Best Wyze Cameras with Two-Way Audio Support for Home Security
Best Cameras with Two-Way Audio Support
If you're searching for security cameras that offer reliable two-way audio communication, you're in the right place. Two-way audio allows you to listen and speak through your camera remotely, making it perfect for home security, monitoring pets, or interacting with visitors. Below, we highlight top Wyze cameras that support two-way audio, each designed to fit different needs and environments.
Wyze Cam v4 – Crystal Clear Two-Way Audio with Advanced Features
Experience unmatched home security with the Wyze Cam v4, a versatile indoor/outdoor camera packed with features:
  • Video Quality: Stunning 2.5K QHD (2560x1440) resolution for crystal-clear footage.
  • Two-Way Audio: Equipped with a 99dB waterproof speaker and microphone featuring noise and echo cancellation for clear conversations.
  • Night Vision: Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) to see vividly even in the dark.
  • Connectivity: Supports Wi-Fi 6 and works seamlessly with Alexa and Google Assistant.
  • Storage: 24/7 local recording with microSD card support up to 512GB and optional cloud storage.
  • Durability: Weather-resistant with IP65 rating, suitable for outdoor use.
  • Mounting Options: Flexible mounting including stand, wall, ceiling, and magnetic adhesive mounts.
This camera is perfect for those who want high-resolution video combined with robust two-way audio capabilities for clear communication anytime.
Wyze Cam Pan v3 – 360° Coverage with Two-Way Talk
For full-room coverage and flexible monitoring, the Wyze Cam Pan v3 offers:
  • Pan & Tilt: 360° horizontal and 180° vertical rotation to cover every angle.
  • Video Resolution: Full HD 1080p with 20 FPS daytime and 15 FPS nighttime.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for smooth conversations.
  • Night Vision: 4 IR LEDs for clear black-and-white night vision.
  • Weatherproof: IP65 rating for outdoor use (requires separate outdoor power adapter).
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
  • Storage: Supports microSD cards up to 256GB.
Ideal for users who want a dynamic camera that can pan and tilt remotely while maintaining clear two-way audio communication. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 offers weather-resistant, 360° coverage with two-way audio.
Wyze Battery Cam Pro – Wire-Free Two-Way Audio with Long Battery Life
If you prefer a wire-free solution, the Wyze Battery Cam Pro is a powerful choice:
  • Video Quality: 2.5K HDR resolution for sharp, detailed images.
  • Two-Way Audio: Built-in speaker and MEMS digital microphone for clear two-way communication.
  • Wireless: Completely wire-free with removable, rechargeable 6200mAh battery lasting up to 6 months.
  • Night Vision: 2 IR LEDs plus 2 white LEDs (187 lumens) for color night vision.
  • Weather Resistance: IP65 rated for all-weather durability.
  • Connectivity: Supports both 2.4 GHz and 5 GHz Wi-Fi.
  • Storage: Local microSD support up to 256GB.
Perfect for flexible placement anywhere around your property without worrying about power cables.
Wyze Video Doorbell v2 – Two-Way Audio at Your Front Door
Secure your entryway with the Wyze Video Doorbell v2, featuring:
  • Video Resolution: Crisp 2K (2048 x 1536) video for detailed visitor monitoring.
  • Two-Way Audio: Electric condenser microphone and 1W speaker for real-time conversations.
  • Field of View: Wide 166.8° diagonal view to capture your porch area.
  • Night Vision: 6 IR LEDs for clear night-time video.
  • Storage: Local microSD storage up to 256GB plus cloud options.
  • Weatherproof: IP65 rating ensures durability in all weather.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
Ideal for answering your door remotely and deterring unwanted visitors with voice deterrence.
Wyze Cam OG – Compact and Clear Two-Way Audio Camera
The Wyze Cam OG is a compact, budget-friendly camera with essential two-way audio features:
  • Video Quality: 1080p HD resolution with 20 FPS daytime and 15 FPS nighttime.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Spotlight & Siren: 40 lumens spotlight and 90-decibel siren for added security.
