Wyze Doorbell Cameras: Free Cloud Storage Trial & Smart Security
Wyze Doorbell Cameras with Free Cloud Storage Trial
Looking for a reliable doorbell camera that offers a free trial of cloud storage plans? Wyze provides some of the best smart video doorbells on the market, combining high-resolution video, two-way audio, and smart home integration. Whether you want a standalone doorbell or a complete front porch security bundle, Wyze has you covered with options like the Wyze Video Doorbell v2 and the Front Porch Security Bundle.
Wyze Video Doorbell v2: Clear 2K Video and Smart Features
The Wyze Video Doorbell v2 is Wyze’s clearest and most capable wired video doorbell yet, designed to keep your home safe with detailed 2K video resolution (2048 x 1536). It offers:
  • 2K Video Resolution: Capture every visitor in crisp detail with a 135° horizontal and 166.8° diagonal field of view.
  • Local and Cloud Storage: Store footage locally on a microSD card (up to 256GB) or opt for cloud storage with Wyze’s Security Plan, which includes a free trial.
  • Two-Way Audio: Speak to visitors or delivery personnel in real-time with noise and echo cancellation.
  • Motion-Activated Voice Deterrence: Automatically warn off unwanted guests with a built-in voice deterrent.
  • Weather Resistant: Rated IP65, it withstands harsh weather conditions from -4°F to 122°F.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
The package includes the doorbell, chime controller, installation kit, and mounting accessories, making setup straightforward.
The Front Porch Security Bundle: Complete Smart Home Protection
For those wanting an all-in-one solution, the Front Porch Security Bundle combines the Wyze Video Doorbell and Chime with the Wyze Lock, offering:
  • 1080p HD Video Doorbell: View your front porch clearly with 1080p resolution and a 120° vertical by 88° horizontal field of view.
  • Remote Lock Control: Lock or unlock your door remotely and monitor lock history via the Wyze app.
  • Two-Way Audio: Communicate with visitors through the doorbell’s built-in speaker and microphone.
  • Multiple Chime Sounds: Choose from modern, classic, animal, automation, or intruder alarm sounds.
  • End-to-End Data Security: Featuring AES 128-bit encryption and HTTPS secure transfer protocols.
  • Smart Assistant Compatibility: Works with Alexa and Google Assistant for voice commands.
This bundle is perfect for enhancing your front porch security with integrated video and smart lock control, all manageable from your smartphone.
Why Choose Wyze Doorbell Cameras?
Wyze doorbell cameras stand out by offering high-quality video, smart features, and flexible storage options including a free trial of cloud storage plans. Their affordable pricing and easy installation make them a top choice for smart home security.
  • Free Cloud Storage Trial: Try Wyze’s cloud storage plans risk-free to keep your footage safe and accessible anytime.
  • Smart Alerts: Receive real-time notifications on your phone when motion or visitors are detected.
  • Wide Compatibility: Supports Android 9.0+ and iOS 15.0+ devices.
  • Durability: Built to withstand outdoor elements with IP65 weather resistance.
Enhance Your Home Security with Wyze
Wyze’s doorbell cameras are part of a broader ecosystem of smart cameras and devices designed to keep your home safe and connected. Whether you want a simple doorbell camera or a full front porch security system, Wyze offers reliable, feature-rich options with free cloud storage trials to get you started.
Wyze Cam Pan v3 in Winter Outdoor Setting Wyze Cam Pan v3 providing weather-resistant outdoor security
Product Highlights Summary
FeatureWyze Video Doorbell v2Front Porch Security Bundle
Video Resolution2K (2048 x 1536)1080p HD
Field of View135° horizontal, 166.8° diagonal120° vertical x 88° horizontal
Two-Way AudioYes, with noise/echo cancellationYes, with noise/echo cancellation
Storage OptionsLocal microSD + Cloud (free trial)Cloud + Local (via doorbell)
Weather ResistanceIP65IP65
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Additional FeaturesMotion-activated voice deterrenceRemote lock control, multiple chime sounds
Conclusion
For anyone searching for a doorbell camera with a free trial of cloud storage plans, the Wyze Video Doorbell v2 and the Front Porch Security Bundle are excellent choices. They combine high-quality video, smart features, and flexible storage options to provide peace of mind and convenience for your home security needs.
