Wyze Battery Cam Pro: Homeowner-Friendly Wireless Security with Cloud Storage
For homeowners seeking a reliable, wireless security camera that stores clips securely in the cloud, the
Wyze Battery Cam Pro stands out as an excellent choice. This camera offers 2.5K HDR video resolution, ensuring crystal-clear footage day and night. With no hub required, it’s easy to install and operate, making it perfect for any homeowner.
Key Features of Wyze Battery Cam Pro
- 2.5K HDR Video Resolution: Capture sharp, detailed video at 2560 x 1440 pixels.
- Wire-Free & No Hub Needed: Completely wireless with removable, rechargeable 6200mAh battery packs lasting up to 6 months on a single charge.
- Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security and deter intruders.
- Radar + PIR Motion Detection: Advanced motion sensors reduce false alerts by detecting human presence accurately.
- Weatherproof Design: IP65 rating means it withstands rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F).
- Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for stable streaming.
- Local & Cloud Storage: Supports up to 256 GB microSD cards for local recording and offers cloud storage options with Cam Plus subscription.
- Two-Way Audio: Communicate through the built-in speaker and microphone.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Available in black or white, the Wyze Battery Cam Pro is compact (2.5 x 1.8 x 3.5 inches) and lightweight (0.94 lbs), with a matte finish that blends seamlessly into any home exterior.
“The Wyze Battery Cam Pro offers a perfect balance of high-quality video, smart features, and homeowner-friendly wireless convenience.”
Secure your home effortlessly with Wyze Battery Cam Pro.
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Ultimate Convenience
For homeowners who want to eliminate the hassle of recharging batteries, the
Wyze Battery Cam Pro + Solar Panel bundle is an ideal solution. It combines all the features of the Wyze Battery Cam Pro with a solar panel that keeps the camera powered continuously using renewable energy.
Highlights of the Solar-Powered Bundle
- Same 2.5K HDR Video Quality: Enjoy the same sharp, clear video resolution.
- Solar Panel Included: The solar panel charges the removable battery packs, reducing maintenance and ensuring your camera stays online longer.
- Color Night Vision: Enhanced night vision with white LEDs for full-color video even in low light.
- Radar + PIR Motion Detection: Smart motion sensing to minimize false alarms.
- Weatherproof & Durable: Both camera and solar panel are IP65 rated for outdoor use.
- Cloud Storage with Cam Plus: Securely store and access your clips in the cloud.
- Easy Installation: Wire-free setup with included wall mount.
This bundle is perfect for homeowners looking for a sustainable, low-maintenance security solution that keeps your property monitored 24/7 without worrying about battery life.
Bird Feeder Wireless Camera Bundle: Security Meets Nature Watching
If you want to combine home security with a touch of nature, the
Bird Feeder Wireless Camera Bundle is a unique offering that includes the Wyze Battery Cam Pro, a Wyze Bird Feeder, and a Wyze Solar Panel.
Why Choose the Bird Feeder Bundle?
- Watch Wildlife & Secure Your Home: The vibrant bird feeder attracts feathered visitors while the Wyze Battery Cam Pro monitors your property.
- Weather-Resistant & Wire-Free: All components are designed for outdoor use with IP65 weatherproofing.
- Macro Lens Adapter: Capture detailed close-ups of birds and surroundings.
- Live Streaming: View live video of your bird feeder and yard through the Wyze app.
- Solar Panel Power: Keeps the camera charged for continuous operation.
This bundle is perfect for homeowners who want to enjoy birdwatching while maintaining a secure home environment.
Why Choose Wyze Cameras for Home Security?
Wyze cameras, especially the Battery Cam Pro series, are designed with homeowners in mind. They offer:
- Easy Installation: No wiring or hubs needed.
- High-Quality Video: 2.5K resolution with HDR and color night vision.
- Smart Features: Motion detection, two-way audio, sirens, and smart home compatibility.
- Flexible Power Options: Rechargeable batteries with optional solar charging.
- Secure Cloud Storage: Keep your footage safe and accessible anytime with Cam Plus.
These features make Wyze Battery Cam Pro an excellent choice for anyone looking to enhance their home security with a user-friendly, reliable, and smart camera system.
Brighten and secure your home with smart lighting and cameras.
Summary of Wyze Battery Cam Pro Specs
Feature | Specification |
Video Resolution | 2560 x 1440 (2.5K HDR) |
Video Encoding | H.264 |
Wireless | Yes, 2.4 & 5 GHz WiFi |
Power Source | Removable, rechargeable 6200mAh battery |
Battery Life | Up to 6 months |
Charging Time | ~9 hours |
Weather Resistance | IP65 |
Operating Temperature | -20°C to 50°C (-4°F to 122°F) |
Local Storage | Up to 256 GB microSD card |
Cloud Storage | Supported with Cam Plus subscription |
Field of View | 134° diagonal |
Night Vision | 2 IR LEDs + 2 White LEDs |
Audio | Two-way with built-in speaker & mic |
Siren | 100 dB |
Smart Home Integration | Alexa, Google Assistant, IFTTT |
Enhance your home security today with the
Wyze Battery Cam Pro and its versatile bundles — the perfect homeowner-friendly cameras that combine wireless convenience, cloud storage, and smart features.
What is the video resolution of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features a 2.5K HDR video resolution (2560 x 1440 pixels), providing sharp and detailed footage both day and night.Is the Wyze Battery Cam Pro completely wireless?
Yes, the Wyze Battery Cam Pro is a wire-free security camera that operates on removable, rechargeable 6200mAh battery packs, lasting up to 6 months on a single charge.Does the Wyze Battery Cam Pro require a hub for installation?
No, the Wyze Battery Cam Pro does not require a hub. It is easy to install and operate, making it ideal for homeowners.How does the Wyze Battery Cam Pro detect motion?
The Wyze Battery Cam Pro uses advanced radar and PIR (Passive Infrared) motion detection to accurately identify human presence and reduce false alerts.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, allowing it to withstand rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F).What storage options are available for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro supports local storage with up to a 256 GB microSD card and offers secure cloud storage through a Cam Plus subscription.Can I use the Wyze Battery Cam Pro with Alexa or Google Assistant?
Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT for voice control and smart home automation.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the camera and a solar panel that continuously charges the battery packs, providing sustainable, low-maintenance power.Does the Wyze Battery Cam Pro offer color night vision?
Yes, the Wyze Battery Cam Pro features color night vision with white LEDs, allowing you to capture full-color video even in low-light conditions.What is the Bird Feeder Wireless Camera Bundle?
The Bird Feeder Wireless Camera Bundle includes the Wyze Battery Cam Pro, a Wyze Bird Feeder, and a Wyze Solar Panel, allowing you to monitor your property and enjoy birdwatching with live streaming and macro lens close-ups.How long does it take to fully charge the Wyze Battery Cam Pro?
It takes approximately 9 hours to fully charge the Wyze Battery Cam Pro’s 6200mAh battery pack.What is the field of view of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers a 134° diagonal field of view, providing wide coverage for your home security needs.Does the Wyze Battery Cam Pro have two-way audio?
Yes, the Wyze Battery Cam Pro is equipped with two-way audio, allowing you to communicate through the built-in speaker and microphone.What smart security features does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro includes a built-in spotlight, a 100 dB siren, radar + PIR motion detection, two-way audio, and smart home integration for enhanced security.What are the main benefits of choosing Wyze cameras for home security?
Wyze cameras offer easy installation, high-quality 2.5K HDR video, smart features like motion detection and two-way audio, flexible power options including solar charging, and secure cloud storage with Cam Plus.
