Reliable Outdoor Power Cables for Wyze Cameras on Exterior Walls
Reliable Cable Solutions for Mounting Wyze Cameras Outdoors
When mounting your Wyze camera high on exterior walls, having a reliable, weather-resistant power source is essential. The Wyze Outdoor Power Adapter is specifically designed to provide a durable and safe power connection for your Wyze cameras in outdoor environments. Whether you have a Wyze Cam Pan v3 or Wyze Cam v4, this adapter ensures your camera stays powered through rain, snow, or shine.
Wyze Outdoor Power Adapter: The Ultimate Outdoor Power Solution
Weather-Resistant and Durable Design
The Wyze Outdoor Power Adapter boasts an IP67 weather resistance rating, making it fully capable of withstanding harsh outdoor conditions such as rain, snow, and extreme temperatures ranging from -30°C to 50°C (-22°F to 122°F). This ensures your camera remains powered without interruption regardless of the weather.
Long Cable Length for Flexible Mounting
With a total cable length of 12.5 feet (3.8 meters), including an 8.5 ft DC cable and a 3.9 ft AC cable, this adapter provides ample reach to mount your camera high on exterior walls without worrying about power outlet proximity.
Compatibility and Included Accessories
  • Compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with additional USB-C adapter).
  • Comes with a weatherproof L-shaped Micro USB adapter, wire clips, screws, and anchors for secure installation.
  • Note: For Pan v3 and Cam v3 Pro, both the Outdoor Power Adapter and L-shaped Micro USB Adapter are required.
Technical Specs at a Glance
  • Input Power: 100V-240V AC
  • Output Power: 5V 2A DC
  • Connector to Camera: Micro USB
  • Connector to Wall Plug: 2-pin flat (US)
  • Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
  • Weight: 235 g
  • Certifications: FCC, UL
  • Warranty: 1 Year
Ready for rain, snow, or shine, the Wyze Outdoor Power Adapter is your go-to solution for powering Wyze cameras outdoors safely and reliably.
Wyze Cam Pan v3 mounted outdoors in snowy weather Wyze Cam Pan v3 powered by Outdoor Power Adapter in snowy conditions
Wyze Cam Pan v3: 360° Pan and Tilt with Outdoor Durability
Full Outdoor-Ready Security Camera
The Wyze Cam Pan v3 is a versatile indoor/outdoor camera featuring 360° horizontal pan and 180° vertical tilt, allowing you to cover every angle around your home. It is rated IP65 weather resistant, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter.
Crisp 1080p HD Video and Night Vision
  • Night Vision: 4 IR LEDs (850 nm)
  • Digital Zoom: 8x
  • Video FPS: 20 fps daytime, 15 fps nighttime
Smart Features and Connectivity
  • Built-in speaker and microphone for 2-way audio with noise and echo cancellation.
  • Push notifications for motion alerts.
  • Compatible with Android 9.0+ and iOS 15.0+.
  • Integrates with Alexa, Google Assistant, and IFTTT.
Installation and Power
  • Mounting: Screw 1/4" - 20 thread.
  • Power: Requires Wyze Outdoor Power Adapter for outdoor use.
  • Cable Length: 6 ft (1.8 m) micro USB cable included.
The Pan v3 is perfect for users who want a flexible, weatherproof camera with full pan and tilt capabilities for comprehensive outdoor surveillance.
Wyze Cam v4: Advanced Outdoor Security with 2.5K QHD Resolution
Superior Video Quality and Night Vision
Wyze Cam v4 offers crystal-clear 2.5K QHD (2560x1440) resolution, providing sharper and more detailed footage than standard HD cameras. It features enhanced color night vision with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens) to illuminate dark areas.
Robust Outdoor Features
  • IP65 weather resistance ensures reliable operation in rain or dust.
  • Motion-activated spotlight enhances security by deterring intruders.
  • Supports Wi-Fi 6 for faster and more stable connectivity.
Versatile Mounting Options
  • Stand, wall mount, ceiling mount, or magnetic wall mount with adhesive.
  • Comes with a 6-foot flat micro USB to USB-A cable for power.
Smart Home Integration
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Supports local microSD storage up to 512 GB and cloud storage options.
  • Built-in 99dB waterproof speaker and siren for alerts and deterrence.
For those seeking high-resolution video and advanced night vision in a compact, weatherproof design, Wyze Cam v4 is an excellent choice.
Wyze Cam Pan v3 outdoor lifestyle Wyze Cam Pan v3 providing reliable outdoor security
Why Choose Wyze Outdoor Power Adapter for Your Wyze Cameras?
  • Reliable Power Supply: Designed specifically for outdoor use with weatherproofing and long cable length.
  • Easy Installation: Comes with mounting hardware and wire clips to secure cables neatly on exterior walls.
  • Compatibility: Works seamlessly with multiple Wyze camera models including Pan v3 and Cam v4.
  • Peace of Mind: Certified by FCC and UL with a 1-year warranty.
Mount your Wyze camera high on exterior walls confidently with the Wyze Outdoor Power Adapter, ensuring continuous power and protection against the elements.
