Reduce Wyze Camera Downtime with a Dedicated Solar Charging System
Reduce Downtime for Wyze Cameras with Dedicated Solar Charging
When it comes to maintaining continuous security coverage, minimizing downtime for your Wyze cameras is essential. One of the most effective ways to achieve this is by using a dedicated solar charging system designed specifically for Wyze Battery Cams. This solution ensures your cameras stay powered longer without frequent manual recharging, making it ideal for outdoor surveillance, vacation homes, RVs, and remote locations.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Battery Life Naturally
Designed for Seamless Solar Charging
The Wyze Battery Cam Solar Panel is a purpose-built accessory that attaches directly to your Wyze Battery Cam Pro or Wyze Cam Outdoor (v1/v2). It harnesses the power of the sun to keep your camera charged, significantly extending its battery life and reducing the need for manual recharging.
  • Weather Resistant: Rated IP65, this solar panel is built to withstand rain, dust, and other outdoor elements, ensuring reliable performance year-round.
  • Compact & Mountable Anywhere: Measuring 173 mm x 120 mm x 17 mm, it features a versatile 360° mount for easy installation on walls, poles, or other surfaces.
  • Power Output: Provides 2.5W at 5V DC, delivering steady solar power to your camera.
  • Long Power Cable: Comes with a 13-foot (4m) micro USB-C cable, allowing flexible placement of the panel in optimal sunlight while your camera remains mounted in the best surveillance position.
  • Complete Kit: Includes solar panel, wall mount, micro USB adapter cable, USB-C adapter cable, screws, wall anchors, and a quick start guide.
With this solar panel, your Wyze Battery Cam Pro can record for longer periods without interruption, making it perfect for continuous outdoor monitoring.
Wyze Battery Cam Pro: High-Performance Wire-Free Security Camera
Powerful Features Meet Long Battery Life
The Wyze Battery Cam Pro is a cutting-edge wire-free security camera designed for flexible outdoor use. When paired with the solar panel, it becomes a powerhouse of uninterrupted surveillance.
  • 2.5K HDR Video Resolution: Crystal-clear 2560 x 1440 video quality with H.264 encoding.
  • Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security and deterrence.
  • Radar + PIR Motion Detection: Advanced motion sensing for accurate alerts.
  • Battery Life: Removable, rechargeable 6200mAh battery lasts up to 6 months on a single charge.
  • Weatherproof: IP65 rating ensures durability in harsh weather conditions.
  • Connectivity: Supports both 2.4 GHz and 5 GHz WiFi for stable connections.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
  • Local & Cloud Storage: Supports up to 256 GB microSD cards and cloud recording with Cam Plus.
Dimensions & Design
  • Compact size: 2.5 x 1.8 x 3.5 inches
  • Lightweight at 0.94 lbs
  • Available in Black and White with a matte finish
The Wyze Battery Cam Pro combined with the solar panel creates a reliable, low-maintenance security system that keeps your property monitored day and night.
Wyze Battery Cam Pro + Solar Panel Bundle: Ready-to-Go Solar-Powered Security
All-in-One Solution for Extended Outdoor Surveillance
For those looking for convenience and value, the Wyze Battery Cam Pro + Solar Panel Bundle offers a complete package. This bundle includes the camera and the dedicated solar panel, optimized to work together for maximum uptime.
  • Same advanced camera features as the standalone Battery Cam Pro.
  • Solar panel included to keep your camera charged continuously.
  • No hub required: Completely wire-free setup.
  • IP65 Weatherproof: Both camera and solar panel withstand outdoor conditions.
  • Supports 2.4 & 5 GHz WiFi: Ensures strong connectivity in various environments.
This bundle is perfect for users who want to install a solar-powered security camera system quickly and easily, reducing downtime and maintenance.
Why Choose Solar Charging for Wyze Battery Cams?
Solar charging is an eco-friendly, cost-effective way to keep your security cameras running without interruption. It eliminates the hassle of frequent battery swaps or manual recharging, especially in remote or hard-to-reach locations.
  • Continuous Monitoring: Never miss a moment due to dead batteries.
  • Ideal for Outdoor Use: Weather-resistant design ensures durability.
  • Flexible Installation: Long cables and versatile mounts allow optimal solar panel placement.
  • Saves Time & Effort: Less frequent battery maintenance means more peace of mind.
