Full HD Wireless Smart Home Security Cameras with Two-Way Audio
When it comes to securing your home with crystal-clear video and seamless communication, choosing the right smart security camera is essential. Whether you want a wireless setup for flexible placement or wired cameras for continuous power, Wyze offers a range of full HD and higher resolution smart home security cameras equipped with two-way audio. This guide highlights the best Wyze cameras that meet your needs for Full HD or better video quality, wireless or wired connectivity, and enhanced two-way audio for real-time conversations.
Wyze Battery Cam Pro: Premium Wireless Security with 2.5K HDR
Experience the freedom of a truly wireless security camera with the Wyze Battery Cam Pro. This camera delivers stunning 2.5K HDR video resolution, providing vibrant and detailed footage day or night. Its wire-free design means no hubs or power outlets are required, making it perfect for flexible indoor or outdoor placement.
Key Features:
  • 2.5K HDR Video Resolution: Capture every detail with high dynamic range for balanced, colorful images.
  • Wireless & Battery Powered: Removable, rechargeable battery packs with optional solar panel support for extended use.
  • Integrated Spotlight & Siren: 150 lumens LED spotlight and siren deter intruders effectively.
  • Radar + PIR Motion Detection: Dual sensors for precise and early motion alerts with customizable detection zones.
  • IP65 Weatherproof: Built to withstand rain, dust, and extreme temperatures.
  • Enhanced Two-Way Audio: Built-in microphone and speaker with noise and echo cancellation for clear conversations.
  • Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
  • Local & Cloud Storage: Supports microSD card local recording and optional cloud storage with subscription.
The Wyze Battery Cam Pro is ideal for those who want a high-resolution, wireless camera with professional-grade features and flexible power options.
Outdoor lifestyle with wireless security camera Stay protected day and night with wireless freedom.
Wyze Cam v4: Wired 2.5K QHD Security with Enhanced Color Night Vision
For users preferring a wired camera with continuous power, the Wyze Cam v4 offers unmatched clarity and smart features. This camera boasts 2.5K Quad HD resolution and enhanced color night vision, ensuring your home is monitored with vivid detail even in low light.
Highlights:
  • 2.5K QHD Resolution: Crystal-clear video with wide dynamic range for vibrant colors.
  • Color Night Vision: See more than just black and white at night with enhanced hardware.
  • Motion-Activated Spotlight: Automatically lights up dark areas when motion is detected.
  • Wi-Fi 6 Support: Faster, more stable connection for smooth live streaming.
  • Two-Way Audio: Improved microphone and speaker for clear communication.
  • Smart Alerts: Motion, sound, smoke, and CO alarm detection with customizable zones.
  • 24/7 Local Recording: Continuous recording with included microSD cards.
  • Smart Home Integration: Compatible with Alexa and Google Assistant.
The Wyze Cam v4 is perfect for those who want wired reliability combined with advanced night vision and smart home compatibility.
Indoor lifestyle with Wyze Cam v4 Reliable wired security with vibrant night vision.
Wyze Bulb Cam: 2-in-1 Security Camera and Smart LED Light
If you want to combine lighting and security in one device, the Wyze Bulb Cam is a unique solution. This smart LED bulb doubles as a 2K HD security camera with color night vision and two-way audio, fitting into any standard E26 light socket.
Features:
  • 2K HD Video Resolution: Clear video with a wide 160° field of view.
  • Color Night Vision: See full color even in low light conditions.
  • Two-Way Audio: Built-in microphone and speaker for real-time conversations.
  • Motion-Activated Light: Automatically turns on the light when motion is detected.
  • Easy Installation: Fits most standard light fixtures, no extra wiring needed.
  • Local Storage Support: Compatible with microSD cards up to 256 GB.
  • Weather Resistant: Rated IP65 for outdoor use.
  • Smart Controls: Schedule, manual, and automation options via Wyze app.
The Wyze Bulb Cam is ideal for users who want discreet security with integrated lighting and two-way communication.
Wyze Bulb Cam installed in outdoor light fixture Smart lighting meets security with two-way talk.
Additional Options: Wyze Cam Pan v3 and Wyze Cam OG
Wyze Cam Pan v3
  • 1080p Full HD Resolution with 360° pan and 180° tilt for wide coverage.
  • Two-Way Audio with noise and echo cancellation.
  • IP65 Weatherproof for indoor/outdoor use.
  • Built-in Siren and Spotlight for added security.
