Wyze Duo Cam: Easy Self-Install Smart Doorbell, No Pro Needed
Self-Install Smart Doorbells: Wyze Duo Cam & More
Looking for a smart doorbell that you can easily install yourself without professional help? Wyze offers some of the most user-friendly, feature-packed smart doorbells designed for hassle-free installation and seamless home security. Whether you want a battery-powered option or a wired model with crystal-clear video, Wyze has you covered. In this guide, we focus on the Wyze Duo Cam Battery Doorbell, the Wyze Video Doorbell v2, and essential accessories like the Wyze Chime Controller and Wyze Universal Wi-Fi Chime to complete your setup.
Wyze Duo Cam Battery Doorbell: The Ultimate Wireless Smart Doorbell
Wyze Duo Cam Doorbell Lifestyle Experience advanced home security with Wyze Duo Cam Doorbell The Wyze Duo Cam Battery Doorbell is Wyze’s most advanced battery-powered video doorbell, perfect for those who want a wireless, self-install solution with no complicated wiring.
Key Features:
  • Dual Camera Views: Front camera captures 2K video (2048 x 1536) with a 132° horizontal field of view, while the bottom camera covers packages and doorstep activity in 1080p.
  • Battery Powered: Comes with a removable 6200 mAh lithium-ion battery pack for flexible installation without wiring.
  • Local & Cloud Storage: Supports up to 256GB microSD card for 24/7 local recording plus cloud storage options.
  • Two-Way Audio & Voice Deterrence: Talk to visitors or deter unwanted guests with motion-activated voice warnings.
  • Smart Alerts: Real-time AI detections notify you instantly of people, packages, or suspicious activity.
  • Weather Resistant: IP65 rating ensures reliable performance in all weather conditions.
  • Easy Setup: Includes Wyze Wi-Fi Chime and all necessary mounting hardware for quick self-installation.
This doorbell is ideal for homeowners wanting a powerful, wireless smart doorbell with dual-camera coverage and easy DIY installation.
Wyze Video Doorbell v2: Wired 2K Video with Essential Features
Wyze Video Doorbell v2 Lifestyle Clear 2K video and two-way audio in a sleek wired design If you prefer a wired doorbell with enhanced video quality, the Wyze Video Doorbell v2 offers 2K resolution and a robust feature set.
Highlights:
  • 2K Video Resolution: Crisp 2048 x 1536 video with a wide 135° horizontal field of view captures every detail.
  • Two-Way Audio: Built-in microphone and speaker with noise and echo cancellation for clear communication.
  • Motion-Activated Voice Deterrence: Warn visitors or intruders with a customizable voice alert.
  • Local MicroSD Storage: Save footage locally without monthly fees.
  • Weatherproof Design: IP65 rating for durability in rain, snow, or heat.
  • Easy Installation: Comes with a complete installation kit including wall plates, wire caps, and screws.
  • Smart Integrations: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
This wired doorbell is perfect for users who want high-resolution video and reliable wired power with straightforward installation.
Essential Accessories for Your Wyze Doorbell Setup
The Wyze Chime Controller is a standalone unit compatible with both the Wyze Video Doorbell v2 and the Wyze Duo Cam Doorbell. It connects to your existing mechanical chime system, enabling traditional doorbell sounds inside your home.
  • Easy Wiring Installation: Simple setup with included wiring and compact design.
  • Compatibility: Works with nearly every mechanical chime.
  • Compact Size: 47mm x 32mm x 15mm, fits discreetly behind your chime.
For a completely wireless chime option, the Wyze Universal Wi-Fi Chime plugs into any standard outlet and pairs with your Wyze doorbell or cameras.
  • No Wiring Needed: Just plug in and connect via Wi-Fi.
  • Multiple Tones: Choose from 17 different chime sounds.
  • Smart Automations: Set it to chime when your Wyze cameras detect people or motion.
  • Works with All Wyze Cams and Doorbells: Versatile accessory for your smart home.
Why Choose Wyze for Your Self-Install Smart Doorbell?
Wyze smart doorbells combine advanced technology with user-friendly installation, making home security accessible to everyone. Whether you want the flexibility of a battery-powered doorbell or the reliability of a wired system, Wyze offers solutions that fit your needs without requiring professional help.
  • DIY Friendly: Clear instructions and included hardware make installation simple.
  • High-Quality Video: 2K resolution and wide fields of view capture more detail.
  • Smart Features: AI detection, two-way talk, voice deterrence, and app alerts keep you connected.
  • Expandable Ecosystem: Add chimes, cameras, and other Wyze accessories for a complete smart home.
Summary of Wyze Smart Doorbells and Accessories
ProductPower TypeVideo ResolutionKey FeaturesInstallation
Wyze Duo Cam Battery DoorbellBatteryFront: 2K / Bottom: 1080pDual cameras, AI alerts, removable batteryWireless, self-install
Wyze Video Doorbell v2Wired2K (2048 x 1536)Two-way audio, voice deterrence, local storageWired, easy install
Wyze Chime ControllerAccessoryN/AConnects to mechanical chimesSimple wiring
Wyze Universal Wi-Fi ChimeAccessoryN/AWireless chime, 17 tones, smart automationsPlug & play
Enhance your home security today with Wyze’s self-install smart doorbells and accessories — no professional assistance needed!
