Monitor Package Deliveries with Wyze Cam & Window Mount
Secure Package Deliveries with Wyze Cam and Window Mount
Checking your package deliveries by placing a Wyze Cam behind a front door window is a smart and effective way to monitor your doorstep without exposing your camera to the elements. The Wyze Window Mount is specifically designed to attach your Wyze Cam securely to glass surfaces, providing a clear, glare-free view of your front door and porch area. This setup is perfect for keeping an eye on package deliveries, visitors, and any activity outside your home.
Wyze Window Mount: Perfect for Glass Surface Installation
Clear View Without Glare or Reflection
The Wyze Window Mount allows you to mount your Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, or Wyze Cam OG Telephoto directly on your front door window or any glass surface. This accessory ensures your camera lens stays flush against the glass, eliminating annoying glare and reflections that can obscure your view.
  • Compatible with multiple Wyze Cam models including v3, v3 Pro, v4, and OG series
  • Easy to install and reposition without damaging your window
  • Ideal for monitoring package deliveries through your front door window
  • Enhances exterior security by providing a discreet camera placement
Mount your camera behind the glass for a weather-protected, clear view of your doorstep.
Wyze Cam v4: Crystal-Clear 2.5K QHD Outdoor Security
Advanced Features for Day and Night Monitoring
The Wyze Cam v4 is an excellent choice for outdoor monitoring when paired with the Wyze Window Mount. It offers superior video quality and smart features to keep your home safe.
  • 2.5K QHD resolution for crystal-clear video footage
  • Enhanced Color Night Vision with motion-activated spotlight for clear nighttime monitoring
  • 24/7 local recording with microSD card support (up to 512GB)
  • Wi-Fi 6 support for faster, more reliable connectivity
  • Compatible with Alexa and Google Assistant for voice control
  • IP65 weather resistance for outdoor durability
This camera’s wide field of view and powerful night vision make it perfect for watching packages and visitors at your front door, even in low light conditions. Wyze Cam v4 Outdoor Monitoring
Wyze Cam Pan v3: 360° Coverage for Complete Doorstep Surveillance
Flexible Pan, Tilt, and Zoom Capabilities
If you want to cover a wider area around your front door or porch, the Wyze Cam Pan v3 is a versatile option that can be mounted behind a window using the Wyze Window Mount.
  • 360° horizontal pan and 180° vertical tilt for full coverage
  • 1080p HD video with 8x digital zoom
  • IP65 weather resistance for outdoor use (requires Wyze Outdoor Power Adapter)
  • Two-way audio with built-in speaker and microphone for real-time communication
  • Motion tracking and customizable detection zones
  • Compatible with Alexa, Google Assistant, and IFTTT
This camera’s ability to pan and tilt remotely means you can check every corner of your porch and driveway from your phone, ensuring no package goes unnoticed. Wyze Cam Pan v3 in snowy outdoor setting
Wyze Cam OG: Reliable and Affordable Doorstep Monitoring
Essential Features for Everyday Security
For those looking for a budget-friendly yet reliable camera to pair with the Wyze Window Mount, the Wyze Cam OG offers solid performance.
  • 1080p HD video with 120° field of view
  • 4 IR LEDs for night vision
  • Built-in spotlight and 90-decibel siren for deterrence
  • Faster live streaming and improved 2-way audio
  • Supports up to 256GB microSD card for local storage
This camera is a great entry-level option for monitoring your front door and packages through a window mount setup.
Why Use the Wyze Window Mount for Package Delivery Monitoring?
  • Weather Protection: Keep your camera safe from rain, snow, and dust by mounting it behind a window.
  • Discreet Placement: Cameras behind glass are less noticeable and less prone to tampering.
  • Clear Visibility: The mount eliminates glare and reflections, ensuring sharp video quality.
  • Easy Installation: No drilling or permanent fixtures needed; perfect for renters or temporary setups.
Using the Wyze Window Mount with any compatible Wyze Cam model is a smart, convenient way to keep your packages safe and your home secure.
Summary of Recommended Products for Window-Mounted Package Monitoring
ProductKey FeaturesPrice (USD)
Wyze Window MountGlass surface mount, glare-free view$9.98
Wyze Cam v42.5K QHD, color night vision, Wi-Fi 6$69.99
Wyze Cam Pan v3360° pan/tilt, 1080p, weather resistant$114.94
Wyze Cam OG1080p, spotlight, siren, budget-friendly$29.98
By combining the Wyze Window Mount with any of these Wyze cameras, you can effectively monitor your front door and package deliveries with ease and confidence.