  • Ideal for users needing flexible viewing angles and full HD video.
Wyze Cam OG
  • 1080p Full HD Video with upgraded two-way audio.
  • Built-in Spotlight and Siren for enhanced protection.
  • IP65 Weather Resistance for outdoor durability.
  • Great for budget-conscious buyers wanting reliable wired security.
Why Choose Wyze Smart Home Security Cameras?
Wyze cameras combine high-resolution video, smart detection, and two-way audio to keep your home safe and connected. Whether you prefer wireless freedom with the Battery Cam Pro or wired reliability with the Cam v4, Wyze offers versatile options that integrate seamlessly with your smart home ecosystem.
Clear video, reliable connectivity, and real-time communication — Wyze smart cameras deliver peace of mind wherever you need it.
Summary Table of Featured Cameras
Camera ModelResolutionPower TypeTwo-Way AudioNight VisionWeatherproofSpecial Features
Wyze Battery Cam Pro2.5K HDRWirelessYesColor Night VisionIP65Spotlight, Siren, Radar + PIR
Wyze Cam v42.5K QHDWiredYesEnhanced Color NVIP65Wi-Fi 6, Motion Spotlight
Wyze Bulb Cam2K HDWired (Bulb)YesColor Night VisionIP652-in-1 Light & Camera
Wyze Cam Pan v31080p Full HDWiredYesIR Night VisionIP65360° Pan & 180° Tilt, Siren
Wyze Cam OG1080p Full HDWiredYesIR Night VisionIP65Built-in Spotlight & Siren
Protect your home with Wyze’s full HD wireless and wired smart security cameras featuring two-way audio. Choose the model that fits your lifestyle and enjoy peace of mind with crystal-clear video and instant communication.
FeatureWyze Battery Cam ProWyze Cam v4Wyze Cam v4 Home Security BundleWyze Bulb CamWyze Cam Pan v3Wyze Cam OG
Video Resolution2.5K HDR (2560 x 1440)2.5K QHD (2560 x 1440)2.5K QHD (2560 x 1440)2K HD (2304 x 1296)1080p (1920 x 1080)1080p (1920 x 1080)
Video EncodingH.264H.264H.264N/AH.264H.264
WirelessYesYesYesYesWired (requires power adapter)Wired
Power SourceRemovable, Rechargeable Battery PacksWired (Indoor USB Power Adapter)Wired (Indoor USB Power Adapter)120V AC (Bulb socket)Wired (requires Wyze Outdoor Power Adapter)Wired
Battery LifeUp to 6 MonthsN/AN/AN/AN/AN/A
Charging TimeApprox. 9 hoursN/AN/AN/AN/AN/A
Weather ResistanceIP65IP65IP65IP65IP65IP65
Operating Temperature-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)-20°C to +55°C (-4°F to +131°F)
Field of View (DFOV)134°115.8°115.8°160°120°120°
Night Vision2 IR LEDs (850 nm), 2 White LEDs (187 lumens)4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)4 IR LEDs (850 nm), Color Night Vision4 IR LEDs (850 nm)4 IR LEDs (850 nm)
Color Night VisionNoYesYesYesNoYes
AudioTwo-way Audio with built-in speaker & micTwo-way Audio with built-in speaker & micImproved Two-way AudioTwo-way AudioTwo-way AudioBuilt-in Speaker & Microphone
Siren100 dB SPL @ 0.1mBuilt-in sirenBuilt-in siren95 dB at 4 inNo90 dB user-activated siren
Local StorageSupports up to 256 GB microSDmicroSD card up to 512 GB128 GB microSD includedSupports up to 256 GB microSDSupports up to 256 GB microSDSupports up to 256 GB microSD
Cloud StorageWith subscription planWith subscription planWith subscription planStored in AWS cloudN/AN/A
WiFi Support2.4 & 5 GHz, 802.11a/n/g/b2.4 GHz & Wi-Fi 6Wi-Fi 62.4 GHz b/g/n2.4 GHz b/g/n (5 GHz not supported)2.4 GHz b/g/n
BluetoothBLE 5.1Bluetooth 5.2N/ABluetooth 4.2, BLEN/AN/A
Dimensions2.5 x 1.8 x 3.5 in2 x 2 x 2 3/8 in2 x 2 x 2 3/8 inN/A (Bulb shape)124 x 60 x 63 mm (4.88 x 2.36 x 2.48 in)1.89 x 1.89 x 1.89 in
Weight0.94 lbs0.49 lbs (222 g)0.49 lbs (222 g)N/A11.29 oz (320 g)4.1 oz (116 g)
Mounting Options1/4" - 20 standard, wall mount includedStand, Wall, Ceiling, Magnetic wall mountStand, Wall, Ceiling, Magnetic wall mountStandard E26 socketScrew 1/4" - 20Stand, Wall, Ceiling, Magnetic wall mount
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Price Range (USD)$89.98 - $219.98$35.98 - $107.94$169.99$49.98$39.98 - $114.94$29.98 - $89.94
What are the best Wyze smart home security cameras with two-way audio?Wyze offers several smart home security cameras with two-way audio, including the Wyze Battery Cam Pro, Wyze Cam v4, Wyze Bulb Cam, Wyze Cam Pan v3, and Wyze Cam OG. These cameras provide options for both wireless and wired setups, high-definition video, and real-time communication.
