Quick Wyze Cam V3 Outdoor Power Cord & Adapter Replacement
Quick Switch Replacement and Power Solutions for Wyze Cam V3 Outdoor
If you are looking for a quick switch replacement or a reliable outdoor power adapter for your damaged Wyze Cam V3 outdoor power cord, Wyze offers several compatible products designed to keep your security system running smoothly. Whether you want to replace the power source or upgrade your setup, these Wyze products provide seamless power solutions and smart home integration.
Wyze Cam V4 Outdoor Bundle: The Ultimate Outdoor Security Upgrade
The Wyze Cam V4 Outdoor Bundle is an excellent choice for those seeking a robust and reliable outdoor camera system with a complete power solution included.
Key Features:
  • Crystal-clear 2.5K QHD resolution for sharp, detailed video footage.
  • Enhanced Color Night Vision and a motion-activated spotlight to keep your property safe day and night.
  • 24/7 local recording with included 128GB microSD card for continuous surveillance.
  • Wi-Fi 6 support ensures fast and stable connectivity.
  • Compatible with Alexa and Google Assistant for voice control convenience.
  • Wired power source with the included Wyze Outdoor Power Adapter, designed specifically for outdoor use.
  • Weather-resistant design suitable for all outdoor conditions.
This bundle is perfect if you want a quick and reliable replacement for your damaged outdoor power cord, as it comes with the power adapter and everything needed for a hassle-free setup. Wyze Cam V4 Outdoor Lifestyle Experience enhanced outdoor security with Wyze Cam V4 and its motion-activated spotlight.
Wyze Cam V4: Standalone Camera with Flexible Power Options
If you already have a power adapter or want to replace just the camera or power cord, the Wyze Cam V4 is a versatile option compatible with the Wyze outdoor power adapter sold separately.
Highlights:
  • 2.5K QHD video resolution with wide dynamic range (WDR) for clear images in varying light.
  • Color night vision supported by 4 IR LEDs and 2 white spotlight LEDs.
  • Multiple mounting options including wall, ceiling, and magnetic mounts.
  • 6-foot flat micro USB to USB-A cable for flexible power connection.
  • Supports Wi-Fi 6 and integrates with Alexa, Google Assistant, and IFTTT.
  • Weather-resistant with an IP65 rating, ideal for outdoor use.
  • Requires a separate outdoor power adapter for wired power outdoors.
This camera is ideal if you want to replace your damaged Wyze Cam V3 with a newer model and pair it with a compatible outdoor power adapter.
Cam V4 + Lamp Socket v2 Bundle: Power Your Wyze Cam Without an Outlet
For a unique and convenient power solution, the Cam V4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam V4 (and compatible Wyze cams including V3) directly from a lamp socket.
Why Choose This Bundle?
  • No need for a traditional power outlet; simply screw into an existing E26 lamp socket.
  • Supports motion-activated lights and dusk-to-dawn scheduling for smart lighting control.
  • Compatible with Wyze Cam V3, V3 Pro, V4, OG, and Pan V3.
  • Compact and easy to install with polycarbonate and plastic materials.
  • Suitable for damp locations (not fully weatherproof).
  • Works with LED or CFL bulbs under 20W (incandescent bulbs not recommended).
This is a perfect quick fix if your outdoor power cord is damaged and you want a smart, integrated power source that also enhances your outdoor lighting.
Wyze Switch: Smart Control for Your Outdoor Power Setup
While not a direct replacement for the power cord, the Wyze Switch can complement your outdoor camera setup by enabling smart control of your outdoor lighting and power devices.
Features:
  • Turn normal lights into smart lights controllable from anywhere via the Wyze app.
  • Multi-tap functionality to control other Wyze devices like cameras and locks.
  • Create custom automations, schedules, and vacation modes.
  • Power loss recovery ensures your devices stay connected after outages.
  • Integrates seamlessly with the Wyze ecosystem for a unified smart home experience.
Using the Wyze Switch alongside your outdoor camera and power adapter can enhance your home security and lighting automation. Wyze Switch Lifestyle Control your outdoor lighting smartly with Wyze Switch, perfect for integration with Wyze Cams.
Summary: Best Options for Replacing or Upgrading Your Wyze Cam V3 Outdoor Power
ProductPower Solution TypeCompatibilityKey Benefit
Wyze Cam V4 Outdoor BundleIncludes Outdoor Power AdapterWyze Cam V4Complete outdoor security bundle
Wyze Cam V4Requires separate adapterWyze Cam V4Flexible camera replacement
Cam V4 + Lamp Socket v2 BundleLamp socket powerWyze Cam V3, V4, othersOutlet-free power, smart lighting
Wyze SwitchSmart light switchWyze ecosystemSmart control for outdoor power
For a quick switch replacement or outdoor power adapter for your Wyze Cam V3, the Cam V4 + Lamp Socket v2 Bundle offers a smart, outlet-free power solution, while the Wyze Cam V4 Outdoor Bundle provides a full upgrade with a reliable outdoor power adapter included.
