Affordable Indoor & Outdoor Security Cameras with LED Spotlight
Affordable Indoor and Outdoor Security Cameras with LED and Motion Spotlight
Looking to buy an affordable security camera that works both indoors and outdoors, equipped with LED lighting and motion-activated spotlights? Wyze offers a range of smart cameras designed to keep your home safe and well-lit, day and night. Whether you want a standalone camera or a complete security kit, these options combine advanced video quality, smart features, and reliable motion-activated lighting to enhance your home security.
Wyze Cam Floodlight v2: Powerful Outdoor Security with 2800 Lumens LED Spotlight
Wyze Cam Floodlight v2 illuminating driveway at night Alt: Outdoor security camera with bright floodlight illuminating driveway at night The Wyze Cam Floodlight v2 is a top choice for outdoor security with its ultra-bright 2800 lumens LED floodlight and 2K video resolution. This camera offers:
  • 2800 Lumens LED Lighting: Two dimmable LED panels provide bright, clear illumination to deter intruders and improve night visibility.
  • 2K Video with Color Night Vision: Capture crisp, colorful footage even in low light.
  • 160° Wide-Angle View: Covers a broad area for comprehensive monitoring.
  • Motion-Activated Spotlight: Lights up automatically when motion is detected, enhancing security and alerting you to activity.
  • 24/7 Local Recording: Supports up to 256 GB microSD card for continuous video storage.
  • Two-Way Audio & 105dB Siren: Communicate with visitors or scare off unwanted guests.
  • Weather Resistant (IP65): Built to withstand rain, snow, and extreme temperatures.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Dusk-to-Dawn Automation: Automatically turns on the floodlight at night and off during the day.
Priced affordably at under $90, this camera is perfect for securing your porch, driveway, or backyard with powerful lighting and smart detection.
Wyze Cam v4: Versatile Indoor/Outdoor Camera with Motion-Activated Spotlight
Wyze Cam v4 mounted outdoors with motion spotlight Alt: Indoor/outdoor security camera with two-way audio and spotlight The Wyze Cam v4 is a compact yet feature-packed camera suitable for both indoor and outdoor use. Key highlights include:
  • 2.5K QHD Video Resolution: Crystal-clear video quality for detailed monitoring.
  • Enhanced Color Night Vision: See vivid colors even in the dark.
  • Motion-Activated Spotlight: Integrated white spotlight (72 lumens) automatically turns on when motion is detected, providing extra security and visibility.
  • Wide Field of View: 115.8° diagonal angle covers a large area.
  • Wi-Fi 6 Support: Faster and more reliable wireless connection.
  • Two-Way Audio & Built-In Siren: Communicate and deter intruders with ease.
  • Weather Resistant (IP65): Durable for outdoor conditions.
  • Local and Cloud Storage Options: Supports microSD cards up to 512 GB and cloud plans.
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT.
This camera is ideal for users who want a flexible solution that can be placed indoors or outdoors, with the added benefit of a motion-triggered spotlight to brighten up suspicious activity.
Wyze Cam Pan v3: 360° Pan & Tilt with Motion Spotlight for Full Coverage
Wyze Cam Pan v3 outdoor in snowy weather Alt: Weather-resistant pan-tilt security camera outdoors in snowy conditions For those needing full-area coverage with motion spotlight capabilities, the Wyze Cam Pan v3 offers:
  • 360° Horizontal and 180° Vertical Rotation: Pan and tilt to cover every angle around your home.
  • 1080p Full HD Video: Clear and smooth video streaming.
  • Motion Tracking: Automatically follows movement to keep subjects in frame.
  • 4 IR LEDs for Night Vision: See clearly in complete darkness.
  • Motion-Activated Spotlight: Bright white LEDs activate on motion detection.
  • Two-Way Audio with Noise Cancellation: Clear communication with visitors or intruders.
  • IP65 Weather Resistance: Suitable for outdoor use with the Wyze Outdoor Power Adapter.
  • Supports up to 256 GB microSD Storage: Local video recording.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This camera is perfect for users who want dynamic coverage with the ability to spotlight and track movement, ensuring no blind spots around your property.
Whole Home Security Enhanced Kit: Complete Indoor & Outdoor Protection
If you want a comprehensive security solution, the Whole Home Security Enhanced Kit bundles the best of Wyze’s indoor and outdoor cameras:
  • Includes Wyze Cam v4 and Wyze Cam Floodlight v2 in your choice of colors.
  • Combines indoor/outdoor video quality with powerful floodlight security.
  • Offers seamless integration and control through the Wyze app.
  • Priced at $256.91, this kit provides excellent value for full home coverage.
This kit is ideal for homeowners looking to secure multiple areas with advanced cameras and motion-activated lighting.
Why Choose Wyze Cameras with LED and Motion Spotlight?
"Motion-activated spotlights not only illuminate suspicious activity but also act as a strong deterrent against intruders. Wyze cameras combine this with high-resolution video and smart home compatibility, making them an affordable and effective security solution."
Wyze cameras stand out for their:
  • Affordable pricing without compromising on features.
  • Motion-activated LED spotlights that enhance night security.
  • High-quality video resolution for clear identification.
  • Weather resistance for reliable outdoor use.
  • Smart home integration for convenient voice and app control.
  • Flexible mounting options for indoor and outdoor placement.
Secure your home today with Wyze’s affordable indoor and outdoor security cameras featuring LED lighting and motion spotlights. Choose the model that fits your needs and enjoy peace of mind with smart, bright, and reliable home security.