FeatureWyze Duo Cam Battery DoorbellWyze Video Doorbell v2Wyze Chime ControllerWyze Universal Wi-Fi Chime
TypeBattery-powered Video DoorbellWired Video DoorbellChime Controller UnitWi-Fi Chime Accessory
Video ResolutionTop: 2K, Bottom: 1080p2KN/AN/A
CamerasDual cameras (people and package views)Single cameraN/AN/A
Local StoragemicroSD support (up to 256GB), 24/7 recording with hardwired powermicroSD support with 24/7 continuous recordingN/AN/A
PowerWyze Removable Battery Pack or Wired (AC 16-24V)Wired (AC 16-24V)AC16V/AC24V, ≥10VA10-24V AC, 10VA 60Hz
Two-Way AudioYesYesN/AN/A
AI Detections & AlertsPerson, Package, Pet, Vehicle DetectionPerson, Package Detection (with Cam Plus subscription)N/AN/A
Voice DeterrenceMotion-activated voice deterrenceMotion-activated voice deterrence (requires subscription)N/AN/A
Included AccessoriesWyze Wi-Fi Chime, Removable Battery PackChime Controller1x Chime Controller Unit1x Wyze Wi-Fi Chime, Quick Start Guide
Chime CompatibilityWyze Wi-Fi Chime or Wyze Chime ControllerWorks with existing chime via included Chime ControllerCompatible with nearly every mechanical chimeCompatible with all Wyze Cams and Doorbells
InstallationAdhesive strips or screw mountingScrew mountingEasy wiring installationPlug and play, no wiring required
Weather ResistanceIP65IP65Operating temp: -20°C to 50°COperating temp: -20°C to 50°C
ConnectivityDual-Band Wi-Fi (2.4 GHz & 5 GHz)Wi-Fi 2.4 GHzN/AWi-Fi 2.4 GHz (IEEE802.11 b/g/n)
DimensionsNot specifiedNot specified47mm x 32mm x 15mm81 x 53 x 38 mm
Compatible Smart AssistantsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/AAlexa, Google Assistant, IFTTT
Price (USD)$89.98 (Doorbell), $109.99 (Doorbell + Extra Battery)$44.98 (Doorbell + Chime Controller)$17.99$19.98
What are the main differences between the Wyze Duo Cam Battery Doorbell and the Wyze Video Doorbell v2?The Wyze Duo Cam Battery Doorbell is a wireless, battery-powered smart doorbell featuring dual cameras (2K front and 1080p bottom) for package and doorstep monitoring, while the Wyze Video Doorbell v2 is a wired model with 2K video resolution and a wide 135° field of view. The Duo Cam offers flexible installation without wiring, whereas the v2 provides continuous power and works with existing doorbell wiring.
Is professional installation required for Wyze smart doorbells?No, Wyze smart doorbells are designed for easy self-installation. Both the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2 come with clear instructions and all necessary hardware, allowing homeowners to install them without professional help.
Does the Wyze Duo Cam Battery Doorbell require wiring?No, the Wyze Duo Cam Battery Doorbell is completely battery-powered and does not require any wiring. It comes with a removable 6200 mAh lithium-ion battery pack for flexible, wireless installation.
What storage options are available for Wyze smart doorbells?Wyze smart doorbells support both local and cloud storage. You can use a microSD card (up to 256GB) for 24/7 local recording, and also opt for cloud storage plans for additional backup and features.
Are Wyze doorbells weatherproof?Yes, both the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2 have an IP65 weather resistance rating, ensuring reliable performance in rain, snow, or heat.
Can I use a traditional chime with Wyze doorbells?Yes, with the Wyze Chime Controller accessory, you can connect your Wyze doorbell to your existing mechanical chime system for traditional doorbell sounds inside your home.
What is the Wyze Universal Wi-Fi Chime and how does it work?The Wyze Universal Wi-Fi Chime is a wireless accessory that plugs into any standard outlet and pairs with your Wyze doorbell or cameras. It offers 17 different chime sounds and can be set to ring when your Wyze devices detect people or motion, with no wiring required.
Do Wyze smart doorbells support smart home integrations?Yes, the Wyze Video Doorbell v2 works with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation. The Wyze Universal Wi-Fi Chime also supports smart automations with Wyze cameras and doorbells.
What smart features do Wyze doorbells offer?Wyze doorbells include advanced features such as AI-powered real-time alerts for people, packages, and suspicious activity, two-way audio for communicating with visitors, and motion-activated voice deterrence to warn or deter unwanted guests.
Are Wyze doorbells suitable for DIY installation?Absolutely. Wyze doorbells are designed with DIY installation in mind, providing clear instructions and all necessary mounting hardware for a hassle-free setup.
What are the key features of the Wyze Duo Cam Battery Doorbell?Can you tell me more about the Wyze Video Doorbell v2 and its installation process?Are there any ongoing promotions or discounts available for Wyze products?