Summary
For mounting Wyze cameras outdoors, especially high on exterior walls, the Wyze Outdoor Power Adapter is the essential accessory to ensure your camera stays powered and protected. Pair it with the Wyze Cam Pan v3 for flexible 360° coverage or the Wyze Cam v4 for high-resolution, color night vision security. Together, these products provide a reliable, weather-resistant surveillance solution for your home. Two-way audio with Wyze Cam Enjoy two-way audio communication with Wyze cameras
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam v4
TypeAccessoryCameraCamera
Weather ResistanceIP67IP65IP65
UsagePowers Wyze cameras outdoorsIndoor/outdoor 360° pan & 180° tilt security cameraIndoor/outdoor security camera
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Works with Outdoor Power Adapter (sold separately)Requires Outdoor Power Adapter (sold separately)
Power Adapter Output5V/1A (Indoor)5V/2000mA5V/1A
Cable LengthNot specified6' micro USB cable6' micro USB cable
Video ResolutionN/A1080p (1920x1080)2.5K QHD (2560x1440)
Field of ViewN/A360° horizontal, 180° vertical, 120° FOVDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionN/A4 IR LEDs (850 nm), Color Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs, Color Night Vision
Audio FeaturesN/ABuilt-in speaker, microphone, 2-way audio, noise & echo cancellation99dB waterproof speaker, simultaneous 2-way talk, noise & echo cancellation
Motion TrackingN/AAutomatic motion trackingMotion detection, person detection
ConnectivityN/A802.11 b/g/n 2.4 GHz Wi-Fi (no 5 GHz)2.4 GHz Wi-Fi, Wi-Fi 6
DimensionsN/A124mm (H) x 60mm (W) x 63mm (D)2in x 2in x 2 3/8in
WeightN/A11.29 oz (320 g)0.49 lb (222 g)
Mounting OptionsN/AScrew 1/4" - 20 mountStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
WarrantyNot specified1 Year1 Year
Price$14.99 - $19.99 (varies by variant)$39.98 (single)$35.98 - $107.94 (varies by pack and variant)
What is the Wyze Outdoor Power Adapter and why do I need it for outdoor camera installation?The Wyze Outdoor Power Adapter is a weather-resistant power solution designed specifically for powering Wyze cameras outdoors. It ensures your camera remains safely powered in harsh conditions such as rain, snow, and extreme temperatures, making it essential for mounting Wyze cameras high on exterior walls or in exposed outdoor locations.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, Wyze Cam v4, Wyze Cam Pan v3, and Battery Cam Pro (with an additional USB-C adapter). For Pan v3 and Cam v3 Pro, both the Outdoor Power Adapter and the included L-shaped Micro USB Adapter are required.
How weather-resistant is the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter has an IP67 weather resistance rating, making it fully protected against dust and capable of withstanding heavy rain, snow, and extreme temperatures ranging from -30°C to 50°C (-22°F to 122°F).
What is the total cable length of the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter provides a total cable length of 12.5 feet (3.8 meters), which includes an 8.5 ft DC cable and a 3.9 ft AC cable. This allows for flexible camera placement, even when power outlets are not nearby.
What accessories are included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a weatherproof L-shaped Micro USB adapter, wire clips, screws, and anchors for secure and tidy installation on exterior walls.
What are the technical specifications of the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter features an input power of 100V-240V AC, output power of 5V 2A DC, a Micro USB connector for the camera, and a 2-pin flat (US) connector for the wall plug. It is FCC and UL certified and comes with a 1-year warranty.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is rated IP65 weather resistant and is suitable for outdoor use when paired with the Wyze Outdoor Power Adapter. It offers 360° horizontal pan and 180° vertical tilt for comprehensive coverage.
What video quality does the Wyze Cam Pan v3 provide?The Wyze Cam Pan v3 delivers crisp 1080p HD video resolution (1920 x 1080), 8x digital zoom, and features night vision with 4 IR LEDs for clear footage day and night.
What are the key features of the Wyze Cam v4 for outdoor security?The Wyze Cam v4 offers 2.5K QHD (2560x1440) resolution, enhanced color night vision with IR and spotlight LEDs, IP65 weather resistance, motion-activated spotlight, Wi-Fi 6 support, and versatile mounting options. It also includes a built-in 99dB waterproof speaker and siren for alerts.
Does the Wyze Cam v4 support smart home integration?Yes, the Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT. It also supports local microSD storage up to 512 GB and offers cloud storage options.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 can be mounted using a stand, wall mount, ceiling mount, or magnetic wall mount with adhesive, providing flexibility for various installation scenarios.
Why should I choose the Wyze Outdoor Power Adapter for my Wyze cameras?The Wyze Outdoor Power Adapter is specifically designed for outdoor use, offering reliable power, weatherproofing, long cable length, easy installation with included hardware, and compatibility with multiple Wyze camera models. It is FCC and UL certified and comes with a 1-year warranty for peace of mind.
What are the installation requirements for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with other Wyze camera models?Are there any ongoing promotions or discounts for the Wyze Outdoor Power Adapter?