FeatureWyze Cam Floodlight v2Wyze Cam v4Whole Home Security Enhanced KitWyze Cam Pan v3
TypeFloodlight CameraSecurity CameraBundle (Wyze Cam v4 + Wyze Cam Floodlight v2)Pan & Tilt Security Camera
Resolution2K (2560x1440)2.5K QHD (2560x1440)Wyze Cam v4: 2.5K QHD, Floodlight v2: 2K1080p (1920x1080)
Field of View160° wide-angle115.9° (D) x 98.5° (H) x 53.1° (V)Wyze Cam v4: 115.9° (D) x 98.5° (H) x 53.1° (V)120° FOV
Night VisionColor Night VisionEnhanced Color Night VisionEnhanced Color Night Vision (Wyze Cam v4) + Floodlight v24 IR LEDs (850 nm), B&W + Color Night Vision
Lighting2 floodlight heads, 2800 lumens, Ambient Light ModeMotion-activated spotlight, 2 white spotlight LEDs (72 lumens)Floodlight v2: 2 floodlight heads, 2800 lumensNo built-in floodlight
Motion Detection270° PIR motion detectionYes, with custom detection zonesYes (Wyze Cam v4 + Floodlight v2)Yes
Two-Way TalkYesYesYesYes
Siren105 dB99 dBIncludedIncluded
Local Recording24/7 local recording to microSD (up to 256GB)24/7 local recording to microSD (up to 256GB)24/7 local recording (Wyze Cam v4 + Floodlight v2)Supports up to 256GB microSD
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Weather ResistanceIP65IP65IP65IP65
Power SourceWired (floodlight wiring or plug-in mount)WiredWiredWired
Wi-Fi Support2.4 GHz2.4 GHz + Wi-Fi 62.4 GHz + Wi-Fi 6 (Wyze Cam v4)2.4 GHz
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Special FeaturesAI-Powered Light Control, Dusk-to-Dawn Automation, Ambient Light ModeAuto-zoom with AI, Smoke & CO Alerts, Wide Dynamic Range (WDR)Combination of Wyze Cam v4 and Floodlight v2 features360° pan, 180° tilt, magnetic mount
DimensionsNot specified2in x 2in x 2 3/8inN/A124mm (H) x 60mm (W) x 63mm (D)
WeightNot specified0.49 lb (222 g)N/A11.29 oz (320 g)
Price$89.98$35.98 (with free 32GB microSD card)$256.91$39.98
Color VariantsBlack, WhiteBlack, Grey, WhiteWyze Cam v4: Black, Grey, White; Floodlight v2: Black, WhiteBlack, White
What are the best affordable security cameras with LED and motion-activated spotlights?Wyze offers a range of affordable security cameras equipped with LED lighting and motion-activated spotlights, including the Wyze Cam Floodlight v2, Wyze Cam v4, and Wyze Cam Pan v3. These cameras provide advanced video quality, smart features, and reliable motion-activated lighting for both indoor and outdoor security.
What features does the Wyze Cam Floodlight v2 offer for outdoor security?The Wyze Cam Floodlight v2 features ultra-bright 2800 lumens LED lighting, 2K video resolution with color night vision, a 160° wide-angle view, motion-activated spotlight, 24/7 local recording, two-way audio, a 105dB siren, IP65 weather resistance, smart home integration, and dusk-to-dawn automation. It is ideal for illuminating and securing driveways, porches, and backyards.
Can Wyze security cameras be used both indoors and outdoors?Yes, Wyze offers versatile cameras like the Wyze Cam v4 and Wyze Cam Pan v3 that are designed for both indoor and outdoor use. These cameras are weather resistant (IP65 rated) and come with features such as motion-activated spotlights, high-resolution video, and smart home compatibility.
How does the motion-activated spotlight work on Wyze cameras?Wyze cameras with motion-activated spotlights automatically turn on their integrated LED lights when motion is detected. This not only illuminates the area for better video capture but also acts as a deterrent to potential intruders.
What is included in the Wyze Whole Home Security Enhanced Kit?The Wyze Whole Home Security Enhanced Kit includes both the Wyze Cam v4 and Wyze Cam Floodlight v2, allowing for comprehensive indoor and outdoor protection. The kit offers seamless integration and control through the Wyze app and is designed to provide full home coverage at an affordable price.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras are compatible with popular smart home systems, including Amazon Alexa, Google Assistant, and IFTTT. This allows for convenient voice control and automation of your home security setup.
What storage options are available for Wyze security cameras?Wyze cameras support both local and cloud storage options. Depending on the model, you can use microSD cards (up to 256 GB or 512 GB) for continuous local recording, or subscribe to Wyze cloud plans for additional storage and features.
How weather resistant are Wyze outdoor security cameras?Wyze outdoor security cameras, such as the Wyze Cam Floodlight v2, Wyze Cam v4, and Wyze Cam Pan v3, are IP65 weather resistant. This means they are built to withstand rain, snow, and extreme temperatures, making them reliable for year-round outdoor use.
What are the benefits of choosing Wyze cameras with LED and motion spotlights?Wyze cameras with LED and motion spotlights offer enhanced night security by illuminating suspicious activity and deterring intruders. They also provide high-quality video resolution, smart home integration, flexible mounting options, and affordable pricing without compromising on essential security features.
How much do Wyze security cameras with LED and motion spotlights cost?Wyze security cameras with LED and motion spotlights are affordably priced. For example, the Wyze Cam Floodlight v2 is available for under $90, while the Whole Home Security Enhanced Kit, which includes multiple cameras, is priced at $256.91.
What colors are available for the Wyze Cam v4?Can you tell me more about the features of the Whole Home Security Enhanced Kit?How does the motion-activated spotlight work on the Wyze cameras?
