Buy IP65 Outdoor Security Cameras with Continuous microSD Recording
Looking for reliable
IP65-rated outdoor security cameras that offer
continuous microSD recording? Whether you want wired or wireless options, floodlight integration, or 360° pan and tilt capabilities, Wyze has you covered with a range of smart cameras designed for robust outdoor protection and seamless local storage.
Wyze Cam v4 – Advanced Wired Outdoor Security Camera
Experience crystal-clear security with the
Wyze Cam v4, a versatile wired camera built for outdoor use with an IP65 weather resistance rating. This camera delivers stunning
2.5K QHD resolution and features
Enhanced Color Night Vision with motion-activated spotlights to keep your property safe day and night.
Key Features:
- Continuous microSD recording up to 512 GB (local storage) for uninterrupted footage without subscription.
- IP65 weather resistance ensures durability in rain, snow, and dust.
- Wide field of view: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°.
- Wi-Fi 6 support for faster, more reliable connectivity.
- Smart integrations: Alexa, Google Assistant, and IFTTT compatibility.
- Two-way audio with a 99dB waterproof speaker and built-in siren for active deterrence.
- Multiple mounting options: stand, wall, ceiling, and magnetic mounts.
Why Choose Wyze Cam v4?
With continuous local recording on a microSD card, you can store weeks of footage without worrying about cloud subscription fees. The camera’s
color night vision and spotlight provide clear visibility even in complete darkness, making it ideal for monitoring driveways, backyards, and entryways.
Wyze Cam Floodlight v2 – Brighten and Secure Your Outdoors
Illuminate your property while securing it with the
Wyze Cam Floodlight v2. This wired floodlight camera combines powerful
2800 lumens LED lighting with
2K video resolution and
color night vision to dominate the dark.
Brighten your outdoor security with Wyze Cam Floodlight v2
Highlights:
- Continuous local recording on microSD cards up to 256 GB.
- IP65 weatherproof design for reliable outdoor use.
- 160° wide-angle view captures a broad area.
- Dusk-to-dawn automation and AI-powered light control for smart lighting.
- Two-way talk and a loud 105dB siren for active security.
- Compatible with Alexa, Google Assistant, and IFTTT.
Perfect For:
Porches, driveways, and large outdoor spaces where both lighting and security are priorities. The floodlight’s bright LEDs and wide field of view ensure you never miss a detail, while continuous recording keeps a local backup of all activity.
Wyze Cam Pan v3 – 360° Pan & Tilt Outdoor Camera
For full coverage with flexible viewing angles, the
Wyze Cam Pan v3 is a smart choice. This IP65-rated camera offers
360° horizontal and 180° vertical rotation, allowing you to monitor large outdoor areas with a single device.
Weather-resistant Wyze Cam Pan v3 for versatile outdoor monitoring
Features:
- Supports continuous microSD recording up to 256 GB (ExFAT format).
- 1080p HD video with 120° field of view.
- IP65 weather resistance for all-season outdoor use.
- Two-way audio with noise and echo cancellation.
- Requires Wyze Outdoor Power Adapter (sold separately) for outdoor power.
Ideal Use Cases:
Perfect for patios, gardens, and wide yards where you want to pan and tilt remotely to track movement or scan the environment. Continuous recording ensures you have a full video history stored locally.
Wyze Battery Cam Pro – Wire-Free Outdoor Security with Continuous Recording
If you prefer a
wireless, battery-powered option, the
Wyze Battery Cam Pro offers
2.5K HDR video with
IP65 weatherproofing and
continuous microSD recording capability.
Standout Specs:
- Removable rechargeable battery packs with up to 6 months battery life (in motion-activated mode).
- Supports microSD cards up to 256 GB for local continuous recording.
- Integrated spotlight and siren with radar + PIR motion detection.
- Dual-band Wi-Fi (2.4 & 5 GHz) for flexible connectivity.
- Two-way audio with built-in speaker and microphone.
Important Notes:
Continuous recording on battery power will drain the battery faster; for 24/7 recording, connecting to a 5V 2A AC power source is recommended. This camera is ideal for locations where wiring is difficult or impossible.
Why Choose IP65 Outdoor Cameras with Continuous microSD Recording?
