Durable Outdoor Cameras with Wired Recording & MicroSD Support
Durable Outdoor Cameras with Wired Continuous Recording and MicroSD Support
When it comes to securing your outdoor spaces, durability, continuous recording, and reliable local storage are key features to look for in a security camera. Wyze offers a range of wired outdoor cameras that combine weather resistance, high-quality video, and microSD card support for continuous local recording. Whether you want a camera with pan and tilt capabilities, enhanced night vision, or telephoto zoom, Wyze has you covered.
Wyze Cam Pan v3: Weatherproof 360° Pan & Tilt Security
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera designed for full coverage and durability. With an IP65 weather resistance rating, it withstands rain, snow, and harsh outdoor conditions when paired with the Wyze Outdoor Power Adapter (sold separately).
Key Features:
  • 360° Pan and 180° Tilt: Covers every angle of your property with smooth, quiet motorized movement.
  • Color Night Vision: Equipped with a Starlight Sensor, it delivers vibrant color footage even in low light.
  • Automatic Motion Tracking: The camera detects and follows motion automatically, ensuring nothing escapes its view.
  • Two-Way Audio: Communicate through the camera using the Wyze app, perfect for interacting with visitors or pets.
  • MicroSD Card Support: Local storage up to 256GB for continuous recording without subscription fees.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward for privacy when needed.
This camera is ideal for those who want a dynamic, weatherproof solution with extensive coverage and local recording capabilities. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 - Durable outdoor security in all weather
Wyze Cam v4: Crystal-Clear 2.5K QHD Outdoor Security
Wyze Cam v4 is the clearest Wyze outdoor camera yet, offering 2.5K Quad HD resolution and enhanced color night vision for stunning detail day and night. Its IP65 weather resistance rating ensures reliable performance in any climate.
Standout Features:
  • 2.5K QHD Resolution: Capture ultra-clear video with vibrant colors and wide dynamic range (WDR).
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • 24/7 Continuous Recording: Supports microSD cards up to 256GB for uninterrupted local video storage.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for seamless streaming.
  • Easy Setup & Mounting: Magnetic base and metal plate allow quick installation without tools.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Advanced Audio: Enhanced two-way talk with clearer sound quality.
Wyze Cam v4 is perfect for users who want high-resolution video, continuous recording, and smart features in a rugged outdoor camera. Wyze Cam v4 mounted outdoors with spotlight Wyze Cam v4 - High-definition outdoor security with spotlight
Wyze Cam OG and Wyze Cam OG Telephoto: Reliable 1080p Outdoor Cameras
For those seeking dependable 1080p outdoor cameras with local storage and weather resistance, Wyze Cam OG and its Telephoto variant offer excellent options.
Wyze Cam OG Highlights:
  • 1080p Full HD Video: Clear and smooth video streaming with 20 FPS during the day.
  • Built-in Spotlight & Siren: 40 lumens spotlight and 90-decibel siren for added security.
  • IP65 Weather Resistance: Designed to endure outdoor environments.
  • MicroSD Support: Up to 256GB local storage for continuous recording.
  • Two-Way Audio: Enhanced microphone and speaker with noise and echo cancellation.
  • Wide 120° Field of View: Covers broad outdoor areas effectively.
Wyze Cam OG Telephoto Features:
  • 3x Telephoto Lens: Narrower field of view (27° diagonal) for zoomed-in detail.
  • Same 1080p Resolution: Crisp video quality with day and night modes.
  • Weatherproof & MicroSD Support: Same durability and local recording capabilities as the OG model.
  • Smart Integrations: Works with Alexa, Google Assistant, and IFTTT.
These cameras are ideal for users who want straightforward, reliable outdoor monitoring with continuous recording and local storage.
Wyze Cam v4 Home Security Bundle: Complete Outdoor Protection
For a comprehensive security setup, the Wyze Cam v4 Home Security Bundle offers multiple cameras with all the benefits of the Wyze Cam v4, plus included microSD cards for local storage.
Bundle Benefits:
  • Multiple Cameras: Covers several outdoor areas with consistent 2.5K QHD clarity.
  • 128GB MicroSD Cards Included: Ready for continuous 24/7 recording out of the box.
  • Enhanced Night Vision & Spotlight: Keep your property safe day and night.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible installation.
  • Smart Features: Person detection, smoke and CO alerts, and integration with smart assistants.
This bundle is perfect for those who want a ready-to-go, high-quality outdoor security system with wired continuous recording and local storage.
Why Choose Wyze Outdoor Cameras for Durable Continuous Recording?
Wyze outdoor cameras combine rugged IP65 weather resistance with wired power for uninterrupted operation. Their support for microSD cards up to 256GB means you can record continuously without monthly fees or cloud dependency. Whether you need pan-tilt flexibility, ultra-clear 2.5K video, or telephoto zoom, Wyze offers durable, feature-rich cameras that keep your home safe in any weather.
Summary of Key Specs
ModelResolutionWeather ResistanceContinuous RecordingMicroSD SupportSpecial Features
Wyze Cam Pan v31080pIP65YesUp to 256GB360° pan/180° tilt, motion tracking
Wyze Cam v42.5K QHDIP65YesUp to 256GBSpotlight, siren, Wi-Fi 6, WDR
Wyze Cam OG1080pIP65YesUp to 256GBBuilt-in spotlight & siren
Wyze Cam OG Telephoto1080pIP65YesUp to 256GB3x telephoto lens
Wyze Cam v4 Bundle2.5K QHDIP65Yes128GB includedMultiple cams, spotlight, smart alerts
Protect your home with Wyze’s durable outdoor cameras featuring wired continuous recording and microSD support. Choose the model that fits your needs and enjoy peace of mind with reliable, high-quality security.
