Wyze Cam Pan v3: The Ultimate Cloud-Enabled Security Camera
The
Wyze Cam Pan v3 is a cutting-edge indoor/outdoor security camera designed for comprehensive home and business surveillance. With its cloud-enabled video storage, you can quickly reference video clips anytime, ensuring you never miss a moment. This camera offers a 360° horizontal pan and 180° vertical tilt, providing full coverage of your space with smooth, fast rotation up to 110° per second.
Experience peace of mind with a camera that adapts to your environment — whether indoors or outdoors — thanks to its IP65 weather resistance rating.
Wyze Cam Pan v3 weather resistant outdoor camera
Key Features and Specifications
- Video Quality: Full HD 1080p resolution with H.264 encoding ensures crisp, clear footage day and night.
- Field of View: 120° wide-angle lens combined with 360° horizontal and 180° vertical rotation covers every corner.
- Night Vision: Equipped with 4 IR LEDs (850 nm) for clear black-and-white night vision, plus color night vision in the Cam Plus bundle.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation allow seamless communication.
- Storage Options: Supports up to 256 GB microSD card for local storage and offers cloud storage for quick video clip reference.
- Connectivity: Compatible with 2.4 GHz Wi-Fi networks (802.11 b/g/n), supporting Android 9.0+ and iOS 15.0+ devices.
- Durability: Polycarbonate body with IP65 rating withstands rain, snow, and dust for reliable outdoor use.
- Smart Integrations: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Alerts: Instant push notifications keep you informed of motion or sound events.
Dimensions and Design
- Size: 124mm (H) x 60mm (W) x 63mm (D)
- Weight: 11.29 oz (320 g)
- Finish: Matte in Black or White
- Mounting: Standard 1/4" - 20 screw mount with a compact circular base
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Cloud Storage and Features
For users seeking an all-in-one solution with cloud convenience, the
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle is the perfect choice. This bundle includes the same robust Pan v3 camera with added benefits:
- Color Night Vision: See more detail in low-light conditions with enhanced color night vision.
- Cloud Storage: 30 days of continuous cloud video storage for quick and easy access to recorded clips.
- Included Accessories: Comes with a power adapter, 6' micro USB cable, mounting kit, and quick start guide for hassle-free setup.
This bundle is ideal for those who want to maximize their security system with cloud backup and advanced features without additional purchases.
Stay connected with two-way audio, perfect for pet monitoring
Additional Accessories for Wyze Cam Pan v3
Wyze Cam Pan v3 Skins by dBrand
Customize and protect your Wyze Cam Pan v3 with stylish vinyl skins available in Green Camo and Triple Black. These precision-cut skins prevent scratches and give your camera a unique look without compromising functionality.
- Easy to apply with included instructions
- Durable protection for everyday use
Wyze Cam Pan v3 USB Cable
Keep your camera powered with an official replacement USB cable designed specifically for the Pan v3. Affordable and reliable, this cable ensures your camera stays connected without interruption.
Pan v3 + Lamp Socket v2 Bundle
Power your Wyze Cam Pan v3 without needing a traditional outlet by using the Lamp Socket v2. This accessory fits standard E26 sockets and supports CFL or LED bulbs under 20W, making it perfect for smart exterior lighting setups.
Why Choose Wyze Cam Pan v3 for Cloud-Enabled Video Storage?
The Wyze Cam Pan v3 stands out as a versatile, reliable security camera that combines advanced hardware with cloud-enabled convenience. Whether you want to monitor your home, keep an eye on pets, or secure your outdoor spaces, this camera offers:
- Seamless cloud video clip storage for quick reference and peace of mind
- Wide coverage with pan and tilt capabilities
- Durable weatherproof design for all-season use
- Smart home integration for effortless control
Invest in the Wyze Cam Pan v3 or the Cam Plus bundle today to elevate your security system with cloud-enabled video storage and smart features.
What is the Wyze Cam Pan v3?
The Wyze Cam Pan v3 is a cloud-enabled indoor/outdoor security camera designed for comprehensive home and business surveillance. It features 360° horizontal pan, 180° vertical tilt, and offers both local and cloud video storage options.Is the Wyze Cam Pan v3 weatherproof for outdoor use?
Yes, the Wyze Cam Pan v3 has an IP65 weather resistance rating, making it suitable for both indoor and outdoor use. It is designed to withstand rain, snow, and dust.What video quality does the Wyze Cam Pan v3 offer?
The Wyze Cam Pan v3 provides Full HD 1080p resolution with H.264 encoding, ensuring crisp and clear footage both day and night.Does the Wyze Cam Pan v3 have night vision?
Yes, the Wyze Cam Pan v3 is equipped with 4 IR LEDs for black-and-white night vision. With the Cam Plus bundle, you also get enhanced color night vision for better detail in low-light conditions.What storage options are available for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 supports up to a 256 GB microSD card for local storage and offers cloud storage for quick video clip reference. The Cam Plus bundle includes 30 days of continuous cloud video storage.Can I use the Wyze Cam Pan v3 with smart home devices?
Yes, the Wyze Cam Pan v3 works with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The bundle includes the Wyze Cam Pan v3 camera, 30 days of continuous cloud video storage, color night vision, a power adapter, a 6' micro USB cable, a mounting kit, and a quick start guide.Does the Wyze Cam Pan v3 support two-way audio?
Yes, the Wyze Cam Pan v3 features built-in two-way audio with noise and echo cancellation, allowing you to communicate seamlessly through the camera.What accessories are available for the Wyze Cam Pan v3?
Available accessories include Wyze Cam Pan v3 Skins by dBrand for customization and protection, an official replacement USB cable, and the Pan v3 + Lamp Socket v2 Bundle for powering the camera via standard E26 lamp sockets.What are the dimensions and design features of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 measures 124mm (H) x 60mm (W) x 63mm (D), weighs 11.29 oz (320 g), and comes in a matte black or white finish. It features a standard 1/4" - 20 screw mount with a compact circular base.What type of Wi-Fi does the Wyze Cam Pan v3 support?
The Wyze Cam Pan v3 is compatible with 2.4 GHz Wi-Fi networks (802.11 b/g/n) and supports Android 9.0+ and iOS 15.0+ devices.How does the Wyze Cam Pan v3 provide security alerts?
The Wyze Cam Pan v3 sends instant push notifications to your device when it detects motion or sound events, keeping you informed in real time.
