Best Affordable Wired Video Doorbells for Hardwired Homes
Best Affordable Wired Video Doorbell for Hardwired Installation
When it comes to securing your home with a reliable and affordable wired video doorbell, choosing the right product that offers excellent video quality, easy installation, and smart features is essential. Below, we highlight the best wired video doorbell options designed for hardwired installation, focusing on affordability without compromising on performance.
Wyze Video Doorbell v2: Affordable and Feature-Rich Wired Doorbell
Crystal Clear 2K Video Quality
The Wyze Video Doorbell v2 delivers stunning 2K resolution video, providing a detailed and clear view of your porch. This high-definition video quality ensures you never miss a visitor’s face or package details.
Local MicroSD Storage for 24/7 Recording
Unlike many competitors, this doorbell includes a local microSD card slot for continuous recording. This means you can review footage anytime without relying solely on cloud storage.
Seamless Integration with Existing Chimes
Wyze includes a chime controller that allows you to keep your traditional doorbell chime working alongside the smart doorbell. No need to bypass your existing setup.
Smart Features for Enhanced Security
  • Two-way audio lets you communicate with visitors directly from your phone.
  • Motion-activated voice deterrence warns unwanted visitors they are being recorded (requires Cam Plus subscription).
  • Pre-roll motion recording captures 3-6 seconds before motion events, giving you full context.
  • IP65 weatherproof rating ensures durability in all weather conditions.
  • Works with Alexa and Google Home for voice control and live feed viewing.
Easy Installation and Perfect Viewing Angle
The Wyze Video Doorbell v2 comes with a 30° corner wedge kit included, allowing you to adjust the viewing angle for optimal coverage, especially useful for angled door frames or porches with stairs.
“Answer your door from anywhere with our clearest and most capable wired video doorbell yet.” – Wyze
Homeowner answering doorbell on smartphone Alt text: Homeowner answering Wyze Video Doorbell v2 on smartphone at front porch
The Front Porch Security Bundle: Wired Doorbell Plus Smart Lock
Comprehensive Front Porch Security
For those looking to upgrade their home security beyond just a doorbell, the Front Porch Security Bundle combines the Wyze Video Doorbell v2 with a Wyze Lock Bolt Matte Black smart lock.
Features of the Bundle
  • Wyze Video Doorbell v2 with 1080p HD video and two-way audio.
  • Wyze Lock Bolt allows remote locking/unlocking and lock history monitoring via the Wyze app.
  • Control your door security and monitor visitors all from one app interface.
This bundle is perfect for homeowners who want an integrated smart home security solution with wired doorbell installation and enhanced access control.
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle Adjustment Accessory
Optimize Your Doorbell’s Field of View
If your doorbell installation spot has an awkward angle or your porch has stairs, the Wyze Video Doorbell v2 Wedge Kit is the ideal accessory. It includes:
  • 1x 15° horizontal bracket
  • 2x 7.5° vertical brackets
  • All necessary screws and a quick start guide
This weather-resistant, easy-to-install plastic wedge kit helps eliminate blind spots and ensures your doorbell camera captures the best possible view.
Essential Security Bundle: All-in-One Home Protection
More Than Just a Doorbell
For those seeking a full home security upgrade, the Essential Security Bundle includes:
  • Wyze Video Doorbell v2 with 2K video and two-way audio.
  • Wyze Lock Bolt with fingerprint sensor and backlit keypad for keyless entry.
  • Wyze Cam Pan v3 for 360° horizontal and 180° vertical coverage with motion tracking.
  • Two Wyze Cam OG cameras with motion-activated spotlights and color night vision.
This bundle offers comprehensive coverage for your home’s exterior and entry points, all managed through the Wyze app.
Why Choose a Wired Video Doorbell for Hardwired Installation?
  • Reliable Power Source: Wired doorbells draw power directly from your home’s electrical system, eliminating the need for battery replacements.
  • Continuous Operation: No downtime due to dead batteries means your security is always active.
  • Enhanced Features: Wired setups often support advanced features like pre-roll video and continuous local recording.
  • Integration: Easily integrates with existing doorbell chimes and smart home systems.
Conclusion
For the best affordable wired video doorbell with hardwired installation, the Wyze Video Doorbell v2 stands out as a top choice. It offers high-resolution 2K video, local storage, smart features, and easy integration with your existing chime system — all at an unbeatable price point. If you want a more comprehensive security solution, consider the Front Porch Security Bundle or the Essential Security Bundle for added smart locks and cameras. Enhance your installation with the Wyze Video Doorbell v2 Wedge Kit to ensure perfect viewing angles and maximum coverage. Secure your home smartly and affordably with these wired video doorbell options designed for hardwired installation.
