Reduce Glare & Reflection: Wyze Window Mount for Clear Camera Views
Adjusting Camera Angle Through a Window to Reduce Glare and Reflection with Wyze Window Mount
When installing security cameras behind glass windows, glare and reflections can significantly reduce video clarity and effectiveness. The Wyze Window Mount is designed specifically to solve this problem by allowing you to securely attach your Wyze Cam directly to the window glass, enabling optimal camera angles that minimize glare and reflections for a crystal-clear view.
Wyze Window Mount: Clear Views Without Glare or Reflection
Designed for Window Installation
The Wyze Window Mount is an essential accessory for anyone looking to mount their Wyze Cam on a glass surface. Compatible with Wyze Cam v3, v3 Pro, v4, and the Wyze Cam OG series, this mount lets you position your camera flush against the window, eliminating the common issues of glare and reflection that occur when cameras are placed behind glass.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, and Wyze Cam OG series
  • Mounting Surface: Glass windows and other smooth surfaces
  • Price: Affordable at $9.98 for the v2 style, which supports the latest Wyze cameras
Mount your camera on the window to enjoy a clear, unobstructed view of the outdoors without the hassle of reflections or glare interfering with your security footage.
Outdoor lifestyle with Wyze Cam mounted on window Enhance your home security with a Wyze Cam mounted on your window for glare-free monitoring.
Wyze Cam v4 and Wyze Cam OG: Perfect Cameras for Window Mounting
Wyze Cam v4: Advanced Optics and Sensor Technology
The Wyze Cam v4 is a cutting-edge smart camera that pairs perfectly with the Wyze Window Mount. Featuring a CMOS Starlight Sensor and a wide field of view (115.8° diagonal), it captures sharp, detailed video even in low-light conditions. Its polycarbonate body and glass/plastic lens materials ensure durability and excellent image quality.
  • Field of View: 115.8° diagonal, 98.5° horizontal, 53.1° vertical
  • Sensor: CMOS Starlight Sensor for enhanced night vision
  • Material: Durable polycarbonate body with glass/plastic lens
  • Price: $100.00
Wyze Cam OG: Reliable and Feature-Rich
The Wyze Cam OG is a versatile indoor/outdoor camera that offers 1080p HD video resolution with a 120° field of view. It includes a motion-activated spotlight and improved two-way audio, making it ideal for monitoring your home through a window with the Wyze Window Mount.
  • Field of View: 120°
  • Sensor: CMOS-Starlight Sensor
  • Video FPS: 20 FPS (day), 15 FPS (night)
  • Price: Starting at $29.98
Both cameras provide excellent video quality and smart features that maximize the benefits of mounting on a window with the Wyze Window Mount.
Additional Mounting Solutions and Accessories
Wyze Cam Floodlight Plug-In Mount
For outdoor lighting and security, the Wyze Cam Floodlight Plug-In Mount offers an easy plug-and-play solution without the need for complex wiring or junction boxes. Available in black or white, it complements window-mounted cameras by providing additional illumination and security coverage around your home.
  • Price: $19.98
  • Colors: Black, White
  • Installation: Simple plug-in setup
Outdoor lifestyle with Wyze Cam Floodlight Enhance your outdoor security with the Wyze Cam Floodlight Plug-In Mount for bright, reliable lighting.
Why Choose Wyze Window Mount and Compatible Cameras?
Using the Wyze Window Mount with compatible Wyze cameras allows you to:
  • Reduce glare and reflections that typically degrade video quality when cameras are placed behind glass.
  • Adjust camera angles easily to capture the best possible view through your window.
  • Maintain a clean, unobtrusive installation that blends seamlessly with your home’s exterior.
  • Leverage advanced camera features like night vision, motion detection, and two-way audio for comprehensive security.
Summary of Products for Window Mounting and Glare Reduction
Product NameKey FeaturesPrice (USD)
Wyze Window MountGlass surface mount, glare-free viewing9.98
Wyze Cam v4CMOS Starlight Sensor, 115.8° FOV, durable100.00
Wyze Cam OG1080p HD, 120° FOV, spotlight, indoor/outdoorFrom 29.98
Wyze Cam Floodlight Plug-In MountEasy plug-in floodlight mount, black/white19.98
By combining the Wyze Window Mount with the Wyze Cam v4 or Wyze Cam OG, you can achieve a glare-free, clear, and secure view through your windows, enhancing your home security setup with ease and affordability.
