Automatic Motion Tracking Outdoor Camera Bundles with 128GB Storage
When it comes to securing your outdoor spaces with smart, reliable technology, having an automatic motion tracking camera paired with ample local storage is essential. Whether you want to monitor your driveway, backyard, or front porch, Wyze offers a range of outdoor cameras that combine advanced motion tracking, weather resistance, and support for 128GB microSD cards to keep your footage safe and accessible. Explore the best Wyze outdoor cameras designed for automatic motion tracking and local storage, perfect for any home security setup.
Wyze Cam Pan v3: 360° Pan & Tilt with Automatic Motion Tracking
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera that brings award-winning pan and tilt capabilities to your outdoor monitoring needs. With its fully IP65 weather-resistant design, it’s built to withstand rain, snow, and harsh conditions when paired with the Wyze Outdoor Power Adapter (sold separately).
Key Features:
  • Automatic Motion Tracking: The camera detects motion and smoothly follows the subject with a quiet motor, ensuring you never miss important activity.
  • 360° Pan and 180° Tilt: Covers every angle with full horizontal rotation and double the tilt range, allowing you to see straight up and down.
  • Color Night Vision: Equipped with a Starlight Sensor, it delivers vibrant color footage even in low-light conditions.
  • Two-Way Audio: Communicate through the camera using the Wyze app, perfect for interacting with visitors or deterring intruders.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward when you want privacy.
  • Supports up to 256GB microSD Cards: Store days or weeks of continuous footage locally without a subscription.
"Take Wyze Cam Pan v3 outside. Not just an indoor cat anymore."
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1_7d89a30d-1292-41d4-b3ef-71d305710824.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3 weatherproof outdoor use
This camera is ideal for users who want a dynamic, wide-coverage camera with smart tracking and local storage options up to 128GB or more.
Wyze Cam v4: Crystal-Clear 2.5K QHD Outdoor Security
For those seeking the clearest image quality in an outdoor camera, the Wyze Cam v4 offers stunning 2.5K Quad HD resolution combined with enhanced color night vision and a motion-activated spotlight.
Highlights:
  • 2.5K QHD Resolution: Capture every detail with ultra-clear video quality.
  • Enhanced Color Night Vision: See vibrant colors even in near darkness, thanks to upgraded hardware.
  • Motion-Activated Spotlight & Siren: Deter unwanted visitors with a bright spotlight and a loud siren.
  • IP65 Weather Resistance: Built to perform in all weather conditions.
  • 24/7 Local Recording: Supports continuous recording to microSD cards up to 256GB, including 128GB for extended storage.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Auto-Zoom with AI Tracking: Focus on important motion events with smart zoom and tracking.
<img src="https://www.wyze.com/cdn/shop/files/WyzeCamFloodlightv2Main-05_76f5ff71-b16d-4814-a365-7c14c1006cf5.jpg?v=1743789457&width=1946" alt="Wyze Cam v4 lifestyle image showing outdoor security with phone app">
Wyze Cam v4 outdoor security with app control
Wyze Cam v4 is perfect for users who want high-resolution video, smart spotlight features, and robust local storage for continuous recording.
Wyze Cam Floodlight v2: Bright 2800 Lumens with 2K Video & AI Light Control
If you want to combine powerful lighting with security, the Wyze Cam Floodlight v2 is a top choice. It offers a bright 2800 lumens LED floodlight paired with a 2K camera and AI-powered light control for superior outdoor protection.
Features:
  • 2800 Lumens Brightness: Two dimmable LED panels provide clear illumination for large outdoor areas.
  • 2K Video with Color Night Vision: Capture sharp, colorful footage day and night.
  • 160° Wide-Angle View: Covers a broad field of view to monitor wide spaces.
  • AI-Powered Light Control: Automatically adjusts lighting based on motion and ambient light.
  • Dusk-to-Dawn Automation: Lights turn on and off automatically with natural light changes.
  • IP65 Weather Resistance: Durable for all weather conditions.
  • Two-Way Audio & 105dB Siren: Communicate and deter intruders effectively.
  • Supports up to 256GB microSD Cards: Local storage for continuous or event-based recording.
<img src="https://www.wyze.com/cdn/shop/files/WyzeCamFloodlightv2Main-08.jpg?v=1743789457&width=1946" alt="Wyze Cam Floodlight v2 illuminating driveway at night">
Wyze Cam Floodlight v2 bright outdoor security
This floodlight camera is ideal for users who want a combination of bright security lighting and high-quality video with ample local storage.
Why Choose a 128GB Storage Option?
All these Wyze outdoor cameras support microSD cards up to 256GB, with 128GB being a popular choice for balancing storage capacity and cost. A 128GB card can store days to weeks of continuous or event-triggered footage, ensuring you have a comprehensive record of your outdoor environment without relying solely on cloud subscriptions.
Summary of Top Automatic Motion Tracking Outdoor Cameras with 128GB Storage
Camera ModelResolutionMotion TrackingNight VisionStorage SupportWeather ResistanceSpecial Features
Wyze Cam Pan v31080pYesColor Night VisionUp to 256GB microSDIP65360° Pan & 180° Tilt, Privacy Mode
Wyze Cam v42.5K QHDAI Auto-ZoomEnhanced Color NVUp to 256GB microSDIP65Spotlight, Siren, Wi-Fi 6 Support
Wyze Cam Floodlight v22KMotion-ActivatedColor Night VisionUp to 256GB microSDIP652800 Lumens Floodlight, AI Light
Investing in any of these Wyze outdoor cameras with 128GB storage ensures you get automatic motion tracking, weatherproof durability, and local video storage to keep your home safe and monitored around the clock.
