Cuttable Indoor LED Strip with Multi-Color Zones | Wyze Light Strip
Cuttable LED Strip for Indoor Installation with Multiple Color Zones
If you're looking to brighten up your indoor spaces with customizable, vibrant lighting, cuttable LED strips with multiple color zones are the perfect solution. These LED strips allow you to tailor the length to your space and create dynamic lighting effects with a spectrum of colors. Among the top options available, the Wyze Light Strip stands out as an excellent choice for indoor use, offering cuttable flexibility and rich color customization.
Wyze Light Strip: Brilliant, Cuttable, and Colorful
Key Features and Specifications
  • Cuttable Design: Easily trim the Wyze Light Strip to fit your desired length, making it perfect for custom indoor installations such as under cabinets, behind TVs, or along shelves.
  • Multiple Color Zones: While this model supports a single customizable color zone, it offers access to 16 million colors, allowing you to create the perfect ambiance for any room.
  • Length Options: Available in 16.4 feet and 32.8 feet variants, providing flexibility depending on your project size.
  • Indoor Use Only: Designed specifically for indoor environments, ensuring optimal performance and safety.
  • Power and Connectivity: Powered by a 12V adapter with 100-240V input, it connects via 2.4 GHz Wi-Fi and Bluetooth for seamless smart control.
  • Brightness: Features LEDs with varying lumens per meter (Blue: 0.8 lm, Red: 1.0 lm, Green: 2.5 lm), delivering vibrant and balanced lighting.
  • Long Lifespan: Rated for 25,000 hours of use, ensuring years of reliable illumination.
  • Easy Installation: Comes with adhesive backing and includes adhesive clips for secure mounting on various surfaces.
  • Smart Features: Includes a built-in microphone for music sync, allowing the lights to pulse and change with your favorite tunes.
What’s in the Box?
  • Wyze Light Strip
  • Controller
  • Power Adapter
  • Adhesive Clips (x10)
  • Quick Start Guide
  • Alcohol Wipes (x2)
The Wyze Light Strip is perfect for those who want a customizable, cuttable LED strip that can transform any indoor space with millions of colors and smart features.
Wyze Light Strip in Kitchen Alt text: Wyze Light Strip installed under kitchen cabinets creating colorful ambient lighting
Why Choose a Cuttable LED Strip for Indoor Use?
Cuttable LED strips provide unmatched flexibility for indoor lighting projects. Whether you want to highlight architectural features, add mood lighting to your living room, or create a vibrant gaming setup, these strips can be tailored to fit any space perfectly. The Wyze Light Strip’s adhesive backing and included clips make installation quick and hassle-free, while its smart connectivity allows you to control colors and brightness from your phone or voice assistant.
Complementary Accessories for Your LED Setup
While the Wyze Light Strip is the centerpiece for indoor color zone lighting, pairing it with reliable power accessories ensures a smooth experience.
Wyze Surge Protector
  • Power for Your Devices: Features 3 USB ports and 3 grounded outlets to power your LED strips and other smart home devices.
  • Safety First: Includes surge protection with a 268-joule suppression rating and 15A overload protection.
  • Compact and Practical: Slim design with a right-angle flat plug and non-slip rubber pads for stable placement.
  • Certifications: UL and FCC certified for peace of mind.
This surge protector is ideal for powering your LED strips safely and efficiently, especially when multiple devices are involved.
Summary
For indoor installations requiring cuttable LED strips with multiple color zones, the Wyze Light Strip offers an outstanding combination of flexibility, vibrant color options, and smart home integration. Its easy installation and long lifespan make it a top choice for enhancing your indoor ambiance. Pair it with the Wyze Surge Protector to ensure your setup is powered safely and conveniently.
Wyze Plug-in Cam Lifestyle Alt text: Modern home interior with smart lighting and security camera
FeatureWyze Light StripWyze Surge Protector
TypeConnected Home - LED Accent LightingAccessories - Power Strip with Surge Protection
Price$19.99 (16.4 ft, sold out), $35.99 (32.8 ft, sold out)$4.99 (Default)
Length/Size16.4 Feet or 32.8 FeetNot applicable
Outlets/PortsNot applicable3 USB ports, 3 grounded outlets
Colors16 million colorsNot applicable
FeaturesMusic Mode with built-in microphone, Sun Match, Voice Control, Vacation Mode, Sleep Routines, Timers & AutomationsSurge protection, multiple outlets and USB ports
InstallationPeel, stick, and plug in anywherePlug-in power strip
ConnectivityVoice control via Alexa, Google AssistantNot specified
Return Policy30-day hassle-free returns30-day hassle-free returns
WarrantyNot specifiedNot specified
What is a cuttable LED strip and how does it benefit indoor lighting?A cuttable LED strip is a flexible lighting solution that can be trimmed to your desired length, making it ideal for custom indoor installations. This allows you to fit the strip perfectly under cabinets, behind TVs, or along shelves, providing tailored and vibrant lighting for any space.
What are the key features of the Wyze Light Strip for indoor use?The Wyze Light Strip offers a cuttable design, supports a single customizable color zone with access to 16 million colors, comes in 16.4 ft and 32.8 ft lengths, is designed for indoor use, and features smart connectivity via Wi-Fi and Bluetooth. It also includes a built-in microphone for music sync, adhesive backing for easy installation, and a long lifespan of 25,000 hours.
Can the Wyze Light Strip be used outdoors?No, the Wyze Light Strip is designed specifically for indoor use to ensure optimal performance and safety.
How do I install the Wyze Light Strip?The Wyze Light Strip is easy to install with its adhesive backing and included adhesive clips. Simply clean the surface, stick the strip in place, and secure it with the clips for a hassle-free setup.
What is included in the Wyze Light Strip package?The Wyze Light Strip package includes the LED strip, a controller, a power adapter, 10 adhesive clips, a quick start guide, and 2 alcohol wipes for surface preparation.
How many color zones does the Wyze Light Strip support?The Wyze Light Strip supports a single customizable color zone, allowing you to choose from 16 million colors to create the perfect ambiance.
What are the available length options for the Wyze Light Strip?The Wyze Light Strip is available in two length options: 16.4 feet and 32.8 feet, providing flexibility for different indoor projects.
How is the Wyze Light Strip powered and controlled?The Wyze Light Strip is powered by a 12V adapter with 100-240V input and connects via 2.4 GHz Wi-Fi and Bluetooth. You can control it using your smartphone or compatible voice assistants.
Does the Wyze Light Strip have music sync capabilities?Yes, the Wyze Light Strip features a built-in microphone that allows the lights to pulse and change colors in sync with your favorite music.
What is the lifespan of the Wyze Light Strip?The Wyze Light Strip is rated for 25,000 hours of use, ensuring years of reliable and vibrant indoor lighting.
What accessories are recommended for powering the Wyze Light Strip?The Wyze Surge Protector is recommended for powering your Wyze Light Strip and other smart home devices. It features 3 USB ports, 3 grounded outlets, surge protection, and a compact design for safe and efficient power management.
Is the Wyze Surge Protector safe to use with LED strips?Yes, the Wyze Surge Protector is UL and FCC certified, offers 268-joule surge suppression, and 15A overload protection, making it a safe and reliable choice for powering LED strips and other devices.
What are the installation requirements for the Wyze Light Strip?Can the Wyze Light Strip be used outdoors?Is there a warranty for the Wyze Light Strip?