FeatureWyze Window MountWyze Cam OGWyze Cam v4
TypeAccessoryCameraCamera
Compatible CamerasWyze Cam v3/v3 Pro/v4, Wyze Cam OG seriesWyze Cam OG, Wyze Cam OG TelephotoWyze Cam v4
Price$9.98$29.98 (1 Pack)$35.98 (single unit with 32GB MicroSD)
Mounting SurfaceGlass (window)Stand, wall mount, ceiling mountStand, wall mount, ceiling mount, magnetic mount
Video ResolutionN/A1080p (1920x1080)2.5K QHD (2560x1440)
Field of ViewN/A120° (Wyze Cam OG), 27° (Telephoto)DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionN/A4 IR LEDs (850 nm), Color Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens), Color Night Vision
SpotlightN/ABuilt-in 40-lumen spotlightMotion-activated spotlight (72 lumens)
AudioN/A2-way audio with noise & echo cancellationImproved 2-way audio with noise & echo cancellation
Weather ResistanceN/AIP65IP65
Local StorageN/ASupports microSD up to 256GBSupports microSD up to 512GB
Cloud StorageN/AAvailable with subscriptionAvailable with subscription
ConnectivityN/A2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6
DimensionsN/A1.89in x 1.89in x 1.89in2in x 2in x 2 3/8in
WeightN/A4.1 oz (116 g)0.49 lb (222 g)
WarrantyN/A1 Year1 Year
Additional FeaturesReduces glare and reflection on glass3x faster notifications, built-in spotlight & mini-siren8x digital zoom, built-in siren, Bluetooth 5.2, Alexa & Google Assistant integration
How does the Wyze Window Mount reduce glare and reflections when using a security camera through a window?The Wyze Window Mount is designed to securely attach your Wyze Cam directly to the window glass, allowing the camera to sit flush against the surface. This positioning minimizes the distance between the lens and the glass, effectively reducing glare and reflections that typically occur when cameras are placed behind windows.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, and the Wyze Cam OG series. This ensures you can use the latest Wyze cameras for optimal performance when mounting on glass surfaces.
What surfaces can the Wyze Window Mount be installed on?The Wyze Window Mount is specifically designed for glass windows and other smooth surfaces, providing a secure and stable attachment for your Wyze Cam.
What is the price of the Wyze Window Mount?The Wyze Window Mount is affordably priced at $9.98 for the v2 style, which supports the latest Wyze cameras.
What are the benefits of using the Wyze Cam v4 with the Wyze Window Mount?The Wyze Cam v4 features a CMOS Starlight Sensor for enhanced night vision, a wide 115.8° diagonal field of view, and a durable polycarbonate body. When paired with the Wyze Window Mount, it delivers sharp, detailed video with minimal glare or reflection, even in low-light conditions.
Is the Wyze Cam OG suitable for window mounting?Yes, the Wyze Cam OG is ideal for window mounting. It offers 1080p HD video resolution, a 120° field of view, a motion-activated spotlight, and improved two-way audio, making it perfect for monitoring your home through a window with the Wyze Window Mount.
How much does the Wyze Cam v4 and Wyze Cam OG cost?The Wyze Cam v4 is priced at $100.00, while the Wyze Cam OG starts at $29.98.
Are there additional accessories to enhance Wyze camera installations?Yes, the Wyze Cam Floodlight Plug-In Mount is available for $19.98 in black or white. It provides easy plug-and-play outdoor lighting, complementing window-mounted cameras by increasing security coverage and illumination around your home.
What are the main advantages of using the Wyze Window Mount with compatible cameras?Using the Wyze Window Mount with compatible Wyze cameras allows you to reduce glare and reflections, easily adjust camera angles for the best view, maintain a clean and unobtrusive installation, and leverage advanced features like night vision, motion detection, and two-way audio for comprehensive home security.
Can the Wyze Window Mount be used for both indoor and outdoor security monitoring?Yes, when paired with compatible Wyze cameras like the Wyze Cam v4 or Wyze Cam OG, the Wyze Window Mount enables clear, glare-free monitoring of outdoor areas from inside your home, making it suitable for both indoor and outdoor security needs.
How do I install the Wyze Window Mount on my window?Can the Wyze Window Mount be used with other camera brands?What are the benefits of using the Wyze Cam v4 with the Wyze Window Mount?
