Seamless Home Security Doorbells That Integrate with Your Wi-Fi Network
When it comes to securing your home’s entry points, having a reliable, smart doorbell that integrates effortlessly with your existing Wi-Fi network is essential. Wyze offers cutting-edge video doorbells designed to provide crystal-clear video, two-way communication, and smart alerts — all while fitting seamlessly into your smart home ecosystem. Whether you prefer a wired setup or a battery-powered option, Wyze has you covered with the
Wyze Video Doorbell v2 and the
Wyze Duo Cam Battery Doorbell.
Wyze Video Doorbell v2: Wired 2K Video Doorbell with Local Storage
Experience crystal-clear 2K video and smart home integration with Wyze Video Doorbell v2.
Key Features:
- 2K HD Video Quality: Capture every visitor in stunning detail with 2K resolution, providing a head-to-toe view of your porch.
- Local MicroSD Storage: Unlike many doorbells, this model supports continuous 24/7 local recording via a built-in microSD card slot, so you never miss a moment.
- Works with Existing Chime: Keep your traditional doorbell chime ringing with the included chime controller—no need to bypass your current setup.
- Two-Way Audio: Speak directly to visitors or delivery personnel from anywhere using the Wyze app.
- Motion-Activated Voice Deterrence: Automatically warn unwanted visitors with a customizable voice prompt when motion is detected (requires Cam Plus subscription).
- Pre-Roll Motion Recording: Capture 3-6 seconds before motion events to get the full context of any activity.
- Weatherproof Design: Rated IP65, it withstands rain, snow, and harsh weather conditions.
- Smart Home Compatibility: Works seamlessly with Alexa and Google Home for voice commands and live feed viewing.
Why Choose Wyze Video Doorbell v2?
This wired doorbell is perfect for homeowners who want a high-resolution, reliable video doorbell that integrates easily with their existing Wi-Fi and chime system. Its local storage option ensures privacy and continuous recording without relying solely on cloud storage.
Wyze Duo Cam Battery Doorbell: Advanced Dual-Camera Battery-Powered Doorbell
Dual camera views and battery-powered convenience with Wyze Duo Cam Doorbell.
Key Features:
- Dual Camera Views: Front camera offers 2K resolution (2048 x 1536) with a wide 132° horizontal field of view, while the bottom camera captures packages and ground-level activity in 1080p.
- Battery Powered with Optional Hardwired Setup: Comes with a removable battery pack for flexible installation; can also be hardwired for continuous power.
- Local and Cloud Storage: Supports up to 256GB microSD card for local storage and AWS cloud storage for added security.
- Two-Way Talk & Siren: Communicate with visitors or deter intruders with a loud 90 dB siren and clear two-way audio.
- Real-Time AI Detections: Get smart alerts for people, packages, and vehicles with AI-powered notifications.
- Motion-Activated Voice Warning: Automatically informs visitors they are being recorded.
- Wi-Fi Dual Band Support: Connects to both 2.4 GHz and 5 GHz Wi-Fi networks for stable performance.
- Weather Resistant: IP65 rating ensures durability in all weather conditions.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
Why Choose Wyze Duo Cam Battery Doorbell?
Ideal for those who want advanced monitoring with dual camera angles and flexible installation options. The battery-powered design means no wiring hassle, while smart AI detections keep you informed in real time.
Enhance Your Home Security with Wyze Cam v4
While the focus is on doorbells, pairing your Wyze doorbell with the
Wyze Cam v4 can provide comprehensive home security coverage.
Complement your doorbell with Wyze Cam v4 for 24/7 home monitoring.
Key Features:
- 2.5K QHD Resolution: Crystal-clear video with enhanced color night vision.
- Motion-Activated Spotlight: Illuminates your property when motion is detected.
- Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
- 24/7 Local Recording: Continuous recording with microSD card support.
- Smart Alerts: Motion, sound, and smoke/CO alarm detection.
- Smart Home Compatibility: Works with Alexa and Google Assistant.
Why Add Wyze Cam v4?
This camera is perfect for monitoring areas beyond your front door, such as backyards or garages, providing a complete security solution when paired with your Wyze doorbell.
Conclusion: Choose the Perfect Wyze Doorbell for Your Home
- Wyze Video Doorbell v2 is the best choice if you want a wired doorbell with 2K video, local storage, and integration with your existing chime.
- Wyze Duo Cam Battery Doorbell offers dual camera views, battery-powered flexibility, and advanced AI detections for those who prefer wireless installation.
- Pair either doorbell with Wyze Cam v4 for enhanced home security coverage with 2.5K video and smart features.
Wyze doorbells integrate seamlessly with your home Wi-Fi network and smart home devices, making them an excellent choice for modern, connected home security.
What are the main features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers 2K HD video quality, local microSD storage for continuous 24/7 recording, compatibility with your existing doorbell chime, two-way audio, motion-activated voice deterrence (with Cam Plus subscription), pre-roll motion recording, weatherproof IP65 design, and seamless integration with Alexa and Google Home.Does the Wyze Video Doorbell v2 work with my existing doorbell chime?
Yes, the Wyze Video Doorbell v2 includes a chime controller that allows it to work with your existing traditional doorbell chime, so you don’t need to bypass your current setup.Can I use local storage with Wyze doorbells?
Yes, both the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell support local storage via a microSD card, allowing for continuous 24/7 recording without relying solely on cloud storage.What is the difference between the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell?
The Wyze Video Doorbell v2 is a wired doorbell with 2K video, local storage, and existing chime compatibility. The Wyze Duo Cam Battery Doorbell is battery-powered (with optional hardwired setup), features dual cameras for both front and package views, supports both local and cloud storage, and offers advanced AI detections for people, packages, and vehicles.Does the Wyze Duo Cam Battery Doorbell require wiring?
No, the Wyze Duo Cam Battery Doorbell is battery-powered for flexible installation, but it can also be hardwired for continuous power if you prefer.What smart home systems are Wyze doorbells compatible with?
Wyze doorbells are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice commands, live feed viewing, and seamless integration into your smart home ecosystem.Do Wyze doorbells support both 2.4 GHz and 5 GHz Wi-Fi networks?
The Wyze Duo Cam Battery Doorbell supports both 2.4 GHz and 5 GHz Wi-Fi networks for stable and reliable performance. The Wyze Video Doorbell v2 connects to 2.4 GHz Wi-Fi.Are Wyze doorbells weatherproof?
Yes, both the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell are rated IP65, making them weatherproof and suitable for use in rain, snow, and harsh weather conditions.What is the benefit of pairing a Wyze doorbell with Wyze Cam v4?
Pairing a Wyze doorbell with Wyze Cam v4 provides comprehensive home security coverage. The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, and smart alerts, making it ideal for monitoring areas beyond your front door.How does the motion-activated voice deterrence work on Wyze doorbells?
The motion-activated voice deterrence feature automatically plays a customizable voice prompt to warn unwanted visitors when motion is detected. This feature requires a Cam Plus subscription on the Wyze Video Doorbell v2.What kind of AI detections does the Wyze Duo Cam Battery Doorbell offer?
The Wyze Duo Cam Battery Doorbell provides real-time AI-powered notifications for people, packages, and vehicles, helping you stay informed about important activity at your doorstep.