FeatureWyze Window MountWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam Pan v3
TypeAccessoryCameraCamera BundleCamera
Compatible CamerasWyze Cam v3/v3 Pro/v4, Wyze Cam OG seriesN/AWyze Cam v4Indoor/Outdoor Pan/Tilt Camera
Price$9.98$35.98 - $107.94 (varies by pack/color)$69.99$39.98 - $114.94 (varies by pack/color)
Video ResolutionN/A2.5K QHD (2560x1440)2.5K QHD1080p (1920x1080)
Night VisionReduces glare (mount feature)Enhanced Color Night VisionEnhanced Color Night Vision4 IR LEDs (850 nm)
Field of ViewN/ADFOV 115.8°, HFOV 98.5°, VFOV 53.1°N/A120° FOV
Motion DetectionN/AYesYesYes
Sound DetectionN/AYesYesYes
Local StorageN/AmicroSD card up to 512 GB requiredmicroSD Card 128GB includedSupports up to 256 GB microSD
Power SourceN/AWired (Indoor adapter included)Wired (Outdoor Power Adapter included)Wired (Outdoor Power Adapter sold separately)
Weather ResistanceN/AIP65IP65IP65
Mounting OptionsWindow (glass surface)Stand, Wall, Ceiling, Magnetic wall mountN/AScrew mount (1/4"-20), Indoor/Outdoor
DimensionsN/A2in x 2in x 2 3/8inN/A124mm x 60mm x 63mm
WeightN/A0.49 lb (222 g)N/A11.29 oz (320 g)
ConnectivityN/A2.4 GHz Wi-Fi, Wi-Fi 6Wi-Fi 62.4 GHz Wi-Fi (5 GHz not supported)
Two-Way AudioN/AYesYesYes
Built-in SirenN/AYesYesNo
Additional FeaturesReduces glare and reflection on glassMotion-activated spotlight, Smoke & CO alerts, Wide Dynamic Range (WDR)Motion-activated spotlight, Smoke & CO alerts, WDR360° pan, 180° tilt, Noise & echo cancellation
WarrantyNot specified1 Year1 Year1 Year
How does the Wyze Window Mount improve package delivery monitoring?The Wyze Window Mount allows you to securely attach your Wyze Cam to a glass surface, such as your front door window. This setup provides a clear, glare-free view of your doorstep, making it easy to monitor package deliveries without exposing your camera to the weather.
Which Wyze Cam models are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto models. This ensures flexibility in choosing the right camera for your package monitoring needs.
Can I use the Wyze Window Mount without damaging my window?Yes, the Wyze Window Mount is designed for easy installation and repositioning without causing any damage to your window. It does not require drilling or permanent fixtures, making it ideal for renters or temporary setups.
What are the benefits of mounting a Wyze Cam behind a window?Mounting a Wyze Cam behind a window protects the camera from rain, snow, and dust, offers discreet placement to reduce tampering, and eliminates glare and reflections for sharp video quality.
Is the Wyze Cam v4 suitable for monitoring package deliveries?Yes, the Wyze Cam v4 is an excellent choice for package delivery monitoring. It features 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, 24/7 local recording, and Wi-Fi 6 support for reliable connectivity.
Does the Wyze Cam Pan v3 provide full coverage of my front porch?The Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your porch and driveway. It also features 1080p HD video, motion tracking, and two-way audio for comprehensive doorstep surveillance.
Is the Wyze Cam OG a good budget option for front door monitoring?Yes, the Wyze Cam OG is a reliable and affordable camera for monitoring your front door. It offers 1080p HD video, night vision, a built-in spotlight, a 90-decibel siren, and supports up to 256GB microSD card for local storage.
How does the Wyze Window Mount help with night-time package monitoring?The Wyze Window Mount, when paired with compatible Wyze Cams like the v4 or OG, enables clear night vision by eliminating window glare and reflections. Cameras such as the Wyze Cam v4 offer enhanced color night vision and motion-activated spotlights for superior nighttime monitoring.
Can I use voice assistants with Wyze Cams for package monitoring?Yes, Wyze Cams such as the v4 and Pan v3 are compatible with Alexa and Google Assistant, allowing you to use voice commands to check your camera feed and monitor package deliveries.
What is the price of the Wyze Window Mount and compatible cameras?The Wyze Window Mount is priced at $9.98. Compatible cameras include the Wyze Cam v4 ($69.99), Wyze Cam Pan v3 ($114.94), and Wyze Cam OG ($29.98).
What are the installation steps for the Wyze Window Mount?Can the Wyze Window Mount be used with all Wyze Cam models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Window Mount?
