If you're looking for a battery-powered camera, we recommend the following options from our selection:
Wyze Duo Cam Doorbell
- Our most advanced battery-powered video doorbell.
- Features dual camera views for people and packages.
- 2K video resolution and local storage support (microSD card up to 256 GB).
- Two-way audio, real-time AI detections and alerts, and motion-activated voice deterrence.
- Includes a removable battery pack and Wyze Wi-Fi Chime.
- Can be set up with hardwired power for 24/7 local recording (microSD card required).
- Weather resistant (IP65) and works in temperatures from -4°F to 122°F.
- Integrates with Alexa, Google Assistant, and IFTTT.
Wyze Video Doorbell Pro
- Can be used wired or wirelessly with built-in rechargeable batteries (3-6 months battery life).
- 1440x1440p Full HD video resolution with a wide 150° field of view.
- Two-way audio and waterproof speaker.
- Fast and easy installation—set up in just 30 seconds.
- Weather resistant (IP65) and operates in temperatures from -4°F to 120°F.
- Compatible with both 2.4 GHz and 5 GHz Wi-Fi.
Both options provide reliable battery-powered security with advanced features and easy installation. If you need a camera for locations without wired power, these are excellent choices for your home security needs.