IP65-rated cameras are dust-tight and protected against water jets, making them perfect for outdoor environments exposed to weather elements. Continuous microSD recording allows you to store video locally without relying solely on cloud subscriptions, giving you control over your footage and privacy.
With Wyze’s lineup, you get a variety of options tailored to your needs—whether you want wired power and floodlight integration, pan and tilt flexibility, or wireless freedom with long battery life.
Summary of Wyze IP65 Outdoor Cameras with Continuous microSD Recording
Product | Resolution | Continuous microSD Recording | Weatherproof | Power Type | Special Features |
Wyze Cam v4 | 2.5K QHD | Up to 512 GB | IP65 | Wired | Color Night Vision, Spotlight, Wi-Fi 6 |
Wyze Cam Floodlight v2 | 2K | Up to 256 GB | IP65 | Hardwired | 2800 Lumens LED, AI Light Control |
Wyze Cam Pan v3 | 1080p HD | Up to 256 GB | IP65 | Wired (adapter required) | 360° Pan & Tilt, Two-way Audio |
Wyze Battery Cam Pro | 2.5K HDR | Up to 256 GB | IP65 | Battery/Wireless | Radar + PIR Detection, Spotlight |
Invest in a Wyze IP65 outdoor security camera today to enjoy
continuous local recording,
robust weather resistance, and
smart home integration for comprehensive home protection.
What does IP65 weather resistance mean for outdoor security cameras?
IP65 weather resistance means the camera is dust-tight and protected against water jets from any direction, making it ideal for outdoor use in rain, snow, and dusty environments.Which Wyze outdoor security cameras support continuous microSD recording?
Wyze Cam v4, Wyze Cam Floodlight v2, Wyze Cam Pan v3, and Wyze Battery Cam Pro all support continuous microSD recording, allowing you to store video footage locally without a subscription.How much local storage do Wyze outdoor cameras support for continuous recording?
Wyze Cam v4 supports microSD cards up to 512 GB, while Wyze Cam Floodlight v2, Wyze Cam Pan v3, and Wyze Battery Cam Pro support microSD cards up to 256 GB.Do Wyze outdoor security cameras require a cloud subscription for continuous recording?
No, Wyze outdoor security cameras with microSD card slots offer continuous local recording without the need for a cloud subscription, giving you full control over your footage.What are the power options for Wyze IP65 outdoor security cameras?
Wyze offers both wired and wireless options. Wyze Cam v4 and Wyze Cam Floodlight v2 are wired, Wyze Cam Pan v3 requires a Wyze Outdoor Power Adapter (sold separately), and Wyze Battery Cam Pro is battery-powered for wire-free installation.Can I use Wyze outdoor cameras with Alexa or Google Assistant?
Yes, all Wyze IP65 outdoor security cameras are compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.What is the video resolution of Wyze outdoor security cameras?
Wyze Cam v4 and Wyze Battery Cam Pro offer 2.5K QHD/HDR resolution, Wyze Cam Floodlight v2 provides 2K resolution, and Wyze Cam Pan v3 delivers 1080p HD video.Do Wyze outdoor cameras have night vision capabilities?
Yes, Wyze Cam v4 and Wyze Cam Floodlight v2 feature enhanced color night vision, while Wyze Cam Pan v3 and Wyze Battery Cam Pro also offer night vision for clear footage in low-light conditions.How does continuous recording affect the battery life of Wyze Battery Cam Pro?
Continuous recording on battery power will drain the battery faster. For 24/7 continuous recording, it is recommended to connect the Wyze Battery Cam Pro to a 5V 2A AC power source.What special features do Wyze outdoor security cameras offer?
Wyze outdoor cameras offer features such as color night vision, motion-activated spotlights, two-way audio, built-in sirens, 360° pan and tilt, AI-powered light control, and radar + PIR motion detection, depending on the model.Are Wyze outdoor security cameras suitable for all weather conditions?
Yes, all listed Wyze outdoor security cameras are IP65-rated, making them suitable for use in various weather conditions including rain, snow, and dust.What are the ideal use cases for each Wyze outdoor camera model?
Wyze Cam v4 is ideal for driveways and entryways, Wyze Cam Floodlight v2 is perfect for porches and large outdoor spaces needing lighting, Wyze Cam Pan v3 is great for patios and wide yards requiring pan and tilt, and Wyze Battery Cam Pro is best for locations where wiring is difficult.