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell v2 Wedge KitEssential Security Bundle
Product TypeWired Video DoorbellSecurity Bundle (Video Doorbell + Lock + Cam options)Accessory (Wedge Kit for Doorbell v2)Security Bundle (Doorbell v2 + Lock Bolt + Cameras)
Video Resolution2K (2048 x 1536)1080p HD (Doorbell)N/A2K (Doorbell v2), plus other cameras with various specs
Local StoragemicroSD slot for local recordingNot specified (depends on included devices)N/AmicroSD local storage (Doorbell v2), cloud/local for others
Cloud StorageOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionN/AOptional with Cam Plus subscription
Two-Way AudioYesYesN/AYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)Not specifiedN/AYes (Doorbell v2)
Field of View135° horizontal, 103° verticalNot specifiedN/ADoorbell v2: 135° horizontal, 103° vertical
Weather ResistanceIP65IP65 (Doorbell)Weather resistantIP65 (Doorbell v2 and cameras)
Works with Existing ChimeYes, includes chime controllerYes (Doorbell and Chime included)N/AYes (Doorbell v2)
Included ItemsDoorbell + Chime ControllerWyze Lock + Wyze Video Doorbell and Chime (varies by variant)15° Horizontal Bracket, 2x 7.5° Vertical Brackets, screws, guideDoorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2x Wyze Cam OG
Price$44.98From $123.99 to $173.97 (depending on variant)$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge Kit)$199.99
InstallationWired, includes wedge (30°)Wired (Doorbell), Lock installationQuick installationWired (Doorbell), Lock, Cameras
Special Features3-6 seconds pre-roll recording, Alexa/Google Home compatibleRemote lock/unlock via app, lock history viewAdjust viewing angle for Doorbell v2Pan & tilt camera with motion tracking, spotlights on OG cams
Warranty1 yearNot specified1 yearNot specified
What is the best affordable wired video doorbell for hardwired installation?The Wyze Video Doorbell v2 is considered the best affordable wired video doorbell for hardwired installation. It offers 2K video quality, local microSD storage, smart features, and easy integration with existing chimes, all at a budget-friendly price.
Does the Wyze Video Doorbell v2 support local video storage?Yes, the Wyze Video Doorbell v2 features a local microSD card slot for continuous 24/7 recording, allowing you to review footage anytime without relying solely on cloud storage.
Can I use my existing doorbell chime with the Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 includes a chime controller that allows you to keep your traditional doorbell chime working alongside the smart doorbell, so you don’t have to bypass your existing setup.
What smart features does the Wyze Video Doorbell v2 offer?The Wyze Video Doorbell v2 offers two-way audio, motion-activated voice deterrence (with Cam Plus subscription), pre-roll motion recording, IP65 weatherproof rating, and compatibility with Alexa and Google Home for voice control and live feed viewing.
Is the Wyze Video Doorbell v2 easy to install?Yes, the Wyze Video Doorbell v2 is designed for easy installation and comes with a 30° corner wedge kit to help you adjust the viewing angle for optimal coverage, especially for angled door frames or porches with stairs.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes the Wyze Video Doorbell v2 with 1080p HD video and two-way audio, and the Wyze Lock Bolt Matte Black smart lock, allowing you to monitor visitors and control your door security from the Wyze app.
What is the Wyze Video Doorbell v2 Wedge Kit and why do I need it?The Wyze Video Doorbell v2 Wedge Kit is an accessory that helps you adjust your doorbell’s field of view. It includes a 15° horizontal bracket and two 7.5° vertical brackets, making it ideal for installations with awkward angles or stairs, ensuring your camera captures the best possible view.
What does the Essential Security Bundle include?The Essential Security Bundle includes the Wyze Video Doorbell v2 with 2K video and two-way audio, Wyze Lock Bolt with fingerprint sensor and backlit keypad, Wyze Cam Pan v3 for 360° horizontal and 180° vertical coverage, and two Wyze Cam OG cameras with motion-activated spotlights and color night vision.
What are the benefits of choosing a wired video doorbell for hardwired installation?Wired video doorbells offer a reliable power source from your home’s electrical system, continuous operation without battery changes, support for advanced features like pre-roll video and continuous local recording, and easy integration with existing doorbell chimes and smart home systems.
Is the Wyze Video Doorbell v2 weatherproof?Yes, the Wyze Video Doorbell v2 has an IP65 weatherproof rating, ensuring durability and reliable performance in all weather conditions.
What are the key features of the Wyze Video Doorbell v2?How does the Wyze Video Doorbell v2 compare to other wired doorbells on the market?Are there any ongoing promotions or discounts for the Wyze Video Doorbell v2?
