Dual View Security Cameras with Stack Kit Mount & MicroSD Cards
Dual View Security Cameras with Stack Kit Dual Mount and MicroSD Cards
When it comes to securing your home or business, having a dual view security camera setup with versatile mounting options and reliable local storage is essential. Whether you want to monitor multiple angles simultaneously or need a flexible mounting solution like a stack kit dual mount, Wyze offers a range of cutting-edge cameras and accessories that fit your needs perfectly. Plus, with compatible MicroSD cards, you can enjoy continuous local recording without worrying about cloud subscriptions. Explore the best Wyze cameras designed for dual view security, stack kit dual mounts, and MicroSD card support to enhance your surveillance system.
Wyze Cam v4: The Ultimate Dual View Security Camera
Wyze Cam v4 is the clearest and most advanced Wyze camera yet, perfect for dual view security setups. Its 2.5K Quad HD resolution delivers crystal-clear video, capturing every detail with stunning clarity. The camera features a wide 115.9° diagonal field of view, allowing you to cover large areas with a single device.
Key Features:
  • Dual View Capability: With its wide-angle lens and AI-powered auto-zoom and tracking, Wyze Cam v4 can focus on important details while still showing the bigger picture.
  • Enhanced Color Night Vision: See vibrant colors even in low light, thanks to the upgraded hardware that outperforms traditional night vision.
  • Motion-Activated Spotlight & Siren: Deter intruders with a built-in spotlight and a loud 99 dB siren.
  • Weather Resistant (IP65): Suitable for both indoor and outdoor use.
  • 24/7 Local Recording: Supports MicroSD cards up to 256GB for continuous recording without monthly fees.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Mounting and Setup:
Wyze Cam v4 features a screw-free magnetic mount, making it easy to install and reposition without tools. This flexibility is ideal for stack kit dual mounts, allowing you to position two cameras together for comprehensive dual view coverage.
"Pound for pound, the clearest Wyze Cam ever."
Wyze Cam v4 lifestyle image showing indoor use with two-way audio Experience clear two-way audio and vibrant video with Wyze Cam v4.
Wyze Cam Pan v3: 360° Pan and Tilt for Complete Coverage
For a truly dynamic dual view security solution, the Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, letting you monitor every corner of a room or outdoor space with a single camera.
Highlights:
  • Full 360° Pan & 180° Tilt: Covers every angle, eliminating blind spots.
  • Automatic Motion Tracking: The camera detects and follows moving objects quietly, ensuring you never miss important activity.
  • IP65 Weather Resistance: Perfect for outdoor use when paired with the Wyze Outdoor Power Adapter.
  • Color Night Vision: See clear, colorful images even at night.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
  • MicroSD Card Support: Local storage up to 256GB for continuous recording.
  • Two-Way Audio: Communicate through the camera using the Wyze app.
  • Easy Mounting: Compatible with stack kit dual mounts for versatile installation.
Ideal For:
Use Wyze Cam Pan v3 in combination with other cameras on a stack kit dual mount to achieve multi-angle surveillance with pan and tilt flexibility. Wyze Cam Pan v3 outdoor lifestyle image in snowy weather Wyze Cam Pan v3 withstands harsh weather while providing 360° coverage.
Wyze MicroSD Cards: Reliable Local Storage for Your Security Cameras
To maximize your dual view security camera setup, reliable local storage is a must. Wyze MicroSD cards are designed to work seamlessly with Wyze cameras, providing ample space for continuous 24/7 recording.
Available Capacities:
  • 32GB MicroSDHC Card: Ideal for basic recording needs.
  • 128GB MicroSDXC Card: Extended storage for longer video retention.
  • 256GB MicroSDXC Card: Maximum capacity for continuous, high-resolution recording.
Benefits:
  • No Subscription Required: Store footage locally without monthly fees.
  • High Compatibility: Works with Wyze Cam v4, Wyze Cam Pan v3, and other Wyze cameras.
  • Durable and Reliable: Designed for constant video recording and rewrites.
Why Choose Wyze for Your Dual View Security Needs?
Wyze offers a comprehensive ecosystem of security cameras and accessories that cater to dual view setups with stack kit dual mounts and MicroSD card support. Whether you want fixed dual cameras like the Wyze Cam v4 or a flexible pan-and-tilt solution like the Wyze Cam Pan v3, Wyze provides:
  • Affordable Pricing: High-quality security without breaking the bank.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • Weatherproof Designs: Cameras built to withstand outdoor conditions.
  • Easy Installation: Magnetic mounts and stack kit compatibility simplify setup.
  • Advanced Features: AI tracking, color night vision, motion-activated spotlight, and sirens.
