Buy Budget Outdoor IP65 Pan-Tilt Security Camera with Floodlight
Buy Outdoor IP65 Security Cameras with Enhanced Resolution and Wide Angle
Looking for a reliable, budget-friendly outdoor security camera with IP65 weather resistance, enhanced resolution, pan-tilt capabilities, hardwired floodlight, and a wide-angle view? Discover the Wyze Cam Floodlight v2 and the Whole Home Security Enhanced Kit — perfect solutions to illuminate and secure your property with smart features and crystal-clear video.
Wyze Cam Floodlight v2: Powerful Outdoor Security with 2K Resolution
Brilliant Illumination and Wide-Angle Coverage
The Wyze Cam Floodlight v2 is designed to dominate the dark with 2800 lumens of bright, dimmable LED light panels. Its 160° diagonal wide-angle lens ensures you capture a broad view of your driveway, porch, or backyard, minimizing blind spots and maximizing security coverage.
Enhanced 2K Video Quality with Color Night Vision
Equipped with a 2K (2304 x 1296) resolution camera, this floodlight camera delivers crisp, detailed video day and night. The Color Night Vision feature allows you to see vibrant, full-color footage even in low-light conditions, enhancing your ability to identify visitors or intruders clearly.
Hardwired Power and IP65 Weather Resistance
This camera is hardwired with a 110-120V AC power supply, ensuring continuous operation without worrying about battery life. Its IP65 rating guarantees protection against dust and water, making it ideal for all weather conditions — rain or shine.
Smart Features for Seamless Home Integration
  • Two-way audio with built-in microphone and speaker lets you communicate directly through the camera.
  • AI-powered light control and dusk-to-dawn automation provide smart lighting that adjusts automatically.
  • Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Supports local storage with up to 256GB microSD card for continuous or event-triggered recording.
Dimensions and Build
  • Size: 9.5in x 7.7in x 7.0in (24.13cm x 19.56cm x 17.78cm)
  • Weight: 2.76 lbs (1.25 kg)
  • Durable polycarbonate body with glass/plastic lens options
  • Available in Black or White with a matte finish
The Wyze Cam Floodlight v2 is a perfect blend of powerful lighting, enhanced video quality, and smart home compatibility — all at a budget-friendly price of $89.98.
Wyze Cam Floodlight v2 illuminating driveway at night Alt text: Outdoor driveway illuminated by Wyze Cam Floodlight v2 with motion detection
Whole Home Security Enhanced Kit: Comprehensive Protection Bundle
What’s Included?
The Whole Home Security Enhanced Kit bundles the Wyze Cam Floodlight v2 with the Wyze Cam v4 (Color), providing a versatile security solution for your entire home.
  • Wyze Cam Floodlight v2: Hardwired floodlight camera with 2K resolution and wide-angle view.
  • Wyze Cam v4 (Color): Compact indoor/outdoor camera with color video and smart features.
Benefits of the Kit
  • Enhanced coverage with both floodlight and standard cameras.
  • Easy integration and management through the Wyze app.
  • Cost-effective bundle priced at $256.91, offering savings over individual purchases.
  • Multiple color combinations available to match your home’s aesthetic.
This kit is ideal for users who want to secure multiple areas with high-quality cameras and floodlights, all controlled from a single app.
Why Choose Wyze Outdoor Security Cameras?
IP65 Weatherproof Rating
Wyze outdoor cameras, including the Floodlight v2, are IP65 rated, meaning they are dust-tight and protected against water jets from any direction. This makes them reliable for outdoor use in various climates.
Wide-Angle and Enhanced Resolution
With a 160° field of view and 2K video quality, Wyze cameras provide expansive coverage and detailed footage, helping you monitor your property effectively.
Hardwired Power for Continuous Operation
Unlike battery-powered cameras, the Wyze Cam Floodlight v2 uses a hardwired power supply, ensuring uninterrupted security without the hassle of recharging.
Smart Home Integration and AI Features
Wyze cameras support popular smart assistants and offer AI-powered features like light control and motion detection, enhancing your home security experience.
