Easy Install Doorbells & Cameras – Adhesive Mount, No Technician
Easy Install Doorbells and Security Cameras with Adhesive Mounting – No Technician Required
Looking for a hassle-free doorbell or security camera that installs easily without the need for professional help? Whether you want to secure your front door or monitor your outdoor spaces, these Wyze products offer simple adhesive mounting options and wireless setups that anyone can handle. Say goodbye to complicated wiring, drilling, or calling a technician!
Wyze Bulb Cam: 2-in-1 Security Camera and Smart Light Bulb
Effortless Installation with Adhesive and Fixture Compatibility
The Wyze Bulb Cam transforms any standard outdoor light fixture into a smart security camera and LED light bulb combo. Installation is as simple as screwing in a light bulb—no wires, no drilling, no technician needed. It fits most fixtures and uses a standard E26 socket, making it perfect for quick upgrades.
Key Features
  • 2K HD Video with Color Night Vision: Capture crisp video day and night with a wide 160° field of view.
  • Motion Alerts & Two-Way Audio: Receive instant notifications and communicate through the built-in mic and speaker.
  • Dimmable 800 Lumen LED Bulb: Customize brightness for perfect lighting and security.
  • Local Video Storage: Supports microSD cards up to 256GB—no subscription required.
  • Smart Lighting Control: Connect up to 5 Wyze Accessory Bulbs for synchronized lighting and motion-activated effects.
  • Weather Resistant: Designed for outdoor use with IP65 rating.
Installation is as easy as twisting the bulb into your existing fixture—no messy cables or complicated setups.
Wyze Bulb Cam in Outdoor Setting Wyze Bulb Cam installed on a porch light fixture, blending security and lighting seamlessly.
Wyze Battery Cam Pro: Wireless, No Hub, No Technician Needed
True Wire-Free Security with Adhesive Mounting Options
The Wyze Battery Cam Pro offers a completely wireless security solution that requires no power outlet or hub. Its compact design and included mounting accessories allow for easy adhesive mounting on walls or other surfaces, making installation quick and tool-free.
Standout Specifications
  • 2.5K HDR Video Resolution: See every detail clearly with enhanced color and contrast.
  • Integrated Spotlight & Siren: Motion-activated 150-lumen spotlight and 100 dB siren deter intruders.
  • Radar + PIR Motion Detection: Dual sensors for precise and early motion alerts.
  • Removable Rechargeable Batteries: Hot-swap batteries to keep your camera running without downtime.
  • IP65 Weatherproof: Built to withstand rain, dust, and extreme temperatures.
  • Dual-Band Wi-Fi & Bluetooth Setup: Connect easily with 2.4 & 5 GHz Wi-Fi and quick Bluetooth pairing.
  • Local and Cloud Storage: Supports microSD cards for local recording and optional cloud plans.
Mount your camera anywhere with included adhesive mounts—no drilling or electrician required.
Wyze Battery Cam Pro + Solar Panel: Extended Wireless Security
Solar-Powered Convenience for Long-Term Monitoring
Upgrade your wireless security with the Wyze Battery Cam Pro bundled with a solar panel. This combo lets you mount your camera with adhesive and enjoy months of battery life powered by the sun, eliminating frequent recharging.
Features at a Glance
  • Up to 6 Months Battery Life: Powered by removable batteries and solar energy.
  • 2.5K HDR Video & Color Night Vision: High-quality footage day and night.
  • Weatherproof & Durable: IP65 rating for all-weather protection.
  • Integrated Spotlight & Siren: Enhanced security with light and sound deterrents.
  • Easy Mounting: Includes wall mount with adhesive options for quick setup.
Wyze Bulb Cam + Accessory Bulbs Bundle: Enhanced Outdoor Security Lighting
Complete Smart Lighting and Security Setup
This bundle pairs the Wyze Bulb Cam with additional Wyze Accessory Bulbs, all easily installed with adhesive mounting or standard fixtures. Control your outdoor lighting and security cameras from one app, with synchronized lighting effects and motion-activated alerts.