FeatureWyze Video Doorbell v2The Front Porch Security Bundle
Included DevicesWyze Video Doorbell v2 (Doorbell + Chime Controller)Wyze Video Doorbell and Chime, Wyze Lock (varies by variant)
Video Resolution2K (2048 x 1536)1080p HD (Video Doorbell and Chime)
Local StoragemicroSD card slot for 24/7 local recordingNot specified (depends on included devices)
Two-Way AudioYesYes (Video Doorbell and Chime)
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect subscription)Not specified
Pre-roll Motion Recording3-6 secondsNot specified
Weather ResistanceIP65Not specified
Works with Existing ChimeYes, includes chime controllerYes (Video Doorbell and Chime)
Smart Lock IncludedNoYes (Wyze Lock or Wyze Lock Bolt depending on variant)
Lock/Unlock RemotelyNoYes (via Wyze Lock in bundle)
Lock History ViewingNoYes (via Wyze Lock in bundle)
Video Doorbell Resolution2K1080p HD
Price Range$44.98 (Doorbell + Chime Controller)$123.99 - $173.97 (depending on variant)
Cloud Storage SubscriptionOptional Cam Plus (free 30 days, then $2.99/mo)Optional Cam Plus (same terms)
Alexa & Google Home IntegrationYesYes (Video Doorbell and Lock)
Additional Cameras IncludedNoOptional Wyze Cam V3 in some variants
Fingerprint Sensor LockNoYes (Wyze Lock Bolt variants)
Auto-lock FeatureNoYes (Wyze Lock Bolt variants)
WarrantyStandard Wyze warrantyStandard Wyze warranty
What Wyze doorbell cameras offer a free cloud storage trial?Wyze offers a free trial of cloud storage plans with its doorbell cameras, including the Wyze Video Doorbell v2 and the Front Porch Security Bundle. This allows you to securely store and access your video footage online during the trial period.
What are the main features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features 2K video resolution (2048 x 1536), a 135° horizontal and 166.8° diagonal field of view, two-way audio with noise and echo cancellation, motion-activated voice deterrence, IP65 weather resistance, and smart home integration with Alexa, Google Assistant, and IFTTT. It supports both local microSD card storage and cloud storage with a free trial.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a 1080p HD video doorbell, a chime, and the Wyze Lock. It offers remote lock control, two-way audio, multiple chime sounds, end-to-end data security with AES 128-bit encryption, and compatibility with Alexa and Google Assistant.
Can Wyze doorbell cameras store footage locally?Yes, Wyze doorbell cameras like the Wyze Video Doorbell v2 support local storage via a microSD card (up to 256GB), allowing you to save video footage directly on the device in addition to cloud storage options.
Are Wyze doorbell cameras weather resistant?Yes, Wyze doorbell cameras are rated IP65 for weather resistance, making them suitable for outdoor use in temperatures ranging from -4°F to 122°F and able to withstand harsh weather conditions.
Do Wyze doorbell cameras support smart home integration?Wyze doorbell cameras are compatible with popular smart home platforms, including Alexa, Google Assistant, and IFTTT, enabling voice control and automation within your smart home ecosystem.
What devices are compatible with Wyze doorbell cameras?Wyze doorbell cameras support Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher, ensuring wide compatibility with most smartphones and tablets.
How does two-way audio work on Wyze doorbell cameras?Wyze doorbell cameras feature built-in two-way audio with noise and echo cancellation, allowing you to communicate clearly with visitors or delivery personnel in real-time through the Wyze app.
What security features do Wyze doorbell cameras offer?Wyze doorbell cameras provide end-to-end data security with AES 128-bit encryption and HTTPS secure transfer protocols, ensuring your video footage and personal data remain protected.
How do I receive alerts from my Wyze doorbell camera?Wyze doorbell cameras send real-time smart alerts and notifications to your smartphone whenever motion is detected or a visitor arrives, helping you stay informed about activity at your front door.
What features does the Wyze Video Doorbell v2 offer?Can you tell me more about the Front Porch Security Bundle?Are there any ongoing promotions or discounts for Wyze products?