  • Weather Resistance: IP65 rating for indoor/outdoor use.
  • Fast Streaming: 50% faster live streaming than previous Wyze models.
Great for users seeking a straightforward camera with reliable two-way audio and smart security features.
Wyze Cam Floodlight v2 – Bright Security with Two-Way Audio
Illuminate and secure your property with the Wyze Cam Floodlight v2:
  • Lighting: Powerful 2800 lumens from two dimmable LED panels with AI-powered light control.
  • Video Quality: 2K resolution with color night vision and a wide 160° diagonal field of view.
  • Two-Way Audio: Built-in speaker and microphone for clear communication.
  • Siren: Loud 105dB siren to deter intruders.
  • Weatherproof: IP65 rating for reliable outdoor use.
  • Smart Features: Dusk-to-dawn automation and integration with Alexa, Google Assistant, and IFTTT.
This floodlight camera is perfect for those who want bright illumination combined with two-way audio and advanced security. Wyze Cam Floodlight v2 lifestyle image showing two-way audio use Wyze Cam Floodlight v2 enables two-way talk while illuminating your outdoor space.
Why Choose Wyze Cameras with Two-Way Audio?
Two-way audio security cameras provide peace of mind by allowing you to communicate directly through your camera. Whether it's greeting guests, warning intruders, or checking on loved ones, these Wyze cameras combine high-quality video with clear, responsive audio.
With options ranging from compact indoor cams to rugged outdoor floodlights and wire-free battery models, Wyze offers versatile solutions tailored to your security needs.
Summary of Two-Way Audio Wyze Cameras
Camera ModelVideo ResolutionTwo-Way AudioWeather ResistanceSpecial Features
Wyze Cam v42.5K QHDYesIP65Color Night Vision, Spotlight, Wi-Fi 6
Wyze Cam Pan v31080pYesIP65360° Pan & 180° Tilt
Wyze Battery Cam Pro2.5K HDRYesIP65Wire-Free, Long Battery Life
Wyze Video Doorbell v22KYesIP65Doorbell with Voice Deterrence
Wyze Cam OG1080pYesIP65Compact, Spotlight & Siren
Wyze Cam Floodlight v22KYesIP652800 Lumens Floodlight, AI Lighting
Choose the Wyze camera that fits your lifestyle and enjoy the convenience and security of two-way audio communication.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Video Doorbell v2Wyze Cam OGWyze Cam Floodlight v2
TypeWired CameraWired Pan & Tilt CameraWireless Battery CameraWired Video DoorbellWired CameraWired Floodlight Camera
Video Resolution2.5K QHD (2560 x 1440)Not specified (award-winning)2.5K HDR (2560 x 1440)2K (2048 x 1536)1080p (1920 x 1080)2K (2304 x 1296)
Field of View (Diagonal)115.9°360° pan, 180° tilt134°166.8°120°160°
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)2 IR LEDs + 2 White LEDs (Color)6 x 940nm IR lights (B&W)4 IR LEDs (850nm) (B&W)Color Night Vision
AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way AudioTwo-Way AudioBuilt-in Speaker & Mic (Upgraded)Built-in Speaker & Mic (2-way)
SpotlightMotion-activated spotlightNoIntegrated SpotlightNoBuilt-in Spotlight (40 Lumens)2 Dimmable LED Light Panels
Siren99 dBNot specified100 dBNot specified90 dB user-activated105 dB
Weather ResistanceIP65IP65IP65IP65IP65IP65
Power SourceWiredWiredRemovable, Rechargeable BatteryWired (16V-24V AC)Wired (5V/1A adapter)Hardwired (110-120V AC)
WirelessNoNoYesNoNoNo
Local StorageMicroSD up to 256GBMicroSD up to 256GBMicroSD up to 256GBMicroSD up to 256GBMicroSD up to 256GBMicroSD up to 256GB
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
ConnectivityWi-Fi 6 (requires Wi-Fi 6 router)Wi-Fi (2.4 GHz)Wi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
Dimensions (inches)Not specifiedNot specified2.5 x 1.8 x 3.54.3 x 1.7 x 0.91.89 x 1.89 x 1.899.5 x 7.7 x 7.0
WeightNot specifiedNot specified0.94 lbsNot specified4.1 oz (116 g)2.76 lbs (1.25 kg)
Special FeaturesAuto-zoom with AI, Motion-activated spotlight, Smoke & CO alerts360° pan & 180° tilt, Motion tracking, Privacy ModeRadar + PIR motion detection, Rechargeable battery, Up to 6 months battery lifeMotion-activated voice deterrence, Real-time alertsFaster live streaming, 3X faster notifications, Built-in spotlight2800 Lumens LEDs, AI-Powered Light Control, Dusk-to-dawn automation
Price (1 Pack)$35.98$39.98$159.98$44.98$29.98$89.98
What is two-way audio in security cameras and why is it important?Two-way audio in security cameras allows you to both listen and speak through the camera remotely. This feature is important for home security, monitoring pets, greeting visitors, or deterring intruders, as it enables real-time communication directly from your smartphone or device.
