Cost-Effective Solar Power for Multiple Wyze Cameras
Cost-Effective Solar Power Solutions for Multiple Wyze Cameras
When looking to power multiple Wyze cameras using solar energy, understanding compatibility and the right accessories is crucial. Wyze offers a dedicated Wyze Solar Panel designed specifically to extend the battery life of certain Wyze cameras, making it a cost-effective and eco-friendly solution for outdoor surveillance.
Which Wyze Cameras Work with the Wyze Solar Panel?
Compatible Cameras
The Wyze Solar Panel is engineered to work seamlessly with: Wyze Cam Outdoor (v1 and v2) Wyze Battery Cam Pro These cameras benefit from the solar panel’s ability to keep them charged longer without the need for frequent manual recharging. The solar panel features IP65 weather resistance and dustproof design, ensuring durability in various outdoor conditions.
Note: The Wyze Battery Cam Pro requires an additional Wyze Solar Panel USB-C Adapter Cable (sold separately) to connect properly.
Incompatible Cameras
It is important to note that the Wyze Solar Panel does not support:
  • Wyze Cam OG (Original)
  • Wyze Cam OG Telephoto 3x
  • Wyze Cam v1, v2, v3, v3 Pro
  • Wyze Cam Pan (v1, v2, v3)
  • Wyze Doorbells
Attempting to use the solar panel with these models will not work and may void warranties.
Features of the Wyze Solar Panel
Durable and Flexible Installation
  • 360º Freestyle Mount: Allows you to position the solar panel optimally for maximum sunlight exposure.
  • 13-foot Weatherproof Power Cable: Provides flexibility in mounting locations.
  • Adjustable Angle: Easily tilt the panel up to 90° vertically and adjust side to side for best sun capture.
  • Weatherproof: Rated IP65, suitable for outdoor use in rain, dust, and other elements.
Efficient Charging
  • The solar panel charges the camera battery during daylight hours and automatically stops charging once the battery reaches 100%.
  • Charging resumes when the battery level drops below 90%, ensuring efficient power management.
  • Requires direct sunlight to function effectively; it does not charge at night or in heavy shade.
How to Power Multiple Wyze Cameras via Solar Arrays
Using Multiple Solar Panels
For powering multiple Wyze Cam Outdoor or Wyze Battery Cam Pro units, the most straightforward and cost-effective method is to use one Wyze Solar Panel per camera. Each panel is designed to maintain the battery of a single camera efficiently.
Considerations for Stacking Cameras
  • Wyze Cam OG Stack Kit: Allows stacking two Wyze Cam OG cameras (including Telephoto 3x) for a dual-camera system, but these cameras are not compatible with the Wyze Solar Panel.
  • For outdoor solar power, focus on Wyze Cam Outdoor or Battery Cam Pro models, as stacking or linking OG cameras does not support solar charging.
Installation Tips for Optimal Solar Charging
1. Choose a Sunny Location: Mount the solar panel where it receives the most direct sunlight throughout the day. 2. Angle the Panel Correctly: A 30° upward tilt is recommended for optimal sun exposure. 3. Orientation: Point the panel south if you are in the northern hemisphere, or north if in the southern hemisphere. 4. Secure Mounting: Use the included wall mount base, screws, and anchors to ensure the panel stays firmly in place. 5. Cable Management: Coil any excess cable behind the winding board on the back of the panel to keep the installation tidy.
Benefits of Using Wyze Solar Panels for Outdoor Cameras
  • Extended Battery Life: Reduces the need to manually recharge cameras frequently.
  • Eco-Friendly: Harnesses renewable solar energy to power your security system.
  • Weather Resistant: Designed to withstand outdoor conditions year-round.
  • Cost-Effective: Saves on electricity costs and reduces maintenance time.
Summary
For a cost-effective solar power solution to keep multiple Wyze cameras running outdoors, the Wyze Solar Panel paired with Wyze Cam Outdoor (v1/v2) or Wyze Battery Cam Pro is the best choice. While the Wyze Cam OG and other models do not support solar charging, the Outdoor and Battery Cam Pro models provide reliable, weatherproof, and efficient solar-powered surveillance.
Outdoor Solar Powered Wyze Cameras Harness the power of the sun to keep your Wyze cameras running longer without interruption.
Wyze Solar Panel Installation Easy installation with adjustable mounting for optimal sunlight exposure.
Multiple Wyze Cameras Secured Outdoors Secure multiple Wyze Cam Outdoor units powered efficiently by individual solar panels.
