Waterproof Security Cameras with Enhanced Two-Way Audio and Local Recording
When it comes to securing your home or business, having a reliable waterproof security camera with improved two-way audio and local recording capabilities is essential. Wyze offers a range of cutting-edge cameras designed to meet these needs, combining weather resistance, crystal-clear video, and advanced audio features to keep you connected and protected around the clock.
Wyze Cam v4: The Ultimate Waterproof Security Camera
Experience unmatched security with the
Wyze Cam v4, the clearest Wyze Cam ever made, designed for both indoor and outdoor use with an IP65 weather resistance rating.
Key Features:
- 2.5K QHD Resolution: Capture stunningly detailed video with Quad High Definition clarity, ensuring you never miss a detail.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware that outperforms traditional night vision.
- Improved Two-Way Audio: Featuring Advanced Audio Coding (AAC), a powerful amplifier, and an updated microphone, Wyze Cam v4 delivers crystal-clear conversations.
- 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without any subscription fees.
- Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection at greater distances.
- Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT for smart home integration.
- Easy Installation: Screw-free magnetic mount for quick setup anywhere.
The Wyze Cam v4 is perfect for those who want a robust, weatherproof camera with superior video quality and enhanced audio communication.
Wyze Cam v4 in a home security setup
Wyze Cam Pan v3: Weatherproof 360° Pan and Tilt Security
For comprehensive coverage, the
Wyze Cam Pan v3 offers a fully weather-resistant IP65 design with 360° horizontal pan and 180° vertical tilt, making it ideal for both indoor and outdoor surveillance.
Highlights:
- Full 360° Pan & 180° Tilt: Monitor every corner of your property with smooth, quiet motorized movement.
- Automatic Motion Tracking: The camera detects and follows moving objects automatically, ensuring nothing escapes your view.
- Enhanced Two-Way Audio: Communicate clearly through the camera with built-in speaker and microphone.
- Color Night Vision: Equipped with a Starlight Sensor for vivid nighttime video.
- IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions (requires Wyze Outdoor Power Adapter for outdoor use).
- Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
- Local Storage Support: Compatible with microSD cards for continuous local recording.
The Wyze Cam Pan v3 is perfect for users who want dynamic, weatherproof coverage with smart tracking and clear two-way communication.
Wyze Cam Pan v3 enduring snowy outdoor conditions
Wyze Cam OG: Reliable Indoor/Outdoor Security with Spotlight and Improved Audio
The
Wyze Cam OG is a versatile security camera that balances affordability with essential features like improved two-way audio and a built-in spotlight, all in a weather-resistant IP65 housing.
Features:
- 1080p Full HD Video: Clear and smooth video streaming with 20 FPS during the day and 15 FPS at night.
- Upgraded Two-Way Audio: Enhanced microphone and speaker with noise and echo cancellation for clear conversations.
- Built-in 40 Lumen Spotlight: Illuminate dark areas to deter unwanted visitors.
- 90 dB User-Activated Siren: Add an extra layer of security with a loud siren.
- Local Storage: Supports up to 256GB microSD cards for continuous recording.
- IP65 Weather Resistance: Suitable for outdoor use in various weather conditions.
- Fast Live Streaming: 50% faster than previous Wyze models for real-time monitoring.
- Custom Detection Zones & Alerts: Tailor motion detection to your needs and receive instant alerts.
Ideal for users seeking a dependable, weatherproof camera with spotlight and enhanced audio for both indoor and outdoor security.
Wyze Cam v4 Home Security Bundle: Complete Protection with Local Recording
For those looking for a comprehensive security solution, the
Wyze Cam v4 Home Security Bundle offers multiple cameras with all the advanced features of the Wyze Cam v4, plus a 128GB microSD card for extensive local recording.
Bundle Benefits:
- Multiple Cameras: Cover more areas of your home or property with several Wyze Cam v4 units.
- 128GB MicroSD Included: Store up to 192 hours of HD video locally without monthly fees.
- All Features of Wyze Cam v4: Including 2.5K QHD video, enhanced color night vision, motion-activated spotlight, and improved two-way audio.
