Eliminate IR Reflection at Night with Wyze Window Mount
Eliminate IR Light Reflection When Filming Through a Window at Night with Wyze Window Mount
Filming through a window at night often results in frustrating infrared (IR) light reflections that obscure your footage. The Wyze Window Mount is the perfect solution to this problem, designed specifically to mount your Wyze cameras directly on glass surfaces. This accessory ensures a clear, glare-free view, eliminating IR reflection and enhancing your nighttime security footage.
Wyze Window Mount: Clear Nighttime Filming Through Windows
Designed for Glare-Free Window Mounting
The Wyze Window Mount is compatible with multiple Wyze camera models including Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto. By mounting your camera directly on the window glass, this accessory prevents the common issue of IR light reflecting back into the lens, which typically causes blurry or washed-out night videos.
  • Compatibility: Works with Wyze Cam v3/v3 Pro/v4 and Wyze Cam OG series
  • Purpose: Mounts camera on glass surfaces for clear, reflection-free footage
  • Price: $9.98
Mount your Wyze camera on your window and enjoy crystal-clear night vision without annoying IR glare or reflections.
Wyze Cam Floodlight on Deck at Night Enhance your outdoor security with clear, glare-free footage.
Best Wyze Cameras to Use with the Window Mount for Night Filming
Wyze Cam v4: Advanced Night Vision and High Resolution
The Wyze Cam v4 is an excellent choice for window mounting due to its advanced features that complement the mount’s glare elimination:
  • Resolution: 2.5K QHD (2560x1440) for crystal-clear video
  • Night Vision: Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens)
  • Field of View: Wide 115.8° diagonal for broad coverage
  • Connectivity: Wi-Fi 6 support for faster, more reliable streaming
  • Weather Resistance: IP65 rated for outdoor use
  • Mounting Options: Stand, wall, ceiling, and magnetic adhesive mounts
This camera’s powerful night vision combined with the window mount ensures you get sharp, reflection-free footage even in low light conditions.
Wyze Cam OG: Compact and Efficient Outdoor Camera
For those seeking a smaller, budget-friendly option, the Wyze Cam OG is a solid pick:
  • Resolution: 1080p Full HD video
  • Night Vision: 4 IR LEDs (850nm) for clear night footage
  • Field of View: 120° wide angle
  • Built-in Spotlight: 40 lumens for added illumination
  • Weather Resistance: IP65 for outdoor durability
  • Two-Way Audio: Enhanced microphone and speaker with noise cancellation
Paired with the Wyze Window Mount, the Wyze Cam OG delivers reliable night surveillance without IR reflection issues.
Additional Wyze Security Solutions for Outdoor Night Filming
Wyze Cam Floodlight v2: Bright Illumination and 2K Video
If you want to add powerful lighting to your outdoor security setup, the Wyze Cam Floodlight v2 offers:
  • Lighting: 2800 lumens with two dimmable LED panels
  • Video Quality: 2K resolution with Color Night Vision
  • Field of View: 160° wide-angle lens
  • Weatherproof: IP65 rating for all-weather use
  • Smart Features: AI-powered light control, two-way talk, and dusk-to-dawn automation
This camera is ideal for mounting on walls or ceilings but can complement window-mounted cameras by illuminating dark areas.
Wyze Cam Floodlight Pro + Plug-In Mount: Plug-and-Play Convenience
For an all-in-one floodlight and camera solution without complex wiring:
  • Resolution: 2.5K QHD video with color night vision
  • Lighting: 3000 lumens output
  • Field of View: Ultra-wide 180°
  • Plug-In Mount: Easy installation without junction box
  • Smart Integrations: Alexa, Google Assistant, IFTTT compatibility
This bundle is perfect for users wanting bright, wide coverage with simple setup.
Why Choose Wyze Window Mount for Nighttime Filming?
"The Wyze Window Mount is a game-changer for anyone filming through windows at night. It eliminates IR reflection, providing clear, sharp footage that enhances your home security."
  • Eliminates IR glare and reflections for better night vision footage
  • Compatible with multiple Wyze camera models for versatile use
  • Easy installation on any glass surface without damage
  • Affordable accessory that significantly improves video quality
Summary
For anyone struggling with IR light reflection when filming through windows at night, the Wyze Window Mount is the essential accessory. When paired with advanced Wyze cameras like the Wyze Cam v4 or Wyze Cam OG, it delivers clear, glare-free night vision footage. For enhanced outdoor lighting and security, consider the Wyze Cam Floodlight v2 or the Wyze Cam Floodlight Pro + Plug-In Mount. Upgrade your nighttime home security setup today with Wyze’s innovative window mounting and camera solutions.
Wyze Cam Floodlight Lifestyle Wyze Cam Floodlight v2 providing bright, clear night vision.
Product Highlights
  • Wyze Window Mount: Mount on glass, no glare
  • Wyze Cam v4: 2.5K QHD, color night vision
  • Wyze Cam OG: Compact, 1080p, IR night vision
  • Wyze Cam Floodlight v2: 2800 lumens, 2K video
  • Wyze Cam Floodlight Pro + Plug-In Mount: 2.5K QHD, plug-n-play
Optimize your night filming through windows with Wyze’s trusted accessories and cameras for unmatched clarity and security.
