Smart AssistantsAlexa, Google HomeAlexa, Google Assistant, IFTTTAlexa, Google Assistant, Bluetooth, Wi-FiAlexa, Google Assistant, Bluetooth, Wi-FiAlexa, Google, IFTTT
Power SourceWiredPlug-in camerasLamp Socket (E26, 120V~, 60Hz)Lamp Socket (E26, 120V~, 60Hz)Plug-in (10-24V AC)
Special FeaturesPre-roll motion recording, chime controller included, 30° corner kit includedPan v3: 360° pan & 180° tilt, automatic motion trackingMotion-activated lights, dusk to dawn schedulingMotion-activated lights, dusk to dawn scheduling17 different tones, easy installation, connect multiple devices
Included AccessoriesChime Controller, mounting wedge1x Wyze Cam v4, 1x Wyze Cam Pan v3Lamp Socket v2Lamp Socket v2Wyze Wi-Fi Chime, Quick Start Guide
Warranty1 yearNot specified1 year1 yearNot specified
Color OptionsBlackPan v3: Black/White, Cam v4: Gray/WhiteWhiteBlack, WhiteBlack
DimensionsNot specifiedNot specified56.5mm x 56.5mm x 65mm56.5mm x 56.5mm x 65mm81 x 53 x 38 mm
WeightNot specifiedNot specified80 g80 gNot specified
InstallationWired, works with existing chimePlug-inScrew-in lamp socketScrew-in lamp socketPlug-in, no wiring required
*Motion-activated voice deterrence requires Cam Plus or Cam Protect subscription.
What is the Wyze Video Doorbell v2 and how does it enhance entryway security?The Wyze Video Doorbell v2 is a smart doorbell that provides 2K resolution video, a wide 166.8° field of view, two-way audio, motion-activated voice deterrence, and local microSD storage. It enhances entryway security by allowing you to see, hear, and communicate with visitors or delivery personnel from anywhere using your smartphone. Its weather-resistant design and compatibility with Alexa, Google Assistant, and IFTTT make it a reliable choice for smart home integration.
Are Wyze entryway monitoring systems compatible with personal smart devices?Yes, Wyze entryway monitoring systems are fully compatible with personal smart devices. They work with Android (9.0+) and iOS (15.0+) smartphones, and integrate seamlessly with popular smart home platforms like Alexa, Google Assistant, and IFTTT. This allows you to view live streams, receive alerts, and control devices using your phone or voice commands.
What is included in the Wyze Security Starter Pack for home monitoring?The Wyze Security Starter Pack includes the Wyze Cam v4 and Wyze Cam Pan v3. The Cam v4 offers 2.5K QHD video, color night vision, and versatile mounting options, while the Pan v3 provides 360° horizontal and 180° vertical coverage with 1080p HD video. Both cameras are compatible with Alexa, Google Assistant, and IFTTT, making them ideal for comprehensive entryway and perimeter monitoring.
How do Wyze Lamp Socket Bundles work for powering security cameras?Wyze Lamp Socket Bundles allow you to power your Wyze Cam v4 or Pan v3 directly from a standard lamp socket, eliminating the need for nearby electrical outlets. These bundles feature motion-activated lights, dusk-to-dawn scheduling, and the ability to link multiple devices for synchronized operation. They are compatible with several Wyze camera models, making them perfect for outdoor setups.
What features does the Wyze Universal Wi-Fi Chime offer?The Wyze Universal Wi-Fi Chime plugs into any indoor outlet and pairs with all Wyze Cams and doorbells, including the Wyze Video Doorbell v2. It offers 17 customizable chime tones, smart automations to ring when a person is detected, and easy plug-and-play installation. The chime also works with Alexa, Google Assistant, and IFTTT for enhanced smart home integration.
Can I control Wyze entryway monitoring products with voice assistants?Yes, Wyze entryway monitoring products are compatible with voice assistants such as Alexa and Google Assistant. You can use voice commands to view camera feeds, receive alerts, and control your devices, making it easy to manage your home security system hands-free.
Is local video storage available on Wyze entryway cameras?Yes, Wyze entryway cameras like the Wyze Video Doorbell v2 support local video storage via microSD cards (up to 256GB). This ensures your video footage is securely stored even if cloud access is unavailable.
How easy is it to install Wyze entryway monitoring systems?Wyze entryway monitoring systems are designed for easy installation. The Wyze Video Doorbell v2 comes with a comprehensive installation kit, including a chime controller, wall plate, mounting wedge, and wire caps. The Universal Wi-Fi Chime and Lamp Socket Bundles are plug-and-play, requiring no complex wiring.
Do Wyze entryway monitoring products support smart home automation?Yes, Wyze products support smart home automation through integrations with Alexa, Google Assistant, and IFTTT. You can automate routines such as turning on lights when motion is detected, receiving alerts when someone approaches your door, and linking multiple devices for synchronized operation.
Which Wyze products are best for building a smart entryway monitoring system?For a smart entryway monitoring system, Wyze recommends the Wyze Video Doorbell v2 for door monitoring, the Security Starter Pack (Wyze Cam v4 and Pan v3) for versatile coverage, Lamp Socket Bundles for flexible power and lighting, and the Universal Wi-Fi Chime to ensure you never miss a visitor. These products work together to provide comprehensive, connected entryway security.
Can you tell me more about the features of the Wyze Video Doorbell v2?How does the Wyze Cam v4 compare to the Wyze Cam Pan v3 in terms of video quality?Do you have any ongoing sales or promotions for the Wyze products?
