Water Resistant Wiring Harness & Power for Wyze Cam v3 Near Sprinklers
Effective Water Resistant Wiring Harness and Power Solutions for Wyze Cam v3 Near Sprinklers
When installing your Wyze Cam v3 near sprinklers or other outdoor water sources, ensuring a water-resistant wiring harness and reliable power adapter is crucial for long-lasting performance and safety. Wyze offers several products and accessories designed to provide robust outdoor security with weather-resistant features and power solutions tailored for outdoor use.
Wyze Cam v4 Outdoor Bundle: Ultimate Weather-Resistant Security Solution
All-in-One Outdoor Security with Power Adapter Included
The Wyze Cam v4 Outdoor Bundle is a comprehensive package designed for outdoor environments, including areas near sprinklers. It includes the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB MicroSD card for local storage.
  • Water Resistance & Durability: Rated IP65, the camera and power adapter withstand rain, splashes, and sprinkler sprays, making it ideal for outdoor installations.
  • Power Source: Wired with the included outdoor power adapter, ensuring continuous power without worrying about battery life.
  • Video Quality: Crystal-clear 2.5K QHD resolution with Enhanced Color Night Vision and motion-activated spotlight for clear footage day and night.
  • Connectivity: Supports Wi-Fi 6 for stable, fast connections even in busy network environments.
  • Smart Features: Compatible with Alexa and Google Assistant, plus motion and sound detection with customizable zones.
  • Local Storage: Comes with a 128GB MicroSD card for 24/7 local recording, so you never miss a moment.
This bundle is perfect for users who want a reliable, weatherproof camera system with a power adapter designed specifically for outdoor use near sprinklers or wet conditions.
Outdoor Security Camera Mounted on House Wyze Cam v4 Outdoor Bundle installed near garden sprinklers
Wyze Cam v4: Advanced Outdoor Camera with Optional Outdoor Power Adapter
Flexible Installation with Weather-Resistant Design
The Wyze Cam v4 itself is a powerful outdoor camera with IP65 weather resistance, making it suitable for installation near sprinklers. While the outdoor power adapter is sold separately, this camera supports wired power for continuous operation.
  • Durability: IP65 rating protects against water jets and dust, perfect for sprinkler proximity.
  • Power Options: Comes with a 6-foot flat micro USB to USB-A cable; outdoor power adapter available separately to ensure safe, weatherproof power.
  • Video & Night Vision: 2.5K QHD resolution, 4 IR LEDs plus 2 white spotlight LEDs for color night vision.
  • Mounting Versatility: Multiple mounting options including wall, ceiling, stand, and magnetic mounts for flexible placement.
  • Smart Features: Person detection, built-in siren, two-way talk, and noise cancellation.
  • Connectivity: Supports both 2.4 GHz Wi-Fi and Wi-Fi 6 for reliable streaming.
Ideal for users who want to customize their outdoor power setup while benefiting from a rugged, high-quality camera.
Wyze Cam v3 Spotlight Kit: Enhance Visibility and Security Near Sprinklers
Motion-Activated, Water-Resistant Spotlight Accessory
For those using the Wyze Cam v3, the Wyze Cam v3 Spotlight Kit is a perfect accessory to improve night-time visibility and security near sprinkler zones.
  • Water Resistance: IP65 rated, the spotlight withstands water exposure from sprinklers and rain.
  • Brightness: 70 lumens with a wide 130-degree beam angle to illuminate dark areas effectively.
  • Power Supply: Powered by 5V 1A via Micro USB, compatible with Wyze Cam v3 power setups.
  • Easy Installation: Compact and lightweight, it integrates seamlessly with your existing Wyze Cam v3 system.
  • Operating Conditions: Works reliably in temperatures from -4°F to 131°F (-20°C to 55°C).
This spotlight kit is an excellent addition to boost your camera’s night vision and deter intruders in sprinkler-prone outdoor areas.
Why Choose Wyze Outdoor Power Adapter for Your Wyze Cam v3?
While the Wyze Cam v3 is weather-resistant (IP65), powering it near sprinklers requires a power adapter designed for outdoor use:
  • Weatherproof Design: The Wyze Outdoor Power Adapter is built to resist water and dust, ensuring safe operation even when exposed to sprinkler spray.
  • Reliable Power: Provides consistent 5V/1A output to keep your camera running 24/7 without interruption.
  • Compatibility: Specifically designed for Wyze Cam v3 and v4, ensuring optimal performance and safety.
  • Peace of Mind: Avoids the risks of indoor adapters failing outdoors, protecting your investment.
Summary: Best Setup for Wyze Cam v3 Near Sprinklers
  • Use the Wyze Cam v4 Outdoor Bundle for an all-in-one, weatherproof camera and power solution.
  • If you already own a Wyze Cam v3, pair it with the Wyze Outdoor Power Adapter (sold separately) for safe outdoor power.
  • Enhance night security with the Wyze Cam v3 Spotlight Kit, a water-resistant, motion-activated light.
  • Ensure all wiring and connections are sealed and routed away from direct sprinkler spray for maximum longevity.
Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 providing vibrant, clear outdoor security footage
Technical Highlights at a Glance
FeatureWyze Cam v4 Outdoor BundleWyze Cam v4 (Standalone)Wyze Cam v3 Spotlight Kit
Resolution2.5K QHD2.5K QHDN/A (Spotlight only)
Night VisionEnhanced Color Night VisionColor Night Vision70 lumens spotlight
Weather ResistanceIP65IP65IP65
Power SourceWired (Outdoor Adapter incl.)Wired (Outdoor Adapter sold separately)5V 1A Micro USB
Motion DetectionYesYesMotion-activated light
Local Storage128GB MicroSD includedMicroSD up to 512GBN/A
Wi-Fi SupportWi-Fi 6Wi-Fi 6N/A
Smart Assistant CompatibilityAlexa, Google AssistantAlexa, Google AssistantN/A
By choosing Wyze’s weather-resistant cameras and outdoor power solutions, you ensure your security system remains effective and durable even when installed near sprinklers or other wet outdoor environments.
