Buy Wyze Indoor Home Security Kit with Pan Camera Option
When it comes to securing your home with smart, reliable, and versatile cameras, Wyze offers some of the best indoor home security kits featuring pan camera options. Whether you want full 360° coverage inside your home or a weather-resistant camera for both indoor and outdoor use, Wyze has you covered with their advanced Wyze Cam Pan v3 and Wyze Cam v4 Outdoor Bundle.
Wyze Cam Pan v3: The Ultimate Indoor Pan Camera
360° Pan and 180° Tilt for Complete Coverage
The Wyze Cam Pan v3 is a redesigned indoor/outdoor security camera that offers a full 360° horizontal pan and 180° vertical tilt. This means you can monitor every corner of your room or outdoor space with just one camera, eliminating blind spots and the need for multiple fixed cameras.
Crystal-Clear 1080p Full HD Video
Enjoy sharp and clear video quality with 1080p resolution. The camera supports smooth video streaming at 20 fps during the day and 15 fps at night, ensuring you never miss a detail.
Color Night Vision & Motion Tracking
Equipped with a Starlight sensor and 4 IR LEDs, the Pan v3 delivers vivid color night vision even in low-light environments up to 25 times darker than traditional cameras. Its automatic motion-tracking feature quietly follows movement, so you always know what’s happening without manually adjusting the camera.
Weather-Resistant & Versatile Mounting
Rated IP65, the Wyze Cam Pan v3 is weatherproof, making it suitable for both indoor and outdoor use. It comes with a mounting kit that allows installation on walls or ceilings, even upside down, giving you flexible placement options.
Privacy Mode & Two-Way Audio
Privacy is important, and the Pan v3 offers a unique "Head Down" Privacy Mode that points the camera lens downward and disables recording with a single tap. Plus, built-in microphone and speaker enable two-way audio, so you can communicate with family, pets, or visitors remotely.
Smart Integrations & Storage
Compatible with Alexa, Google Assistant, and IFTTT, the Pan v3 fits seamlessly into your smart home ecosystem. It supports microSD cards up to 256 GB for local storage and offers cloud recording options with Wyze Cam Plus.
"These little plug-and-play cameras are both high-quality and feature-packed while remaining surprisingly affordable." – Verified Customer
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3: Weather-resistant and versatile for indoor/outdoor use
Wyze Cam v4 Outdoor Bundle: Advanced Security with 2.5K QHD Resolution
Crystal-Clear 2.5K QHD Video Quality
The Wyze Cam v4 Outdoor Bundle offers stunning 2.5K QHD resolution, providing ultra-clear video footage that captures every detail with precision.
Enhanced Color Night Vision & Motion-Activated Spotlight
Unlike many outdoor cameras that only offer black-and-white night vision, the Wyze Cam v4 features enhanced color night vision and a motion-activated spotlight to illuminate and deter intruders during nighttime.
24/7 Local Recording & Wi-Fi 6 Support
This bundle includes a 128GB microSD card for continuous local recording, ensuring you never miss a moment. With Wi-Fi 6 support, the camera maintains a stable and fast connection for smooth streaming and alerts.
Smart Home Compatibility
Works seamlessly with Alexa and Google Assistant, allowing voice control and integration with other smart devices in your home.
Included Accessories for Easy Setup
The bundle comes with the Wyze Cam v4 camera, an outdoor power adapter, and a microSD card, making it a complete package for outdoor security.
Ideal for users who want a high-resolution, weatherproof camera with advanced night vision and spotlight features.
Why Choose Wyze for Your Home Security?
  • Affordable yet Feature-Rich: Wyze cameras provide professional-grade features at a fraction of the cost of other brands.
  • Easy Installation: With mounting kits and flexible placement options, setting up your cameras is quick and hassle-free.
  • Smart Automation: Use the Wyze app to create automations, schedules, and shortcuts to customize your home security experience.
  • Reliable Alerts: Receive push notifications and critical alerts to stay informed about any unusual activity.
  • Privacy Control: Easily toggle privacy modes to protect your personal space without unplugging devices.
Enhance Your Setup with Wyze Cam Pan Mounting Kit
For indoor use, the Wyze Cam Pan Mounting Kit offers extra-strong magnetic mounting with a 15-foot micro USB cable and adjustable hinge for perfect camera angles. This kit is ideal for mounting your Pan v3 camera on walls or ceilings indoors, providing secure and flexible installation.
