Customized Air Filters for Homes Affected by Wildfire Smoke
When wildfire smoke invades your home, the air quality can deteriorate rapidly, posing serious health risks. Protect your family with
customized air filters designed specifically to combat wildfire smoke and other airborne pollutants. Wyze offers a range of smart air purifiers and specialized filters that adapt to your home's unique air quality needs, ensuring you breathe cleaner, safer air every day.
Wyze Air Filter: Tailored Filtration for Your Home
Why Customize Your Air Filter?
You don’t eat or drink the same as everyone else—so why breathe the same air? The
Wyze Air Filter lets you customize your air purification to target specific concerns such as wildfire smoke, allergens, pet odors, formaldehyde, and harmful gases. This flexibility is essential for homes affected by wildfire smoke, where particulate matter and toxic compounds can linger indoors.
Key Features
Filter Variants:
- Wildfire Filter (Special Use): Designed to capture fine particulate matter from wildfire smoke with a particulate matter CADR of 342 m³/h (201 CFM).
- Allergen Filter (Standard) and Formaldehyde Filter (Premium) also available for broader air quality needs.
- Advanced Filtration: Combines a pre-filter, True HEPA 12 or 13, and activated carbon to remove 97.1% of TVOCs (volatile organic compounds) and 99% of viruses and bacteria.
- Dimensions & Weight: Compact size (8.1" x 8.1" x 11.3") and lightweight (1.9 lb for wildfire filter) for easy placement anywhere in your home.
- Filter Life: Lasts 4 to 12 months depending on filter type and usage.
“Customize your air like you customize your burger. Well done! Hold the formaldehyde!” — Wyze
Wyze Air Purifier: Smart, Powerful, and Quiet
Designed for Large Spaces and Sensitive Lungs
The
Wyze Air Purifier is a connected home device that pairs perfectly with the customized filters, including the wildfire-specific filter. It’s ideal for medium to large rooms (450-550 sq ft), making it a great choice for living rooms, bedrooms, or home offices.
Standout Specifications
- Pre-installed Filter Options: Comes with Allergen, Formaldehyde, or Wildfire filters pre-installed.
- High CADR Ratings: Wildfire filter CADR at 342 m³/h (201 CFM), ensuring rapid removal of smoke particles.
- Quiet Operation: Runs as low as 20.8 dBA on the lowest setting, so it won’t disturb your daily life or sleep.
Smart Features:
- Laser particle sensor with 0.3-micron accuracy detects fine particles in real-time.
- Air quality alerts and smart home compatibility with Google Home and Alexa.
- Dimensions & Weight: 9.5" x 9.4" x 18.5", weighing around 9.32 lb with the wildfire filter.
- Energy Efficient: Rated power from 3.5 to 45W, suitable for continuous use.
A luxury air purifier without a luxury price tag, designed to clear the air and keep your home safe from wildfire smoke and other pollutants.
Alt text: Man holding Wyze Air Purifier in a bright living room
Wyze Air Filter Subscription: Hassle-Free Replacement Filters
Keep Your Air Purifier Performing at Its Best
To maintain optimal air quality, regular filter replacement is essential—especially when combating wildfire smoke. The
Wyze Air Filter Subscription service ensures you never run out of fresh filters tailored to your needs.
Subscription Benefits
- Filter Types Available: Allergen, Formaldehyde, and Wildfire filters.
- Consistent Quality: Each filter includes a pre-filter, True HEPA, and activated carbon layers for maximum pollutant removal.
- Convenient Delivery: Filters delivered on a schedule that matches your usage and filter life (4-12 months).
- Dimensions & Weight: Same as individual filters, ensuring perfect fit and performance.
Replacement filters designed to keep your Wyze Air Purifier running efficiently and your home air clean.
Alt text: Hand replacing filter in Wyze Air Purifier
Why Choose Wyze for Wildfire Smoke Air Filtration?
- Specialized Wildfire Filter: Specifically engineered to capture the fine particulate matter and harmful gases from wildfire smoke.
- Smart Home Integration: Monitor and control your air quality remotely via app, with real-time alerts.
- Affordable and Effective: High CADR ratings and advanced filtration technology at a price accessible to most households.
