Build a Bigger Wyze Smart Home System with Easy-to-Integrate Cameras
If you're looking to expand your Wyze smart home ecosystem effortlessly, the
Wyze Battery Cam Pro series offers the perfect blend of high-quality video, wireless convenience, and smart integrations. These cameras are designed to be wire-free, weatherproof, and packed with features that make them ideal for both indoor and outdoor use. Whether you want standalone cameras or bundles with solar power and accessories, Wyze has you covered.
Wyze Battery Cam Pro: The Core of Your Wireless Security
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers crystal-clear 2560 x 1440 (2.5K) HDR video resolution, ensuring you never miss a detail. Its CMOS-Starlight sensor combined with an F1.6 lens provides excellent image clarity even in low light conditions.
Wire-Free and Weatherproof
Enjoy complete freedom with a wire-free design powered by removable, rechargeable 6200mAh battery packs that last up to 6 months on a single charge. The camera is IP65 rated, making it resistant to rain, dust, and harsh weather, perfect for outdoor installation.
Advanced Motion Detection and Alerts
Equipped with Radar + PIR motion detection, the camera intelligently distinguishes between people, animals, and objects to reduce false alerts. The integrated spotlight and 100 dB siren add an extra layer of security by deterring intruders.
Smart Home Integration
Seamlessly connect with Alexa, Google Assistant, and IFTTT for voice control and automation. The camera supports both 2.4 GHz and 5 GHz WiFi bands, ensuring stable connectivity in various home environments.
Flexible Mounting and Local Storage
Mount your camera easily with the included wall mount (1/4” - 20 standard). It supports local storage up to 256 GB microSD cards, giving you options for continuous recording without relying solely on cloud services.
Wyze Battery Cam Pro + Solar Panel: Continuous Power, Less Hassle
Solar-Powered Convenience
For those wanting to minimize battery charging interruptions, the Wyze Battery Cam Pro + Solar Panel bundle offers the same powerful camera features with the added benefit of solar charging. The solar panel keeps your camera powered continuously, reducing the need for manual recharging.
All the Features of the Battery Cam Pro
This bundle includes the integrated spotlight, siren, radar + PIR motion detection, and color night vision. It’s also IP65 weatherproof and supports dual-band WiFi, making it a reliable choice for any outdoor setting.
Experience uninterrupted security with the eco-friendly solar panel that keeps your camera running day and night.
Wyze Bird Feeder Wireless Camera Bundle: Smart Security Meets Nature Watching
Multi-Purpose Bundle for Bird Lovers and Security
This unique bundle combines the Wyze Battery Cam Pro with a vibrant Wyze Bird Feeder and a solar panel. It’s perfect for birdwatchers who want to monitor feathered visitors while also securing their property.
Features That Enhance Your Outdoor Experience
- Weather-resistant and wire-free setup
- Macro lens adapter for detailed close-ups of birds
- Live streaming and recording via the Wyze app
- Solar panel for continuous power supply
Enjoy the best of both worlds—nature observation and home security—in one easy-to-integrate system.
Essential Accessories to Maximize Your Wyze Battery Cam Pro
Wyze Removable Battery Pack
Keep your cameras running longer with extra 6200mAh rechargeable battery packs. These batteries are easy to swap out and charge via USB-C, providing up to 6 months of power per charge.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with the dual charging dock. This accessory is compact and efficient, ensuring your spare batteries are always ready to go.
Why Choose Wyze Battery Cam Pro for Your Smart Home?
- Easy Integration: No hub required, works seamlessly with existing Wyze devices.
- Wireless Freedom: Install anywhere without worrying about power cables.
- High-Quality Video: 2.5K HDR resolution with color night vision.
- Smart Alerts: Radar + PIR motion detection reduces false alarms.
- Weatherproof Durability: IP65 rating for reliable outdoor use.
- Long Battery Life: Up to 6 months on a single charge, extendable with solar power.
- Voice Assistant Compatible: Works with Alexa, Google Assistant, and IFTTT.
Expand your Wyze smart home system today with these versatile, easy-to-integrate cameras and accessories designed to keep your home safe and connected.
Experience wireless freedom and crystal-clear security with Wyze Battery Cam Pro.
Keep your Wyze Battery Cam Pro powered continuously with the solar panel.
Enjoy birdwatching and home security combined with the Wyze Bird Feeder Wireless Camera Bundle.
What is the Wyze Battery Cam Pro and how does it enhance my smart home security?
The Wyze Battery Cam Pro is a wire-free, weatherproof security camera that delivers 2.5K HDR video quality and advanced motion detection. It integrates seamlessly with Alexa, Google Assistant, and IFTTT, making it easy to expand your Wyze smart home system for both indoor and outdoor security.How long does the Wyze Battery Cam Pro battery last on a single charge?
The Wyze Battery Cam Pro uses a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.Is the Wyze Battery Cam Pro weatherproof for outdoor use?
Yes, the Wyze Battery Cam Pro is IP65 rated, making it resistant to rain, dust, and harsh weather conditions. It is ideal for both indoor and outdoor installation.What video quality does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro provides stunning 2.5K HDR video resolution (2560 x 1440), ensuring crystal-clear footage and excellent image clarity, even in low light conditions.Does the Wyze Battery Cam Pro support local storage?
Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB, allowing for continuous recording without relying solely on cloud services.How does the Wyze Battery Cam Pro detect motion and reduce false alerts?
The camera uses advanced Radar + PIR motion detection to intelligently distinguish between people, animals, and objects, significantly reducing false alerts. It also features an integrated spotlight and a 100 dB siren for added security.Can I use the Wyze Battery Cam Pro with voice assistants?
Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing for convenient voice control and smart home automation.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the camera, an integrated spotlight, siren, radar + PIR motion detection, color night vision, and a solar panel for continuous power, reducing the need for manual recharging.How does the Wyze Bird Feeder Wireless Camera Bundle work?
The Wyze Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, a vibrant bird feeder, and a solar panel. It allows you to monitor birds with a macro lens adapter for close-ups, live stream and record via the Wyze app, and enjoy continuous power with the included solar panel.What accessories are available for the Wyze Battery Cam Pro?
Essential accessories include the Wyze Removable Battery Pack for extended use and the Wyze Battery Charging Dock, which can charge two battery packs simultaneously, ensuring your cameras are always powered.Do I need a hub to use the Wyze Battery Cam Pro?
No, the Wyze Battery Cam Pro does not require a hub. It works seamlessly with existing Wyze devices and connects directly to your WiFi network.What WiFi bands does the Wyze Battery Cam Pro support?
The Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi bands, ensuring stable and flexible connectivity in various home environments.How easy is it to mount the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro comes with an included wall mount (1/4” - 20 standard), making it easy to install in a variety of locations indoors or outdoors.What makes the Wyze Battery Cam Pro a good choice for smart home security?
The Wyze Battery Cam Pro offers easy integration, wireless freedom, high-quality 2.5K HDR video, smart motion alerts, weatherproof durability, long battery life, and compatibility with popular voice assistants, making it a versatile and reliable choice for smart home security.