What is the video resolution of Wyze security cameras?Wyze security cameras offer a range of video resolutions: Wyze Battery Cam Pro and Wyze Cam v4 provide 2.5K (QHD/HDR) resolution, Wyze Bulb Cam offers 2K HD, and Wyze Cam Pan v3 and Wyze Cam OG deliver 1080p Full HD video.
Which Wyze camera is completely wireless?The Wyze Battery Cam Pro is a completely wireless security camera. It features a removable, rechargeable battery and supports optional solar panel charging, making it ideal for flexible indoor or outdoor placement without the need for power outlets or hubs.
Do Wyze cameras support two-way audio for real-time communication?Yes, all featured Wyze cameras, including the Battery Cam Pro, Cam v4, Bulb Cam, Cam Pan v3, and Cam OG, are equipped with two-way audio. This allows you to have real-time conversations through the camera using the Wyze app.
Can Wyze security cameras be used outdoors?Yes, most Wyze cameras, such as the Wyze Battery Cam Pro, Wyze Cam v4, Wyze Bulb Cam, Wyze Cam Pan v3, and Wyze Cam OG, are rated IP65 weatherproof. This makes them suitable for both indoor and outdoor use, withstanding rain, dust, and extreme temperatures.
What night vision features do Wyze cameras offer?Wyze cameras offer advanced night vision capabilities. The Wyze Battery Cam Pro, Cam v4, and Bulb Cam feature color night vision, allowing you to see full-color images even in low light. The Cam Pan v3 and Cam OG provide IR night vision for clear black-and-white footage in the dark.
How do Wyze cameras store video footage?Wyze cameras support both local and cloud storage options. Most models are compatible with microSD cards for local recording, and cloud storage is available through a subscription service for added convenience and backup.
Are Wyze cameras compatible with smart home systems?Yes, Wyze cameras such as the Cam v4 are compatible with popular smart home systems, including Amazon Alexa and Google Assistant, allowing for seamless integration and voice control.
What is the Wyze Bulb Cam and how does it work?The Wyze Bulb Cam is a 2-in-1 device that combines a smart LED light with a 2K HD security camera. It fits into any standard E26 light socket, offers color night vision, two-way audio, and motion-activated lighting, making it a discreet and easy-to-install security solution.
What are the power options for Wyze security cameras?Wyze offers both wireless and wired security cameras. The Wyze Battery Cam Pro is battery-powered and supports solar charging, while the Wyze Cam v4, Bulb Cam, Cam Pan v3, and Cam OG are wired for continuous power.
Which Wyze camera is best for flexible viewing angles?The Wyze Cam Pan v3 is ideal for flexible viewing angles, featuring 360° pan and 180° tilt capabilities. This allows you to monitor large areas and adjust the camera’s view remotely.
Do Wyze cameras have built-in security features like spotlights and sirens?Yes, several Wyze cameras include built-in security features. The Wyze Battery Cam Pro and Cam OG have integrated spotlights and sirens, while the Cam v4 and Cam Pan v3 also offer motion-activated spotlights and sirens for enhanced protection.
What makes Wyze security cameras a good choice for home security?Wyze security cameras combine high-resolution video, advanced motion detection, two-way audio, weatherproof design, and smart home integration. They offer both wireless and wired options, making them versatile and reliable for any home security need.
What are the key features of the Wyze Battery Cam Pro?Can you explain the differences between the Wyze Cam v4 and the Wyze Bulb Cam?Are there any ongoing sales or discounts for Wyze cameras?