- Subscription Convenience: Never worry about forgetting to replace your filters with scheduled deliveries.
Protect your home and loved ones from the invisible dangers of wildfire smoke with Wyze’s customizable air filtration solutions.
Summary of Products for Wildfire Smoke Air Filtration
Product Name | Filter Type | CADR (Particulate Matter) | Price (USD) | Filter Life |
Wyze Air Filter | Wildfire Filter | 342 m³/h (201 CFM) | $63.99 | 4-12 months |
Wyze Air Purifier | Wildfire Filter | 342 m³/h (201 CFM) | $194.99 | 6 months |
Wyze Air Filter Subscription | Wildfire Filter | 342 m³/h (201 CFM) | $63.99 | 4-12 months |
Breathe easier and live healthier with Wyze’s customized air filters and smart purifiers designed to tackle wildfire smoke and improve your indoor air quality.
What makes Wyze air filters effective against wildfire smoke?
Wyze air filters are specifically engineered to capture fine particulate matter and harmful gases from wildfire smoke. The Wildfire Filter variant features a high Clean Air Delivery Rate (CADR) of 342 m³/h (201 CFM) and uses a combination of pre-filter, True HEPA 12 or 13, and activated carbon layers to remove up to 99% of viruses, bacteria, and 97.1% of volatile organic compounds (TVOCs).How do I choose the right Wyze air filter for my home?
Wyze offers customized air filters to target specific air quality concerns. For homes affected by wildfire smoke, the Wildfire Filter is recommended. Other options include the Allergen Filter for general allergens and the Formaldehyde Filter for chemical pollutants. You can select the filter that best matches your needs for optimal indoor air quality.What are the key features of the Wyze Air Purifier for wildfire smoke?
The Wyze Air Purifier is designed for medium to large rooms (450-550 sq ft) and pairs with specialized filters, including the Wildfire Filter. It features a high CADR of 342 m³/h, quiet operation as low as 20.8 dBA, a laser particle sensor with 0.3-micron accuracy, real-time air quality alerts, and smart home compatibility with Google Home and Alexa.How often should I replace my Wyze air filter when dealing with wildfire smoke?
Filter life depends on the type and usage, typically lasting between 4 to 12 months. For homes exposed to wildfire smoke, more frequent replacement may be necessary to maintain optimal air quality. Wyze offers a subscription service to ensure you always have fresh filters delivered on schedule.What is included in the Wyze Air Filter Subscription service?
The Wyze Air Filter Subscription provides hassle-free, scheduled delivery of replacement filters tailored to your needs. You can choose from Allergen, Formaldehyde, or Wildfire filters, all featuring pre-filter, True HEPA, and activated carbon layers. The subscription ensures consistent air quality and keeps your purifier running efficiently.Are Wyze air purifiers energy efficient?
Yes, Wyze air purifiers are energy efficient, with a rated power range from 3.5 to 45W. This makes them suitable for continuous use, even during extended periods of poor air quality caused by wildfire smoke.Can I control my Wyze Air Purifier with smart home devices?
Absolutely. The Wyze Air Purifier is compatible with Google Home and Alexa, allowing you to monitor and control your air quality remotely. It also provides real-time air quality alerts through the Wyze app.What are the dimensions and weight of the Wyze Air Purifier and filters?
The Wyze Air Purifier measures 9.5" x 9.4" x 18.5" and weighs approximately 9.32 lb with the wildfire filter installed. The Wildfire Filter itself is compact at 8.1" x 8.1" x 11.3" and weighs 1.9 lb, making it easy to place and replace in your home.How does the Wyze Air Purifier detect and respond to wildfire smoke indoors?
The Wyze Air Purifier uses a laser particle sensor with 0.3-micron accuracy to detect fine particles, including those from wildfire smoke, in real time. It automatically adjusts its operation based on detected air quality and sends alerts to your smartphone, ensuring your indoor air remains clean and safe.Why should I choose Wyze for wildfire smoke air filtration?
Wyze offers specialized wildfire filters, advanced smart features, high CADR ratings, and affordable pricing. With customizable filtration options, smart home integration, and a convenient subscription service, Wyze provides effective and accessible solutions to protect your home from wildfire smoke and other airborne pollutants.
