Easy to Install Refurbished Wyze Thermostat with C-Wire Adapter
Looking for a smart thermostat that’s easy to install, budget-friendly, and reliable? The Refurbished Wyze Thermostat is your perfect solution. Designed for simple DIY installation and equipped with a C-wire adapter, this thermostat brings smart heating and cooling control to your home without the hassle.
Why Choose the Refurbished Wyze Thermostat?
Like-New Quality at a Great Price
This refurbished Wyze Thermostat is a fully tested, A-grade product that works like new but comes at a fraction of the original price. It’s a final sale item, ensuring you get the best deal on a smart thermostat that’s guaranteed to perform.
Simple 20-Minute DIY Installation
Forget complicated setups. The Wyze app guides you step-by-step through the installation process, making it easy for anyone to install—even if you’re not a tech expert. The included C-wire adapter ensures compatibility with most HVAC systems, providing stable power without rewiring headaches.
Sleek Design and Durable Build
  • Dimensions: 120mm (L) x 65mm (W) x 33mm (D)
  • Wall Cover: 165mm (L) x 140mm (W)
  • Lightweight: Less than 1 lb
  • Materials: PC+ABS body with PMMA faceplate
  • IPS Display with 180º viewing angle for clear visibility
Smart Features for Comfort and Savings
  • Control your thermostat remotely via the Wyze app from anywhere in the world
  • Compatible with Alexa and Google Assistant for voice control
  • Create daily schedules to optimize heating and cooling automatically
  • Motion-Sensing Comfort Mode with Wyze Room Sensors (sold separately) to prioritize rooms you use
  • Energy-saving tips based on your usage history help reduce bills
  • Always-on display and wireless setup for convenience
Eco-Friendly and Certified
  • Recyclable packaging
  • Mercury-free, arsenic-free, and PVC-free materials
  • Certified by FCC, IC, and California Proposition 65
What’s Included in the Box?
  • Wyze Thermostat x1
  • C-Wire Adapter x1
  • Back Panel x1
  • Mounting Plate x1
  • Wall Cover x1
  • Wall Screws and Anchors
  • Wire Label Sheets
  • Screwdrivers x2
  • Quick Start Guide
“Installing a new thermostat is easier than you might think. The Wyze app guides you through the installation process, step-by-step.”
Wyze Thermostat Replacement Part Kit
For added convenience and peace of mind, the Wyze Thermostat Replacement Part Kit is available to keep your thermostat running smoothly. This kit includes essential screws, cables, and other parts you might need for maintenance or repair.
  • Price: Affordable at $19.99
  • 30-day hassle-free returns
  • Ideal for quick fixes and replacements
Enhance Your Smart Home with Wyze Bulb Cam
While focusing on smart climate control, consider complementing your home environment with the Wyze Bulb Cam, a 2-in-1 outdoor security camera and smart LED light bulb. It’s easy to install and fits most light fixtures, making it a perfect addition to your smart home setup.
Key Features of Wyze Bulb Cam
  • 2K HD video with color night vision for clear security footage day and night
  • Wide 160° field of view to cover more area
  • Motion alerts sent directly to your phone
  • Dimmable 800 lumen LED bulb with customizable brightness
  • Supports local video storage with microSD card (no subscription needed)
  • Two-way audio to communicate remotely
  • Works with Alexa, Google Assistant, and IFTTT for seamless integration
Easy Installation and Smart Lighting
Installation is as simple as screwing in a light bulb—no messy wires or complicated setups. You can also auto-connect up to 5 Wyze Accessory Bulbs for synchronized lighting control and motion-activated lights. Wyze Bulb Cam Outdoor Installation Wyze Bulb Cam installed in an outdoor light fixture, blending security and smart lighting.
Summary
If you want an easy to install refurbished Wyze Thermostat with a C-wire adapter, this product offers smart, reliable, and affordable climate control with a simple DIY setup. Pair it with the Wyze Bulb Cam for enhanced home security and smart lighting, creating a connected home environment that’s both comfortable and safe.