FeatureWyze Battery Cam ProWyze Solar Panel USB-C Adapter CableWyze Cam OGWyze Cam OG TelephotoWyze Cam OG Stack Kit
TypeCameraReplacement PartCameraCameraAccessory
Price$89.98 (1 Pack)$5.99$29.98 (1 Pack)$25.98 (1 Pack)$9.99
Video Resolution2560 x 1440 (2.5K HDR)N/A1920 x 1080 (1080p)1920 x 1080 (1080p)N/A
Field of View134° DFOV, 108° HFOV, 56° VFOVN/A121.4° DFOV, 102.3° HFOV, 54.1° VFOV27° DFOV, 23.6° HFOV, 13.6° VFOVN/A
Night Vision2 IR LEDs (850 nm), 2 White LEDs (187 lumens)N/A4 IR LEDs (850 nm)4 IR LEDs (850 nm)N/A
SpotlightIntegrated Spotlight (150 lumens)N/ABuilt-in Spotlight (40 lumens)Built-in Spotlight (40 lumens)N/A
Motion DetectionRadar + PIR Motion DetectionN/AMotion-activated spotlightMotion-activated spotlightN/A
BatteryRemovable, Rechargeable 6200mAh batteryN/APlug-in powerPlug-in powerN/A
Battery LifeUp to 6 monthsN/AN/AN/AN/A
Charging TimeApprox. 9 hoursN/AN/AN/AN/A
Power SourceBatteryN/AAC/DC power adapter (5V/1A)AC/DC power adapter (5V/1A)AC/DC power adapter (5V/1.5A) included
Weather ResistanceIP65N/AIP65IP65N/A
Connectivity2.4 & 5 GHz Wi-Fi, BLE 5.1N/A2.4 GHz Wi-Fi2.4 GHz Wi-FiN/A
Local StorageSupports up to 256 GB microSDN/ASupports up to 256 GB microSDSupports up to 256 GB microSDN/A
AudioTwo-way audio, MEMS Digital MicN/ABuilt-in Speaker & Microphone; Noise & Echo CancellationBuilt-in Speaker & Microphone; Noise & Echo CancellationN/A
Siren100 dB user-activated sirenN/A90 dB user-activated siren90 dB user-activated sirenN/A
Dimensions2.5 x 1.8 x 3.5 inchesN/A1.89 x 1.89 x 1.89 inches1.89 x 1.89 x 1.89 inchesN/A
Weight0.94 lbs (approx. 426 g)N/A4.1 oz (116 g)4.1 oz (116 g)N/A
SetupBluetoothⓇ setup, no hub requiredN/AStandard wired setupStandard wired setupStack mount for two Wyze Cam OG or Telephoto
MountingWall mount included, 1/4” - 20 standardN/AStand, wall mount, ceiling mountStand, wall mount, ceiling mountStack mount included
Compatible WithWyze Battery Cam Pro, Wyze Duo Cam DoorbellWyze Solar PanelWyze Cam OGWyze Cam OG TelephotoWyze Cam OG, Wyze Cam OG Telephoto
Additional FeaturesColor Night Vision, Integrated Spotlight, Radar + PIR, Local recordingUSB-C adapter cable for solar panelFaster live-streaming, 3X faster notifications, built-in spotlightFaster live-streaming, 3X faster notifications, 3x telephoto lensUSB Cable Splitter, Power Brick, Stack Mount
WarrantyNot specifiedNot specified1 Year1 YearNot specified
Which Wyze cameras are compatible with the Wyze Solar Panel?The Wyze Solar Panel is compatible with the Wyze Cam Outdoor (v1 and v2) and the Wyze Battery Cam Pro. These models can be efficiently powered and kept charged using the Wyze Solar Panel for extended outdoor surveillance.
Can I use the Wyze Solar Panel with Wyze Cam OG or Wyze Cam Pan models?No, the Wyze Solar Panel is not compatible with Wyze Cam OG (Original), Wyze Cam OG Telephoto 3x, Wyze Cam v1, v2, v3, v3 Pro, Wyze Cam Pan (v1, v2, v3), or Wyze Doorbells. Attempting to use the solar panel with these models will not work and may void your warranty.
What accessories are needed to connect the Wyze Solar Panel to the Wyze Battery Cam Pro?To connect the Wyze Solar Panel to the Wyze Battery Cam Pro, you will need the Wyze Solar Panel USB-C Adapter Cable, which is sold separately. This adapter ensures proper connection and charging.
How many Wyze Solar Panels do I need to power multiple cameras?You will need one Wyze Solar Panel per camera. Each solar panel is designed to efficiently maintain the battery of a single Wyze Cam Outdoor or Wyze Battery Cam Pro unit.
What are the key features of the Wyze Solar Panel for outdoor cameras?The Wyze Solar Panel features a 360º freestyle mount for optimal positioning, a 13-foot weatherproof power cable, adjustable angle up to 90° vertically, and IP65 weather resistance. It is designed for flexible, durable, and efficient outdoor installation.
How does the Wyze Solar Panel manage charging for cameras?The Wyze Solar Panel charges the camera battery during daylight hours and automatically stops charging when the battery reaches 100%. Charging resumes when the battery drops below 90%, ensuring efficient power management. The panel requires direct sunlight to function and does not charge at night or in heavy shade.
Are Wyze Cam OG Stack Kits compatible with solar charging?No, Wyze Cam OG Stack Kits, including the Telephoto 3x, are not compatible with the Wyze Solar Panel. Only Wyze Cam Outdoor (v1/v2) and Wyze Battery Cam Pro support solar charging.
What are the installation tips for optimal solar charging of Wyze cameras?For best results, mount the solar panel in a sunny location with a 30° upward tilt. Point the panel south in the northern hemisphere or north in the southern hemisphere. Use the included wall mount base, screws, and anchors for secure installation, and manage excess cable using the winding board on the back of the panel.
What are the benefits of using Wyze Solar Panels for outdoor cameras?Wyze Solar Panels extend camera battery life, reduce the need for manual recharging, harness eco-friendly solar energy, are weather resistant for year-round outdoor use, and offer a cost-effective solution for powering your security system.
Does the Wyze Solar Panel work in all weather conditions?Yes, the Wyze Solar Panel is rated IP65 for weather resistance, making it suitable for outdoor use in rain, dust, and other challenging conditions. However, it requires direct sunlight to charge effectively.
Can you explain how to install the Wyze Solar Panel for optimal performance?What are the weather resistance features of the Wyze Solar Panel?How does the charging process work for the Wyze Solar Panel?
