Easy Smart Plug & Night Light Setup for Airbnb Hosts | Wyze
Easy Smart Plug and Night Light Setup for Airbnb Hosts
Airbnb hosts know the importance of creating a welcoming, convenient, and secure environment for their guests. Smart home devices like smart plugs and night lights can transform any rental property into a modern, guest-friendly space with minimal effort. This guide highlights the best Wyze smart plugs and lighting solutions designed for easy setup and seamless control, perfect for Airbnb hosts looking to enhance their property’s comfort and security.
Smart Plugs for Effortless Control and Energy Savings
Wyze Plug Outdoor: Weatherproof Convenience for Outdoor Spaces
The Wyze Plug Outdoor is an ideal choice for Airbnb hosts who want to extend smart control beyond the indoors. Whether it’s garden lights, holiday decorations, or outdoor appliances, this plug offers:
  • Durable IP64 weather rating for rain or shine use
  • Dual outlets with 15A max output and overload protection
  • Control via app with scheduling and energy monitoring
  • Compatibility with Alexa voice commands
  • Operating temperature range from -4°F to 120°F
  • Connectivity through 2.4GHz WiFi and Bluetooth V4.2
This plug makes managing outdoor lighting and devices effortless, enhancing guest experience with automated ambiance and security.
Wyze Plug: Compact Indoor Smart Plug for Any Room
For indoor use, the Wyze Plug is a compact, reliable solution to make any device smart. Perfect for lamps, fans, or coffee makers, it features:
  • Easy app control and scheduling
  • Compatibility with Alexa, Google Assistant, and IFTTT
  • 15A max output with ETL certification
  • Operating temperature from -4°F to 104°F
  • Simple setup with 2.4GHz WiFi connectivity
Airbnb hosts can remotely control appliances, set timers for guest convenience, and reduce energy waste effortlessly. Wyze Plug in Lifestyle Setting Smart plug controlling home devices with app
Smart Lighting: Create the Perfect Ambiance with Wyze Bulb Color
Wyze Bulb Color: Vibrant, Tunable Lighting for Every Mood
The Wyze Bulb Color is a versatile smart bulb that offers Airbnb hosts the ability to customize lighting to suit any occasion or guest preference:
  • 16 million colors and tunable white light (1800K to 6500K)
  • Extra bright at 1100 lumens with dimmable options
  • Compatible with Alexa, Google Assistant, and IFTTT
  • Suitable for damp locations, perfect for bathrooms or covered patios
  • Long lifespan of 25,000 hours
  • Easy app control for color and brightness adjustments
Guests can enjoy personalized lighting scenes, from relaxing warm tones to vibrant party colors, enhancing their stay experience. Wyze Bulb Color in Cozy Living Room Color-changing smart bulb setting cozy mood
Night Light and Security: Wyze Cam Floodlight Pro + Plug-In Mount
Wyze Cam Floodlight Pro + Plug-In Mount: Brighten and Secure Your Airbnb
For Airbnb hosts prioritizing guest safety and property security, the Wyze Cam Floodlight Pro + Plug-In Mount bundle offers a simple, plug-and-play solution:
  • 2.5K QHD resolution with color night vision for clear video day and night
  • 180° ultra-wide field of view to cover large outdoor areas
  • Powerful 3000 lumens floodlight to illuminate dark spaces
  • Easy installation with included plug-in mount—no junction box needed
  • Weather-resistant IP65 rating and wide operating temperature range (-22°F to 122°F)
  • Supports microSD cards up to 256GB for local video storage
This setup not only deters unwanted visitors but also provides peace of mind for hosts and guests alike. Wyze Cam Floodlight Pro Installed Outdoors Outdoor floodlight camera securing home entrance
Why Airbnb Hosts Choose Wyze Smart Devices
"Smart home technology should be simple, affordable, and reliable—Wyze delivers all three, making it easy for Airbnb hosts to upgrade their properties without hassle."
  • Easy Setup: All Wyze devices connect via the Wyze app, compatible with Android and iOS, allowing hosts to control devices remotely.
  • Voice Control: Integration with Alexa and Google Assistant enables hands-free operation.
  • Energy Efficiency: Smart plugs with scheduling and energy monitoring help reduce utility costs.
  • Guest Comfort: Customizable lighting and automated devices create a welcoming atmosphere.
  • Enhanced Security: Smart cameras and floodlights provide real-time monitoring and deterrence.
Conclusion
For Airbnb hosts seeking an easy smart plug and night light setup, Wyze offers a comprehensive range of products that combine convenience, security, and ambiance. From the weatherproof Wyze Plug Outdoor to the vibrant Wyze Bulb Color and the powerful Wyze Cam Floodlight Pro, these devices are designed to simplify property management and elevate guest experiences.