Bundle Highlights
  • Multiple Accessory Bulbs: Auto-connect and control up to 5 bulbs for full coverage.
  • 2K HD Video & Color Night Vision: Keep an eye on your property with clear video.
  • Motion-Activated Lighting: Lights turn on automatically when motion is detected.
  • Dimmable and Schedule-Controlled: Customize brightness and set lighting schedules.
  • Weather Resistant: IP65 certified for outdoor durability.
Wyze Bulb Cam Motion Detection Motion-activated lighting and security alerts keep your garage and porch safe.
Wyze Cam Mounting Kit: Adhesive Mounting Made Simple
Perfect Accessory for Easy Installation
For those using Wyze Cam v2, v3, or v3 Pro, the Wyze Cam Mounting Kit includes everything you need for adhesive mounting without drilling or professional help.
Kit Contents
  • Wall Plate with strong adhesive tape
  • 5-foot USB extension cable for flexible placement
  • Screw set for optional secure mounting
This kit ensures your camera stays firmly in place with minimal effort and no technician required.
Why Choose Wyze for Easy Install Doorbells and Cameras?
Wyze products are designed with the user in mind—offering wireless, adhesive, and fixture-based mounting options that eliminate the need for complicated wiring or professional installation. Whether you want a smart doorbell or a security camera, Wyze makes it simple, affordable, and effective.
Summary of Easy Install, Adhesive Mount Doorbell and Security Cameras
ProductInstallation TypeVideo QualityPower SourceWeatherproofSpecial Features
Wyze Bulb CamScrew-in bulb, adhesive2K HDWired (light fixture)IP65Color night vision, two-way audio
Wyze Battery Cam ProAdhesive mount, wireless2.5K HDRRechargeable batteryIP65Spotlight, siren, radar + PIR detection
Wyze Battery Cam Pro + SolarAdhesive mount, wireless2.5K HDRBattery + solar panelIP65Extended battery life, solar powered
Wyze Bulb Cam + Accessory BulbsScrew-in bulb, adhesive2K HDWired (light fixture)IP65Multi-bulb sync, motion-activated lighting
Wyze Cam Mounting KitAdhesive mounting kitN/AN/AN/AAdhesive tape, USB extension cable
Secure your home today with easy-to-install, adhesive-mounted doorbells and cameras from Wyze—no technician required!
FeatureWyze Battery Cam Pro + Solar PanelWyze Bulb CamWyze Battery Cam ProWyze Bulb Cam + Accessory Bulbs
Price$109.98$49.98$159.98 (1 Pack)$64.98 (Bulb Cam + 1 Accessory Bulb)
Video Resolution2.5K HDR (2560 x 1440)2K HD (2304 x 1296)2.5K HDR (2560 x 1440)2K HD (2304 x 1296)
Night VisionYes, 2 IR LEDs + 2 White LEDs (Color Night)Color Night Vision with 4 IR LEDsYes, 2 IR LEDs + 2 White LEDs (Color Night)Color Night Vision with 4 IR LEDs
Power SourceRemovable rechargeable battery + Solar PanelPowered by light fixture (E26 socket)Removable rechargeable batteryPowered by light fixture (E26 socket)
Battery LifeExtended with Solar PanelN/A (wired to fixture)Up to 6 months per chargeN/A (wired to fixture)
Wireless ConnectivityWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHz + Bluetooth Low EnergyWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHz + Bluetooth Low Energy
Motion DetectionRadar + PIR Motion DetectionMotion alerts with customizable zonesRadar + PIR Motion DetectionMotion alerts with customizable zones
AudioTwo-way audio with built-in mic & speakerTwo-way audio with built-in mic & speakerTwo-way audio with built-in mic & speakerTwo-way audio with built-in mic & speaker
SirenIntegrated siren (100 dB)Built-in siren (95 dB)Integrated siren (100 dB)Built-in siren (95 dB)
Local StorageSupports microSD up to 256 GBSupports microSD up to 256 GBSupports microSD up to 256 GBSupports microSD up to 256 GB
Weather ResistanceIP65IP65IP65IP65
Field of View134° diagonal160° wide134° diagonal160° wide
Spotlight / LightIntegrated spotlight (150 lumens)Dimmable 800 lumen LED bulbIntegrated spotlight (150 lumens)Dimmable 800 lumen LED bulb + Accessory Bulbs
Mounting OptionsFlexible, wire-free, no hub requiredFits most E26 light fixturesFlexible, wire-free, no hub requiredFits most E26 light fixtures
SetupBluetoothⓇ setup, no hub requiredEasy twist installationBluetoothⓇ setup, no hub requiredEasy twist installation
Additional FeaturesSolar panel for continuous powerAuto-connect up to 5 Accessory BulbsRemovable battery packs, hot-swap capableAuto-connect up to 5 Accessory Bulbs
How do I install Wyze doorbells and security cameras without a technician?Wyze doorbells and security cameras are designed for easy DIY installation. Most models use adhesive mounting or screw-in bulb installation, so you don’t need to drill holes, run wires, or hire a technician. Simply follow the included instructions to mount your device using the provided adhesive or by screwing the Wyze Bulb Cam into a standard E26 light fixture.
