Wyze Battery Cam & Solar Panel: Eco-Friendly Security Solution
Combining Wyze Cameras with Solar Energy for Eco-Friendly Security
Harness the power of the sun to keep your home and outdoor spaces secure with Wyze’s innovative solar-compatible security solutions. By pairing Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel, you can enjoy extended battery life, reduced environmental impact, and reliable, wire-free surveillance. This combination is perfect for those seeking an environmentally friendly security system that’s easy to install and maintain.
Wyze Battery Cam Solar Panel: Sustainable Power for Continuous Security
Extend Your Camera’s Battery Life with Solar Energy
The Wyze Battery Cam Solar Panel is designed to keep your Wyze Battery Cam Pro and Wyze Cam Outdoor (v1 and v2) running longer by harnessing sunlight. This eco-conscious accessory reduces the need for frequent battery recharges, making your security setup more sustainable and hassle-free.
Key Features:
  • Weather Resistant (IP65 Rated): Built to withstand rain, dust, and outdoor elements, ensuring durability in all seasons.
  • Easy 360° Mount: Flexible mounting options let you position the solar panel for optimal sun exposure anywhere around your home.
  • Power Output: 2.5W, 5V DC solar power rating with a 13-foot USB-C cable for convenient placement.
  • Complete Kit: Includes solar panel, wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide.
By running your Wyze Battery Cam Pro on solar power, you reduce electricity consumption and contribute to a greener planet without compromising security.
Wyze Battery Cam Solar Panel in Outdoor Setting Solar panel powering Wyze Battery Cam for continuous, eco-friendly security
Wyze Battery Cam Pro: High-Performance Wire-Free Security Camera
Advanced Features for Reliable Outdoor Monitoring
The Wyze Battery Cam Pro offers 2.5K HDR video resolution with a wide 134° field of view, capturing crisp, detailed footage day and night. Its wire-free design and rechargeable battery packs provide up to 6 months of battery life, making it ideal for locations without easy access to power outlets.
Highlights Include:
  • Integrated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 100 dB siren.
  • Radar + PIR Motion Detection: Enhanced motion sensing reduces false alerts by detecting both movement and heat signatures.
  • Color Night Vision: See clear, colorful video even in low-light conditions thanks to dual white LEDs.
  • Weatherproof (IP65): Durable against rain and dust, suitable for all outdoor environments.
  • Connectivity: Supports both 2.4 GHz and 5 GHz WiFi for stable streaming.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation.
  • Local and Cloud Storage: Supports up to 256 GB microSD cards and optional Cam Plus cloud recording.
Dimensions & Design:
  • Compact size (2.5 x 1.8 x 3.5 inches) with a matte finish and lightweight build (0.94 lbs).
  • Includes a wall mount for easy installation.
Wyze Battery Cam Pro Mounted Outdoors Wyze Battery Cam Pro wire-free security with rechargeable battery
Wyze Battery Cam Pro + Solar Panel Bundle: The Ultimate Eco-Friendly Security Solution
Ready-to-Go Solar-Powered Security
For those who want the best of both worlds, the Wyze Battery Cam Pro + Solar Panel bundle offers a complete package that combines high-quality video surveillance with sustainable solar charging. This bundle ensures your camera stays powered longer without manual recharging, perfect for remote or off-grid locations.
Bundle Benefits:
  • All the advanced features of the Wyze Battery Cam Pro.
  • Continuous power supply from the included solar panel.
  • Weatherproof and wire-free design for flexible outdoor placement.
  • Cost-effective and environmentally responsible security setup.
This bundle is an excellent choice for eco-conscious homeowners, RV enthusiasts, and outdoor adventurers who want reliable security with minimal environmental impact.
Why Choose Wyze Solar-Powered Security?
  • Eco-Friendly: Reduce your carbon footprint by using renewable solar energy.
  • Convenient: Less frequent battery charging means less maintenance.
  • Reliable: IP65 weather resistance ensures your system works rain or shine.
  • Flexible Installation: Mount cameras and solar panels wherever you need them, no wiring required.
  • Smart Features: Integrate with your smart home ecosystem for enhanced control and automation.