FeatureWyze Cam Pan v3Wyze Cam v4Wyze Cam OGWyze Cam OG TelephotoWyze Cam v4 Home Security Bundle
Resolution1080p (1920 x 1080)2.5K QHD (2560 x 1440)1080p (1920 x 1080)1080p (1920 x 1080)2.5K QHD (2560 x 1440)
Field of View (DFOV)120°115.8°120°Telephoto: 27°115.8°
Night Vision4 IR LEDs (850 nm)4 IR LEDs + 2 white spotlight LEDs4 IR LEDs (850 nm)4 IR LEDs (850 nm)4 IR LEDs + 2 white spotlight LEDs
Color Night VisionNoYesNoNoYes
Audio2-way talk; noise & echo cancellationEnhanced 2-way talk; noise & echo cancellationBuilt-in speaker & mic; noise & echo cancellationBuilt-in speaker & mic; noise & echo cancellationImproved 2-way audio
SirenNoYes (99 dB)90 dB user-activated sirenNoYes
SpotlightYesMotion-activated spotlightBuilt-in spotlight (40 lumens)NoMotion-activated spotlight
Pan & Tilt360° pan, 180° tiltFixedFixedFixedFixed
Zoom8x digital zoom8x digital zoom8x digital zoom8x digital zoom8x digital zoom
Weather ResistanceIP65IP65IP65IP65IP65
Connectivity2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6
Local Storage SupportmicroSD up to 256 GBmicroSD up to 512 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD 128 GB included
Cloud StorageOptional (subscription)Optional (subscription)Optional (subscription)Optional (subscription)Optional (subscription)
Motion & Sound DetectionYesYesYesYesYes
Smart Detection (Person, Pet, Package, Vehicle)Yes (with subscription)Yes (with subscription)Yes (with subscription)Yes (with subscription)Yes (with subscription)
Smoke & CO AlertsYesYesYesYesYes
Mounting OptionsStand, wall, ceiling mountStand, wall, ceiling, magnetic mountStand, wall, ceiling mountStand, wall, ceiling mountStand, wall, ceiling, magnetic mount
Dimensions (approx.)124mm x 60mm x 63mm2" x 2" x 2 3/8"1.89" x 1.89" x 1.89"1.89" x 1.89" x 1.89"2" x 2" x 2 3/8"
Weight11.29 oz (320 g)0.49 lb (222 g)4.1 oz (116 g)4.1 oz (116 g)0.49 lb (222 g)
Power Adapter Output5V/2000mA5V/1A5V/1A5V/1A5V/1A
Bluetooth VersionNo5.2NoNo5.2
Wi-Fi 6 SupportNoYesNoNoYes
Warranty1 Year1 Year1 Year1 Year1 Year
Price (approximate)$114.94 (1 pack)$107.94 (1 pack)$29.98 (1 pack)$25.98 (1 pack)$169.99 (bundle)
What makes Wyze outdoor cameras suitable for continuous outdoor security?Wyze outdoor cameras are designed with IP65 weather resistance, ensuring durability in rain, snow, and harsh conditions. They support wired continuous recording and microSD cards up to 256GB, allowing for uninterrupted local video storage without monthly fees.
Which Wyze outdoor cameras support microSD cards for local storage?All current Wyze outdoor camera models—including Wyze Cam Pan v3, Wyze Cam v4, Wyze Cam OG, and Wyze Cam OG Telephoto—support microSD cards up to 256GB for continuous local recording.
Does Wyze offer outdoor cameras with pan and tilt capabilities?Yes, the Wyze Cam Pan v3 features 360° pan and 180° tilt, allowing you to cover every angle of your property. It also includes automatic motion tracking and is weatherproof when used with the Wyze Outdoor Power Adapter.
What is the video resolution of Wyze outdoor cameras?Wyze offers outdoor cameras in different resolutions: Wyze Cam Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto provide 1080p Full HD video, while Wyze Cam v4 and the Wyze Cam v4 Home Security Bundle deliver ultra-clear 2.5K QHD resolution.
Do Wyze outdoor cameras have night vision?Yes, Wyze outdoor cameras are equipped with advanced night vision. The Wyze Cam Pan v3 and Wyze Cam v4 feature color night vision, while the OG models offer clear video in low-light conditions.
Can Wyze outdoor cameras deter intruders?Yes, select Wyze outdoor cameras such as Wyze Cam v4 and Wyze Cam OG include built-in spotlights and loud sirens to help deter intruders and enhance your home’s security.
Are Wyze outdoor cameras compatible with smart home systems?Wyze outdoor cameras work with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras, 128GB microSD cards for each camera, enhanced night vision, spotlights, and flexible mounting options for comprehensive outdoor protection.
How easy is it to install Wyze outdoor cameras?Wyze outdoor cameras are designed for easy installation, featuring magnetic bases, metal plates, and multiple mounting options such as stand, wall, or ceiling mounts. No special tools are required for setup.
Do Wyze outdoor cameras require a subscription for continuous recording?No, Wyze outdoor cameras support continuous recording directly to a microSD card, so you can store video locally without needing a subscription or paying monthly fees.
What are the key features of the Wyze Cam Pan v3?Can you tell me more about the Wyze Cam v4 and its capabilities?Are there any ongoing sales or discounts for Wyze cameras?