Product Highlights at a Glance
ProductPriceKey FeaturesInstallation
Refurbished Wyze Thermostat$29.98C-wire adapter included, app & voice control20-minute DIY guided
Wyze Thermostat Replacement Kit$19.99Screws, cables, parts for maintenanceEasy replacement
Wyze Bulb Cam$49.982K HD video, color night vision, smart bulbScrew-in bulb install
Feature(Refurbished) Wyze ThermostatWyze ThermostatWyze Thermostat Replacement Part Kit
Product TypeRefurbishedConnected HomeReplacement Parts
Price$29.98 (Regular $79.98)$79.98$19.99
Return PolicyFinal Sale, no returns (Wyze decision)30-day hassle-free returns30-day hassle-free returns
ConditionLike new, fully tested and guaranteedNewNew replacement parts
Smart FeaturesYes, smart heating & coolingYes, smart heating & coolingNo
App ControlYesYesNo
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google AssistantNo
Wyze Room Sensor SupportYesYesNo
SchedulingYes, simple daily schedulingYes, simple daily schedulingNo
Energy Saving TipsYesYesNo
Installation20-minute DIY guided by app20-minute DIY guided by appN/A
Included ItemsThermostat unit onlyThermostat unit only or with Room Sensor (3-pack)Screws, cables, and other parts
WarrantyNot specifiedNot specified30-day hassle-free returns
AvailabilitySold outSold outAvailable
What is included with the Refurbished Wyze Thermostat?The Refurbished Wyze Thermostat package includes the thermostat itself, a C-wire adapter, back panel, mounting plate, wall cover, wall screws and anchors, wire label sheets, two screwdrivers, and a quick start guide for easy installation.
How easy is it to install the Refurbished Wyze Thermostat?The Refurbished Wyze Thermostat is designed for simple DIY installation, typically taking about 20 minutes. The Wyze app provides step-by-step guidance, and the included C-wire adapter ensures compatibility with most HVAC systems.
Does the Refurbished Wyze Thermostat work with Alexa and Google Assistant?Yes, the Refurbished Wyze Thermostat is compatible with both Alexa and Google Assistant, allowing you to control your home's temperature using voice commands.
What smart features does the Wyze Thermostat offer?The Wyze Thermostat offers remote control via the Wyze app, daily scheduling, energy-saving tips, compatibility with Wyze Room Sensors for motion-sensing comfort, and an always-on display. It also supports wireless setup and voice control.
Is the Refurbished Wyze Thermostat eco-friendly?Yes, the thermostat is made with recyclable packaging and is free from mercury, arsenic, and PVC. It is also certified by FCC, IC, and California Proposition 65.
What is the Wyze Thermostat Replacement Part Kit?The Wyze Thermostat Replacement Part Kit is an affordable kit priced at $19.99, containing essential screws, cables, and other parts needed for maintenance or repair of your Wyze Thermostat. It comes with a 30-day hassle-free return policy.
What are the dimensions and materials of the Wyze Thermostat?The Wyze Thermostat measures 120mm (L) x 65mm (W) x 33mm (D), with a wall cover of 165mm (L) x 140mm (W). It weighs less than 1 lb and is made from a PC+ABS body with a PMMA faceplate. The IPS display offers a 180º viewing angle.
What is the Wyze Bulb Cam and how does it enhance home security?The Wyze Bulb Cam is a 2-in-1 outdoor security camera and smart LED light bulb. It features 2K HD video with color night vision, a 160° field of view, motion alerts, two-way audio, and dimmable lighting. It installs easily by screwing into most light fixtures and works with Alexa, Google Assistant, and IFTTT.
Can I control the Wyze Thermostat remotely?Yes, you can control the Wyze Thermostat remotely from anywhere in the world using the Wyze app, allowing you to adjust your home's temperature and settings on the go.
Is the Refurbished Wyze Thermostat a final sale item?Yes, the Refurbished Wyze Thermostat is a final sale item, offering like-new quality at a reduced price with no returns.
What are the key features of the refurbished Wyze Thermostat?Can you tell me more about the installation process for the Wyze Thermostat?Is there a warranty for the refurbished Wyze Thermostat?