Summary of Products for Solar-Powered Security
ProductTypeKey FeaturePrice (USD)
Wyze Battery Cam Solar PanelAccessoryWeather-resistant solar charging$24.99
Wyze Battery Cam ProCamera2.5K HDR, wire-free, spotlightFrom $89.98
Wyze Battery Cam Pro + Solar PanelCamera BundleSolar-powered camera bundle$109.98
By combining Wyze’s cutting-edge battery cameras with the Wyze Battery Cam Solar Panel, you create a sustainable, efficient, and powerful security system that protects your property while respecting the environment.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel
TypeAccessoryCameraCamera Bundle
Video ResolutionN/A2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery Packs (6200mAh)Removable, Rechargeable Battery Packs + Solar Panel
Battery LifeExtends battery life of compatible camerasUp to 6 MonthsUp to 6 Months (extended with solar panel)
Charging TimeN/AApproximately 9 hoursApproximately 9 hours
Weather ResistanceIP65 (weatherproof and dustproof)IP65IP65
Compatible CamerasWyze Cam Outdoor v1/v2, Wyze Battery Cam ProWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel
Mounting360° Freestyle Mount, mountable anywhereMultiple mounting options including ceiling mount with Universal MountMultiple mounting options including ceiling mount with Universal Mount
Power Cable Length13-foot weatherproof power cableN/AIncluded with solar panel
WirelessN/AYes (2.4 & 5 GHz WiFi)Yes (2.4 & 5 GHz WiFi)
Motion DetectionN/ARadar + PIR Motion DetectionRadar + PIR Motion Detection
Integrated Spotlight & SirenN/AYesYes
Local Storage SupportN/ASupports up to 256 GB microSD cardsSupports up to 256 GB microSD cards
Two-Way AudioN/AYesYes
DimensionsSolar Panel: 173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches
WeightN/A0.94 lbs0.94 lbs
Price$24.99 (solar panel), $5.99 (USB-C adapter cable)From $89.98 (single camera)$109.98 (bundle)
How does the Wyze Battery Cam Solar Panel work with Wyze cameras?The Wyze Battery Cam Solar Panel is designed to harness sunlight and provide continuous power to compatible Wyze cameras, such as the Wyze Battery Cam Pro and Wyze Cam Outdoor (v1 and v2). By connecting the solar panel to your camera, you can significantly extend its battery life and reduce the need for manual recharging, making your security system more sustainable and convenient.
Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor (v1 and v2). This allows you to power these cameras using solar energy for eco-friendly, wire-free security.
What are the benefits of using a solar-powered Wyze security camera system?Using a solar-powered Wyze security camera system offers several benefits, including reduced environmental impact, less frequent battery charging, reliable performance in all weather conditions, flexible installation without wiring, and integration with smart home platforms like Alexa, Google Assistant, and IFTTT.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is IP65 rated, making it weather resistant and durable against rain, dust, and other outdoor elements. This ensures reliable performance year-round.
How easy is it to install the Wyze Battery Cam Solar Panel and camera?Both the Wyze Battery Cam Solar Panel and Wyze Battery Cam Pro are designed for easy installation. The solar panel features a 360° adjustable mount and a 13-foot USB-C cable for flexible placement, while the camera comes with a wall mount and requires no wiring, making setup quick and hassle-free.
What features does the Wyze Battery Cam Pro offer for outdoor security?The Wyze Battery Cam Pro provides 2.5K HDR video resolution, a wide 134° field of view, integrated spotlight and 100 dB siren, radar and PIR motion detection, color night vision, weatherproof design, dual-band WiFi connectivity, smart home integration, and support for both local and cloud storage.
How long does the Wyze Battery Cam Pro battery last when used with the solar panel?When paired with the Wyze Battery Cam Solar Panel, the Wyze Battery Cam Pro can maintain continuous operation with minimal manual recharging, depending on sunlight exposure and camera usage. On its own, the camera’s rechargeable battery can last up to 6 months, but solar charging significantly extends this period.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the Wyze Battery Cam Pro, Wyze Battery Cam Solar Panel, wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide. This bundle provides everything needed for a complete, eco-friendly security setup.
Can I use the Wyze Battery Cam Pro and Solar Panel in remote or off-grid locations?Yes, the Wyze Battery Cam Pro and Solar Panel bundle is ideal for remote or off-grid locations, such as cabins, RVs, or outdoor areas without easy access to power outlets. The solar panel ensures your camera stays powered for reliable security wherever you need it.
How does using Wyze solar-powered security cameras help the environment?Wyze solar-powered security cameras reduce electricity consumption by utilizing renewable solar energy, which lowers your carbon footprint and supports a more sustainable lifestyle without compromising on home security.
What are the key features of the Wyze Battery Cam Solar Panel?How does the Wyze Battery Cam Pro compare to other security cameras?Are there any ongoing promotions or discounts for the Wyze Battery Cam Pro?