FeatureWyze Cam v4 Outdoor BundleWyze Cam v4Cam v4 + Lamp Socket v2 BundleWyze Switch
Price$69.99$35.98 (1 Pack)$49.96$14.99 (1 Pack)
Product TypeSecurity Camera BundleSecurity CameraCamera + Lamp Socket BundleConnected Home Switch
Camera Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)N/A
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionN/A
Motion-Activated SpotlightYesYesYesN/A
Local Recording24/7 local recording with microSD card24/7 local recording with microSD card24/7 local recording with microSD cardN/A
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6N/A
CompatibilityAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantControls Wyze devices (Cams, Locks, etc.)
Outdoor UseYes (with Outdoor Power Adapter included)Yes (requires Outdoor Power Adapter)Yes (requires Outdoor Power Adapter)N/A
Included AccessoriesWyze Outdoor Power Adapter, 128GB microSDIndoor USB Power Adapter, cableLamp Socket v2 (E26 socket)N/A
Power SourceWired (Outdoor Power Adapter included)Wired (Indoor USB Power Adapter)Powered via Lamp Socket (E26)Wired (standard switch wiring)
Weather ResistanceIP65IP65Lamp Socket: Not weatherproof, suitable for damp locationsN/A
Motion & Sound DetectionYesYesYes (via Cam v4)N/A
Smart Home IntegrationAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTWyze app, integrates with Wyze ecosystem
Additional FeaturesMotion Detection Zones, Smoke & CO AlertsMotion Detection Zones, Smoke & CO Alerts, Siren, Two-way TalkMotion-Activated Lights, Dusk to Dawn Scheduling, LinkabilityMulti-tap control, automation, power loss recovery
Dimensions (Lamp Socket)N/AN/A56.5mm x 56.5mm x 65mmStandard switch size
Warranty1 Year1 Year1 YearNot specified
What is the best quick switch replacement for a damaged Wyze Cam V3 outdoor power cord?The Cam V4 + Lamp Socket v2 Bundle is an excellent quick switch replacement for a damaged Wyze Cam V3 outdoor power cord. It allows you to power your Wyze Cam V3 (and other compatible models) directly from a standard E26 lamp socket, eliminating the need for a traditional power outlet and providing smart lighting control.
Which Wyze product includes an outdoor power adapter for easy camera setup?The Wyze Cam V4 Outdoor Bundle comes with a dedicated Wyze Outdoor Power Adapter, making it a complete solution for outdoor camera installation. This bundle is ideal for replacing a damaged power cord and upgrading your outdoor security system.
Can I use the Wyze Cam V4 as a replacement for my Wyze Cam V3?Yes, the Wyze Cam V4 is a suitable replacement for the Wyze Cam V3. It offers enhanced features such as 2.5K QHD video resolution, color night vision, and Wi-Fi 6 support. For outdoor use, you will need to pair it with a compatible Wyze outdoor power adapter, which is sold separately.
Is there a way to power my Wyze Cam V3 or V4 without using a traditional power outlet?Yes, the Cam V4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam V3, V4, and other compatible models directly from an E26 lamp socket. This solution is perfect for locations without accessible power outlets and also provides smart lighting features.
What are the benefits of the Wyze Cam V4 Outdoor Bundle for outdoor security?The Wyze Cam V4 Outdoor Bundle offers crystal-clear 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with a 128GB microSD card, Wi-Fi 6 support, and a weather-resistant design. It includes a dedicated outdoor power adapter for reliable and hassle-free installation.
How can I add smart control to my Wyze outdoor camera and lighting setup?The Wyze Switch is a smart light switch that integrates with the Wyze ecosystem, allowing you to control your outdoor lighting and other Wyze devices from anywhere using the Wyze app. It supports custom automations, schedules, and multi-tap functionality for enhanced smart home control.
Are Wyze outdoor power solutions weather-resistant?Yes, both the Wyze Cam V4 and the included Wyze Outdoor Power Adapter in the Outdoor Bundle are designed to be weather-resistant, making them suitable for all outdoor conditions. The Cam V4 + Lamp Socket v2 is suitable for damp locations but is not fully weatherproof.
Which Wyze products are compatible with the Lamp Socket v2 Bundle?The Lamp Socket v2 Bundle is compatible with Wyze Cam V3, V3 Pro, V4, OG, and Pan V3. It provides a convenient power solution and smart lighting control for these camera models.
What type of bulbs can be used with the Wyze Lamp Socket v2?The Wyze Lamp Socket v2 supports LED or CFL bulbs under 20W. Incandescent bulbs are not recommended for use with this product.
Does the Wyze Cam V4 support voice control and smart home integration?Yes, the Wyze Cam V4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless voice control and integration with your smart home devices.
What are the key features of the Wyze Cam V4 Outdoor Bundle?Can the Wyze Cam V4 be used with a different power adapter?Do you have any deals, ongoing sales, discounts, or promotions?
