Best Cordless Stick Vacuum for Dorm Rooms: Wyze Cordless Vacuum S
When living in a dorm room with limited space, having a compact, lightweight, and powerful vacuum is essential. The
Wyze Cordless Vacuum S is designed to meet these needs perfectly. It combines strong suction, portability, and smart features, making it an ideal cleaning companion for small living spaces like dorms.
Why Choose Wyze Cordless Vacuum S for Dorm Rooms?
Ultra-Lightweight and Compact Design
Weighing only
2.8 lbs (main unit) and
4.9 lbs (assembled), the Wyze Cordless Vacuum S is incredibly easy to handle and store. Its slim profile and compact dimensions (
12.4 x 4.5 x 8.7 inches main unit) make it perfect for dorm rooms where space is at a premium. You can easily tuck it away in a closet or under a bed without hassle.
Powerful Suction for Deep Cleaning
Despite its small size, this vacuum packs a punch with
20,000 Pa suction power in Turbo Mode and
100 AW suction rating. It offers three suction modes to suit different cleaning needs:
- Turbo Mode: 20,000 Pa for tough dirt (10 minutes runtime)
- Medium Mode: 9,000 Pa for everyday cleaning (23 minutes runtime)
- ECO Mode: 6,000 Pa for extended cleaning (40 minutes runtime)
This versatility ensures your dorm floor, rugs, and even upholstery stay spotless.
Long-Lasting Battery Life
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the vacuum provides up to
40 minutes of runtime on ECO mode, enough to clean your entire dorm room on a single charge. The battery is interchangeable, and you can extend cleaning time with an optional battery pack accessory.
Smart Features and Attachments
- LED screen displays battery life and suction mode.
- Two motors for enhanced cleaning efficiency.
- 3-stage filtration system with HEPA filter to trap dust and allergens.
- 6 daylight-bright LED lights on the brush head illuminate hidden dirt.
- Comes with multiple attachments: Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, and Standard Tube.
Lightweight and pet-friendly vacuuming in small spaces
Accessories to Enhance Your Wyze Cordless Vacuum S Experience
Wyze Cordless Vacuum S - Battery Pack
Need extra cleaning time? The
Wyze Cordless Vacuum S Battery Pack is designed specifically for this vacuum, allowing you to swap batteries and double your runtime. Perfect for larger dorm rooms or quick cleanups between classes.
Wyze Cordless Vacuum S - Charger
Keep your vacuum ready to go with the official
replacement charger. Compact and efficient, it ensures your vacuum is always powered up.
This accessory bends for easier reach under furniture and tight corners, reducing strain while cleaning. It’s designed exclusively for the Wyze Cordless Vacuum.
Wyze Cordless Vacuum - HEPA Filter
Maintain optimal air quality by regularly replacing your vacuum’s
HEPA filter. Available in convenient 2-packs, these filters trap fine dust and allergens, ideal for dorm rooms where air circulation can be limited.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Perfect for cleaning car seats, sofas, or dorm room upholstery, this mini brush head attachment tackles pet hair and stubborn debris with ease.
Summary: The Perfect Dorm Room Vacuum
The
Wyze Cordless Vacuum S stands out as a top choice for dorm rooms due to its:
- Lightweight and compact design ideal for small spaces
- Powerful suction modes for versatile cleaning
- Long battery life with optional battery pack for extended use
- Smart LED display and multiple attachments for thorough cleaning
- Easy maintenance with replaceable HEPA filters and accessories
Whether you’re tackling dust on hardwood floors, cleaning pet hair from your sofa, or reaching tight corners, the Wyze Cordless Vacuum S offers a convenient, efficient, and space-saving solution.
Effortless cordless cleaning for compact living spaces
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." — Wyze Cordless Vacuum S
Product Specifications at a Glance
Feature | Specification |
Suction Power | 20,000 Pa (Turbo), 9,000 Pa (Medium), 6,000 Pa (ECO) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | Up to 40 minutes (ECO mode) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo mode) |
Dimensions | 12.4 x 4.5 x 8.7 inches (main unit) |
Filtration | 3-stage with HEPA filter |
Included Attachments | Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, Standard Tube |
Enhance Your Cleaning Setup with Wyze Accessories
- Battery Pack: Extend cleaning sessions effortlessly.
- Charger: Keep your vacuum powered and ready.
- Foldable Tube: Reach under furniture with ease.
- HEPA Filter: Maintain clean air quality.
- Mini Motorized Brush: Perfect for upholstery and car seats.
What makes the Wyze Cordless Vacuum S ideal for dorm rooms?
The Wyze Cordless Vacuum S is perfect for dorm rooms due to its ultra-lightweight and compact design, weighing only 2.8 lbs (main unit) and measuring 12.4 x 4.5 x 8.7 inches. Its powerful suction, long battery life, and multiple attachments make it easy to clean small spaces efficiently and store the vacuum without taking up much room.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 20,000 Pa of suction power in Turbo Mode, 9,000 Pa in Medium Mode, and 6,000 Pa in ECO Mode. This ensures deep cleaning for various surfaces, from hard floors to rugs and upholstery.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime on ECO mode, 23 minutes on Medium mode, and 10 minutes on Turbo mode. The battery is interchangeable, and you can extend cleaning time with an optional battery pack.What attachments are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, and Standard Tube. Additional accessories like a Foldable Vacuum Tube and Mini Motorized Brush Head are also available for enhanced cleaning.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system with a HEPA filter, which helps trap dust and allergens, making it ideal for maintaining clean air quality in dorm rooms.How do I extend the cleaning time of my Wyze Cordless Vacuum S?
You can extend the cleaning time by purchasing the Wyze Cordless Vacuum S Battery Pack, which allows you to swap batteries and double your runtime—perfect for larger dorm rooms or multiple cleaning sessions.What is the noise level of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo mode, making it relatively quiet and suitable for shared living spaces like dorm rooms.How do I maintain the Wyze Cordless Vacuum S for optimal performance?
To maintain optimal performance, regularly empty the dust cup, clean or replace the HEPA filter (available in convenient 2-packs), and use the appropriate attachments for different cleaning tasks. Keeping the battery charged and using the official charger also ensures consistent performance.Can the Wyze Cordless Vacuum S clean under furniture and in tight spaces?
Yes, the Wyze Cordless Vacuum S is designed for easy maneuverability in small spaces. The optional Foldable Vacuum Tube accessory allows you to reach under furniture and into tight corners with ease.Is the Wyze Cordless Vacuum S suitable for pet hair and upholstery?
Absolutely. The Mini Motorized Brush Head attachment is perfect for removing pet hair and stubborn debris from upholstery, car seats, and dorm room furniture.How long does it take to fully charge the Wyze Cordless Vacuum S?
It takes approximately 4-6 hours to fully charge the Wyze Cordless Vacuum S using the official replacement charger.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, which is sufficient for cleaning small spaces like dorm rooms without frequent emptying.