Outdoor Security Camera with Solar Panel Alt text: Wyze Battery Cam Pro mounted outdoors with solar panel in sunlight
Summary: Maximize Your Wyze Camera Uptime
ProductKey Benefits
Wyze Battery Cam Solar PanelWeatherproof, easy mount, 13 ft cable, solar-powered
Wyze Battery Cam Pro2.5K HDR, spotlight, siren, 6-month battery life, IP65
Wyze Battery Cam Pro + Solar Panel BundleComplete solar-powered camera system, no hub needed
By combining the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel, you ensure your security system stays powered longer, reducing downtime and enhancing your home or property’s safety.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel
TypeAccessoryCameraCamera Bundle
Video ResolutionN/A2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)
WirelessN/AYesYes
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + Solar Panel
Battery CapacityN/A6200mAh6200mAh
Battery LifeExtends battery lifeUp to 6 MonthsUp to 6 Months (extended with solar panel)
Charging TimeN/AApproximately 9 hoursApproximately 9 hours
Weather ResistanceIP65 (weatherproof and dustproof)IP65IP65
Motion DetectionN/ARadar + PIR Motion DetectionRadar + PIR Motion Detection
SpotlightN/AIntegrated Spotlight (150 lumens)Integrated Spotlight (150 lumens)
SirenN/A100 dB SPL @ 0.1m100 dB SPL @ 0.1m
Mounting360° Freestyle Mount, weatherproof 13-ft cableFlexible mounting options, 1/4” - 20 standard mountFlexible mounting options, 1/4” - 20 standard mount
Local StorageN/ASupports up to 256 GB microSD cardsSupports up to 256 GB microSD cards
Cloud StorageN/AAvailable with Cam Plus subscriptionAvailable with Cam Plus subscription
WiFi SupportN/A2.4 & 5 GHz WiFi2.4 & 5 GHz WiFi
DimensionsN/A2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches
WeightN/A0.94 lbs0.94 lbs
Color OptionsN/ABlack, WhiteBlack, White
Price$24.99 (Solar Panel), $5.99 (USB-C Cable)$89.98 (1 Pack)$109.98 (Bundle)
How does the Wyze Battery Cam Solar Panel reduce downtime for Wyze cameras?The Wyze Battery Cam Solar Panel provides continuous solar charging to your Wyze Battery Cam Pro or Wyze Cam Outdoor (v1/v2), significantly extending battery life and reducing the need for frequent manual recharging. This ensures your cameras remain operational for longer periods, minimizing downtime and maintaining uninterrupted security coverage.
Is the Wyze Battery Cam Solar Panel weatherproof for outdoor use?Yes, the Wyze Battery Cam Solar Panel is rated IP65, making it weather-resistant and suitable for outdoor use. It is designed to withstand rain, dust, and other harsh environmental conditions, ensuring reliable performance year-round.
What Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor (v1/v2). It attaches directly to these models to provide seamless solar charging.
What is included in the Wyze Battery Cam Solar Panel kit?The Wyze Battery Cam Solar Panel kit includes the solar panel, a 360° wall mount, a 13-foot (4m) micro USB-C cable, micro USB adapter cable, USB-C adapter cable, screws, wall anchors, and a quick start guide for easy installation.
How long is the power cable included with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel comes with a 13-foot (4 meters) micro USB-C cable, allowing flexible placement of the solar panel in optimal sunlight while keeping your camera mounted in the best surveillance position.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features 2.5K HDR video resolution, a built-in spotlight and 100 dB siren, radar and PIR motion detection, a removable 6200mAh battery with up to 6 months of life per charge, IP65 weatherproof rating, support for 2.4 GHz and 5 GHz WiFi, smart integrations with Alexa, Google Assistant, and IFTTT, and both local (up to 256 GB microSD) and cloud storage options.
Does the Wyze Battery Cam Pro require a hub for installation?No, the Wyze Battery Cam Pro and the Wyze Battery Cam Pro + Solar Panel Bundle do not require a hub. They offer a completely wire-free setup for easy installation and use.
What are the benefits of using solar charging for Wyze Battery Cams?Solar charging for Wyze Battery Cams is eco-friendly and cost-effective, providing continuous power without the need for frequent battery swaps or manual recharging. It is ideal for outdoor, remote, or hard-to-reach locations, ensuring continuous monitoring, saving time and effort, and offering flexible installation options.
What is included in the Wyze Battery Cam Pro + Solar Panel Bundle?The Wyze Battery Cam Pro + Solar Panel Bundle includes the Wyze Battery Cam Pro and the dedicated Wyze Battery Cam Solar Panel. This all-in-one package is optimized for maximum uptime and easy installation, providing a complete solar-powered security camera system.
Can the Wyze Battery Cam Pro connect to both 2.4 GHz and 5 GHz WiFi networks?Yes, the Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi networks, ensuring strong and stable connectivity in various environments.
How does the Wyze Battery Cam Solar Panel work with the Wyze Battery Cam Pro?What are the installation requirements for the Wyze Battery Cam Solar Panel?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro or Solar Panel?