Summary of Recommended Products for Dual View Security
Product NameResolutionField of ViewNight VisionMounting OptionsMicroSD SupportPrice Range
Wyze Cam v42.5K QHD115.9° diagonalEnhanced Color Night VisionMagnetic mount, stack kit compatibleUp to 256GB$35.98+
Wyze Cam Pan v32.5K360° pan, 180° tiltColor Night VisionWall, ceiling, stack kit compatibleUp to 256GB$39.98+
Wyze MicroSD CardsN/AN/AN/AN/A32GB, 128GB, 256GB$8.99+
Enhance your home or business security today with Wyze’s dual view cameras, stack kit dual mounts, and reliable MicroSD cards. Capture every angle, store your footage locally, and enjoy peace of mind with smart, affordable security solutions.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam Pro
TypeWired Security CameraWired Pan & Tilt Security CameraWire-Free Battery Security Camera
Video Resolution2.5K QHD (2560x1440)2.5K QHD2.5K HDR (2560x1440)
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)360° Pan, 180° Tilt134° (DFOV), 108° (HFOV), 56° (VFOV)
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)Color Night Vision with Starlight Sensor2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)
AudioEnhanced Two-Way Talk, 99 dB SirenTwo-Way AudioTwo-Way Audio with built-in speaker and microphone
Motion DetectionYes, with motion detection zonesYes, with motion tracking and custom zonesRadar + PIR Motion Detection
SpotlightMotion-activated spotlightNoIntegrated Spotlight
SirenYes, 99 dBNoYes, 100 dB SPL @ 0.1m
Weather ResistanceIP65IP65IP65
Power SourceWired (Indoor adapter included, outdoor adapter sold separately)Wired (Outdoor adapter sold separately)Removable, Rechargeable Battery Packs
Battery LifeN/AN/AUp to 6 Months
Wireless ConnectivityWi-Fi 6 (2.4 GHz)Wi-Fi (2.4 GHz)Wi-Fi 2.4 & 5 GHz
Bluetooth Version5.2Not specifiedBLE 5.1
Local StoragemicroSD card up to 512 GB (required)microSD card supportmicroSD card support up to 256 GB
Cloud StorageSubscription availableSubscription availableSubscription available
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Dimensions2in x 2in x 2 3/8inNot specified2.5 x 1.8 x 3.5 inches
Weight0.49 lb (222 g)Not specified0.94 lbs
Mounting OptionsStand, Wall, Ceiling, Magnetic mountMagnetic mount, wall mount1/4” - 20 standard mount, wall mount included
Special FeaturesAuto-zoom with AI, Wide Dynamic Range (WDR), Smoke & CO alerts360° pan, 180° tilt, motion tracking, Privacy ModeRadar + PIR motion detection, removable battery, 2.4 & 5 GHz Wi-Fi
Price (Single Pack)$35.98 (Wyze Cam v4 + FREE 32GB MicroSD Card)$39.98$159.98
What is a dual view security camera and how does it benefit my home or business?A dual view security camera allows you to monitor multiple angles simultaneously, providing comprehensive coverage of your property. This setup is ideal for both homes and businesses, as it helps eliminate blind spots and ensures you capture every important detail for enhanced security.
Which Wyze cameras support dual view security setups?Wyze Cam v4 and Wyze Cam Pan v3 are both excellent choices for dual view security setups. The Wyze Cam v4 offers a wide 115.9° field of view and advanced AI-powered tracking, while the Wyze Cam Pan v3 provides 360° pan and 180° tilt for complete room or outdoor coverage.
What is a stack kit dual mount and how does it work with Wyze cameras?A stack kit dual mount is a versatile mounting solution that allows you to position two Wyze cameras together for comprehensive dual view coverage. Both Wyze Cam v4 and Wyze Cam Pan v3 are compatible with stack kit dual mounts, making installation easy and flexible for multi-angle surveillance.
Do Wyze security cameras support local storage with MicroSD cards?Yes, Wyze security cameras such as the Wyze Cam v4 and Wyze Cam Pan v3 support local storage with MicroSD cards. You can use MicroSD cards up to 256GB for continuous 24/7 recording, eliminating the need for monthly cloud subscription fees.
What are the available Wyze MicroSD card capacities and which should I choose?Wyze offers MicroSD cards in 32GB, 128GB, and 256GB capacities. The 32GB card is suitable for basic recording needs, the 128GB card provides extended storage, and the 256GB card is ideal for continuous, high-resolution recording and longer video retention.
Are Wyze security cameras weather resistant for outdoor use?Yes, both Wyze Cam v4 and Wyze Cam Pan v3 are IP65 weather resistant, making them suitable for both indoor and outdoor use. This ensures reliable performance even in harsh weather conditions.
How easy is it to install Wyze dual view security cameras?Wyze cameras are designed for easy installation. The Wyze Cam v4 features a screw-free magnetic mount for quick setup and repositioning, while both cameras are compatible with stack kit dual mounts for flexible placement. No special tools are required.
Do Wyze cameras offer night vision and motion detection features?Yes, Wyze Cam v4 features enhanced color night vision, and Wyze Cam Pan v3 offers color night vision as well. Both cameras include motion detection, with the Cam v4 providing AI-powered auto-zoom and tracking, and the Cam Pan v3 offering automatic motion tracking.
Can I use Wyze cameras with smart home assistants?Yes, Wyze cameras are compatible with popular smart home assistants including Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.
Is a subscription required to use Wyze cameras for continuous recording?No, a subscription is not required for continuous recording with Wyze cameras. By using a compatible MicroSD card, you can store footage locally and access it anytime without monthly fees.
What are the key features of the Wyze Cam v4?How does the Wyze Cam Pan v3 compare to the Wyze Cam v4?Are there any ongoing sales or discounts for Wyze products?