Product Summary
  • Wyze Plug Outdoor: Outdoor-ready, dual outlet smart plug with energy monitoring and Alexa compatibility.
  • Wyze Plug: Compact indoor smart plug with scheduling and voice assistant support.
  • Wyze Bulb Color: 16 million colors, tunable white, dimmable smart bulb for personalized lighting.
  • Wyze Cam Floodlight Pro + Plug-In Mount: High-resolution floodlight camera with easy plug-in installation and color night vision.
Enhance your Airbnb with smart technology that’s easy to set up and even easier to enjoy.
FeatureWyze PlugWyze Bulb ColorWyze Cam Floodlight Pro + Plug-In Mount
TypeConnected HomeSmart LightingCameras
Price2 Pack: $24.98
4 Pack: $39.98
2 Pack: $26.26
4 Pack: $44.44
6 Pack: $64.98
$169.96
ControlRemote on/off via Wyze app
No hub required
16 million colors, dimmable, white light temp control2.5K QHD video, 180° ultra-wide field of view
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
SchedulingYes, create schedules for on/offCustom presets, sleep routines, vacation modeAI motion detection with adjustable 3000 lumen LED lights
Energy MonitoringNoNoNo
App IntegrationWyze appWyze appWyze app
Special FeaturesVacation Mode (random on/off)
Group control
Brilliant notifications
Music mode
Grouping
Color night vision
AI computer vision
Siren 105dB
ConnectivityWi-Fi 2.4 GHzWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz & 5 GHz dual-band
Power SupplyStandard outletStandard bulb socket (E26)Hardwired 110-120V AC
DimensionsNot specifiedNot specified153mm x 155mm x 79mm (mount)
10.2 in x 9.1 in x 7.8 in (camera)
Warranty30-day hassle-free returns30-day hassle-free returns1 Year
Outdoor UseNoNoYes (IP65 water resistance)
Additional Items IncludedN/AN/AWyze Cam Floodlight Pro and Plug-in Mount
What are the best smart plugs for Airbnb hosts?The Wyze Plug Outdoor and Wyze Plug are top choices for Airbnb hosts. The Wyze Plug Outdoor is weatherproof and ideal for outdoor spaces, while the Wyze Plug is a compact solution for indoor devices. Both offer easy app control, scheduling, and compatibility with Alexa and Google Assistant.
How do Wyze smart plugs help save energy in Airbnb rentals?Wyze smart plugs feature scheduling and energy monitoring, allowing Airbnb hosts to automate device usage and track energy consumption. This helps reduce utility costs by ensuring devices are only on when needed.
Can I control Wyze smart plugs and bulbs remotely?Yes, all Wyze smart plugs and bulbs can be controlled remotely through the Wyze app, available for both Android and iOS devices. This allows Airbnb hosts to manage devices from anywhere for added convenience.
Are Wyze smart plugs compatible with voice assistants?Yes, Wyze smart plugs are compatible with Alexa, Google Assistant, and IFTTT, enabling hands-free voice control for added convenience in your Airbnb property.
What makes the Wyze Plug Outdoor suitable for Airbnb properties?The Wyze Plug Outdoor is IP64 weatherproof, has dual outlets with 15A max output, and offers app-based scheduling and energy monitoring. It's perfect for controlling outdoor lights, appliances, and decorations, enhancing guest experience and property security.
How can I create customizable lighting in my Airbnb with Wyze Bulb Color?The Wyze Bulb Color offers 16 million colors, tunable white light, and dimmable options. You can easily adjust color and brightness via the Wyze app or voice assistants, creating personalized lighting scenes for any mood or occasion.
Is the Wyze Bulb Color suitable for bathrooms or outdoor areas?Yes, the Wyze Bulb Color is suitable for damp locations, making it ideal for bathrooms or covered patios in your Airbnb property.
What security features does the Wyze Cam Floodlight Pro offer for Airbnb hosts?The Wyze Cam Floodlight Pro provides 2.5K QHD resolution, color night vision, a 180° ultra-wide field of view, and a powerful 3000 lumens floodlight. It also features easy plug-in installation, weather resistance, and supports local video storage for enhanced security.
How easy is it to set up Wyze smart devices in an Airbnb property?Wyze smart devices are designed for easy setup using the Wyze app. Most products connect via 2.4GHz WiFi and can be installed without professional help, making them ideal for Airbnb hosts seeking hassle-free smart home upgrades.
Why should Airbnb hosts choose Wyze smart home devices?Wyze smart home devices are simple to set up, affordable, and reliable. They offer remote control, voice assistant integration, energy efficiency, customizable lighting, and enhanced security—making them perfect for improving guest comfort and property management.
What are the key features of the Wyze Plug Outdoor for outdoor use?How does the Wyze Plug help with energy monitoring and scheduling?Do you have any deals, ongoing sales, discounts, or promotions available?