Summary of Wyze Indoor Home Security Kit with Pan Camera Option
FeatureWyze Cam Pan v3Wyze Cam v4 Outdoor Bundle
Resolution1080p Full HD2.5K QHD
Pan & Tilt Range360° pan, 180° tiltFixed camera (no pan/tilt)
Night VisionColor night vision with IR LEDsEnhanced color night vision + spotlight
Weather ResistanceIP65-rated (indoor/outdoor)Outdoor compatible
AudioTwo-way audioYes
StoragemicroSD up to 256GB + cloud option128GB microSD included
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant
PriceStarting at $39.98 (single pack)$69.99 (bundle)
Conclusion
For those looking to buy a Wyze indoor home security kit with a pan camera option, the Wyze Cam Pan v3 is the perfect choice offering dynamic 360° coverage, weather resistance, and smart features. Pair it with the Wyze Cam v4 Outdoor Bundle for comprehensive home security that covers both indoor and outdoor needs with crystal-clear video and advanced night vision. Secure your home with Wyze’s innovative cameras and enjoy peace of mind with smart, affordable, and easy-to-use security solutions. Two-way audio feature with Wyze Cam Pan Communicate easily with two-way audio on Wyze Cam Pan
TypeIndoor/Outdoor Pan & Tilt Security CameraOutdoor Security Camera Bundle
Resolution1080p Full HD (1920 x 1080)2.5K QHD (2560 x 1440)
Pan & Tilt360° Pan, 180° TiltFixed angle (no pan/tilt)
Night VisionColor Night Vision with 4 IR LEDs (850 nm)Enhanced Color Night Vision
Motion TrackingAutomatic motion tracking with quiet motorMotion-activated spotlight
AudioTwo-way audio with noise & echo cancellationTwo-way audio
Weather ResistanceIP65 (requires Outdoor Power Adapter for outdoor use)IP65 (Outdoor Power Adapter included)
Power AdapterSold separately (Wyze Outdoor Power Adapter + L-shaped MicroUSB)Included in bundle
Connectivity802.11 b/g/n, 2.4 GHz Wi-FiWi-Fi 6 support (requires Wi-Fi 6 router)
Field of View120° FOVNot specified
Video Frame RateDay: 20 fps, Night: 15 fpsNot specified
StorageSupports up to 256 GB microSD (local storage)128 GB microSD included for 24/7 local recording
Smart FeaturesMotion & sound detection, custom detection zones, smoke & CO alertsMotion & sound detection, motion detection zones, smoke & CO alerts
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Dimensions124mm (H) x 60mm (W) x 63mm (D)Not specified
Weight320 g (11.29 oz)Not specified
PriceStarting at $39.98 (1 Pack)$69.99 (Bundle with adapter and microSD card)
Included Accessories6' micro USB Cable, Power Adapter, Mounting Kit, Quick Start GuideWyze Cam v4, Outdoor Power Adapter, 128GB microSD Card
Warranty1 Year1 Year
What is included in the Wyze Indoor Home Security Kit with Pan Camera Option?The Wyze Indoor Home Security Kit with Pan Camera Option typically includes the Wyze Cam Pan v3, which offers 360° pan and 180° tilt for complete room coverage. You can also pair it with the Wyze Cam v4 Outdoor Bundle for comprehensive indoor and outdoor security. The kit may include mounting accessories, power adapters, and microSD cards depending on the bundle you choose.
What are the key features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 features 360° horizontal pan, 180° vertical tilt, 1080p Full HD video, color night vision with a Starlight sensor, motion tracking, IP65 weather resistance, two-way audio, privacy mode, and compatibility with Alexa, Google Assistant, and IFTTT. It supports local storage with microSD cards up to 256GB and offers cloud recording options.
Can the Wyze Cam Pan v3 be used outdoors?Yes, the Wyze Cam Pan v3 is IP65-rated for weather resistance, making it suitable for both indoor and outdoor use. It comes with a versatile mounting kit for easy installation on walls or ceilings, even upside down.
How does the Wyze Cam Pan v3’s privacy mode work?The Wyze Cam Pan v3 offers a unique 'Head Down' Privacy Mode, which points the camera lens downward and disables recording with a single tap, ensuring your privacy whenever you need it.
What is the video quality of the Wyze Cam Pan v3 and Wyze Cam v4 Outdoor Bundle?The Wyze Cam Pan v3 records in 1080p Full HD, while the Wyze Cam v4 Outdoor Bundle offers ultra-clear 2.5K QHD resolution for even more detailed video footage.
Does the Wyze Cam Pan v3 have night vision?Yes, the Wyze Cam Pan v3 is equipped with a Starlight sensor and 4 IR LEDs, providing vivid color night vision even in low-light environments up to 25 times darker than traditional cameras.
What storage options are available for Wyze security cameras?Wyze security cameras support local storage via microSD cards (up to 256GB for Pan v3 and 128GB included with the v4 Outdoor Bundle) and offer cloud recording options through Wyze Cam Plus.
Are Wyze cameras compatible with smart home systems?Yes, Wyze cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control within your smart home ecosystem.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 camera, an outdoor power adapter, a 128GB microSD card for continuous local recording, and mounting accessories for easy setup.
How does the Wyze Cam v4 Outdoor Bundle enhance night security?The Wyze Cam v4 Outdoor Bundle features enhanced color night vision and a motion-activated spotlight, which illuminates and deters intruders during nighttime, providing clear and colorful footage even in the dark.
Is the Wyze Cam Pan Mounting Kit necessary for installation?The Wyze Cam Pan Mounting Kit is recommended for secure and flexible indoor installation. It features extra-strong magnetic mounting, a 15-foot micro USB cable, and an adjustable hinge for perfect camera angles on walls or ceilings.
What makes Wyze home security cameras a good choice?Wyze home security cameras are affordable yet feature-rich, offering professional-grade features like high-resolution video, smart automation, reliable alerts, easy installation, and privacy controls at a fraction of the cost of other brands.
Can I communicate through Wyze security cameras?Yes, both the Wyze Cam Pan v3 and Wyze Cam v4 support two-way audio, allowing you to communicate with family, pets, or visitors remotely through the Wyze app.
How do I receive alerts from Wyze security cameras?You will receive push notifications and critical alerts on your smartphone via the Wyze app whenever unusual activity is detected by your Wyze security cameras.
Can you tell me more about the features of the Wyze Cam Pan v3?How does the night vision feature work on the Wyze Cam Pan v3?What is the installation process like for the Wyze Cam Pan Mounting Kit?