Which Wyze cameras support two-way audio communication?Wyze offers several cameras with two-way audio support, including Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Video Doorbell v2, Wyze Cam OG, and Wyze Cam Floodlight v2. Each model is designed for different environments and security needs.
Does the Wyze Cam v4 have two-way audio and what are its key features?Yes, the Wyze Cam v4 features two-way audio with a 99dB waterproof speaker and microphone, noise and echo cancellation, 2.5K QHD video resolution, color night vision, Wi-Fi 6 support, and weather-resistant IP65 rating for indoor and outdoor use.
Can I use two-way audio on the Wyze Cam Pan v3 for full-room coverage?Absolutely. The Wyze Cam Pan v3 offers two-way audio with noise and echo cancellation, along with 360° horizontal and 180° vertical rotation for complete room coverage, making it ideal for monitoring large spaces and communicating clearly.
Is there a wire-free Wyze camera with two-way audio?Yes, the Wyze Battery Cam Pro is a wire-free security camera with two-way audio. It features a rechargeable battery lasting up to 6 months, 2.5K HDR video, color night vision, and IP65 weather resistance for flexible placement anywhere.
Does the Wyze Video Doorbell v2 support two-way audio for front door communication?Yes, the Wyze Video Doorbell v2 includes two-way audio with an electric condenser microphone and 1W speaker, allowing you to have real-time conversations with visitors and deter unwanted guests directly from your smartphone.
What are the benefits of the Wyze Cam OG’s two-way audio feature?The Wyze Cam OG offers reliable two-way audio with noise and echo cancellation, making it easy to communicate with people or pets. Its compact design, 1080p HD video, spotlight, and siren make it a great choice for budget-friendly security.
How does the Wyze Cam Floodlight v2 enhance security with two-way audio?The Wyze Cam Floodlight v2 combines powerful 2800-lumen lighting with two-way audio, allowing you to communicate clearly while illuminating your property. It also features a loud siren, 2K video, color night vision, and smart home integration.
Are Wyze cameras with two-way audio weatherproof?Yes, all the highlighted Wyze cameras with two-way audio, including Wyze Cam v4, Cam Pan v3, Battery Cam Pro, Video Doorbell v2, Cam OG, and Cam Floodlight v2, have an IP65 weather resistance rating, making them suitable for both indoor and outdoor use.
What storage options are available for Wyze cameras with two-way audio?Wyze cameras with two-way audio support local storage via microSD cards (up to 256GB or 512GB depending on the model) and offer optional cloud storage for continuous or event-based video recording.
Do Wyze cameras with two-way audio work with smart home systems?Yes, Wyze cameras with two-way audio are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.
What features does the Wyze Cam v4 offer for two-way audio?Can you explain how the night vision works on the Wyze cameras?Do you have any ongoing sales or discounts for Wyze cameras?