Summary
If you want to buy an outdoor IP65 security camera with enhanced resolution, hardwired floodlight, and a wide-angle view that is budget-friendly, the Wyze Cam Floodlight v2 and the Whole Home Security Enhanced Kit are excellent choices. They combine powerful lighting, crisp 2K video, smart automation, and durable weatherproof design to keep your home safe and well-lit. Man speaking through Wyze Cam Floodlight v2 two-way audio Alt text: Man using two-way audio feature on Wyze Cam Floodlight v2 Smart home integration with Alexa and Google Assistant Alt text: Smart home devices including Wyze Cam Floodlight v2 controlled by Alexa and Google Assistant
FeatureWyze Cam Floodlight v2Whole Home Security Enhanced Kit
Included ProductsWyze Cam Floodlight v2Wyze Cam v4 + Wyze Cam Floodlight v2
Camera Resolution2KWyze Cam v4: 2.5K QHD
Wyze Cam Floodlight v2: 2K
Field of View160°Wyze Cam v4: 115.8° DFOV
Floodlight v2: 160°
Lighting2 floodlight heads, 2800 lumens LEDsFloodlight v2: 2 floodlight heads, 2800 lumens LEDs
Night VisionColor Night VisionWyze Cam v4: Enhanced Color Night Vision
Floodlight v2: Color Night Vision
Local Recording24/7 local recording to microSD (up to 256 GB)24/7 local recording (Wyze Cam v4 and Floodlight v2)
AI-Powered Light ControlYesYes (Floodlight v2)
Two-Way Talk + SirenYes, 105dB sirenYes, included on both cameras
Motion Detection270° PIR motion detectionYes, on both cameras
Ambient Light ModeYesYes (Floodlight v2)
Weather ResistanceIP65IP65
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google Assistant
Wi-Fi Support2.4 GHzWyze Cam v4: 2.4 GHz & Wi-Fi 6
Floodlight v2: 2.4 GHz
Power SourceWiredWired
Subscription RequiredNo (local recording), Cam Plus optionalNo (local recording), Cam Plus optional
Price$89.98$256.91
What is the Wyze Cam Floodlight v2 and what features does it offer?The Wyze Cam Floodlight v2 is a hardwired outdoor security camera with a 2K resolution camera, 2800 lumens of dimmable LED lighting, a 160° wide-angle lens, color night vision, two-way audio, AI-powered light control, dusk-to-dawn automation, and compatibility with Alexa, Google Assistant, and IFTTT. It is IP65 weather-resistant and supports local storage with up to a 256GB microSD card.
Is the Wyze Cam Floodlight v2 weatherproof?Yes, the Wyze Cam Floodlight v2 is IP65 rated, making it dust-tight and protected against water jets from any direction. This ensures reliable performance in various outdoor weather conditions.
What is the video quality of the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 features enhanced 2K (2304 x 1296) resolution, providing crisp and detailed video footage both day and night. It also includes color night vision for vibrant, full-color images in low-light conditions.
Does the Wyze Cam Floodlight v2 require batteries?No, the Wyze Cam Floodlight v2 is hardwired and powered by a 110-120V AC supply, ensuring continuous operation without the need for battery replacements or recharging.
Can I control the Wyze Cam Floodlight v2 with smart home devices?Yes, the Wyze Cam Floodlight v2 is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and seamless integration with your smart home ecosystem.
What is included in the Whole Home Security Enhanced Kit?The Whole Home Security Enhanced Kit includes the Wyze Cam Floodlight v2 and the Wyze Cam v4 (Color), providing comprehensive security coverage for both indoor and outdoor areas. The kit is managed through the Wyze app and is available in multiple color combinations.
How wide is the field of view on the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 offers a 160° diagonal wide-angle lens, ensuring broad coverage and minimizing blind spots around your property.
Does the Wyze Cam Floodlight v2 support local video storage?Yes, the Wyze Cam Floodlight v2 supports local storage with a microSD card of up to 256GB, allowing for continuous or event-triggered recording without a subscription.
What are the dimensions and build materials of the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 measures 9.5in x 7.7in x 7.0in (24.13cm x 19.56cm x 17.78cm), weighs 2.76 lbs (1.25 kg), and features a durable polycarbonate body with glass or plastic lens options. It is available in Black or White with a matte finish.
How much does the Wyze Cam Floodlight v2 and the Whole Home Security Enhanced Kit cost?The Wyze Cam Floodlight v2 is priced at $89.98, while the Whole Home Security Enhanced Kit, which includes both the Floodlight v2 and Wyze Cam v4 (Color), is available for $256.91, offering savings over purchasing the items separately.
What are the benefits of choosing Wyze outdoor security cameras?Wyze outdoor security cameras offer IP65 weatherproof protection, enhanced 2K resolution, wide-angle coverage, hardwired power for continuous operation, smart home integration, AI-powered features, and budget-friendly pricing, making them an excellent choice for reliable home security.
Can you tell me more about the features of the Wyze Cam Floodlight v2?How does the Color Night Vision feature work on the Wyze Cam Floodlight v2?What is the installation process for the Wyze Cam Floodlight v2?