- Flexible Mounting Options: Stand, wall, ceiling, or magnetic mounts included for versatile installation.
- Smart Home Integration: Compatible with Alexa and Google Assistant.
This bundle is perfect for users who want a ready-to-go, high-quality security system with local recording and advanced audio features.
Why Choose Wyze Waterproof Security Cameras?
Wyze security cameras combine affordability with professional-grade features such as IP65 weather resistance, enhanced two-way audio, and local recording capabilities. Whether you need a fixed camera like the Wyze Cam v4, a dynamic pan-tilt option like the Wyze Cam Pan v3, or a spotlight-equipped model like the Wyze Cam OG, Wyze has you covered for reliable, clear, and smart home security.
Summary Table of Key Specs
Model | Resolution | Weatherproof | Two-Way Audio | Local Recording | Night Vision | Special Features |
Wyze Cam v4 | 2.5K QHD | IP65 | Enhanced AAC | Yes (256GB max) | Enhanced Color Night | Motion spotlight, 99 dB siren |
Wyze Cam Pan v3 | 1080p | IP65 | Yes | Yes (256GB max) | Color Night Vision | 360° pan/180° tilt, motion track |
Wyze Cam OG | 1080p | IP65 | Improved | Yes (256GB max) | IR LEDs + Spotlight | 40 lumen spotlight, 90 dB siren |
Wyze Cam v4 Bundle | 2.5K QHD | IP65 | Enhanced AAC | Yes (128GB included) | Enhanced Color Night | Multiple cams, local storage |
What makes Wyze waterproof security cameras suitable for outdoor use?
Wyze waterproof security cameras, including the Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam OG, feature an IP65 weather resistance rating. This ensures they are protected against rain, snow, and harsh outdoor conditions, making them ideal for both indoor and outdoor security applications.How does enhanced two-way audio improve Wyze security cameras?
Enhanced two-way audio in Wyze security cameras uses advanced audio coding (AAC), upgraded microphones, and powerful amplifiers. This results in crystal-clear conversations, reduced noise and echo, and improved communication between you and anyone near the camera.Can Wyze security cameras record video locally without a subscription?
Yes, all featured Wyze security cameras support local recording to microSD cards (up to 256GB for most models). This allows for continuous 24/7 video recording without any monthly subscription fees.What is the video resolution of Wyze Cam v4 and how does it benefit security?
The Wyze Cam v4 offers 2.5K QHD resolution, providing stunningly detailed video with Quad High Definition clarity. This high resolution ensures you capture every detail, making it easier to identify people and objects in your footage.Do Wyze security cameras offer night vision capabilities?
Yes, Wyze security cameras are equipped with advanced night vision features. The Wyze Cam v4 and Pan v3 offer enhanced color night vision, while the Wyze Cam OG uses IR LEDs and a built-in spotlight for clear nighttime video.What special security features do Wyze cameras provide to deter intruders?
Wyze cameras include motion-activated spotlights and loud sirens (up to 99 dB) to deter intruders. These features can be triggered automatically or manually to enhance your property’s security.Are Wyze security cameras compatible with smart home systems?
Yes, Wyze security cameras work seamlessly with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, allowing for easy integration and voice control.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 units and a 128GB microSD card for extensive local recording. It offers all the advanced features of the Wyze Cam v4, such as 2.5K QHD video, enhanced color night vision, motion-activated spotlight, and improved two-way audio.How easy is it to install Wyze waterproof security cameras?
Wyze cameras are designed for easy installation, featuring screw-free magnetic mounts and flexible mounting options for walls, ceilings, or flat surfaces. This allows for quick and versatile setup anywhere around your home or business.What is the difference between Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam OG?
Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, and a motion-activated spotlight. Wyze Cam Pan v3 features 360° pan and 180° tilt for full coverage and automatic motion tracking. Wyze Cam OG provides 1080p HD video, a built-in 40 lumen spotlight, and fast live streaming. All models are IP65 weatherproof and support local recording.
