Wyze Cordless Vacuum S: Sturdy, Powerful, and Perfect for Everyday Use
If you're searching for a
cordless vacuum with sturdy build quality that can handle everyday cleaning tasks effortlessly, the
Wyze Cordless Vacuum S is an excellent choice. Designed for modern homes, this vacuum combines powerful suction, lightweight design, and smart features to make your cleaning routine faster and more efficient.
Powerful Suction and Lightweight Design
The Wyze Cordless Vacuum S boasts an impressive
20,000 Pa suction power in Turbo Mode, ensuring deep cleaning on all surfaces. Whether you need to tackle pet hair, dust, or debris, this vacuum delivers:
- 100 AW suction power for strong cleaning performance
- Multiple suction modes:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
- Ultra-lightweight main unit weighing only 2.8 lbs, making it easy to maneuver and carry around the house
- Total assembled weight of just 4.9 lbs, perfect for extended cleaning sessions without fatigue
This combination of power and portability makes the Wyze Cordless Vacuum S ideal for everyday use, from hardwood floors to carpets and upholstery.
Long-Lasting Battery and Quick Charging
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the Wyze Cordless Vacuum S offers up to
40 minutes of runtime in ECO mode, allowing you to clean larger areas without interruption. When it’s time to recharge, the vacuum takes only
4-6 hours to reach full charge via AC charging.
For those who need even more cleaning time, the
Wyze Cordless Vacuum S Battery Pack is available as an accessory, providing extra juice to extend your cleaning sessions without waiting.
Advanced Features for Efficient Cleaning
The Wyze Cordless Vacuum S is packed with smart features that enhance usability and cleaning effectiveness:
- Dual motors for powerful suction and brush rotation
- 3-stage filtration system including a HEPA filter to trap fine dust and allergens
- 6 daylight-bright LED lights on the brush head to illuminate dark corners and under furniture
- An intuitive LED screen to monitor battery life and suction mode
Included attachments such as the crevice tool, floor brush, and dust cap make it easy to clean various surfaces and hard-to-reach spots.
Accessories to Customize Your Cleaning Experience
To keep your Wyze Cordless Vacuum S performing at its best, a range of accessories and replacement parts are available:
- Wyze Cordless Vacuum S - Battery Pack: Extend your vacuum’s runtime with an additional battery designed specifically for this model.
- Wyze Cordless Vacuum S - Charger: A replacement charger ensures you never run out of power.
- Wyze Cordless Vacuum - Foldable Vacuum Tube: This flexible tube bends to reach awkward spaces without straining your arms.
- Wyze Cordless Vacuum - HEPA Filter (2 Pack): Replace filters regularly to maintain optimal air quality and suction.
- Wyze Cordless Vacuum - Mini Motorized Brush Head: Perfect for cleaning car seats, sofas, and other upholstery with precision.
Why Choose Wyze Cordless Vacuum S for Everyday Use?
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support."
This vacuum is designed to be your reliable cleaning companion with a sturdy build and smart features that simplify your chores. Its lightweight design, powerful suction, and long battery life make it perfect for daily cleaning tasks, whether you have pets, kids, or just want a spotless home.
Specifications at a Glance
Feature | Specification |
Suction Power | 100 AW (20,000 Pa Turbo) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | Up to 40 minutes (ECO mode) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo mode) |
Dimensions | 12.4 x 4.5 x 8.7 in (main unit) |
Color | Steel grey with Wyze green accents |
Filtration | 3-stage with HEPA filter |
LED Lights | 6 daylight-bright LEDs on brush head |
Experience the convenience and power of the
Wyze Cordless Vacuum S — a sturdy, lightweight, and smart vacuum designed for everyday use. With its range of accessories and replacement parts, you can customize and maintain your vacuum for years of reliable performance.
What is the suction power of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers powerful suction with 100 AW and up to 20,000 Pa in Turbo Mode, making it effective for deep cleaning on all surfaces.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode on a full charge.How long does it take to fully charge the Wyze Cordless Vacuum S?
It takes approximately 4-6 hours to fully charge the Wyze Cordless Vacuum S using the included AC charger.Is the Wyze Cordless Vacuum S lightweight and easy to use?
Yes, the main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, and the total assembled weight is just 4.9 lbs, making it easy to maneuver and ideal for extended cleaning sessions.What filtration system does the Wyze Cordless Vacuum S use?
The Wyze Cordless Vacuum S features a 3-stage filtration system, including a HEPA filter, to trap fine dust and allergens for cleaner air.What accessories are available for the Wyze Cordless Vacuum S?
Available accessories include a battery pack for extended runtime, a replacement charger, a foldable vacuum tube for hard-to-reach areas, HEPA filter packs, and a mini motorized brush head for upholstery and car cleaning.Does the Wyze Cordless Vacuum S have LED lights for cleaning?
Yes, the Wyze Cordless Vacuum S is equipped with 6 daylight-bright LED lights on the brush head to illuminate dark corners and under furniture.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for efficient cleaning with fewer interruptions to empty the bin.Is the Wyze Cordless Vacuum S suitable for pet hair and allergies?
Absolutely. The powerful suction and HEPA filtration system make the Wyze Cordless Vacuum S ideal for picking up pet hair and reducing allergens in your home.What are the dimensions and color of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches and comes in a stylish steel grey color with Wyze green accents.Can I extend the cleaning time of my Wyze Cordless Vacuum S?
Yes, you can purchase the Wyze Cordless Vacuum S Battery Pack accessory to extend your vacuum’s runtime for longer cleaning sessions.What is the noise level of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo mode, providing powerful cleaning with minimal disturbance.