What is the Wyze Bulb Cam and how does it work?The Wyze Bulb Cam is a 2-in-1 smart security camera and LED light bulb that fits into any standard E26 outdoor light fixture. It provides 2K HD video with color night vision, motion alerts, two-way audio, and dimmable lighting. Installation is as easy as screwing in a light bulb—no wiring or drilling required.
Can I install Wyze security cameras outdoors?Yes, Wyze security cameras like the Wyze Bulb Cam and Wyze Battery Cam Pro are IP65 weather resistant, making them suitable for outdoor use. They are designed to withstand rain, dust, and extreme temperatures.
What are the benefits of adhesive mounting for Wyze cameras?Adhesive mounting allows you to install Wyze cameras quickly and easily without drilling holes or using tools. This method is perfect for renters or anyone who wants a hassle-free, damage-free installation.
Does the Wyze Battery Cam Pro require a power outlet or hub?No, the Wyze Battery Cam Pro is completely wireless and does not require a power outlet or hub. It runs on removable rechargeable batteries and can be mounted anywhere using the included adhesive mounts.
How does the Wyze Battery Cam Pro + Solar Panel bundle work?The Wyze Battery Cam Pro + Solar Panel bundle combines a wireless security camera with a solar panel for extended battery life. The solar panel keeps the camera charged for up to 6 months, reducing the need for frequent recharging. Installation is easy with adhesive mounting options.
Can I control multiple Wyze Bulb Cams and accessory bulbs together?Yes, you can connect and control up to 5 Wyze Accessory Bulbs with the Wyze Bulb Cam for synchronized lighting and motion-activated effects. All devices can be managed from the Wyze app for seamless smart home integration.
What storage options are available for Wyze security cameras?Wyze security cameras support local video storage via microSD cards (up to 256GB) and offer optional cloud storage plans. This allows you to choose between local and cloud recording based on your preferences.
What is included in the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit includes a wall plate with strong adhesive tape, a 5-foot USB extension cable for flexible placement, and a screw set for optional secure mounting. It is compatible with Wyze Cam v2, v3, and v3 Pro.
Are Wyze security cameras and doorbells suitable for renters?Yes, Wyze products are ideal for renters because they offer adhesive and wireless installation options that do not require drilling or permanent modifications to your property.
Do Wyze cameras offer night vision and motion detection?Yes, Wyze cameras such as the Wyze Bulb Cam and Wyze Battery Cam Pro feature color night vision and advanced motion detection, including radar and PIR sensors for accurate alerts.
How do I power the Wyze Bulb Cam?The Wyze Bulb Cam is powered by screwing it into a standard E26 light fixture, just like a regular light bulb. No additional wiring or batteries are needed.
What makes Wyze security cameras easy to install?Wyze security cameras are designed for user-friendly installation with options like adhesive mounting, wireless operation, and fixture compatibility. This eliminates the need for complicated wiring, drilling, or professional installation.
Can you tell me more about the Wyze Bulb Cam and its features?How does the adhesive mounting work for the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for the Wyze products?