FeatureWyze Window MountWyze Cam v4Wyze Cam OGWyze Cam Floodlight v2Wyze Cam Floodlight Pro + Plug-In Mount
TypeAccessoryCameraCameraCameraCamera + Mount
Price$9.98$35.98 (1 Pack)$29.98 (1 Pack)$89.98$169.96
CompatibilityWyze Cam v3/v3 Pro/v4, Wyze Cam OG seriesWyze Cam v4Wyze Cam OGWyze Cam Floodlight v2Wyze Cam Floodlight Pro + Plug-In Mount
Mount TypeWindow mount (glass surface)Stand, Wall, Ceiling, Magnetic wall mountStand, Wall, CeilingWall, CeilingPlug-In Mount (Wall/Ceiling)
Video ResolutionN/A2.5K QHD (2560x1440)1080p (1920x1080)2K (2304x1296)2.5K QHD (2560x1440)
Field of ViewN/A115.9° (D) x 98.5° (H) x 53.1° (V)120°160° Diagonal180° Ultra-Wide
Night VisionN/AEnhanced Color Night Vision4 IR LEDs (850nm)Color Night VisionColor Night Vision
SpotlightN/AYes (2 white spotlight LEDs, 72 lumens)Built-in spotlight (40 Lumens)2 dimmable LED light panelsYes
SirenN/A99 dB90 dB user-activated siren105 dBNot specified
AudioN/AEnhanced Two-Way Talk, Noise & Echo CancellationBuilt-in Speaker & Microphone; Noise & Echo CancellationBuilt-in speaker and microphone; 2-way audioNot specified
Weather ResistanceN/AIP65IP65IP65IP65
Local Storage SupportN/AmicroSD card up to 512 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB
Power SourceN/AWired (5V/1A adapter included)Wired (5V/1A adapter included)Hardwired (110-120V AC)Hardwired (110-120V AC)
ConnectivityN/A2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi
Smart Assistant IntegrationN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
DimensionsN/A2in x 2in x 2 3/8in1.89in x 1.89in x 1.89in9.5in x 7.7in x 7.0in153mm x 155mm x 79mm (package dimension)
WeightN/A0.49 lb (222 g)4.1 oz (116 g)2.76 lbs (1.25 kg)1.39 lbs (package weight)
Operating TemperatureN/A-4°F to 122°F (-20°C to 50°C)-4°F to 131°F (-20°C to 55°C)-4°F to 140°F (-20°C to 60°C)-22°F to 122°F (-30°C to 50°C)
WarrantyNot specified1 Year1 Year1 Year1 Year
Additional FeaturesReduces glare, clear view through glassMotion-activated spotlight, 24/7 local recording, Wi-Fi 6 support, AI tracking3X faster notifications, upgraded 2-way audioAmbient Light Mode, AI-Powered Light Control, Dusk-to-dawn automationPlug-n-play floodlight solution, no junction box needed
How does the Wyze Window Mount eliminate IR light reflection when filming through a window at night?The Wyze Window Mount is designed to mount your Wyze camera directly onto glass surfaces, preventing infrared (IR) light from reflecting back into the camera lens. This eliminates glare and reflections, resulting in clear, sharp nighttime footage through windows.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto models. This ensures versatile use across multiple Wyze camera options.
What is the price of the Wyze Window Mount?The Wyze Window Mount is affordably priced at $9.98, making it an accessible accessory for improving your nighttime security footage.
What are the benefits of using the Wyze Window Mount for nighttime security footage?Using the Wyze Window Mount eliminates IR glare and reflections, provides clear and sharp night vision footage, is compatible with multiple Wyze camera models, and is easy to install on any glass surface without causing damage.
Which Wyze camera is best for window mounting and night vision?The Wyze Cam v4 is highly recommended for window mounting due to its 2.5K QHD resolution, enhanced color night vision, wide 115.8° field of view, and advanced IR and spotlight LEDs. It pairs perfectly with the Wyze Window Mount for glare-free, high-quality nighttime footage.
Is the Wyze Cam OG a good option for window-mounted night surveillance?Yes, the Wyze Cam OG is a compact and budget-friendly camera with 1080p Full HD video, 4 IR LEDs for clear night vision, a 120° wide angle, and built-in spotlight. When used with the Wyze Window Mount, it delivers reliable, reflection-free night surveillance.
Can I use Wyze Cam Floodlight v2 with the Wyze Window Mount?The Wyze Cam Floodlight v2 is designed for wall or ceiling mounting and provides powerful 2800-lumen lighting and 2K video. While it is not intended for window mounting, it can complement window-mounted cameras by illuminating outdoor areas for enhanced security.
What is the Wyze Cam Floodlight Pro + Plug-In Mount, and how does it enhance outdoor security?The Wyze Cam Floodlight Pro + Plug-In Mount is an all-in-one security solution featuring 2.5K QHD video, 3000 lumens of lighting, an ultra-wide 180° field of view, and easy plug-in installation. It offers bright, wide coverage and smart integrations for comprehensive outdoor security.
Is the Wyze Window Mount easy to install?Yes, the Wyze Window Mount is designed for simple installation on any glass surface. It securely holds your Wyze camera in place without causing damage to your windows.
Why should I choose the Wyze Window Mount for filming through windows at night?The Wyze Window Mount is specifically engineered to eliminate IR reflections and glare when filming through windows at night. It ensures clear, high-quality footage, is compatible with several Wyze camera models, and is an affordable way to upgrade your home security system.
What are the specific Wyze camera models that are compatible with the Wyze Window Mount?Can you explain how the Wyze Window Mount improves nighttime filming?Are there any ongoing promotions or discounts for the Wyze Window Mount?