Product Highlights
Secure your home with Wyze’s advanced outdoor cameras featuring automatic motion tracking and 128GB local storage — the perfect combination for smart, reliable, and weatherproof home security.
FeatureWyze Cam Pan v3Wyze Cam v4Wyze Cam Floodlight v2
TypeIndoor/Outdoor Pan & Tilt CameraIndoor/Outdoor Wired CameraOutdoor Floodlight Camera
Resolution1080p HD2.5K QHD (2560x1440)2K (2304 x 1296)
Field of View360° Pan, 180° Tilt115.9° (D) x 98.5° (H) x 53.1° (V)160° Diagonal
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionColor Night Vision
Weather ResistanceIP65 (requires Outdoor Power Adapter sold separately for outdoor use)IP65IP65
AudioTwo-Way AudioEnhanced Two-Way TalkTwo-Way Audio
SpotlightNo (sold separately)Motion-activated SpotlightBuilt-in LED Floodlight (2800 Lumens)
SirenNo99 dB Siren105 dB Siren
Motion TrackingAutomatic Motion TrackingAuto-Zoom with AI Smart FocusAI-Powered Light Control
StoragemicroSD support up to 256GBmicroSD support up to 256GB (local), cloud optionalmicroSD support up to 256GB
ConnectivityWired (requires power adapter)Wired, Wi-Fi 6 support802.11 b/g/n 2.4 GHz Wi-Fi
Power SourceWired (Outdoor Power Adapter sold separately)WiredHardwired 110-120V AC
Mounting OptionsIndoor/Outdoor mountingStand, Wall, Ceiling, Magnetic MountWall or Ceiling Mount
DimensionsNot specified2in x 2in x 2 3/8in9.5in x 7.7in x 7.0in
WeightNot specified0.49 lb (222 g)2.76 lbs (1.25 kg)
Additional FeaturesPrivacy Mode, Pan Scan™ Patrol, Custom Detection Zones, Smoke & CO AlertsMotion-activated spotlight, Smoke & CO Alerts, Alexa/Google/IFTTT integrationDimmable LED panels, Ambient Light Mode, Dusk-to-Dawn Automation, Alexa/Google/IFTTT integration
Price (Single Pack)$39.98$35.98$89.98
What are the best Wyze outdoor cameras with automatic motion tracking and 128GB storage?The top Wyze outdoor cameras with automatic motion tracking and support for 128GB storage include the Wyze Cam Pan v3, Wyze Cam v4, and Wyze Cam Floodlight v2. These models offer advanced motion tracking, weather resistance, and local storage options for reliable home security.
Does Wyze Cam Pan v3 support automatic motion tracking outdoors?Yes, the Wyze Cam Pan v3 features automatic motion tracking and is designed for both indoor and outdoor use. When paired with the Wyze Outdoor Power Adapter, it is fully IP65 weather-resistant, making it ideal for outdoor monitoring.
How much local storage do Wyze outdoor cameras support?Wyze outdoor cameras, including the Cam Pan v3, Cam v4, and Floodlight v2, support microSD cards up to 256GB. A 128GB microSD card is a popular choice, providing days to weeks of continuous or event-based recording.
What are the benefits of using a 128GB microSD card with Wyze outdoor cameras?A 128GB microSD card allows you to store extensive footage locally, offering a balance between storage capacity and cost. It enables continuous or event-triggered recording for days or weeks, ensuring you have a comprehensive record without relying solely on cloud storage.
Is the Wyze Cam v4 suitable for outdoor use and does it have motion tracking?Yes, the Wyze Cam v4 is IP65 weather-resistant and designed for outdoor use. It features AI-powered auto-zoom and motion tracking, along with 2.5K QHD resolution and enhanced color night vision for clear, detailed footage.
What special features does the Wyze Cam Floodlight v2 offer for outdoor security?The Wyze Cam Floodlight v2 combines a 2K camera with a powerful 2800 lumens LED floodlight, AI-powered light control, dusk-to-dawn automation, two-way audio, and a 105dB siren. It also supports up to 256GB microSD cards for local storage.
Are Wyze outdoor cameras weatherproof?Yes, all featured Wyze outdoor cameras, including the Cam Pan v3, Cam v4, and Floodlight v2, are IP65 weather-resistant. They are built to withstand rain, snow, and harsh outdoor conditions.
Can I use Wyze outdoor cameras without a cloud subscription?Absolutely. Wyze outdoor cameras support local storage via microSD cards (up to 256GB), allowing you to record and access footage without a cloud subscription.
Do Wyze outdoor cameras have night vision?Yes, all the highlighted Wyze outdoor cameras feature color night vision. The Cam Pan v3 and Cam v4 use advanced sensors for vibrant color footage in low light, while the Floodlight v2 offers 2K video with color night vision.
What smart home integrations are available with Wyze outdoor cameras?Wyze outdoor cameras, such as the Cam v4, are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home ecosystem.
What are the key features of the Wyze Cam Pan v3?Can you tell me more about the weather resistance of the Wyze outdoor cameras?Are there any ongoing promotions or discounts for the Wyze outdoor cameras?
