Buy WiFi Enabled Smart Lighting Kit with Multi-Color LED Lights
Upgrade your home lighting experience with the
Wyze Bulb Color, a top-tier WiFi-enabled smart lighting kit that offers vibrant multi-color LED lights. Perfect for creating the perfect ambiance in any room, this smart bulb combines advanced technology with ease of use, making it a must-have for any smart home enthusiast.
Wyze Bulb Color: The Ultimate Multi-Color Smart Bulb
Stunning 16 Million Colors & Tunable White Light
The Wyze Bulb Color stands out with its ability to display
16 million colors, allowing you to customize your lighting to match any mood or occasion. Whether you want a cozy warm white or a bright cool white, this bulb offers a
color temperature range from 1800K to 6500K with a
90+ Color Rendering Index (CRI) for true-to-life colors.
Brightness and Efficiency
With a maximum brightness of
1100 lumens, the Wyze Bulb Color is extra bright yet energy-efficient, consuming only
12 watts of power. Its dimmable feature lets you adjust the light intensity smoothly through the Wyze app or voice commands, perfect for setting the right atmosphere.
Smart Connectivity and Compatibility
- Connects via 802.11 b/g/n WiFi (2.4 GHz) and Bluetooth for seamless setup and control.
- Compatible with Android 9.0+ and iOS 15.0+ devices.
- Integrates effortlessly with Amazon Alexa, Google Assistant, and IFTTT for voice control and automation.
Durable and Safe for Various Environments
- Rated for use in damp locations, ideal for covered outdoor areas or bathrooms.
- Not suitable for fully enclosed luminaires.
- Long lifespan of 25,000 hours ensures years of reliable use.
- Certified with Energy Star, UL, FCC, and other regulatory compliances for safety and efficiency.
Easy Setup and Group Control
You can set up multiple Wyze Bulb Colors simultaneously and group them in the Wyze app for synchronized control. This makes it easy to manage all your smart bulbs in one room or throughout your home with a single tap or voice command.
"Wyze Bulb Color is an insufferable snob, but it’s tough to get excited when you’re the greatest 16 million color smart bulb on earth."
Experience vibrant, customizable lighting in your living space.
Advanced Features for Smart Home Automation
Automations and Scheduling
With the Wyze app, you can create automations such as:
- Scheduling your bulbs to turn on/off at specific times.
- Setting device triggers to sync multiple bulbs.
- Location-based triggers to turn lights on when you arrive home.
- Blink feature for notifications (e.g., package delivery alerts).
Voice and App Control
Control your Wyze Bulb Color hands-free using Alexa or Google Assistant. The Wyze app also allows you to adjust brightness, color, and temperature remotely, giving you full control wherever you are.
Grouping with Other Wyze Devices
Wyze Bulb Color can be grouped with other Wyze lighting products like Wyze Light Strips and the original Wyze Bulb, enabling a comprehensive smart lighting ecosystem.
Set the perfect mood in your bedroom with customizable colors and brightness.
Why Choose Wyze Bulb Color for Your Smart Lighting Kit?
- Multi-pack options: Available in 2, 4, or 6 packs to fit any home size.
- Energy efficient: Save on electricity bills while enjoying bright, colorful lighting.
- Long-lasting: 25,000 hours of life expectancy means fewer replacements.
- Easy installation: Fits standard E26 sockets and works with your existing fixtures.
- Reliable connectivity: Uses 2.4 GHz WiFi and Bluetooth for stable performance.
- Safe and certified: Meets multiple safety and environmental standards.
"You can use multiple color bulbs in one fixture and control them all together for a seamless smart lighting experience."
Brighten up your kitchen with dynamic, color-changing smart bulbs.
Conclusion
The
Wyze Bulb Color is the perfect WiFi-enabled smart lighting kit for anyone looking to add vibrant, customizable multi-color LED lights to their home. With its extensive color range, smart automation features, and compatibility with popular voice assistants, it offers both style and convenience. Whether you want to create a relaxing ambiance, energize your workspace, or set the mood for a party, Wyze Bulb Color delivers exceptional performance and value.
What is the Wyze Bulb Color WiFi Enabled Smart Lighting Kit?
The Wyze Bulb Color is a WiFi-enabled smart lighting kit featuring multi-color LED lights. It allows you to customize your home lighting with 16 million colors, tunable white light, and advanced smart home automation features, making it ideal for any room or occasion.How many colors can the Wyze Bulb Color display?
The Wyze Bulb Color can display up to 16 million colors, allowing you to create the perfect ambiance for any mood or event.What is the brightness and energy efficiency of the Wyze Bulb Color?
The Wyze Bulb Color offers a maximum brightness of 1100 lumens while consuming only 12 watts of power, making it both extra bright and energy efficient.Is the Wyze Bulb Color compatible with voice assistants?
Yes, the Wyze Bulb Color is compatible with Amazon Alexa, Google Assistant, and IFTTT, allowing for convenient voice control and automation.Can I control the Wyze Bulb Color remotely?
Yes, you can control the Wyze Bulb Color remotely using the Wyze app on Android 9.0+ or iOS 15.0+ devices. The app lets you adjust brightness, color, and temperature from anywhere.What smart home features does the Wyze Bulb Color offer?
The Wyze Bulb Color supports automations such as scheduling, device triggers, location-based triggers, and a blink feature for notifications. You can also group bulbs for synchronized control.Is the Wyze Bulb Color suitable for outdoor use?
The Wyze Bulb Color is rated for use in damp locations, making it suitable for covered outdoor areas or bathrooms. However, it is not recommended for fully enclosed luminaires.How long does the Wyze Bulb Color last?
The Wyze Bulb Color has a long lifespan of 25,000 hours, ensuring years of reliable use with minimal replacements.What certifications does the Wyze Bulb Color have?
The Wyze Bulb Color is certified with Energy Star, UL, FCC, and other regulatory compliances, ensuring safety and energy efficiency.Can I group Wyze Bulb Color with other Wyze lighting products?
Yes, you can group Wyze Bulb Color with other Wyze lighting products like Wyze Light Strips and the original Wyze Bulb for a comprehensive smart lighting ecosystem.What are the installation requirements for Wyze Bulb Color?
The Wyze Bulb Color fits standard E26 sockets and works with your existing fixtures. It connects via 2.4 GHz WiFi and Bluetooth for easy setup and reliable performance.Are there multi-pack options available for Wyze Bulb Color?
Yes, the Wyze Bulb Color is available in 2, 4, or 6 pack options to suit different home sizes and lighting needs.