FeatureWyze Cam v4 Outdoor BundleWyze Cam v4Wyze Cam v3 Spotlight KitWyze Cam v4 Home Security Bundle
Price$69.99$35.98 (single)$16.98$169.99
Camera Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)N/A (Accessory)2.5K QHD (2560x1440)
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionN/AEnhanced Color Night Vision
SpotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlight (70 lumens)Motion-activated spotlight
Weather ResistanceIP65IP65IP65IP65
MicroSD Card Included128GB microSD CardNot included (sold separately)N/A128GB microSD Card
Power Adapter IncludedWyze Outdoor Power AdapterIndoor USB Power AdapterN/AIncluded (Indoor/Outdoor compatible)
Wi-Fi SupportWi-Fi 6Wi-Fi 6N/AWi-Fi 6
AudioTwo-way talkEnhanced two-way talkN/AImproved two-way audio
SirenYesYesN/AYes
Motion & Sound DetectionYesYesN/AYes
Motion Detection ZonesYesYesN/AYes
Smoke & CO AlertsYesYesN/AYes
Mounting OptionsStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticN/AStand, Wall, Ceiling, Magnetic
Video Storage24/7 local recording on microSD24/7 local recording on microSDN/A24/7 local recording on microSD
Digital Zoom8x8xN/A8x
Wide Dynamic Range (WDR)YesYesN/AYes
Field of View (DFOV)115.8°115.9°N/A115.8°
WeightNot specified0.49 lb (222 g)N/A0.49 lb (222 g)
Warranty30-day hassle-free returns30-day hassle-free returns1 year1 year
Included in BoxWyze Cam v4, Outdoor Power Adapter, 128GB microSDWyze Cam v4, Indoor USB Power Adapter, Mounting kitSpotlight, USB cable splitterWyze Cam v4, Power Adapter, 128GB microSD
Is the Wyze Cam v4 Outdoor Bundle water-resistant and suitable for installation near sprinklers?Yes, the Wyze Cam v4 Outdoor Bundle is rated IP65 for water resistance, making it ideal for outdoor installations near sprinklers. Both the camera and the included outdoor power adapter are designed to withstand rain, splashes, and sprinkler spray for reliable performance.
What power solutions are recommended for Wyze Cam v3 when installed outdoors near sprinklers?For outdoor installations of Wyze Cam v3 near sprinklers, it is recommended to use the Wyze Outdoor Power Adapter. This adapter is weatherproof and specifically designed to provide safe, reliable power to your camera in wet conditions.
Can I use the Wyze Cam v4 as a standalone outdoor camera near water sources?Yes, the Wyze Cam v4 is IP65 weather-resistant and suitable for use near water sources like sprinklers. For optimal safety and performance, pair it with the Wyze Outdoor Power Adapter, which is sold separately.
What are the benefits of using the Wyze Cam v3 Spotlight Kit in sprinkler-prone areas?The Wyze Cam v3 Spotlight Kit is IP65 rated for water resistance, making it suitable for use near sprinklers. It provides a 70-lumen, motion-activated spotlight to enhance night vision and deter intruders, improving security in wet outdoor environments.
Why should I use the Wyze Outdoor Power Adapter instead of a regular indoor adapter for my Wyze Cam v3 or v4?The Wyze Outdoor Power Adapter is specifically designed to be weatherproof, protecting against water and dust. Using this adapter ensures safe, continuous power for your Wyze Cam v3 or v4 when installed outdoors, especially near sprinklers, and helps prevent failures that can occur with indoor adapters exposed to the elements.
What features make the Wyze Cam v4 Outdoor Bundle a complete outdoor security solution?The Wyze Cam v4 Outdoor Bundle includes an IP65-rated camera and outdoor power adapter, 2.5K QHD video resolution, enhanced color night vision, Wi-Fi 6 support, a 128GB MicroSD card for local storage, and compatibility with Alexa and Google Assistant. This all-in-one package is designed for robust, weather-resistant security near sprinklers and other outdoor water sources.
How should I install wiring and connections for Wyze cameras near sprinklers to ensure longevity?To maximize the lifespan of your Wyze camera system near sprinklers, use weather-resistant wiring harnesses and outdoor-rated power adapters. Ensure all connections are sealed and routed away from direct sprinkler spray to prevent water ingress and maintain reliable operation.
Are Wyze cameras compatible with smart home assistants?Yes, both the Wyze Cam v4 and the Wyze Cam v4 Outdoor Bundle are compatible with Alexa and Google Assistant, allowing for convenient voice control and integration with your smart home ecosystem.
What is the video quality of Wyze outdoor cameras?Wyze outdoor cameras, including the Cam v4 and Cam v4 Outdoor Bundle, offer 2.5K QHD resolution with enhanced color night vision, providing clear and detailed footage both day and night.
What storage options are available for Wyze outdoor cameras?The Wyze Cam v4 Outdoor Bundle comes with a 128GB MicroSD card for 24/7 local recording. The standalone Wyze Cam v4 supports MicroSD cards up to 512GB, allowing for extensive local video storage.
What are the key features of the Wyze Cam v4 Outdoor Bundle?Can you tell me more about the Wyze Cam v3 Spotlight Kit?Are there any ongoing sales or discounts for Wyze products?
